  4. Echarts Presets verschwinden
    5.2k
51 Beiträge 4 Kommentatoren 5.4k Aufrufe 3 Beobachtet
  • B Bambulko
    @homoran Welche Informationen fehlen denn noch?
    Irgendwie ist jetzt komplett der Wurm drin. Aus irgendeinem Grund startet der javascript adapter nicht mehr. Wenn ich es versuche, bleibt er rot. Verbunden mit Host ist rot, und Lebenszeichen ist rot. Im Log steht nichts hilfreiches, nur
    admin.0
    	2023-09-21 13:37:25.684	info	<== Disconnect system.user.admin from ::ffff:192.168.179.201 javascript
    Jetzt kamen mehr Meldungen:
    host.iobroker
    	2023-09-21 13:43:59.614	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    	2023-09-21 13:43:59.614	error	Caught by controller[0]: }
    host.iobroker
    	2023-09-21 13:43:59.614	error	Caught by controller[0]: ]
    host.iobroker
    	2023-09-21 13:43:59.614	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    host.iobroker
    	2023-09-21 13:43:59.614	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core/build/index.js',
    host.iobroker
    	2023-09-21 13:43:59.613	error	Caught by controller[0]: requireStack: [
    host.iobroker
    	2023-09-21 13:43:59.613	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker
    	2023-09-21 13:43:59.613	error	Caught by controller[0]: {
    host.iobroker
    	2023-09-21 13:43:59.613	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.iobroker
    	2023-09-21 13:43:59.613	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
    host.iobroker
    	2023-09-21 13:43:59.613	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.iobroker
    	2023-09-21 13:43:59.613	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.iobroker
    	2023-09-21 13:43:59.613	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.iobroker
    	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.iobroker
    	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:65:19)
    host.iobroker
    	2023-09-21 13:43:59.612	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.iobroker
    	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.iobroker
    	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.iobroker
    	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.iobroker
    	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.iobroker
    host.iobroker
    	2023-09-21 13:43:59.612	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core/build/index.js:21:1)
    host.iobroker
    host.iobroker
    host.iobroker
    	2023-09-21 13:43:59.611	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    host.iobroker
    	2023-09-21 13:43:59.611	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    host.iobroker
    	2023-09-21 13:43:59.611	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    host.iobroker
    	2023-09-21 13:43:59.611	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/adapter-core/build/index.js
    host.iobroker
    	2023-09-21 13:43:59.611	error	Caught by controller[0]: Require stack:
    host.iobroker
    	2023-09-21 13:43:59.611	error	Caught by controller[0]: Error: Cannot find module '@iobroker/types'
    host.iobroker
    	2023-09-21 13:43:59.610	error	Caught by controller[0]: ^
    host.iobroker
    	2023-09-21 13:43:59.610	error	Caught by controller[0]: throw err;
    host.iobroker
    	2023-09-21 13:43:59.610	error	Caught by controller[0]: internal/modules/cj
    @bambulko sagte in Echarts Presets verschwinden:
    node/npm zu alt
    Ausgabe von iob diag in der Langfassung in code-tags posten bitte
      node/npm zu alt
      Bambulko
      @homoran said in Echarts Presets verschwinden:
      iob diag
      ' diag' kennt mein iobroker nicht. sollte das' iob debug javascript.0' heissen?
      Das ergibt das hier:
      Debugger listening on ws://127.0.0.1:9229/3f305bff-7859-4bf4-bfdd-d9e831503a04
      For help, see: https://nodejs.org/en/docs/inspector
      internal/modules/cjs/loader.js:905
        throw err;
      Require stack:
        requireStack: [
      • B Bambulko
        iob diag
          throw err;
        Require stack:
          requireStack: [
        nein! aber auch da ist was krumm.
        dann ist das System steinalt und/oder total verbogen!
        iob stop
        iob fix
        iob start
        ...warten...
        iob diag
          iob stop
          iob fix
          iob start
          ...warten...
