  4. Speicherprobleme - Absturz?
22 Beiträge 3 Kommentatoren 2.8k Aufrufe 2 Beobachtet
    @schandmann sagte in Test Adapter Energiefluss-erweitert v0.0.x GitHub/Latest:
    iob diag ist bei mir anscheinend nicht installiert. Kann ich zumindest nicht ausführen...
    zeigen!
    als Text in code-tags
    dito mit top, allerdings ausnahmsweise als Screenshot
    load ist vieeel zu hoch und RAM ist fast verbraucht, war es sogar schon, da Swap verwendet wurde
    Schandmann
    iob diag:
    root@iobroker:/opt/iobroker# iob diag
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    top:
    • S Schandmann
      iob diag:
      iobroker [command]
      Commands:
      Options:
      top:
      iob diag
      da ist aber einiges faul
      iob stop
      iob fix
      iob start
      iob diag
      top:
      redis ist IMHO auch hyperaktiv
      Mach mal den fix und den diag, ich glieder das hier aus
      • S Schandmann
        @SKB @Homoran
        Guten Morgen,
        nochmal zu dem Absturz-Problem von gestern...
        Mit dem Begriff OOM-Reaper kann ich nichts anfangen.
        Der Datenpunkt für die Batterie-Prozent ist: 0_userdata.0.Huawei.Wichtig.Batteriefüllstand
        Habe heute morgen die Berechnung für die Akkulaufzeit und für den Verbrauch rausgenommen und den Energiefluss-erweitert-Adapter gestartet. Iobroker hat sich dann wieder ein paar Minuten aufgehangen und alle laufenden Instanzen/Adapter gekillt. Die Werte, die der Energiefluss-erweitert-Adapter abgreift schienen im vorfeld plausibel. Auch die Fabelwerte von gestern (Akkuladung /-entladung) habe ich in Node-Red gefiltert, so dass nur plausible Werte geschrieben werden. Der Akku wurde zu dem Zeitpunkt aber eh bereits minimal geladen mit 76W.
        Hier das Logfile aus dem Iobroker:
        2023-09-14 08:28:32.869 - info: host.iobroker "system.adapter.energiefluss-erweitert.0" enabled
        2023-09-14 08:28:34.009 - info: host.iobroker instance system.adapter.energiefluss-erweitert.0 started with pid 460773
        2023-09-14 08:28:38.909 - info: energiefluss-erweitert.0 (460773) starting. Version 0.0.2-alpha.18 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert#d3bd48eb3b875ee87924f1761153f71fed5ae6fb) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v16.20.1, js-controller: 4.0.24
        2023-09-14 08:28:39.053 - info: energiefluss-erweitert.0 (460773) Adapter started. Loading config!
        2023-09-14 08:28:39.614 - info: energiefluss-erweitert.0 (460773) Configuration loaded!
        2023-09-14 08:28:39.616 - info: energiefluss-erweitert.0 (460773) Requesting the following states: energiefluss-erweitert.0.configuration,0_userdata.0.Huawei.Wichtig.PV Leistung,0_userdata.0.Huawei.Wichtig.PV West Leistung,0_userdata.0.Huawei.Wichtig.Batteriefüllstand,0_userdata.0.Huawei.Wichtig.Verbrauch,evcc.0.loadpoint.1.status.vehicleSoc,evcc.0.loadpoint.1.status.chargePower,0_userdata.0.Huawei.Wichtig.Batterie Lade und Entladeleistung,sonoff.0.Stromzaehler.Power_Power_curr,evcc.0.status.homePower,shelly.0.SHSW-PM#34945472C362#1.Relay0.Power,sonoff.0.DVES_4AC6DE.ENERGY_Power,shelly.0.SHPLG2-1#2844E2#1.Relay0.Power,shelly.0.SHPLG2-1#2846E5#1.Relay0.Power,0_userdata.0.Huawei.Wichtig.PV Tagesertrag,mqtt.0.Hoymiles1500.Hoymiles1500.ch0.YieldDay,javascript.0.Haus.Stromzähler.Einspeisung.heute/aktuell,javascript.0.Haus.Stromzähler.Einspeisung.heute/aktuell_in_Euro,evcc.0.status.tariffEffectivePrice,evcc.0.loadpoint.1.status.sessionEnergy,evcc.0.loadpoint.1.status.sessionPrice,javascript.0.Photovoltaik.Gesamtertrag_heute/aktuell,javascript.0.Haus.Stromverbrauch.Tagesverbrauch
        2023-09-14 08:29:56.725 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:02.709 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:03.133 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:51.670 - info: admin.0 (2524484) ==> Connected system.user.admin from undefined
        2023-09-14 08:30:53.524 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.541 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.545 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.549 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.554 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.562 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.571 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.578 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.583 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.588 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.662 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.663 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.665 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.666 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.668 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.669 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.670 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.672 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.751 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.752 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.754 - info: admin.0 (2524484) <== Disconnect system.user.admin from undefined admin
