  4. Wie mit MQTT Daten in der IOBroker VIS justgage anzeigen?
    5.2k
155 Beiträge 2 Kommentatoren 17.9k Aufrufe 1 Beobachtet
  • mickymM mickym
    @einstein2002 Na mach erst mal über den IOB
    Oben ist Deine Node - unten habe ich das mal mit Inject Nodes simuliert.
    Die IP Adressen sind unwichtig - über mqtt gehst Du ja immer auf den Broker und nicht auf das Gerät direkt.
    Zum Flow: Unten kannst Du einfach mit Inject Nodes den Power-Wert simulieren - habe ihn dann oben einfach dran kopiert:
    Hier der Import:
           "id": "3a114f3e5d7c60a4",
           "type": "ioBroker in",
           "z": "2b32c5600523cb37",
           "name": "Denon AV Verstärker Power",
           "topic": "alias.0.DenonAV_Verstärker_Power",
           "payloadType": "value",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "false",
           "outFormat": "ioBroker",
           "x": 200,
           "y": 120,
           "wires": [
                   "40f257dded17cb33"
           "id": "64f69b8efa3b7f1f",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
                   "p": "topic",
                   "vt": "str"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "Power",
           "payload": "30",
           "payloadType": "num",
           "x": 260,
           "y": 260,
           "wires": [
                   "5892611f8119f5f8"
           "id": "90ee794dcff20ccf",
           "type": "inject",
           "name": "",
           "props": [
                   "p": "payload"
                   "p": "topic",
                   "vt": "str"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "Power",
           "payload": "10",
           "x": 260,
           "y": 300,
           "wires": [
                   "5892611f8119f5f8"
           "id": "5892611f8119f5f8",
           "type": "switch",
           "name": "Power > 15 ?",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "gt",
                   "v": "15",
                   "vt": "num"
                   "t": "lte",
                   "v": "15",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 450,
           "y": 280,
           "wires": [
                   "f9b6279a692d9ba2"
                   "171d64e63cd547c2"
           "id": "f9b6279a692d9ba2",
           "type": "change",
           "name": "schalte Power ON",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "ON",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 670,
           "y": 260,
           "wires": [
                   "cf26662e193cce84"
           "id": "171d64e63cd547c2",
           "type": "change",
           "name": "schalte Power OFF",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "OFF",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 670,
           "y": 300,
           "wires": [
                   "cf26662e193cce84"
           "id": "cf26662e193cce84",
           "type": "rbe",
           "name": "",
           "func": "rbe",
           "gap": "",
           "start": "",
           "inout": "out",
           "septopics": false,
           "topi": "topic",
           "x": 890,
           "y": 280,
           "wires": [
                   "b7849be5ef3ba27a"
           "id": "b7849be5ef3ba27a",
           "type": "debug",
           "name": "Ausgabe für POW2",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 1070,
           "y": 280,
           "wires": []
           "id": "40f257dded17cb33",
           "type": "switch",
           "rules": [
                   "t": "gt",
                   "v": "15",
                   "vt": "num"
                   "t": "lte",
                   "v": "15",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 450,
           "y": 120,
           "wires": [
                   "1bf71a47bfb12894"
                   "d4fdc570441e974b"
           "id": "1bf71a47bfb12894",
           "type": "change",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "ON",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 670,
           "y": 100,
           "wires": [
                   "1d085c8d5e5b146a"
           "id": "d4fdc570441e974b",
           "type": "change",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "OFF",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 670,
           "y": 140,
           "wires": [
                   "1d085c8d5e5b146a"
           "id": "1d085c8d5e5b146a",
           "type": "rbe",
           "name": "",
           "func": "rbe",
           "gap": "",
           "start": "",
           "inout": "out",
           "septopics": false,
           "topi": "topic",
           "x": 890,
           "y": 120,
           "wires": [
                   "e20b5d836ca279e6"
           "id": "e20b5d836ca279e6",
           "type": "debug",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1070,
           "y": 120,
           "wires": []
    Einstein2002
    @mickym
    dann teste ich das mal, bis gleich.
    Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
    Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
    • mickymM mickym
      Hier der Import:
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 200,
             "y": 120,
             "wires": [
                     "40f257dded17cb33"
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "Power",
             "payload": "30",
             "x": 260,
             "y": 260,
             "wires": [
                     "5892611f8119f5f8"
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
                     "p": "topic",
                     "vt": "str"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "Power",
             "payload": "10",
             "x": 260,
             "y": 300,
             "wires": [
                     "5892611f8119f5f8"
             "type": "switch",
             "rules": [
                     "t": "gt",
                     "v": "15",
                     "vt": "num"
                     "t": "lte",
                     "v": "15",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 450,
             "y": 280,
             "wires": [
                     "f9b6279a692d9ba2"
                     "171d64e63cd547c2"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "ON",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 670,
             "y": 260,
             "wires": [
                     "cf26662e193cce84"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "OFF",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 670,
             "y": 300,
             "wires": [
                     "cf26662e193cce84"
             "type": "rbe",
             "name": "",
             "func": "rbe",
             "gap": "",
             "start": "",
             "inout": "out",
             "septopics": false,
             "topi": "topic",
             "x": 890,
             "y": 280,
             "wires": [
                     "b7849be5ef3ba27a"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1070,
             "y": 280,
             "wires": []
             "type": "switch",
             "rules": [
                     "t": "gt",
                     "v": "15",
                     "vt": "num"
                     "t": "lte",
                     "v": "15",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 450,
             "y": 120,
             "wires": [
                     "1bf71a47bfb12894"
                     "d4fdc570441e974b"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "ON",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 670,
             "y": 100,
             "wires": [
                     "1d085c8d5e5b146a"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "OFF",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 670,
             "y": 140,
             "wires": [
                     "1d085c8d5e5b146a"
             "type": "rbe",
             "name": "",
             "func": "rbe",
             "gap": "",
             "start": "",
             "inout": "out",
             "septopics": false,
             "topi": "topic",
             "x": 890,
             "y": 120,
             "wires": [
                     "e20b5d836ca279e6"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1070,
             "y": 120,
             "wires": []
      Einstein2002
      schrieb am zuletzt editiert von Einstein2002
      @mickym
      irgendwie kapier ich es nicht, im debug sehe ich wie er an oder aus schaltet, aber welcher Wert kommt in den Sonoff Schalter?
      • E Einstein2002
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        @einstein2002 Nun - erstens war mir nicht bewusst, dass Du auch noch Tasmota Nodes verwendest. Du musst bissi aufpassen, dass Du möglichst NUR mit einem System auf Deine Hardware zugreifst. Also entweder Du steuerst direkt über mqtt, über den iobroker oder über diese Tasmota Nodes - ich würde sie NICHT verwenden, wenn Du sonst alles über den iobroker machst. Wenn Du über den Alias steuerst - dann musst halt entspechend die payload ändern.
        Ich hätte halt sonst einfach mit einer iobroker OUT Node direkt in Dein mqtt geschrieben.
        Wichtig ist, dass Du command nimmst.
        E 1 Antwort Letzte Antwort
        • mickymM mickym
          Einstein2002
          @mickym
          ich stehe auf dem SCHLAUCH!!
          Ausgabe für den POW2 dieser Wert muss doch weitergegeben werden oder ?
          Aber wie?
          Deshalb dachte ich dann hänge ich mal den Tasmota Schalter dran.
          Ich sehe den Wald vor lauter Bäumen nicht.
          • E Einstein2002
            @mickym
            Aber wie?
            mickymM Offline
            mickymM Offline
            mickym
            @einstein2002 Na Du hast doch alles in mqtt - dachte ich? - Überwelchen Datenpunkt schaltest Du den sonst Deinen Ventilator`? Wenn Du ihn über die VIS schaltest??
            • mickymM mickym
              Einstein2002
              @mickym
              über den iob
              • E Einstein2002
                @mickym
                über den iob
                mickymM Offline
                mickymM Offline
                mickym
                @einstein2002 sagte in Wie mit MQTT Daten in der IOBroker VIS justgage anzeigen?:
                @mickym
                über den iob
                Na dann würde ich es auch so belassen und die Tasmota Nodes aus NodeRed wieder entfernen, die brauchst Du dann ja nicht.
                Und über welchen Datenpunkt (Sprich Alias oder direkt? ) schaltest Du Deinen Ventilator?
                Und was braucht dieser Datenpunkt um ein- oder auszuschalten? ON/OFF - true/false - EIN/AUS - was für Werte gibst Du in den Datenpunkt ein, damit dieser geschaltet wird?
                • mickymM mickym
                  @mickym
                  über den iob
                  Einstein2002
                  @mickym
                  den habe ich noch nicht angelegt!
                  Das mache ich schnell.
                  • E Einstein2002
                    @mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @einstein2002 Und dann aber testen, wie Du über den iob auch den Ventilator schaltest. Sprich über das direkte Setzen des Wertes im iob.
                    • mickymM mickym
                      Einstein2002
                      @mickym
                      nächstes Problem:
                      der taucht hier nicht auf
                      hier ist er angelegt:
                      hab schon beide aktuallisiert aber ohne erfolg.
