  4. kann vis nicht installieren
    1.0k
    6.1k
29 Beiträge 3 Kommentatoren 4.2k Aufrufe 1 Beobachtet
  • L LJSven
    Skript v.2023-06-20
    *** BASE SYSTEM ***
     Static hostname: tinkerboard
           Icon name: computer
          Machine ID: affa5e932b3247b79051b4333d4219f7
             Boot ID: 3ae4f613cf714e029c51e550b44607a3
    Operating System: Armbian 23.8.3 bookworm
              Kernel: Linux 6.1.50-current-rockchip
        Architecture: arm
    model name	: ARMv7 Processor rev 1 (v7l)
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     21:24:09 up  6:04,  2 users,  load average: 0.86, 0.50, 0.35
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sun 2023-10-01 21:24:09 CEST
               Universal time: Sun 2023-10-01 19:24:09 UTC
                     RTC time: Sun 2023-10-01 19:24:10
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    sven
    /home/sven
    sven tty disk dialout sudo audio video plugdev games users input netdev bluetooth systemd-journal iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            2.1G        1.4G        358M        2.7M        458M        750M
    Swap:           1.1G        786K        1.0G
    Total:          3.2G        1.4G        1.4G
             2004 M total memory
             1288 M used memory
             1279 M active memory
              261 M inactive memory
              342 M free memory
               48 M buffer memory
              388 M swap cache
             1002 M total swap
                0 M used swap
             1001 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  990M     0  990M   0% /dev
    tmpfs          tmpfs     201M  3.1M  198M   2% /run
    /dev/mmcblk1p1 ext4       57G  3.9G   53G   7% /
    tmpfs          tmpfs    1003M     0 1003M   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs    1003M     0 1003M   0% /tmp
    /dev/zram1     ext4       47M  1.9M   42M   5% /var/log
    tmpfs          tmpfs     201M     0  201M   0% /run/user/1000
    [Sun Oct  1 15:19:25 2023] Kernel command line: earlyprintk root=UUID=5171d208-24a4-446e-a0a7-673ec46f0c58 rootwait rootfstype=ext4 splash=verbose console=ttyS2,115200n8 console=tty1 consoleblank=0 loglevel=1 ubootpart=2215e05a-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
    [Sun Oct  1 15:19:30 2023] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Quota mode: none.
    [Sun Oct  1 15:19:32 2023] EXT4-fs (mmcblk1p1): re-mounted. Quota mode: none.
    [Sun Oct  1 15:19:35 2023] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
    TARGET         SOURCE                   FSTYPE OPTIONS
    /              /dev/mmcblk1p1           ext4   rw,noatime,errors=remount-ro,commit=600
    |-/var/log.hdd /dev/mmcblk1p1[/var/log] ext4   rw,noatime,errors=remount-ro,commit=600
    `-/var/log     /dev/zram1               ext4   rw,relatime,discard
    /var:
    385M	/var/
    226M	/var/cache
    221M	/var/cache/apt
    153M	/var/cache/apt/archives
    151M	/var/lib
    Archived and active journals take up 6.4M in the file system.
    /opt/iobroker/backups:
    24M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    395M	/opt/iobroker/iobroker-data/
    305M	/opt/iobroker/iobroker-data/files
    52M	/opt/iobroker/iobroker-data/files/javascript.admin
    34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    33M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    44M	/opt/iobroker/iobroker-data/objects.jsonl
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    20M	/opt/iobroker/iobroker-data/states.jsonl
    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.17.1
    /usr/bin/node 		v18.17.1
    /usr/bin/npm 		9.6.7
    /usr/bin/npx 		9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bookworm/main armhf Packages
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 0.0.0.0
    States:                     jsonl on 0.0.0.0
    Core adapters versions
    js-controller: 	5.0.12
    admin: 		6.10.1
    javascript: 	7.1.4
    Adapters from github: 	1
    Adapter State
    + system.adapter.admin.0                  : admin                 : tinkerboard                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : tinkerboard                              -  enabled
      system.adapter.asterisk.0               : asterisk              : raspberrypi                              - disabled, port: 5038
    + system.adapter.backitup.0               : backitup              : tinkerboard                              -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberryzeropi                          - disabled
      system.adapter.daswetter.0              : daswetter             : tinkerboard                              - disabled
      system.adapter.deconz.0                 : deconz                : tinkerboard                              - disabled, port: 80
      system.adapter.device-reminder.0        : device-reminder       : tinkerboard                              - disabled
      system.adapter.discovery.0              : discovery             : tinkerboard                              - disabled
      system.adapter.email.0                  : email                 : raspberrypi                              - disabled
      system.adapter.enigma2.0                : enigma2               : tinkerboard                              - disabled
      system.adapter.enigma2.1                : enigma2               : tinkerboard                              - disabled
      system.adapter.flot.0                   : flot                  : tinkerboard                              - disabled
      system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
    + system.adapter.geofency.0               : geofency              : raspberrypi                              -  enabled, port: 7999, bind: 0.0.0.0
      system.adapter.history.0                : history               : tinkerboard                              - disabled
      system.adapter.ical.0                   : ical                  : tinkerboard                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : tinkerboard                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : tinkerboard                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : tinkerboard                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : tinkerboard                              - disabled
      system.adapter.info.0                   : info                  : tinkerboard                              - disabled