        2023-09-14 08:30:53.913 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.914 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.920 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.921 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.923 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.924 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.925 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:53.927 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.928 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.939 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.940 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.943 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.944 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:53.948 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:30:54.151 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:30:54.196 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:31:06.197 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:31:06.211 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:31:06.215 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:31:06.869 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:31:19.027 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:31:41.153 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:31:41.155 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:31:43.183 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:31:43.222 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:32:00.372 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:32:10.457 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:32:15.169 - info: admin.0 (2524484) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:32:36.306 - warn: web.0 (2525058) Timeout by termination of web-extensions!
        2023-09-14 08:32:38.294 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:32:37.743 - info: web.0 (2525058) <== Disconnect system.user.admin from ::ffff:192.168.178.9 vis.0
        2023-09-14 08:32:37.784 - info: web.0 (2525058) <== Disconnect system.user.admin from ::ffff:192.168.178.9 vis.0
        2023-09-14 08:32:38.044 - info: web.0 (2525058) terminated http server on port 8082
        2023-09-14 08:32:38.815 - info: energiefluss-erweitert.0 (460773) Cleared interval for relative values!
        2023-09-14 08:32:38.297 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:32:39.230 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:32:39.231 - info: admin.0 (2524484) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:32:40.324 - info: energiefluss-erweitert.0 (460773) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:40.182 - info: admin.0 (2524484) terminating http server on port 8081
        2023-09-14 08:32:41.124 - info: web.0 (2525058) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:43.983 - info: info.0 (2524876) cleaned everything up...
        2023-09-14 08:32:45.443 - info: admin.0 (2524484) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:46.824 - info: info.0 (2524876) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:44.655 - info: alexa2.0 (2524842) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:43.171 - info: tr-064.0 (2524776) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:46.692 - info: iot.0 (2524892) Connection changed: disconnect
        2023-09-14 08:32:48.642 - info: iot.0 (2524892) Connection lost
        2023-09-14 08:32:48.690 - info: iot.0 (2524892) Terminated (START_IMMEDIATELY_AFTER_STOP): Without  reason
        2023-09-14 08:32:40.850 - info: terminal.0 (2525000) terminated http server on port 8088
        2023-09-14 08:33:06.875 - info: terminal.0 (2525000) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:36.036 - info: pi-hole.0 (2524929) cleaned everything up...
        2023-09-14 08:33:03.920 - info: evcc.0 (2525125) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:33:11.854 - info: pi-hole.0 (2524929) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:59.974 - info: tankerkoenig.0 (2524983) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:57.505 - info: backitup.0 (2524801) cleaned everything up...
        2023-09-14 08:32:43.894 - info: go-e.0 (2525132) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:33:30.373 - info: backitup.0 (2524801) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:32:56.664 - info: hs100.0 (2524861) cleaned everything up...
        2023-09-14 08:32:56.452 - info: simple-api.0 (2524968) terminating http server on port 8087
        2023-09-14 08:32:52.552 - info: trashschedule.0 (2525110) cleaned everything up...
        2023-09-14 08:32:49.958 - info: vis-inventwo.0 (2525089) cleaned everything up...
