  4. Wie mit MQTT Daten in der IOBroker VIS justgage anzeigen?
    5.2k
155 Beiträge 2 Kommentatoren 17.9k Aufrufe 1 Beobachtet
  • mickymM mickym
    @einstein2002 So hier der Flow:
    In die iobroker-OUT Node darfst Du nichts schreiben - der Pfad zum Datenpunkt wird über das msg.topic gesetzt.
           "id": "f9ce820bf650ca95",
           "type": "change",
           "z": "eb632aa6ea31f654",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "ON",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 870,
           "y": 300,
           "wires": [
                   "32058775de38cd03"
           "id": "1523407ee33a68b0",
           "type": "switch",
           "name": "TAG (OFF)/NACHT(ON)",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "eq",
                   "v": "ON",
                   "vt": "str"
                   "t": "eq",
                   "v": "OFF",
                   "vt": "str"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 430,
           "y": 300,
           "wires": [
                   "c706b21e7d3e9bda"
                   "3f2018783720dbe6"
           "id": "3f2018783720dbe6",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "mqtt.0.SmartHome.Haus.Obergeschoss.Esszimmer.EZ_Rollo.cmnd.POWER1",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 660,
           "y": 320,
           "wires": [
                   "f9ce820bf650ca95"
           "id": "c706b21e7d3e9bda",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "mqtt.0.SmartHome.Haus.Obergeschoss.Esszimmer.EZ_Rollo.cmnd.POWER2",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 660,
           "y": 280,
           "wires": [
                   "f9ce820bf650ca95"
           "id": "32058775de38cd03",
           "type": "ioBroker out",
           "name": "",
           "topic": "",
           "ack": "false",
           "autoCreate": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1080,
           "y": 300,
           "wires": []
    mickymM Offline
    mickymM Offline
    mickym
    #67
    @mickym Statt ON und OFF aus der LIGHT Scheduler Node hättest Du auch TAG und NACHT ausgeben lassen können, dann ist es anschaulicher.
    Wenn Du das machst dann musst halt die Switch Node ändern:
    dann wird im oberen Ast das topic auf
    also POWER2 gesetzt, unten auf POWER1.
    Da wir die payload anschließend immer auf ON setzen, wird ON bei beginnender NACHT auf den Datenpunkt POWER2 gesetzt und bei TAG auf POWER1.
    E 1 Antwort Letzte Antwort
    • mickymM mickym
      Einstein2002
      #68
      @mickym
      du hast die ohne Light Scheduler kopiert?
      Da hab ich meinen zu früh gelöscht.
      Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
      Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
      • E Einstein2002
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        #69
        @einstein2002 Du kannst doch einfach Deinen Lightscheduler vorne dran setzen.
        Ich zeig Dir trotzdem noch wie es mit der cron-Node geht.
        E mickymM 3 Antworten Letzte Antwort
        • mickymM mickym
          Einstein2002
          #70
          @mickym
          ja bin ich gerade dabei.
          Hatte ihn nur kurz vorher gelöscht... ☺
          • mickymM mickym
            mickymM Offline
            mickymM Offline
            mickym
            #71
            Ich zeig Dir noch wie einfach es mit der CRONPLUS Node geht.
            • mickymM mickym
              Einstein2002
              #72
              @mickym
              welches Topic soll ich reinschreiben?
              Über TAG / NACHT
              • E Einstein2002
                @mickym
                Über TAG / NACHT
                mickymM Offline
                mickymM Offline
                mickym
                #73
                @einstein2002 da brauchst nichts reinschreiben
                • mickymM mickym
                  Einstein2002
                  #74
                  @mickym
                  Okay,
                  kann ich die Testen??
                  Mit inject?
                  • E Einstein2002
                    @mickym
                    Okay,
                    Mit inject?
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #75
                    @einstein2002
                    Ja mit einer Inject NOde:
                    Hier siehst Du die Hilfe mit on/1 simulierst Du wenn es Nacht wird mit off/0 Tag.
