  4. Admin Adapter Upgrade von 6.3 -> 6.8 schlägt fehl
    5.2k
15 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
    @masterg87
    cd /opt/iobroker && npm ls iobroker.type-detector
    MasterG87
    @thomas-braun said in Admin Adapter Upgrade von 6.3 -> 6.8 schlägt fehl:
    iobroker.inst@1.3.1 /opt/iobroker
    └─┬ iobroker.iot@1.14.5
      └── iobroker.type-detector@1.1.2
    • M MasterG87
      @masterg87 sagte in Admin Adapter Upgrade von 6.3 -> 6.8 schlägt fehl:
      iobroker.iot
      Installier den nochmal drüber.
        iobroker.iot
        MasterG87
        Bin mir leider nicht ganz sicher wie man drüber installiert. Habe es jetzt so gemacht und folgenden Fehler. Hast du folgenden Befehl gemeint?
        npm install iobroker.iot
        npm WARN tarball tarball data for iobroker.ws.server@file:iobroker.ws.server (null) seems to be corrupted. Trying again.
        npm WARN tarball tarball data for iobroker.ws@file:iobroker.ws (null) seems to be corrupted. Trying again.
        npm WARN tarball tarball data for iobroker.type-detector@file:iobroker.type-detector (null) seems to be corrupted. Trying again.
        npm WARN tarball tarball data for iobroker-react-components@file:iobroker-react-components (null) seems to be corrupted. Trying again.
        npm WARN tarball tarball data for iobroker.objects-redis@file:iobroker.objects-redis (null) seems to be corrupted. Trying again.
        npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
        npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
        npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
        npm WARN deprecated request@2.81.0: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@4.2.1: this library is no longer supported
        npm WARN deprecated node-pre-gyp@0.6.39: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
        npm WARN deprecated appium-logger@2.1.0: Moved into appium-support
        npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
        npm WARN deprecated tar@2.2.2: This version of tar is no longer supported, and will not receive security updates. Please upgrade asap.
        npm WARN deprecated core-js@1.2.7: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
        npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
        npm ERR! code ENOENT
        npm ERR! syscall open
        npm ERR! path /opt/iobroker/iobroker.ws.server/package.json
        npm ERR! errno -2
        npm ERR! enoent ENOENT: no such file or directory, open '/opt/iobroker/iobroker.ws.server/package.json'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-05T19_12_40_374Z-debug-0.log
        • M MasterG87
          npm ERR! errno -2
          npm ERR! enoent
          @masterg87
          Finger weg von direkten npm-Kommandos.
          Und immer vollständige Ein- wie Ausgaben zeigen. Bei einigen Befehlen ist es wichtig wo man gerade im Dateisystem herumsteht. Bei npm z. B....
          iob upgrade iobroker.iot@1.14.5 --debug
          ist dein Freund.
            MasterG87
            schrieb am zuletzt editiert von MasterG87
            Danke für die Aufklärung. Ich habe den Server auch mal wieder aufs letzte Backup zurückgesetzt, da ich so einiges mit npm direkt gerade selbst probiert habe.
            Auf dem zurückgespielten Backup habe ich im Ordner /opt/iobroker folgenden Befehl ausgeführt:
            Output davon ist:
            Would you like to reinstall version 1.14.5 of iot now? [(y)es, (n)o]: y
            Update iot from @1.14.5 to @1.14.5
            host.Iobroker Adapter "system.adapter.iot.0" is stopped.
            NPM version: 9.6.7
            Installing iobroker.iot@1.14.5... (System call)
            npm ERR! path /opt/iobroker/iobroker.type-detector/package.json
            npm ERR! errno -2
            npm ERR! enoent ENOENT: no such file or directory, open '/opt/iobroker/iobroker.type-detector/package.json'
            npm ERR! enoent
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-05T20_32_46_906Z-debug-0.log
            host.Iobroker Cannot install iobroker.iot@1.14.5: 254
            Der Output von deinem vorherigen Tipp war:
            username@Iobroker:/opt/iobroker$ npm ls iobroker.type-detector
            Irgendwie bekomme ich diese npm Warnings und Fehler nicht weg :-(
            • M MasterG87
              Output davon ist:
              NPM version: 9.6.7
              npm ERR! errno -2
              npm ERR! enoent
              MasterG87
              Noch ein kleiner Nachtrag:
              Ich habe noch folgenden Befehl ausgeführt:
              und folgenden Output bekommen:
              npm ERR! code ELSPROBLEMS
              npm ERR! missing: @abandonware/bluetooth-hci-socket@^0.5.3-4, required by iobroker.inst@1.3.1
              npm ERR! missing: @abandonware/noble@^1.9.2-6, required by iobroker.inst@1.3.1
              npm ERR! missing: bluetooth-hci-socket@git+https://github.com/jrobeson/node-bluetooth-hci-socket.git#fix-builds-for-node-10, required by iobroker.inst@1.3.1
              npm ERR! missing: colors@^1.3.2, required by iobroker.inst@1.3.1
              npm ERR! missing: fs-extra@^7.0.0, required by iobroker.inst@1.3.1
              npm ERR! missing: iobroker-react-components@file:node_modules/iobroker-react-components, required by iobroker.inst@1.3.1
              npm ERR! missing: iobroker.objects-redis@file:node_modules/iobroker.objects-redis, required by iobroker.inst@1.3.1