        2023-09-14 08:33:33.639 - info: trashschedule.0 (2525110) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:33:24.690 - info: mclighting.0 (2525154) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:33:35.849 - info: hs100.0 (2524861) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:33:37.315 - info: simple-api.0 (2524968) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:33:00.181 - info: hm-rpc.1 (2524627) xmlrpc -> 192.168.178.50:42001/ init ["http://192.168.178.47:42001",""]
        2023-09-14 08:33:54.145 - info: vis-inventwo.0 (2525089) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:33:55.674 - info: hm-rpc.1 (2524627) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:33:51.572 - info: sonoff.0 (2524769) Client [GartenleuchteVorn] connection closed: closed
        2023-09-14 08:33:04.931 - info: hm-rpc.2 (2524650) xmlrpc -> 192.168.178.50:42010/ init ["http://192.168.178.47:42010",""]
        2023-09-14 08:33:59.530 - info: hm-rpc.2 (2524650) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-09-14 08:33:40.514 - info: tado.0 (2525147) cleaned everything up...
        2023-09-14 08:33:12.585 - info: vw-connect.0 (2525193) cleaned everything up...
        2023-09-14 08:34:22.500 - info: host.iobroker iobroker.js-controller version 4.0.24 js-controller starting
        2023-09-14 08:34:22.508 - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-09-14 08:34:22.520 - info: host.iobroker hostname: iobroker, node: v16.20.1
        2023-09-14 08:34:27.063 - info: host.iobroker connected to Objects and States
        2023-09-14 08:34:27.233 - info: host.iobroker added notifications configuration of host
        2023-09-14 08:34:34.091 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
        2023-09-14 08:34:34.094 - info: host.iobroker 59 instances found
        2023-09-14 08:34:34.656 - info: host.iobroker starting 44 instances
        2023-09-14 08:34:36.579 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
        2023-09-14 08:34:36.615 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
        2023-09-14 08:34:36.654 - info: host.iobroker instance system.adapter.admin.0 started with pid 465613
        2023-09-14 08:34:36.680 - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
        2023-09-14 08:34:36.703 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
        2023-09-14 08:34:36.725 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
        2023-09-14 08:34:36.743 - info: host.iobroker Some obsolete host states deleted.
        2023-09-14 08:34:39.001 - info: host.iobroker instance system.adapter.history.0 started with pid 465620
        2023-09-14 08:34:42.100 - info: history.0 (465620) starting. Version 2.2.6 in /opt/iobroker/node_modules/iobroker.history, node: v16.20.1, js-controller: 4.0.24
        2023-09-14 08:34:44.071 - info: host.iobroker instance system.adapter.javascript.0 started with pid 465635
        2023-09-14 08:34:47.052 - info: host.iobroker instance system.adapter.javascript.1 started with pid 465646
        2023-09-14 08:34:47.657 - info: admin.0 (465613) starting. Version 6.6.1 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.1, js-controller: 4.0.24
        2023-09-14 08:34:47.760 - info: admin.0 (465613) requesting all states
        2023-09-14 08:34:47.763 - info: admin.0 (465613) requesting all objects
        2023-09-14 08:34:51.451 - info: host.iobroker instance system.adapter.node-red.0 started with pid 465666
        2023-09-14 08:34:53.019 - info: admin.0 (465613) received all objects
        2023-09-14 08:34:55.474 - info: host.iobroker instance system.adapter.scenes.0 started with pid 465686
        2023-09-14 08:34:56.020 - info: javascript.0 (465635) starting. Version 7.0.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.20.1, js-controller: 4.0.24
        2023-09-14 08:34:56.083 - info: javascript.1 (465646) starting. Version 7.0.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.20.1, js-controller: 4.0.24
        2023-09-14 08:34:59.277 - info: admin.0 (465613) Request actual repository...
        2023-09-14 08:34:59.523 - info: admin.0 (465613) socket.io server listening on port 8081
        2023-09-14 08:34:59.528 - info: admin.0 (465613) http server listening on port 8081
        2023-09-14 08:34:59.530 - info: admin.0 (465613) Use link "http://127.0.0.1:8081" to configure.