          iob diag
          Bambulko
          iob stop ging nicht. Da kam "iobroker controller daemon is not running" Dann habe ich alle Instanzen von Hand gestoppt. Dann lief fix und diag. Hier ist der output:
          Skript v.2023-06-20
          *** BASE SYSTEM ***
          Hardware Vendor : Intel(R) Client Systems
          Kernel          : x86_64
          Userland        : amd64
          Docker          : v6.1.0
          Virtualization  : Docker
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           14:25:30 up 15 days, 15:53,  0 users,  load average: 4.20, 4.95, 5.89
          CPU threads: 2
          *** Time and Time Zones ***
          Thu Sep 21 12:25:30 UTC 2023
          Thu Sep 21 14:25:30 CEST 2023
          CEST +0200
          Etc/UTC
          *** User and Groups ***
          root
          /root
          root
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:             15G        6.2G        2.5G        697M        6.4G        8.2G
          Swap:           2.0G        3.0M        2.0G
          Total:           17G        6.2G        4.6G
                  15133 M total memory
                   6242 M used memory
                   3832 M active memory
                   7506 M inactive memory
                   2535 M free memory
                   1116 M buffer memory
                   5238 M swap cache
                   2047 M total swap
                      3 M used swap
                   2044 M free swap
          *** FILESYSTEM ***
          Filesystem     Type     Size  Used Avail Use% Mounted on
          overlay        overlay  938G  143G  748G  16% /
          tmpfs          tmpfs     64M     0   64M   0% /dev
          tmpfs          tmpfs    7.4G     0  7.4G   0% /sys/fs/cgroup
          shm            tmpfs     64M     0   64M   0% /dev/shm
          /dev/sda2      ext4     938G  143G  748G  16% /opt/iobroker
          tmpfs          tmpfs    7.4G     0  7.4G   0% /proc/asound
          tmpfs          tmpfs    7.4G     0  7.4G   0% /proc/acpi
          tmpfs          tmpfs    7.4G     0  7.4G   0% /proc/scsi
          tmpfs          tmpfs    7.4G     0  7.4G   0% /sys/firmware
          dmesg: read kernel buffer failed: Operation not permitted
          TARGET           SOURCE        FSTYPE OPTIONS
          /opt/iobroker    /dev/sda2[/docker/iobroker]        ext4   rw,relatime,errors=remount-ro
          /etc/resolv.conf /dev/sda2[/var/lib/docker/containers/69c5eec1e5492be7d313d878b4c87dd57d6a01bdbe577acf7d0de051b9ac6891/resolv.conf] ext4   rw,relatime,errors=remount-ro
          /etc/hostname    /dev/sda2[/var/lib/docker/containers/69c5eec1e5492be7d313d878b4c87dd57d6a01bdbe577acf7d0de051b9ac6891/hostname]    ext4   rw,relatime,errors=remount-ro
          /etc/hosts       /dev/sda2[/var/lib/docker/containers/69c5eec1e5492be7d313d878b4c87dd57d6a01bdbe577acf7d0de051b9ac6891/hosts]       ext4   rw,relatime,errors=remount-ro
          /var:
          33M     /var/
          31M     /var/lib
          18M     /var/lib/apt/lists
          18M     /var/lib/apt
          13M     /var/lib/dpkg
          /opt/iobroker/backups:
          927M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          345M    /opt/iobroker/iobroker-data/
          294M    /opt/iobroker/iobroker-data/files
          88M     /opt/iobroker/iobroker-data/files/echarts.admin
          57M     /opt/iobroker/iobroker-data/files/echarts
          52M     /opt/iobroker/iobroker-data/files/javascript.admin
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
          17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v14.19.1
          /usr/bin/node           v14.19.1
          /usr/bin/npm            6.14.16
          /usr/bin/npx            6.14.16
          nodejs:
            Installed: 14.19.1-deb-1nodesource1
            Candidate: 14.21.3-deb-1nodesource1
            Version table:
               14.21.3-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
           *** 14.19.1-deb-1nodesource1 100
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          No problems detected
          npm ERR! peer dep missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          No configuration change needed.