                    • mickymM mickym
                      @einstein2002
                      Einstein2002
                      schrieb am zuletzt editiert von Einstein2002
                      #76
                      @mickym
                      geht leider nicht,
                      • mickymM Offline
                        mickymM Offline
                        mickym
                        #77
                        Mit der cronplus Node vereinfacht sich der Flow dramatisch. ;)
                               "id": "adb1fab2e10dd6ac",
                               "type": "cronplus",
                               "name": "",
                               "outputField": "payload",
                               "timeZone": "",
                               "persistDynamic": false,
                               "commandResponseMsgOutput": "output1",
                               "outputs": 1,
                               "options": [
                                       "name": "Sonnenaufgang",
                                       "topic": "mqtt.0.SmartHome.Haus.Obergeschoss.Esszimmer.EZ_Rollo.cmnd.POWER1",
                                       "payloadType": "str",
                                       "payload": "ON",
                                       "expressionType": "solar",
                                       "expression": "0 * * * * * *",
                                       "location": "50.05 9.10",
                                       "offset": "0",
                                       "solarType": "selected",
                                       "solarEvents": "sunrise"
                                       "name": "Sonnenuntergang",
                                       "topic": "mqtt.0.SmartHome.Haus.Obergeschoss.Esszimmer.EZ_Rollo.cmnd.POWER2",
                                       "payload": "ON",
                                       "offset": "0",
                                       "solarEvents": "sunset"
                               "x": 340,
                               "y": 480,
                               "wires": [
                                       "e758c9ada7c0988f"
                               "id": "e758c9ada7c0988f",
                               "name": "",
                               "topic": "",
                               "ack": "false",
                               "stateName": "",
                               "role": "",
                               "payloadType": "",
                               "readonly": "",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 680,
                               "y": 480,
                               "wires": []
                        Aber nicht beide gleichzeitig laufen lassen. ;)
                        • E Einstein2002
                          @mickym
                          geht leider nicht,
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #78
                          @einstein2002 sagte in Wie mit MQTT Daten in der IOBroker VIS justgage anzeigen?:
                          @mickym
                          geht leider nicht,
                          Na das ist klar der Light Scheduler gibt ja nun Tag und Nacht aus und nicht on und off. Ausserdem ist ON der blaue Balken also Nacht.
                          und dann musst Du die Switch Node natürlich auch ändern:
                          Weil ja die payload nicht mehr ON / OFF ist.
                          Wenn Du eine Debug Node dahinter hängst, siehst Du, dass bei 0 und 1 entweder POWER1 oder POWER2 mit ON gesetzt wird:
                          und die Node wieder in den Automatik Modus zu versetzen musst Du wieder auto in die Node einspeisen.
                          Hier mal alles korrigiert zum Import:
                                 "id": "b61d3c9d3cf56e29",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "ON",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 930,
                                 "y": 640,
                                 "wires": [
                                         "ff017ac222551112",
                                         "aa341c528df612f5"
                                 "id": "9d28af3ec18dc1a1",
                                 "type": "switch",
                                 "rules": [
                                         "t": "eq",
                                         "v": "NACHT",
                                         "vt": "str"
                                         "t": "eq",
                                         "v": "TAG",
                                         "vt": "str"
                                 "checkall": "true",
                                 "repair": false,
                                 "outputs": 2,
                                 "x": 470,
                                 "y": 640,
                                 "wires": [
                                         "4c45c10c2683b639"
                                         "4f33d29f00090923"
                                 "id": "4f33d29f00090923",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 720,
                                 "y": 660,
                                 "wires": [
                                         "b61d3c9d3cf56e29"
                                 "id": "4c45c10c2683b639",
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 720,
                                 "y": 620,
                                 "wires": [
                                         "b61d3c9d3cf56e29"
                                 "id": "ff017ac222551112",
                                 "name": "",
                                 "topic": "",
                                 "ack": "false",
                                 "stateName": "",
                                 "role": "",
                                 "payloadType": "",
                                 "readonly": "",
                                 "stateUnit": "",
                                 "stateMin": "",
                                 "stateMax": "",
                                 "x": 1140,
                                 "y": 640,
                                 "wires": []
                                 "id": "74fcb844374054ec",
                                 "type": "light-scheduler",
                                 "settings": "a9dca5eacb667924",
                                 "events": "[{\"start\":{\"dow\":1,\"mod\":0},\"end\":{\"dow\":1,\"mod\":480}},{\"start\":{\"dow\":2,\"mod\":0},\"end\":{\"dow\":2,\"mod\":480}},{\"start\":{\"dow\":3,\"mod\":0},\"end\":{\"dow\":3,\"mod\":480}},{\"start\":{\"dow\":4,\"mod\":0},\"end\":{\"dow\":4,\"mod\":480}},{\"start\":{\"dow\":5,\"mod\":0},\"end\":{\"dow\":5,\"mod\":480}},{\"start\":{\"dow\":6,\"mod\":0},\"end\":{\"dow\":6,\"mod\":480}},{\"start\":{\"dow\":0,\"mod\":0},\"end\":{\"dow\":0,\"mod\":480}},{\"start\":{\"dow\":1,\"mod\":960},\"end\":{\"dow\":2,\"mod\":0}},{\"start\":{\"dow\":2,\"mod\":960},\"end\":{\"dow\":3,\"mod\":0}},{\"start\":{\"dow\":3,\"mod\":960},\"end\":{\"dow\":4,\"mod\":0}},{\"start\":{\"dow\":4,\"mod\":960},\"end\":{\"dow\":5,\"mod\":0}},{\"start\":{\"dow\":5,\"mod\":960},\"end\":{\"dow\":6,\"mod\":0}},{\"start\":{\"dow\":6,\"mod\":960},\"end\":{\"dow\":0,\"mod\":0}},{\"start\":{\"dow\":0,\"mod\":960},\"end\":{\"dow\":1,\"mod\":0}}]",