        2023-09-14 08:35:00.069 - info: admin.0 (465613) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:35:03.385 - info: admin.0 (465613) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:35:05.384 - info: admin.0 (465613) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:35:10.163 - info: host.iobroker instance system.adapter.telegram.0 started with pid 465721
        2023-09-14 08:35:11.138 - info: host.iobroker instance system.adapter.telegram.1 started with pid 465728
        2023-09-14 08:35:11.287 - info: host.iobroker instance system.adapter.alexa2.0 started with pid 465734
        2023-09-14 08:35:13.012 - info: admin.0 (465613) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:35:13.987 - info: admin.0 (465613) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:35:20.292 - info: admin.0 (465613) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:35:25.980 - warn: alexa2.0 (465734) slow connection to objects DB. Still waiting ...
        2023-09-14 08:35:27.636 - info: admin.0 (465613) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:35:28.952 - info: javascript.1 (465646) requesting all states
        2023-09-14 08:35:28.956 - info: javascript.0 (465635) requesting all states
        2023-09-14 08:35:28.959 - info: javascript.1 (465646) requesting all objects
        2023-09-14 08:35:28.959 - info: javascript.0 (465635) requesting all objects
        2023-09-14 08:35:31.815 - warn: telegram.0 (465721) slow connection to objects DB. Still waiting ...
        2023-09-14 08:35:31.846 - warn: telegram.1 (465728) slow connection to objects DB. Still waiting ...
        2023-09-14 08:35:37.064 - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 465772
        2023-09-14 08:35:40.144 - info: host.iobroker instance scheduled system.adapter.ical.0 1 1,4,7,10,13,16,19,22 * * *
        2023-09-14 08:35:40.197 - info: host.iobroker instance system.adapter.ical.0 started with pid 465779
        2023-09-14 08:35:40.989 - info: javascript.1 (465646) received all objects
        2023-09-14 08:35:41.074 - info: javascript.0 (465635) received all objects
        2023-09-14 08:35:41.401 - info: host.iobroker instance system.adapter.hm-rpc.0 started with pid 465786
        2023-09-14 08:35:41.873 - info: admin.0 (465613) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:35:41.551 - info: host.iobroker instance system.adapter.hm-rpc.2 started with pid 465792
        2023-09-14 08:35:41.689 - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 465799
        2023-09-14 08:35:42.640 - info: host.iobroker instance system.adapter.mqtt.0 started with pid 465807
        2023-09-14 08:35:42.869 - info: host.iobroker instance system.adapter.ping.0 started with pid 465813
        2023-09-14 08:35:44.643 - info: host.iobroker instance system.adapter.radar2.0 started with pid 465825
        2023-09-14 08:35:44.748 - info: admin.0 (465613) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:35:48.099 - info: admin.0 (465613) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:35:48.335 - info: host.iobroker instance system.adapter.shelly.0 started with pid 465844
        2023-09-14 08:35:53.479 - info: host.iobroker instance system.adapter.sonoff.0 started with pid 465867
        2023-09-14 08:35:56.559 - info: admin.0 (465613) ==> Connected system.user.admin from ::ffff:192.168.178.9
        2023-09-14 08:35:58.316 - info: host.iobroker instance system.adapter.tr-064.0 started with pid 465882
        2023-09-14 08:36:02.271 - info: scenes.0 (465686) starting. Version 2.3.9 in /opt/iobroker/node_modules/iobroker.scenes, node: v16.20.1, js-controller: 4.0.24
        2023-09-14 08:36:02.471 - info: host.iobroker instance system.adapter.backitup.0 started with pid 465899
        2023-09-14 08:36:05.345 - info: host.iobroker instance system.adapter.bring.0 started with pid 465908
        2023-09-14 08:36:07.674 - info: host.iobroker instance system.adapter.fritzbox.0 started with pid 465919
        2023-09-14 08:36:10.600 - info: host.iobroker instance system.adapter.hs100.0 started with pid 465934
        2023-09-14 08:36:13.301 - info: host.iobroker Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
        2023-09-14 08:36:13.833 - info: host.iobroker instance system.adapter.info.0 started with pid 465941
        2023-09-14 08:36:13.925 - info: admin.0 (465613) Repository received successfully.
