  4. NodeJS update nicht möglich...
    5.2k
27 Beiträge 4 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • D Dragon
    @thomas-braun Raspcontroller auf dem chromebook
    @dragon
    Dann verwende ein anderes Terminal.
      @dragon
      Dragon
      @thomas-braun Einen guten Vorschlag für chromebook, dann steige ich sofort um
      • D Dragon
        @dragon
        https://www.zdnet.com/article/how-to-use-the-handy-ssh-management-tool-in-chrome-os/
          @dragon
          Dragon
                               v.2023-06-20
             Static hostname: ioBroker
                   Icon name: computer-vm
                     Chassis: vm
                  Machine ID: 58d2cc2a97184623922200d7fac194bf
                     Boot ID: 1e570689b59e42068bd315fb831075dc
              Virtualization: kvm
            Operating System: Debian GNU/Linux 10 (buster)
                      Kernel: Linux 4.19.0-25-amd64
                Architecture: x86-64
          Installation:           kvm
          Kernel:                 x86_64
          Userland:               amd64
          User-ID:                1000
          X-Server:               false
          Pending OS-Updates:     0
          Pending iob updates:    2
          Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                  /usr/bin/node           v18.17.1
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          Recommended versions are nodejs 18.x.y and npm 9.x.y
          MEMORY:
          Mem:           8.0G        3.7G        3.5G         16M        788M        4.0G
          Swap:          974M          0B        974M
          Total:         9.0G        3.7G        4.5G
          Active iob-Instances:   56
          Active repo(s): stable
          ioBroker Core:          js-controller           5.0.11
                                  admin                   6.10.1
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                27997
          States:                 27613
          Size of iob-Database:
          29M     /opt/iobroker/iobroker-data/objects.jsonl
          18M     /opt/iobroker/iobroker-data/objects.json.migrated
          18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          36M     /opt/iobroker/iobroker-data/states.jsonl
          13M     /opt/iobroker/iobroker-data/states.json.migrated
          13M     /opt/iobroker/iobroker-data/states.json.bak.migrated
          • D Dragon
                                 v.2023-06-20
                       Chassis: vm
                Virtualization: kvm
            Installation:           kvm
            Kernel:                 x86_64
            Userland:               amd64
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
            MEMORY:
            Swap:          974M          0B        974M
                                    admin                   6.10.1
            Objects type: jsonl
            States  type: jsonl
            Objects:                27997
            States:                 27613
            @dragon
            Die Langfassung.
            Aber 'Buster' ist veraltet und muss ersetzt werden.
              @dragon
              Die Langfassung.
              Dragon
              @thomas-braun Ist Buster das Problem?
              Falls ja kann man es updaten oder muss man neu aufsetzen?
              • D Dragon
                @dragon sagte in NodeJS update nicht möglich...:
                Noch kann man nodejs@18 darauf installieren. Das kann und wird sich aber irgendwann ändern. Aber davon abgesehen hat 'Buster' offiziell das EndOfLife überschritten, da kommt also nix mehr vom Hersteller.
                Also ja, muss ersetzt werden. Baldmöglichst. Gibt auch dazu ein HowTo von mir.