                      Aber ich kann ihn hier schalten! Das geht direkt unter mqtt.0
                      So ist es voll funktionsfähig!
                      1000 Dank
                      • E Einstein2002
                        @mickym
                        nächstes Problem:
                        1000 Dank
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @einstein2002 Na freut mich. Die Debug Node kannst ja dann wieder löschen, die brauchst ja dann nicht mehr. ;)
                        Und wie gesagt in Node-Red Nodes für Hardwarezugriff nur dann installieren, wenn Du nicht über den iob schalten willst oder kannst, weil entweder kein Adapter verfügbar ist oder dieser fehlerhaft arbeitet.
                        • mickymM mickym
                          Einstein2002
                          @mickym
                          ja die Stört mich nicht. Als Kontrolle lass ich die mal da.
                          Ich brauche immer irgendwie ein Beispiel,
                          ich wusste ja was ich will, aber nicht wie ich es umsetzten kann.
                          Da gibt es einfach zu wenig Beispiele. Vielen Dank für Deine Zeit.
                          • E Einstein2002
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @einstein2002 Wichtig ist, dass Du verstehst wie NodeRed funktioniert, was die einzelnen Nodes machen. Was eine payload ist - wie diese in einem Nachrichtenobjekt aufgebaut ist usw.
                            Aber das erste bevor Du einen neuen Flow machst und mit dem iob arbeitest ist: Habe einen Datenpunkt oder einen zeitlichen Trigger mit dem Du den Flow anstoßen willst und probiere über welchen Datenpunkt Du im iob die Hardware steuern kannst.
                            Dann weißt Du was Du für Eingangsdaten Du hast und welche Ausgangsdaten Du brauchst - und diese erzeugst Du mit dem Flow.
                            • E Offline
                              Einstein2002
                              @mickym
                              Hast Du noch ein paar Minuten Zeit für mich?
                              • E Einstein2002
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @einstein2002 Ja - gerne - nehme mir alle Zeit, die Du brauchst - und wenn ich nicht mehr kann, dann sage ich Stop.
                                😁 Wer sich für Einstein keine Zeit nimmt, dem ist ja schließlich nicht mehr zu helfen. Schließlich war es einer der schlausten Menschen auf dieser Erde. ;)
                                E 2 Antworten Letzte Antwort
                                • mickymM mickym
                                  Einstein2002
                                  @mickym
                                  Super!! ✌
                                  Bin gerade am Testen.
                                  Möchte gerne mein Blockly Script nun durch NodeRed ersetzen,
                                  Funktioniert auch schon, aber.... dieser SUN Node sendet alle 1 Minuten eine 1 aus.
                                  Warum weiß ich nicht.
                                  Das hat zur folge ich bekomme hier
                                  SmartHome/Haus/Obergeschoss/Esszimmer/EZ_Rollo/cmnd/POWER1
                                  im MQTT Explorer immer eine 1 deswegen habe ich mir mal diesen Test aufgebaut.
                                  Aber so richtig glück hab ich nicht damit.
                                  • mickymM mickym
                                    Einstein2002
                                    @mickym
                                    jaja... mach du nur deine Witze
                                    Mir hat dieser Type sehr gefallen...
                                    Fand ihn Cool
                                    Irgendwann ändere ich meinen Nick.. aber noch nicht!!😁
                                    • E Einstein2002
                                      @mickym
                                      Super!! ✌
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @einstein2002 Nun dann wäre es schön, wenn Du erst mal beschreibst, was Du tun möchtest, warum Du gerade diese Node installiert hast usw.
                                      Welche Node hast Du denn da installiert?
                                      • mickymM mickym
                                        Einstein2002
                                        @mickym
                                        Bin am Testen wie ich sinnvollsten meine Rollläden steuern kann.
                                        Dann hatte ich diese Node entdeckt und dachte damit sollte es recht einfach funktionieren.
                                        Möchte gerne die Rollladensteuerung nach Sonnenauf- / Untergang steuern.
                                        • mickymM mickym
                                          Einstein2002
                                          @mickym
                                                  "id": "292dda794dd19ddd",
                                                  "type": "inject",
                                                  "z": "387ac2a6ae39e966",
                                                  "name": "",
                                                  "props": [
                                                          "p": "payload"
                                                          "p": "topic",
                                                          "vt": "str"
                                                  "repeat": "",
                                                  "crontab": "02 00 * * *",
                                                  "once": false,
                                                  "onceDelay": 0.1,
                                                  "topic": "",
                                                  "payload": "false",
                                                  "payloadType": "bool",
                                                  "x": 290,
                                                  "y": 80,
                                                  "wires": [
                                                          "5312c755ce94a72a"
                                          Ich hab das mal exportiert.