        2023-09-14 08:36:16.647 - info: host.iobroker instance system.adapter.iot.0 started with pid 465959
        2023-09-14 08:36:16.767 - info: admin.0 (465613) <== Disconnect system.user.admin from ::ffff:192.168.178.9 admin
        2023-09-14 08:36:24.401 - info: javascript.0 (465635) received all states
        2023-09-14 08:36:24.560 - info: host.iobroker instance system.adapter.pi-hole.0 started with pid 465987
        2023-09-14 08:36:24.965 - info: javascript.1 (465646) received all states
        2023-09-14 08:36:25.952 - info: javascript.0 (465635) Start javascript script.js.3DDrucker.Display
        2023-09-14 08:36:26.208 - info: admin.0 (465613) ==> Connected system.user.admin from ::ffff:192.168.178.9
        Eine Info noch, vorgestern Vormittag hatte ich mal alle Adapter händisch gestoppt und dann den Energiefluss-Adapter (allein) gestartet. Das hat soweit geklappt. Danach dann die anderen Adapter nach und nach auch wieder gestartet. Dann lief das System so bis irgendwann Abends. Als ich dann von der Spätschicht kam, hatte sich das System wieder aufgehangen.
        Schandmann
        @Homoran
        Hat jetzt mit iob diag geklappt...
                            v.2023-04-16
        Operatingsystem:        Ubuntu 20.04.4 LTS
        Kernel:                 5.4.0-162-generic
        Installation:           microsoft
        User-ID:                0
        X-Server:               false
        Pending OS-Updates:     95
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v16.20.1
                               /usr/bin/node           v16.20.1
                               /usr/bin/npm            8.19.4
                               /usr/bin/npx            8.19.4
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:           3.9G        3.5G        259M        0.0K        170M        223M
        Swap:          3.3G        738M        2.5G
        Total:         7.2G        4.2G        2.8G
        Active iob-Instances:   38
        ioBroker Core:          js-controller           4.0.24
                               admin                   6.6.1
        /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
               throw e;
        Error: Connection is closed.
           at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
           at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
           at Object.onceWrapper (node:events:628:26)
           at Socket.emit (node:events:513:28)
           at TCP.<anonymous> (node:net:301:12)
        Emitted 'error' event on ScanStream instance at:
           at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
           at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
           at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
           at processTicksAndRejections (node:internal/process/task_queues:96:5)
        ioBroker Status:
        Objects:                28968
        States:                 24818
        Size of iob-Database:
        31M     /opt/iobroker/iobroker-data/objects.jsonl
        18M     /opt/iobroker/iobroker-data/objects.json.migrated
        18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        4.2M    /opt/iobroker/iobroker-data/states.json.bak
        • S Schandmann
          @Homoran
                              v.2023-04-16
          User-ID:                0
          X-Server:               false
                                 /usr/bin/npm            8.19.4
                                 /usr/bin/npx            8.19.4
          MEMORY:
                                 admin                   6.6.1
                 throw e;
          ioBroker Status:
          Objects:                28968
          States:                 24818
          @schandmann sagte in Speicherprobleme - Absturz?:
          ach du grüne Neune
          und das bei Windows??
          oder wie passt das Ganze zu Ubuntu?
          bitte
          @homoran sagte in Speicherprobleme - Absturz?:
          besser iob diag komplett
            ach du grüne Neune
            bitte
            Schandmann
            das mit Microsoft könnte daran liegen, dass ich womöglich vor Jahren mal zu testzwecken dort gestartet bin. Bin ansonsten schon über einige Systeme gezogen (RockPI,RaspberryPi und nun Synology)
            Werde die Updates für Ubuntu mal fahren....
            diag komplett muss ich mal schauen wie das geht...