                  Dragon
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                             Chassis: vm
                      Virtualization: kvm
                  model name      : Common KVM processor
                  Docker          : false
                  Virtualization  : kvm
                  Kernel          : x86_64
                  Userland        : amd64
                  Systemuptime and Load:
                   11:30:26 up 48 min,  1 user,  load average: 2.34, 1.83, 1.80
                  CPU threads: 4
                  *** Time and Time Zones ***
                                 Local time: Sat 2023-10-07 11:30:27 CEST
                             Universal time: Sat 2023-10-07 09:30:27 UTC
                                   RTC time: Sat 2023-10-07 09:30:28
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  iobroker
                  /home/iobroker
                  iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:           8.0G        4.3G        2.8G         16M        831M        3.4G
                  Swap:          974M          0B        974M
                  Total:         9.0G        4.3G        3.8G
                           7978 M total memory
                           4303 M used memory
                           4382 M active memory
                            393 M inactive memory
                           2843 M free memory
                            120 M buffer memory
                            711 M swap cache
                            974 M total swap
                              0 M used swap
                            974 M free swap
                  *** FILESYSTEM ***
                  udev           devtmpfs  3.9G     0  3.9G   0% /dev
                  tmpfs          tmpfs     798M   17M  782M   3% /run
                  /dev/sda1      ext4       31G   11G   19G  36% /
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                  tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                  tmpfs          tmpfs     798M     0  798M   0% /run/user/1000
                  [Sat Oct  7 10:42:00 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                  [Sat Oct  7 10:42:00 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                  TARGET        SOURCE    FSTYPE OPTIONS
                  /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
                  `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                  /var:
                  557M    /var/
                  384M    /var/cache
                  379M    /var/cache/apt
                  318M    /var/cache/apt/archives
                  154M    /var/lib
                        Users in the 'systemd-journal' group can see all messages. Pass -q to
                        turn off this notice.
                  No journal files were opened due to insufficient permissions.
                  /opt/iobroker/backups:
                  236M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  1.2G    /opt/iobroker/iobroker-data/
                  759M    /opt/iobroker/iobroker-data/files
                  255M    /opt/iobroker/iobroker-data/backup-objects
                  126M    /opt/iobroker/iobroker-data/files/vis.0
                  88M     /opt/iobroker/iobroker-data/files/echarts.admin
                  59M     /opt/iobroker/iobroker-data/states.jsonl
                  30M     /opt/iobroker/iobroker-data/objects.jsonl
                  23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                  23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                  23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                  *** NodeJS-Installation ***
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Installed: 18.17.1-deb-1nodesource1
                    Candidate: 18.17.1-deb-1nodesource1
                    Version table:
                   *** 18.17.1-deb-1nodesource1 100
                       10.24.0~dfsg-1~deb10u3 500
                          500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                       10.24.0~dfsg-1~deb10u1 500
                          500 http://deb.debian.org/debian buster/main amd64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  No configuration change needed.
                  Multihost discovery server: disabled
                  Discovery authentication:   enabled
                  Persistent activation:      disabled
                  Objects:                    jsonl on 127.0.0.1
                  States:                     jsonl on 127.0.0.1
                  Core adapters versions
                  js-controller:  5.0.11
                  admin:          6.10.1
                  javascript:     7.1.4
                  Adapters from github:   2
                  Adapter State
                  + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
                  + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                  + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
                  + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
                  + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
                    system.adapter.coronavirus-statistics.0 : coronavirus-statistics: ioBroker                                 -  enabled
                  + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                    system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                  + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                  + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 -  enabled
                  + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 - disabled
                    system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                    system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                  + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
                  + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
                  + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                    system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                    system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
                    system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                    system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
                  + system.adapter.imap.0                   : imap                  : ioBroker                                 -  enabled
                  + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                  + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                  + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                  + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1890, bind: 192.168.178.3
                  + system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
                  + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
                  + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
                  + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
                  + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                    system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
                    system.adapter.odl.0                    : odl                   : ioBroker                                 -  enabled
                    system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 - disabled
                  + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
                  + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                  + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                  + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                  + system.adapter.pushsafer.0              : pushsafer             : ioBroker                                 -  enabled
                    system.adapter.rickshaw.0               : rickshaw              : ioBroker                                 - disabled
                  + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
                  + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
                    system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
                    system.adapter.schoolfree.1             : schoolfree            : ioBroker                                 -  enabled