          Multihost discovery server: disabled
          Discovery authentication:   enabled
          Persistent activation:      disabled
          Objects:                    jsonl on 127.0.0.1
          States:                     jsonl on 127.0.0.1
          Core adapters versions
          js-controller:  4.0.21
          admin:          6.3.5
          javascript:     7.1.4
          Adapters from github:   1
          Adapter State
            system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.admin.4                  : admin                 : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
            system.adapter.deconz.0                 : deconz                : iobroker                                 - disabled, port: 8080
            system.adapter.devices.0                : devices               : iobroker                                 - disabled
            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
            system.adapter.echarts.0                : echarts               : iobroker                                 - disabled
            system.adapter.history.0                : history               : iobroker                                 - disabled
            system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
            system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
            system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
            system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
            system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
            system.adapter.linktap.0                : linktap               : iobroker                                 - disabled
            system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 - disabled
            system.adapter.netatmo.0                : netatmo               : iobroker                                 - disabled
            system.adapter.parser.0                 : parser                : iobroker                                 - disabled
            system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
            system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled
            system.adapter.powerfox2.0              : powerfox2             : iobroker                                 - disabled
            system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
            system.adapter.pushsafer.0              : pushsafer             : iobroker                                 - disabled
            system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
            system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
            system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.simple-api.0             : simple-api            : iobroker                                 - disabled, port: 8083, bind: 0.0.0.0, run as: admin
            system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 - disabled
            system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
            system.adapter.sql.0                    : sql                   : iobroker                                 - disabled
            system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
            system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
            system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
            system.adapter.vesync.0                 : vesync                : iobroker                                 - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
            system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.10.1   , installed 6.3.5  [Updatable]
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
          Adapter    "devices"      : 1.1.5    , installed 1.1.5
          Adapter    "echarts"      : 1.5.1    , installed 1.5.1
          Adapter    "history"      : 2.2.6    , installed 2.2.6
          Adapter    "ical"         : 1.13.3   , installed 1.13.3
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 4.0.21 [Updatable]
          Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
          Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
          Adapter    "linktap"      : 0.2.1    , installed 0.2.1
          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "parser"       : 1.3.2    , installed 1.3.2
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
          Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
          Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
          Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
          Adapter    "sonos"        : 2.3.1    , installed 2.3.1
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "vesync"       : 0.0.3    , installed 0.0.3
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "weatherunderground": 3.4.2, installed 3.4.2
          Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
          Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.9.0  [Updatable]
          Objects and States
          Objects:        3566
          States:         2919
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
          Reading package lists...
          Pending Updates: 106
          *** Listening Ports ***
          tcp        0      0 127.0.0.11:44049        0.0.0.0:*               LISTEN      0          43661      -
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       49897      -
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       49882      -
          udp        0      0 127.0.0.11:53377        0.0.0.0:*                           0          43660      -
          2023-09-21 14:21:15.344  - warn: deconz.0 (705912) get state error: DB closed
          2023-09-21 14:21:15.345  - info: host.iobroker stopInstance system.adapter.deconz.0 send kill signal
          2023-09-21 14:21:15.422  - info: host.iobroker instance system.adapter.deconz.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-21 14:21:15.904  - info: host.iobroker "system.adapter.backitup.0" disabled
          2023-09-21 14:21:15.904  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-09-21 14:21:15.912  - info: backitup.0 (705897) Got terminate signal TERMINATE_YOURSELF
          2023-09-21 14:21:15.917  - info: backitup.0 (705897) cleaned everything up...