            • S Schandmann
              dann hast du aber eine ganz krumme Installation.
              auch wenn @thomas-Braun sich ebenso wie ich nicht mit den Tiefen vom M$ aukennt, kann er diese Information vielleicht auflösen
              und Synology heisst womöglich auch noch Docker!???
                Schandmann
                auf der Synology läuft Ubuntu als VM und darauf dann Iobroker.
                also nicht Docker.
                Docker ist der Teufel. :-)
                • S Schandmann
                  @Homoran
                                      v.2023-04-16
                  User-ID:                0
                  X-Server:               false
                                         /usr/bin/npm            8.19.4
                                         /usr/bin/npx            8.19.4
                  MEMORY:
                                         admin                   6.6.1
                         throw e;
                  ioBroker Status:
                  Objects:                28968
                  States:                 24818
                  @schandmann
                  Zu iob_diag:
                  Nie als root agieren. Leg dir einen user mit sudo-Recht an und spring damit durch das System.
                  Updates einspielen.
                     throw e;
                  Komischer Fehler.
                    @schandmann
                    Zu iob_diag:
                    Updates einspielen.
                       throw e;
                    Komischer Fehler.
                    Schandmann
                    Updates fahre ich noch. Muss gleich wieder zur Schicht. Melde mich!
                    • S Schandmann
                      Und dann immer stumpf Verzeichnisse hin- und herkopiert?
                      Das kann nicht vernünftig funktionieren.
                        Schandmann
                        habe immer Backups eingespielt. Habe nie stumpf Verzeichnisse kopiert.
                        • S Schandmann
                          dann ist da aber irgendwann ein Wurm mit den Backups reingekommen.
                          • S Schandmann
                            @schandmann
                            kommt auch aus der Betriebssystem-Ebene (genauer von systemd), nicht vom ioBroker.
                              @schandmann
                              @thomas-braun sagte in Speicherprobleme - Absturz?:
                              wäre es dann möglich dass
                              die anscheinend verwendete Virtualization Station (???) mit einem MS Produkt unter der Haube arbeitet?
                              leider hatte @Schandmann diese Aussage nicht näher spezifiziert wie due VM eingebunden ist.
                                Keine Ahnung was da werkelt.
                                  Schandmann
                                  Moin Leute,
                                  habe noch einige Versuche gestartet um herauszufinden, warum sich Iobroker immer übernommen hat.
                                  Fazit:
                                  -Ohne den aktiven Energieflussadapter lief das System stabil (trotz knappem RAM-Speicher).
                                  -habe der VM (auf der Iobroker läuft) noch 1,5 GB RAM extra freigegeben, keine Verbesserung.
                                  -habe dann auf der Vis vom Energieflussadapter angefangen alle Datenquellen in den Elementen rauszunehmen und auch die Datenquellen unter "verfügbare Datenquellen" zu löschen.
                                  -Dann bin ich darauf gestoßen, dass ich eine Datenquelle nicht löschen kann, da diese noch benutzt wird.
                                  -Habe dann alle Elemente durchgeklickt und tatsächlich ein Rechteck gefunden (mit der Datenquelle), dass mir visuell nicht angezeigt wurde, ebenfalls war die Datenquelle in dem Dropdownmenu der Elemente nicht ersichtlich. Das Rechteck habe ich dann gelöscht.
                                  -Schlussendlich habe ich wieder alle Datenquellen nach und nach angelegt und zwischendurch den Adapter neu gestartet um die Performance zu testen.
                                  -Es scheint, als sei das Problem behoben.
                                  Sollt es dennoch Probleme geben, würde ich mich wieder melden!
                                  Bis hierhin, vielen Dank an alle die geholfen haben!!!
                                  Habt ein schönes Wochenende!!!
                                  mfG
                                  • S Schandmann
                                    Moin Leute,
                                    Fazit:
                                    mfG
                                    @schandmann danke für das Feedback
                                    da hatte sich dann ggf. was verschluckt, möglicherweise als du viele Daten gespeichert hast.
                                    @skb hat das gerade gefixt