                  + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
                  + system.adapter.signal-cmb.0             : signal-cmb            : ioBroker                                 -  enabled
                  + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.178.3
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
                  + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.telegram.2               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                  + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                  + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
                    system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                    system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                    system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker                                 - disabled
                    system.adapter.vis-lcars.0              : vis-lcars             : ioBroker                                 - disabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
                    system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
                    system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                    system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                    system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
                    system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
                    system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                    system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
                    system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
                  + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
                  + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
                  + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.222:6638
                  + instance is alive
                  ioBroker-Repositories
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                  Adapter    "admin"        : 6.10.1   , installed 6.10.1
                  Adapter    "awtrix-light" : 0.8.0    , installed 0.8.0
                  Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                  Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                  Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                  Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                  Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                  Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                  Adapter    "discovery"    : 3.1.0    , installed 3.2.0
                  Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                  Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                  Adapter    "email"        : 1.2.0    , installed 1.2.0
                  Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                  Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                  Adapter    "followthesun" : 0.4.2    , installed 0.4.2
                  Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                  Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                  Adapter    "history"      : 2.2.6    , installed 2.2.6
                  Adapter    "ical"         : 1.13.3   , installed 1.13.3
                  Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                  Adapter    "imap"         : 0.1.1    , installed 0.1.1
                  Adapter    "info"         : 2.0.0    , installed 2.0.0
                  Adapter    "iot"          : 1.14.5   , installed 1.14.5
                  Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                  Controller "js-controller": 5.0.12   , installed 5.0.11 [Updatable]
                  Adapter    "kodi"         : 3.0.0    , installed 3.0.0
                  Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                  Adapter    "meross"       : 1.15.1   , installed 1.15.1
                  Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                  Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                  Adapter    "nina"         : 0.0.25   , installed 0.0.25
                  Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                  Adapter    "nut"          : 1.6.0    , installed 1.6.0
                  Adapter    "octoprint"    : 4.0.0    , installed 5.0.1
                  Adapter    "odl"          : 2.0.5    , installed 2.0.5
                  Adapter    "openweathermap": 0.3.9   , installed 0.4.2
                  Adapter    "parcel"       : 0.0.27   , installed 0.0.32
                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                  Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                  Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
                  Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                  Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                  Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                  Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
                  Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                  Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
                  Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                  Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
                  Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                  Adapter    "text2command" : 3.0.2    , installed 3.0.2
                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                  Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                  Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                  Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                  Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                  Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                  Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                  Adapter    "web"          : 6.1.2    , installed 6.1.2
                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                  Adapter    "windows-control": 0.1.5  , installed 0.1.5
                  Adapter    "wled"         : 0.6.7    , installed 0.7.0
                  Adapter    "ws"           : 2.5.5    , installed 2.5.5
                  Adapter    "zigbee"       : 1.8.23   , installed 1.8.22 [Updatable]
                  Objects and States
                  Objects:        28000
                  States:         27615
                  Hit:1 http://deb.debian.org/debian buster InRelease
                  Hit:2 http://deb.debian.org/debian buster-updates InRelease
                  Hit:3 http://security.debian.org/debian-security buster/updates InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9975       1/init
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13815      366/sshd
                  tcp        0      0 192.168.178.3:1883      0.0.0.0:*               LISTEN      1000       14959      595/io.sonoff.0
                  tcp        0      0 192.168.178.3:1890      0.0.0.0:*               LISTEN      1000       14895      546/io.mqtt.0
                  tcp        0      0 192.168.178.3:1891      0.0.0.0:*               LISTEN      1000       14896      546/io.mqtt.0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       14438      349/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       13909      349/iobroker.js-con
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          10531      1/init
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       14522      380/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       20165      1647/io.web.0
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1000       22548      1766/io.socketio.0
                  tcp6       0      0 :::51989                :::*                    LISTEN      1000       15254      663/io.nuki-extende
                  tcp6       0      0 :::8086                 :::*                    LISTEN      1000       22855      1999/io.ws.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13817      366/sshd
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1000       22716      1958/io.simple-api.