          2023-09-21 14:21:15.920  - info: backitup.0 (705897) terminating
          2023-09-21 14:21:15.927  - info: backitup.0 (705897) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-09-21 14:21:15.999  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
          2023-09-21 14:21:16.520  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-21 14:22:09.381  - info: admin.0 (705862) Adapter is disabled => stop
          2023-09-21 14:22:09.382  - info: admin.0 (705862) terminating http server on port 8081
          2023-09-21 14:22:09.388  - info: host.iobroker "system.adapter.admin.0" disabled
          2023-09-21 14:22:09.397  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
          2023-09-21 14:22:09.424  - info: admin.0 (705862) Got terminate signal TERMINATE_YOURSELF
          2023-09-21 14:22:09.428  - info: admin.0 (705862) terminating
          2023-09-21 14:22:09.429  - info: admin.0 (705862) Terminated (NO_ERROR): Without reason
          2023-09-21 14:22:09.458  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
          2023-09-21 14:22:10.086  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
          2023-09-21 14:24:40.235  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
          2023-09-21 14:24:40.253  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2023-09-21 14:24:40.258  - info: host.iobroker hostname: iobroker, node: v14.19.1
          2023-09-21 14:24:40.259  - info: host.iobroker ip addresses: 172.18.0.2
          2023-09-21 14:24:40.352  - error: host.iobroker-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          iob diag has finished.
          Press any key for a summary
          • B Bambulko
            Skript v.2023-06-20
            *** BASE SYSTEM ***
            Kernel          : x86_64
            Userland        : amd64
            Docker          : v6.1.0
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 2
            CEST +0200
            Etc/UTC
            root
            /root
            root
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
                     6242 M used memory
                     2535 M free memory
                     5238 M swap cache
                     2047 M total swap
                        3 M used swap
                     2044 M free swap
            *** FILESYSTEM ***
            /var:
            33M     /var/
            31M     /var/lib
            18M     /var/lib/apt
            13M     /var/lib/dpkg
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        3566
            States:         2919
            klar, das geht bei
            anders. müsstest du als Docker Nutzer aber wissen.
            wie vermutet
            Viel zu alt.
            Das OS
            verträgt auch mehr Fürsorge!
            Dann dürfte sich auch noch einiges bei iob aktualisieren lassen.
              Bambulko
              Ich versuche den js-controller zu updaten, bekomme aber nur das:
              Update js-controller from @4.0.21 to @5.0.12
              Stopped Objects DB
              Stopped States DB
              NPM version: 6.14.16
              Installing iobroker.js-controller@5.0.12... (System call)
              Es kommt keine Fehlermeldung, aber wenn ich dann iobroker starte ist immer noch die alt Version installiert.
              • B Bambulko
                Stopped Objects DB
                Stopped States DB
                Welches nodejs-Umfeld? Das scheint mir mit npm 6.14.16 zu alt zu sein.
                Edit: nodejs@14 ist zu alt...
                Update den Docker.
                • B Bambulko
                  Stopped Objects DB
                  Stopped States DB
                  ich schrieb doch
                  @homoran sagte in Echarts Presets verschwinden:
                  Das OS
                  in dem Zustand geht das nicht
                    ich schrieb doch
                    Das OS
                    Bambulko
                    @homoran Ich hätte niemals den iobroker in docker installieren sollen. Das scheint alles nur unnötig kompliziert zu machen. Vielleicht sollte ich alles nochmal neu ohne docker aufsetzen. Aber kann man dann die Daten irgendwie retten?
                    • B Bambulko
                      wenn man sich damit nicht auskennt, kann das schon sein.
                      neu installieren und letztes Backup wieder herstellen
                        Bambulko
                        @homoran Heute ist so ein Tag, an dem nichts funktioniert. Ich habe jetzt versucht iobroker ohne Docker mit
                        sudo curl -sLf https://iobroker.net/install.sh | bash -
                        zu installieren. Es läuft auch durch, und ich bekomme die Meldung, dass iobroker erfolgreich installiert wurde. Aber bei loccalhost:8081 tut sich gar nichts. Und iobroker status gibt folgendes aus:
                         Cannot read system.config: null (OK when migrating or restoring)
                        Objects type: jsonl
                        States  type: jsonl
                        • B Bambulko
                          Objects type: jsonl
                          States  type: jsonl
                          @bambulko
                          iob diag
                          sagt?