                                 "topic": "",
                                 "name": "Rollladensteuerung",
                                 "onPayload": "NACHT",
                                 "onPayloadType": "str",
                                 "offPayload": "TAG",
                                 "offPayloadType": "str",
                                 "onlyWhenDark": true,
                                 "scheduleRndMax": 0,
                                 "sunElevationThreshold": 6,
                                 "sunShowElevationInStatus": false,
                                 "outputfreq": "output.statechange.startup",
                                 "x": 210,
                                 "y": 640,
                                 "wires": [
                                         "9d28af3ec18dc1a1"
                                 "id": "9455f99c681c540d",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "0",
                                 "payloadType": "num",
                                 "x": 230,
                                 "y": 720,
                                 "wires": [
                                         "74fcb844374054ec"
                                 "id": "987990821fd1dcd6",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "1",
                                 "x": 230,
                                 "y": 780,
                                 "wires": [
                                         "74fcb844374054ec"
                                 "id": "aa341c528df612f5",
                                 "type": "debug",
                                 "name": "Ausgabe Lightscheduler",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "complete": "payload",
                                 "targetType": "msg",
                                 "statusVal": "",
                                 "statusType": "auto",
                                 "x": 1170,
                                 "y": 700,
                                 "wires": []
                                 "id": "b8cbdb2667eae513",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "auto",
                                 "x": 230,
                                 "y": 840,
                                 "wires": [
                                         "74fcb844374054ec"
                                 "id": "a9dca5eacb667924",
                                 "type": "light-scheduler-settings",
                                 "name": "Demo",
                                 "latitude": "50.9446",
                                 "longitude": " 7.0115"
                          Du musst nur Deine Einstellungen wieder einsetzen
                          • mickymM mickym
                            @mickym
                            geht leider nicht,
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "ON",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 930,
                                   "y": 640,
                                   "wires": [
                                           "ff017ac222551112",
                                           "aa341c528df612f5"
                                   "type": "switch",
                                   "rules": [
                                           "t": "eq",
                                           "v": "NACHT",
                                           "vt": "str"
                                           "t": "eq",
                                           "v": "TAG",
                                           "vt": "str"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 470,
                                   "y": 640,
                                   "wires": [
                                           "4c45c10c2683b639"
                                           "4f33d29f00090923"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "topic",
                                           "pt": "msg",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 720,
                                   "y": 660,
                                   "wires": [
                                           "b61d3c9d3cf56e29"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "topic",
                                           "pt": "msg",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 720,
                                   "y": 620,
                                   "wires": [
                                           "b61d3c9d3cf56e29"
                                   "name": "",
                                   "topic": "",
                                   "ack": "false",
                                   "stateName": "",
                                   "role": "",
                                   "payloadType": "",
                                   "readonly": "",
                                   "stateUnit": "",
                                   "stateMin": "",
                                   "stateMax": "",
                                   "x": 1140,
                                   "y": 640,
                                   "wires": []
                                   "topic": "",
                                   "x": 210,
                                   "y": 640,
                                   "wires": [
                                           "9d28af3ec18dc1a1"
                                   "type": "inject",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "0",
                                   "x": 230,
                                   "y": 720,
                                   "wires": [
                                           "74fcb844374054ec"
                                   "type": "inject",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "1",
                                   "x": 230,
                                   "y": 780,
                                   "wires": [
                                           "74fcb844374054ec"
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1170,
                                   "y": 700,
                                   "wires": []
                                   "type": "inject",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "auto",
                                   "x": 230,
                                   "y": 840,
                                   "wires": [
                                           "74fcb844374054ec"
                                   "name": "Demo",
                            Einstein2002
                            #79
                            @mickym
                            okay hab ich geändert,
                            aber es funktioniert nur bedingt. Wenn ich über den MQTT Exploer den Wert von Power1 oder Power2 ändere (ON/OFF) dann klappt das wunderbar.