    + system.adapter.iot.0                    : iot                   : tinkerboard                              -  enabled
      system.adapter.iqontrol.0               : iqontrol              : tinkerboard                              - disabled
    + system.adapter.javascript.0             : javascript            : tinkerboard                              -  enabled
      system.adapter.lgtv11.0                 : lgtv11                : tinkerboard                              - disabled, port: 8080
    + system.adapter.linkeddevices.0          : linkeddevices         : tinkerboard                              -  enabled
    + system.adapter.mihome.0                 : mihome                : tinkerboard                              -  enabled, port: 9898, bind: 0.0.0.0
    + system.adapter.modbus.0                 : modbus                : tinkerboard                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : tinkerboard                              -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.phantomjs.0              : phantomjs             : tinkerboard                              - disabled
      system.adapter.pvforecast.0             : pvforecast            : tinkerboard                              - disabled
      system.adapter.radar2.0                 : radar2                : raspberryzeropi                          - disabled
      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
    + system.adapter.scenes.0                 : scenes                : tinkerboard                              -  enabled
    + system.adapter.shelly.0                 : shelly                : tinkerboard                              -  enabled, port: 1888, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : tinkerboard                              -  enabled, port: 1888, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : tinkerboard                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              - disabled
      system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              - disabled
      system.adapter.smartmeter.2             : smartmeter            : raspberrypi                              - disabled
    + system.adapter.smartmeter.3             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.smartmeter.4             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : tinkerboard                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : tinkerboard                              -  enabled, port: 3306
      system.adapter.tankerkoenig.0           : tankerkoenig          : tinkerboard                              - disabled
    + system.adapter.telegram.0               : telegram              : tinkerboard                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      system.adapter.tinker.0                 : tinker                : tinkerboard                              - disabled
      system.adapter.tr-064.0                 : tr-064                : tinkerboard                              - disabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : tinkerboard                              - disabled
      system.adapter.vis-history.0            : vis-history           : tinkerboard                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : tinkerboard                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : tinkerboard                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : tinkerboard                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : tinkerboard                              - disabled
      system.adapter.vis.0                    : vis                   : tinkerboard                              -  enabled
    + system.adapter.web.0                    : web                   : tinkerboard                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wled.0                   : wled                  : tinkerboard                              - disabled
      system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
      system.adapter.yahka.0                  : yahka                 : tinkerboard                              - disabled
    + system.adapter.zigbee.0                 : zigbee                : tinkerboard                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "deconz"       : 1.3.21   , installed 2.0.5
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "tinker"       : 1.2.0    , installed 1.2.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects: 	14809
    States: 	12780
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-backports InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bookworm InRelease
    Hit:5 http://mirror.vinehost.net/armbian/apt bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17831      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21509      1081/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       23782      1560/io.shelly.1
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       21271      1526/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       23878      1598/io.sonoff.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       22543      961/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22539      961/iobroker.js-con
    tcp6       0      0 :::111                  :::*                    LISTEN      0          17833      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          21511      1081/sshd: /usr/sbi
    tcp6       0      0 :::1884                 :::*                    LISTEN      1001       23855      1331/io.javascript.
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       127843     2507/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21745      1323/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22018      1662/io.web.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17832      1/init
    udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       21207      1473/io.mihome.0
    udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          18367      984/chronyd
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       22845      1541/io.shelly.0
    udp6       0      0 :::111                  :::*                                0          19458      1/init
    udp6       0      0 ::1:323                 :::*                                0          18368      984/chronyd
    udp6       0      0 fe80::79ed:e114:5c1:546 :::*                                0          22533      782/NetworkManager
    2023-10-01 21:12:08.633  - info: vis.0 (4034) vis license is OK.