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       16609      779/io.broadlink2.0
                  udp        0      0 0.0.0.0:44185           0.0.0.0:*                           1000       15997      779/io.broadlink2.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9979       1/init
                  udp        0      0 0.0.0.0:45747           0.0.0.0:*                           1000       16622      779/io.broadlink2.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       21311      1688/io.wled.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       15037      631/io.chromecast.0
                  udp        0      0 192.168.178.3:5353      0.0.0.0:*                           1000       15022      615/io.tr-064.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       21358      1405/io.upnp.0
                  udp        0      0 0.0.0.0:42950           0.0.0.0:*                           1000       20750      1405/io.upnp.0
                  udp6       0      0 :::111                  :::*                                0          9984       1/init
                  2023-10-07 11:30:08.360  - info: host.ioBroker instance system.adapter.ical.0 started with pid 8790
                  2023-10-07 11:30:10.464  - info: dwd.0 (8761) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-10-07 11:30:10.703  - info: javascript.0 (431) script.js.common.Automatisierung.Sonstige.DWD_UWZ_NINA: No change! headline: Amtliche WARNUNG vor WINDBÖEN
                  2023-10-07 11:30:11.459  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-10-07 11:30:12.606  - info: host.ioBroker instance system.adapter.ical.1 started with pid 8803
                  2023-10-07 11:30:12.682  - info: ical.0 (8790) Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
                  2023-10-07 11:30:14.049  - info: ical.0 (8790) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.11
                  2023-10-07 11:30:15.552  - info: ical.0 (8790) processing URL: Brüderkalender https://calendax
                  2023-10-07 11:30:15.609  - info: ical.0 (8790) processing URL: Froebus/Schleibach https://calendar.....
                  2023-10-07 11:30:15.767  - info: ical.0 (8790) processing URL: Familie https://calendar.gx
                  2023-10-07 11:30:15.961  - info: ical.0 (8790) processing URL: Müllabfuhr https://calendar.gox
                  2023-10-07 11:30:16.038  - info: ical.0 (8790) processing URL: Geburtstagskalender https://calendar.goox
                  2023-10-07 11:30:16.753  - info: host.ioBroker instance system.adapter.odl.0 started with pid 8822
                  2023-10-07 11:30:18.262  - info: ical.0 (8790) processing URL: Privat https://calenxs
                  2023-10-07 11:30:18.878  - info: ical.1 (8803) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.11
                  2023-10-07 11:30:20.270  - info: ical.0 (8790) processing URL: Dienstplan https://calendaxsic.ics
                  2023-10-07 11:30:22.105  - info: ical.1 (8803) processing URL: Müllabfuhr https://cax/basic.ics
                  2023-10-07 11:30:23.395  - info: odl.0 (8822) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.odl, node: v18.17.1, js-controller: 5.0.11
                  2023-10-07 11:30:27.246  - info: odl.0 (8822) Terminated (NO_ERROR): Without reason
                  2023-10-07 11:30:27.712  - info: ical.0 (8790) Terminated (NO_ERROR): Without reason
                  2023-10-07 11:30:27.833  - info: ical.1 (8803) Terminated (NO_ERROR): Without reason
                  2023-10-07 11:30:28.023  - info: host.ioBroker instance system.adapter.odl.0 terminated with code 0 (NO_ERROR)
                  2023-10-07 11:30:28.677  - info: host.ioBroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-10-07 11:30:28.754  - info: host.ioBroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                  2023-10-07 11:31:05.702  - info: host.ioBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  iob diag has finished.
                  GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                  • D Dragon
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                               Chassis: vm
                        Virtualization: kvm
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 4
                                  NTP service: active
                              RTC in local TZ: no
                    iobroker
                    /home/iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:          974M          0B        974M
                             7978 M total memory
                             4303 M used memory
                             2843 M free memory
                              120 M buffer memory
                              711 M swap cache
                              974 M total swap
                                0 M used swap
                              974 M free swap
                    *** FILESYSTEM ***
                    /var:
                    557M    /var/
                    384M    /var/cache
                    379M    /var/cache/apt
                    154M    /var/lib
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.10.1
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        28000
                    States:         27615
                    Pending Updates: 0
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @dragon
                    Entferne im Log die URL von ical , sind persönliche Daten !!!