              npm ERR! missing: iobroker.samsung@0.5.8, required by iobroker.inst@1.3.1
              npm ERR! missing: iobroker.type-detector@file:node_modules/iobroker.type-detector, required by iobroker.inst@1.3.1
              npm ERR! invalid: iobroker.ws.server@ /opt/iobroker/node_modules/iobroker.ws.server
              npm ERR! invalid: iobroker.ws@ /opt/iobroker/node_modules/iobroker.ws
              npm ERR! missing: mocha@^9.0.0, required by iobroker.inst@1.3.1
              npm ERR! missing: node-mihome@0.0.32, required by iobroker.inst@1.3.1
              npm ERR! missing: pcap@^3.1.0, required by iobroker.inst@1.3.1
              npm ERR! missing: semver@^5.5.0, required by iobroker.inst@1.3.1
              npm ERR! missing: yargs@^7.0.2, required by iobroker.inst@1.3.1
              ├── UNMET DEPENDENCY @abandonware/bluetooth-hci-socket@^0.5.3-4
              ├── UNMET DEPENDENCY @abandonware/noble@^1.9.2-6
              ├── @iobroker/types@5.0.12
              ├── UNMET DEPENDENCY bluetooth-hci-socket@git+https://github.com/jrobeson/node-bluetooth-hci-socket.git#fix-builds-for-node-10
              ├── UNMET DEPENDENCY colors@^1.3.2
              ├── UNMET DEPENDENCY fs-extra@^7.0.0
              ├── UNMET DEPENDENCY iobroker-react-components@file:node_modules/iobroker-react-components
              ├── iobroker.admin@6.3.5
              ├── iobroker.alexa@0.0.36
              ├── iobroker.alexa2@3.24.1
              ├── iobroker.amazon-dash@1.2.0
              ├── iobroker.backitup@2.6.23
              ├── iobroker.ble@0.13.4
              ├── iobroker.cloud@4.4.1
              ├── iobroker.daswetter@3.1.10
              ├── iobroker.discovery@3.1.0
              ├── iobroker.dwd@2.8.5
              ├── iobroker.fakeroku@0.2.2
              ├── iobroker.geofency@1.2.4
              ├── iobroker.harmony@1.2.2
              ├── iobroker.history@2.2.6
              ├── iobroker.hmip@1.20.0
              ├── iobroker.hs100@2.1.2
              ├── iobroker.hue@3.9.5
              ├── iobroker.ical@1.13.3
              ├── iobroker.icons-mfd-png@1.1.0
              ├── iobroker.icons-mfd-svg@1.1.0
              ├── iobroker.info@1.9.26
              ├── iobroker.iot@1.14.5
              ├── iobroker.javascript@7.0.3
              ├── iobroker.js-controller@4.0.24
              ├── iobroker.mihome-vacuum@3.11.0
              ├── iobroker.mihome@1.4.0
              ├── UNMET DEPENDENCY iobroker.objects-redis@file:node_modules/iobroker.objects-redis
              ├── iobroker.ping@1.6.2
              ├── iobroker.radar@1.2.1
              ├── iobroker.rpi2@1.3.2
              ├── UNMET DEPENDENCY iobroker.samsung@0.5.8
              ├── iobroker.scenes@2.3.9
              ├── iobroker.simple-api@2.7.2
              ├── iobroker.snmp@2.4.11
              ├── iobroker.socketio@6.5.2
              ├── iobroker.spotify-premium@1.2.2
              ├── iobroker.telegram@1.16.0
              ├── iobroker.terminal@1.0.0
              ├── iobroker.text2command@3.0.2
              ├── iobroker.tr-064-community@0.0.1-security
              ├── iobroker.tr-064@4.2.18
              ├── iobroker.tuya@3.14.2
              ├── UNMET DEPENDENCY iobroker.type-detector@file:node_modules/iobroker.type-detector
              ├── iobroker.vis-bars@0.1.4
              ├── iobroker.vis-canvas-gauges@1.0.1
              ├── iobroker.vis-colorpicker@2.0.3
              ├── iobroker.vis-fancyswitch@1.1.0
              ├── iobroker.vis-history@1.0.0
              ├── iobroker.vis-hqwidgets@1.4.0
              ├── iobroker.vis-jqui-mfd@1.0.12
              ├── iobroker.vis-justgage@1.0.2
              ├── iobroker.vis-metro@1.2.0
              ├── iobroker.vis-players@0.1.6
              ├── iobroker.vis-timeandweather@1.2.2
              ├── iobroker.vis-weather@2.5.6
              ├── iobroker.vis@1.4.16
              ├── iobroker.web@6.1.0
              ├── iobroker.ws.server@ invalid: "file:node_modules/iobroker.ws.server" from the root project
              ├── iobroker.ws@ invalid: "file:node_modules/iobroker.ws" from the root project
              ├── UNMET DEPENDENCY mocha@^9.0.0
              ├── UNMET DEPENDENCY node-mihome@0.0.32
              ├── UNMET DEPENDENCY pcap@^3.1.0
              ├── UNMET DEPENDENCY semver@^5.5.0
              ├── typescript@4.7.4
              └── UNMET DEPENDENCY yargs@^7.0.2
              Da ist wohl einiges durcheinander. Gibts da eine Möglichkeit das wieder zu richten?
              • M MasterG87
                Wo fängt man an, wo hört man auf?
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @thomas-braun neue VM und iobroker backup einspielen z.b.😉
                    @crunchip
                    Ich wollt's nicht sagen.
                      MasterG87
                      Ihr hattet Recht und danke für eure super schnelle Hilfe.
                      Nach Neuaufsetzen der VM und Neuinstalltion des Iobroker war der Fehler behoben. Musste dann noch das Backup wiederherstellen und ein paar Sachen manuell in den Skripten und Co nacharbeiten, die nicht mehr aktuell waren. Jetzt läuft es aber wie vorher. Hat aber schon einige Stunden gedauert. Hoffe jetzt habe ich ein paar Jahre wieder Ruhe ;-)
                      • M MasterG87
                        In den Jahren regelmäßig das System pflegen und nicht nach x-Jahren einen großen Satz versuchen. Geht meist in die Hose.