    2023-10-01 21:12:09.054  - error: vis.0 (4034) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-10-01 21:12:09.055  - error: vis.0 (4034) unhandled promise rejection: Not exists
    2023-10-01 21:12:09.058  - error: vis.0 (4034) Error: Not exists
        at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:854:19)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:891:59)
        at process.processImmediate (node:internal/timers:478:21)
    2023-10-01 21:12:09.059  - error: vis.0 (4034) Not exists
    2023-10-01 21:12:09.566  - info: vis.0 (4034) terminating
    2023-10-01 21:12:09.568  - warn: vis.0 (4034) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-10-01 21:15:00.073  - info: host.tinkerboard instance system.adapter.ical.0 started with pid 4046
    2023-10-01 21:15:13.374  - info: host.tinkerboard instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-10-01 21:18:44.560  - info: javascript.0 (1331) script.js.common.Sonstige.EG_Aussenbeleuchtung_Haustuer: HT - Beleuchtung über BWM
    2023-10-01 21:23:36.091  - info: vis.0 (4140) Sets unsupported
    2023-10-01 21:23:36.873  - info: vis.0 (4140) starting. Version 1.4.10 in /opt/iobroker/node_modules/iobroker.vis, node: v18.17.1, js-controller: 5.0.12
    2023-10-01 21:23:37.196  - info: vis.0 (4140) vis license is OK.
    2023-10-01 21:23:37.599  - error: vis.0 (4140) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-10-01 21:23:37.600  - error: vis.0 (4140) unhandled promise rejection: Not exists
    2023-10-01 21:23:37.603  - error: vis.0 (4140) Error: Not exists
    2023-10-01 21:23:37.604  - error: vis.0 (4140) Not exists
    2023-10-01 21:23:38.111  - info: vis.0 (4140) terminating
    2023-10-01 21:23:38.112  - warn: vis.0 (4140) Terminated (UNCAUGHT_EXCEPTION): Without reason
    @ljsven sagte in kann vis nicht installieren:
    ist installiert!
    also mit
    @thomas-braun sagte in kann vis nicht installieren:
    @ljsven sagte in VIS: Keine gültige Lizenz gefunden:
    iob upgrade vis@1.4.10
    downgraden, dann per admin wieder upgraden
    danach könntest du den node-fix drüberjagen.
    @Thomas-Braun
    wieso sind die Repos auf Debian und nicht auf Armbian?
    L 1 Antwort Letzte Antwort
      ist installiert!
      also mit
      @Thomas-Braun
      LJSven
      @homoran sagte in kann vis nicht installieren:
      sven@tinkerboard:/opt/iobroker$ iob upgrade vis@1.4.10
      Adapter "vis"            is not installed.
      • L LJSven
        @ljsven Ins blaue
        iob del vis.0
          @ljsven Ins blaue
          iob del vis.0
          LJSven
          @ljsven Ins blaue
          iob del vis.0
          Ist dann das ganze File weg?
          • L LJSven
            @ljsven Ins blaue
            iob del vis.0
            gute Frage!
            lass es
            • L LJSven
              @ljsven Ins blaue
              iob del vis.0
              versuch es mal mit einer anderen, niedrigeren Version
              wenn alle Stricke reissen (iob fix, reboot, Browsercache)
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.vis@1.4.10
                cd /opt/iobroker
                LJSven
                sven@tinkerboard:/opt/iobroker$ iob upgrade vis@1.4.9
                sven@tinkerboard:/opt/iobroker$ iob upgrade vis@1.4.8
                sven@tinkerboard:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.vis@1.4.10
                [sudo] Passwort für sven:
                npm ERR! code 6
                npm ERR! path /opt/iobroker/node_modules/iobroker.vis
                npm ERR! command failed
                npm ERR! command sh -c node main.js --install
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-01T20_20_04_494Z-debug-0.log
                • L LJSven
                  npm ERR! code 6
                  @ljsven
                  hab keine Ahnung mehr
                  mach nochmal iob install vis@1.4.10 --debug diesmal mit --debug
                  Vielleicht wird er dann gesprächiger.
                  hier gab es das Problem auch schon
                  https://forum.iobroker.net/post/1042831
                  auch ohne Lösung, aber mit Wunderheilung
                    @ljsven
                    LJSven
                    sven@tinkerboard:/opt/iobroker$ iob install vis@1.4.10 --debug
                    NPM version: 9.6.7
                    Installing iobroker.vis@1.4.10... (System call)
                    npm ERR! code 6
                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-02T11_03_09_693Z-debug-0.log
                    npm ERR! code 6
                    host.tinkerboard Cannot install iobroker.vis@1.4.10: 6
                    • L LJSven
                      NPM version: 9.6.7
                      npm ERR! code 6
                      npm ERR! code 6
                      LJSven
                      @Homoran Ich habe Mut zur Lücke bewiesen und den Befehl
                      iob del vis
                      ausgeführt. Danach ließ sich der Adapter neu installieren und das File war noch da.