                          • B Bambulko
                            Objects type: jsonl
                            States  type: jsonl
                            zu installieren. E
                            und sonst nichts?
                            auf welchem System?
                            Absolut sauber?
                              @bambulko
                              iob diag
                              sagt?
                              Bambulko
                              @thomas-braun Hmm, nodejs is NOT correctly installed, obwohl ich v18.18.0 habe.
                                                   v.2023-06-20
                                 Static hostname: Nuc
                                       Icon name: computer-desktop
                                         Chassis: desktop
                                      Machine ID: ad3458d0640e4781a50233d6b3388c72
                                         Boot ID: 0f842b6f9206477d90dac70147d5fedf
                                Operating System: Ubuntu 20.04.6 LTS
                                          Kernel: Linux 5.15.0-84-generic
                                    Architecture: x86-64
                              Kernel:                 x86_64
                              Userland:               amd64
                              User-ID:                0
                              X-Server:               true
                              Pending OS-Updates:     2
                              Error: Object "system.config" not found
                              Pending iob updates:    0
                              Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                                      /usr/bin/node           v18.18.0
                                                      /usr/local/bin/npm              10.1.0
                                                      /usr/local/bin/npx              10.1.0
                              Recommended versions are nodejs 18.x.y and npm 9.x.y
                              *** nodejs is NOT correctly installed ***
                              MEMORY:
                              Mem:            15G        4.2G        6.8G        509M        4.2G         10G
                              Swap:          2.0G          0B        2.0G
                              Total:          17G        4.2G        8.8G
                              Active iob-Instances:   1
                              List is empty
                              ioBroker Core:          js-controller           4.0.24
                                                      admin                   6.3.5
                              ioBroker Status:         Cannot read system.config: null (OK when migrating or restoring)
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                34
                              States:                 27
                              Size of iob-Database:
                              16K     /opt/iobroker/iobroker-data/objects.jsonl
                              16K     /opt/iobroker/iobroker-data/states.jsonl
                              code_text
                              • B Bambulko
                                                     v.2023-06-20
                                           Chassis: desktop
                                Kernel:                 x86_64
                                Userland:               amd64
                                User-ID:                0
                                X-Server:               true
                                MEMORY:
                                Swap:          2.0G          0B        2.0G
                                List is empty
                                                        admin                   6.3.5
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                34
                                States:                 27
                                code_text
                                @bambulko
                                npm irgenwie und irgendwarum von Hand reingeklatscht.
                                Und du kasperst als root herum.
                                Und da rumpelt ein Desktop mit.
                                  @bambulko
                                  Bambulko
                                  @thomas-braun Da war eine alte Version von node installiert, und damit hat das curl.... nicht funktioniert.
                                  • B Bambulko
                                    @bambulko
                                    nodejs hat mit curl nix zu tun.
                                    B HomoranH 2 Antworten Letzte Antwort
                                      @bambulko
                                      Bambulko
                                      schrieb am zuletzt editiert von Bambulko
                                      @thomas-braun Ja, ich meine die Installation hat mit der alten Version nicht funktioniert. Aber jetzt kann ich das nicht reproduzieren, weil immer v18.18.0 installiert wird.
                                        @bambulko
                                        @thomas-braun sagte in Echarts Presets verschwinden:
                                        @bambulko
                                        nicht so wörtlich nehmen!
                                        curl=installer!
                                        und wenn der ein node findet installiert er nicht v18
                                        • B Bambulko
                                          @bambulko
                                          Dann lösch den Quark
                                          sudo rm /usr/local/bin/np*
                                          meld den root ab und schalt den Desktop aus.