                    • GlasfaserG Glasfaser
                      @dragon
                      Dragon
                      @glasfaser
                      Danke dir
                      • D Dragon
                        Skript v.2023-06-20
                        *** BASE SYSTEM ***
                                   Chassis: vm
                            Virtualization: kvm
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 4
                                      NTP service: active
                                  RTC in local TZ: no
                        iobroker
                        /home/iobroker
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:          974M          0B        974M
                                 7978 M total memory
                                 4303 M used memory
                                 2843 M free memory
                                  120 M buffer memory
                                  711 M swap cache
                                  974 M total swap
                                    0 M used swap
                                  974 M free swap
                        *** FILESYSTEM ***
                        /var:
                        557M    /var/
                        384M    /var/cache
                        379M    /var/cache/apt
                        154M    /var/lib
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.10.1
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        28000
                        States:         27615
                        Pending Updates: 0
                        @dragon
                        Es gibt keine nodesource.list bei dir.
                        Das ist aber dem node-fix-Skript egal, das meldet nur:
                        rm: cannot remove '/etc/apt/sources.list.d/nodesource.lis*': No such file or directory
                        und legt dann die richtige Datei an und installiert die letzte Version aus dem 18er-Zweig. Gerade getestet.
                        Was funktioniert denn bei dir mit dem Skript nicht? Vollständige Ausgaben helfen.
                          @dragon
                          Dragon
                          ioBroker nodejs fixer 2023-10-03
                          Recommended nodejs-version is: 18.18.0
                          Checking your installation now. Please be patient!
                          Your current setup is:
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          /usr/bin/corepack       0.18.0
                          We found these nodejs versions available for installation:
                          nodejs:
                            Version table:
                          Nothing to do - Your installation is using the correct paths.
                          You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
                          Press <y> to continue or any other key to quit
                          Trying to fix your installation now. Please be patient.
                          [sudo] password for iobroker:
                          rm: cannot remove '': No such file or directory
                          Virtualization: kvm
                          Beendet
                          iobroker@ioBroker:~$ ^C
                          iobroker@ioBroker:~$ ioBroker nodejs fixer 2023-10-03
                          -bash: ioBroker: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ Recommended nodejs-version is: 18.18.0
                          -bash: Recommended: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ Checking your installation now. Please be patient!
                          -bash: Checking: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ Your current setup is:
                          -bash: Your: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ /usr/bin/nodejs         v18.17.1
                          node:internal/modules/cjs/loader:1080
                            throw err;
                          Error: Cannot find module '/home/iobroker/v18.17.1'
                              at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                              at Module._load (node:internal/modules/cjs/loader:922:27)
                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                              at node:internal/main/run_main_module:23:47 {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: []
                          Node.js v18.17.1
                          iobroker@ioBroker:~$ /usr/bin/node           v18.17.1
                            throw err;
                            requireStack: []
                          Node.js v18.17.1
                          iobroker@ioBroker:~$ /usr/bin/npm            9.6.7
                          Unknown command: "9.6.7"
                          To see a list of supported npm commands, run:
                            npm help
                          iobroker@ioBroker:~$ /usr/bin/npx            9.6.7
                          npm ERR! code E404
                          npm ERR! 404 Not Found - GET https://registry.npmjs.org/9.6.7 - Not found
                          npm ERR! 404
                          npm ERR! 404  '9.6.7@*' is not in this registry.
                          npm ERR! 404
                          npm ERR! 404 Note that you can also install from a
                          npm ERR! 404 tarball, folder, http url, or git url.
                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-07T09_54_10_069Z-debug-0.log
                          iobroker@ioBroker:~$ /usr/bin/corepack       0.18.0
                          Unknown Syntax Error: Command not found; did you mean one of:
                            0. corepack -h
                            1. corepack -v
                            2. corepack enable [--install-directory #0] ...
                            3. corepack disable [--install-directory #0] ...
                            4. corepack hydrate [--activate] <fileName>
                            5. corepack prepare [--activate] [--all] [--json] [-o,--output] ...
                          While running 0.18.0
                          iobroker@ioBroker:~$ We found these nodejs versions available for installation:
                          -bash: We: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ nodejs:
                          -bash: nodejs:: Kommando nicht gefunden.
                          iobroker@ioBroker:~$   Installed: 18.17.1-deb-1nodesource1
                          -bash: Installed:: Kommando nicht gefunden.
                          iobroker@ioBroker:~$   Candidate: 18.17.1-deb-1nodesource1
                          -bash: Candidate:: Kommando nicht gefunden.