                            Mach ich das aber aus dem IOB dann passiert nichts, ausser das sich der Status ändert.
                            ich mach da mal ein paar Bilder.
                            Die Änderungen kommen über die Steuerung rein, werden dann aber nicht weitergegeben.
                            • E Einstein2002
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #80
                              @einstein2002 Ist denn in deiner iobroker OUT Node auch command als Typ angegeben?
                              • mickymM mickym
                                Einstein2002
                                #81
                                @mickym
                                ja ist es
                                • E Einstein2002
                                  @mickym
                                  ja ist es
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #82
                                  @einstein2002 Wir setzen ja immer nur ON - wer setzt den Punkt wieder auf OFF - das Gerät selbst wenn der Rollladen in Endposition ist?
                                  Geht es wenn Du direkt in den Datenpunkt im iobroker schreibst (also unbestätig)?
                                  Vielleicht das "on" klein schreiben? in der payload?
                                  Also wichtig ist, dass es geht wenn Du direkt im iobroker schreibst.
                                  E mickymM 2 Antworten Letzte Antwort
                                  • mickymM mickym
                                    Einstein2002
                                    #83
                                    @mickym
                                    bin noch am testen, ich glaube mit dem Explorer stimmt was nicht.
                                    Ich starte mal neu.
                                    • mickymM mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #84
                                      @mickym
                                      @mickym sagte in Wie mit MQTT Daten in der IOBroker VIS justgage anzeigen?:
                                             "type": "cronplus",
                                             "name": "",
                                             "timeZone": "",
                                             "outputs": 1,
                                             "options": [
                                                     "payload": "ON",
                                                     "offset": "0",
                                                     "payload": "ON",
                                                     "offset": "0",
                                             "x": 340,
                                             "y": 480,
                                             "wires": [
                                                     "e758c9ada7c0988f"
                                             "name": "",
                                             "topic": "",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 680,
                                             "y": 480,
                                             "wires": []
                                      Bei der CronNode definierst Du 2 Events einmal für Sonnenaufgang und Sonnenuntergang und kannst das Topic direkt beim Event festlegen:
                                      Längen- und Breitengrade sind willkürliche Angaben in dem Screenshot
                                      • mickymM mickym
                                        @mickym
                                               "type": "cronplus",
                                               "name": "",
                                               "timeZone": "",
                                               "outputs": 1,
                                               "options": [
                                                       "payload": "ON",
                                                       "offset": "0",
                                                       "payload": "ON",
                                                       "offset": "0",
                                               "x": 340,
                                               "y": 480,
                                               "wires": [
                                                       "e758c9ada7c0988f"
                                               "name": "",
                                               "topic": "",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 680,
                                               "y": 480,
                                               "wires": []
                                        Einstein2002
                                        #85
                                        @mickym
                                        also...
                                        wenn ich die beiden auf OFF setzte
                                        dann geht es genau einmal auf und zu.
                                        Dann bleibt der Wert wieder auf ON stehen und nichts passiert mehr.
                                        • E Einstein2002
                                          @mickym
                                          also...
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #86
                                          Ah ich habe eine Ahnung - das liegt wahrscheinlich an Deinen mqtt- Einstellungen, dass Du nur Änderungen publizierst:
                                          Mach da mal den Haken raus.
                                          Ansonsten würde ich Dir empfehlen über Node-Red direkt Deinen mosquitto Broker anzusprechen und nicht über den iobroker - damit ist eine wesentliche Fehlerquelle ausgeschlossen.
                                          In Node-Red kannst Du jeden mqtt-Broker mit den Standard mqtt Nodes direkt ansprechen:
                                          Im cmnd AST bleibt immer ON stehen - weil wir den Motor ja nicht selbst stoppen!!! Wir schalten ja den Motor IMMER NUR EIN und ausschalten tut er sich ja selbst.
                                          Im stat AST da steht dann der Zustand - ob POWER aktuell ON oder OFF ist.