                          iobroker@ioBroker:~$   Version table:
                          -bash: Version: Kommando nicht gefunden.
                          iobroker@ioBroker:~$  *** 18.17.1-deb-1nodesource1 100
                          -bash: iob_diag.log: Kommando nicht gefunden.
                          iobroker@ioBroker:~$         100 /var/lib/dpkg/status
                          -bash: 100: Kommando nicht gefunden.
                          iobroker@ioBroker:~$      10.24.0~dfsg-1~deb10u3 500
                          -bash: 10.24.0~dfsg-1~deb10u3: Kommando nicht gefunden.
                          iobroker@ioBroker:~$         500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                          -bash: 500: Kommando nicht gefunden.
                          iobroker@ioBroker:~$      10.24.0~dfsg-1~deb10u1 500
                          -bash: 10.24.0~dfsg-1~deb10u1: Kommando nicht gefunden.
                          iobroker@ioBroker:~$         500 http://deb.debian.org/debian buster/main amd64 Packages
                          iobroker@ioBroker:~$ Nothing to do - Your installation is using the correct paths.
                          -bash: Nothing: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
                          -bash: You: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ Press <y> to continue or any other key to quit
                          -bash: y: Datei oder Verzeichnis nicht gefunden
                          iobroker@ioBroker:~$ Trying to fix your installation now. Please be patient.
                          -bash: Trying: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ [sudo] password for iobroker:
                          -bash: [sudo]: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ rm: cannot remove '': No such file or directory
                          -bash: rm:: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ rm: cannot remove '/etc/apt/sources.list.d/nodesource.lis*': No such file or directory
                          iobroker@ioBroker:~$ Virtualization: kvm
                          -bash: Virtualization:: Kommando nicht gefunden.
                          iobroker@ioBroker:~$ Beendet
                          Thomas BraunT DJMarc75D 3 Antworten Letzte Antwort
                          • D Dragon
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            Virtualization: kvm
                            Beendet
                              throw err;
                              requireStack: []
                            Node.js v18.17.1
                              throw err;
                              requireStack: []
                            Node.js v18.17.1
                              npm help
                            npm ERR! code E404
                            npm ERR! 404
                            npm ERR! 404
                              0. corepack -h
                              1. corepack -v
                            @dragon
                            Du kopierst da irgendwie die Ausgabe in die Kommandozeile rein. Logisch kann die mit dem Krempel nix anfangen.
                            Nochmal...
                            • D Dragon
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              nodejs:
                                Version table:
                              Virtualization: kvm
                              Beendet
                                throw err;
                                requireStack: []
                              Node.js v18.17.1
                                throw err;
                                requireStack: []
                              Node.js v18.17.1
                                npm help
                              npm ERR! code E404
                              npm ERR! 404
                              npm ERR! 404
                                0. corepack -h
                                1. corepack -v
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              @dragon zusätzlich würde ich einen anderen User anlegen welcher NICHT iobroker heisst
                              Lehrling seit 1975 !!!
                              • D Dragon
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
                                nodejs:
                                  Version table:
                                Virtualization: kvm
                                Beendet
                                  throw err;
                                  requireStack: []
                                Node.js v18.17.1
                                  throw err;
                                  requireStack: []
                                Node.js v18.17.1
                                  npm help
                                npm ERR! code E404
                                npm ERR! 404
                                npm ERR! 404
                                  0. corepack -h
                                  1. corepack -v
                                @dragon
                                Lad das Skript nochmal frisch herunter.
                                  @dragon
                                  Dragon
                                  @thomas-braun Hat jetzt funktioniert!
                                  • D Dragon
                                    @dragon
                                    Es hat mutmaßlich zuerst nicht funktioniert wegen:
                                    Mit einem anderen username hätte es wohl hingehauen.
                                    Leg dir also einen User 'dragon' oder sonstwas an und verwende den dann für Abenteuer im System. Gruppen 'adm', 'sudo' und 'iobroker' bei dem neuen User eintragen und das System über 'Debian 11 "Bullseye" auf Debian 12 "Bookworm" heben.
