  4. Alexa2 Version 3.24.+
    6.6k
alexa2
157 Beiträge 32 Kommentatoren 36.5k Aufrufe 37 Beobachtet
  • pajdaP pajda
    Ich habe es so gelöst
    code_text<xml xmlns="https://developers.google.com/blockly/xml">
      <variables>
        <variable type="timeout" id="timeout">timeout</variable>
        <variable id="SFXC$`0ng*{4~QEoleV3">aktiveAlexa</variable>
      </variables>
      <block type="on_ext" id="!-#{i-r{yA+lZ2o.cC2j" x="38" y="38">
        <value name="OID0">
          <shadow type="field_oid" id="VVk!p5{kUy?q(!nTZY=D">
            <field name="oid">javascript.0.scriptEnabled.Sensor.Temperatur_Dummy</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="control" id="CgdI;9gh,cancYt3v%~z">
            <field name="OID">alexa2.0.History.#trigger</field>
            <value name="VALUE">
              <block type="logic_boolean" id="pWMh/v6K)7e$#Kay|R]K">
              </block>
            </value>
            <next>
              <block type="timeouts_settimeout" id="!Jh~KMPU,:O~pCQ-T+q0">
                <field name="DELAY">800</field>
                <field name="UNIT">ms</field>
                  <block type="variables_set" id="y]T9N^X+3n04)?IVB4Dw">
                    <field name="VAR" id="SFXC$`0ng*{4~QEoleV3">aktiveAlexa</field>
                      <block type="text_join" id="1+J[TmU42|tQqbaMB$U!">
                        <value name="ADD0">
                          <block type="text" id="GiNMn+S?.p?k_oy@[ZTV">
                            <field name="TEXT">alexa2.0.Echo-Devices.</field>
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="get_value" id="s;f1OUl-55ZG5tdE|6[;">
                            <field name="OID">alexa2.0.History.serialNumber</field>
                          </block>
                        </value>
                        <value name="ADD2">
                          <block type="text" id="Zgc|tuowO8iwAX^Ee-]0">
                            <field name="TEXT">.Commands.speak</field>
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                      <block type="control_ex" id="fD)v;NY5/a2w7acC7?fX">
                        <field name="TYPE">false</field>
                        <value name="OID">
                          <shadow type="field_oid" id="%I!vRYo$6BB-dw0m1]A5">
                            <field name="oid">Object ID</field>
                          </shadow>
                          <block type="variables_get" id="-atA70=V1GK7`7Uje,zP">
                          </block>
                        </value>
                          <shadow type="logic_boolean" id="irANAZ7DC-Y)|hrl4IvG">
                          </shadow>
                          <block type="text_join" id="BZ@Fn|Rj}k;|4OJ,KW8w">
                            <value name="ADD0">
                              <block type="text" id="KT;|H;YHlwCzDI1(WlCH">
                                <field name="TEXT">"Im Wohnzimmer ist es"</field>
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="get_value" id="=U26XYyswo*g.78`dCJh">
                                <field name="OID">shelly.0.SHHT-1#58EF62#1.tmp.temperatureC</field>
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="1wJ)nKp1kU[n6;Me7roF">
                                <field name="TEXT">"Grad"</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="DELAY_MS">
                          <shadow type="math_number" id="-)cZlyRsi^}x|3+OPV)n">
                            <field name="NUM">0</field>
                          </shadow>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    teguruma
    #68
    @pajda said in Alexa2 Version 3.24.+:
    Funktioniert diese Lösung? Wenn ja kann ich die kopiren und einfügen?
    Wenn ich Blockly wähle kann man ja nur manuell nachbauen oder verstehe ich das falsch?
    • Ro75R Ro75
      @apollon77 sagte in Alexa2 Version 3.24.+:
      also die 3.12
      Die habe ich auf meinem Testsytem installiert. Die funktioniert auch nicht. Wenn ich es so wie @haselchen mache und Push = aus und Historie = 5 sec, dann wird zwar die Historie aktualisiert, aber Lists & Co gehen trotzdem nicht. Die 3.12.x ist also keine Lösung. Selbst meine ursprüngliche Version (3.11.2) läuft nicht. Eventuell müsste man ggfs. noch weiter zurück?
      EDIT: Bei der 3.11.2 läuft jedoch der Player definitiv besser (also Datenanzeige und Aktualisierung).
      Ro75.
      haselchenH Offline
      haselchenH Offline
      haselchen
      #69
      @ro75
      Aber das ist es doch was bei 90% hier fehlt ?!
      (die History…..)
      Ro75R 1 Antwort Letzte Antwort
      • haselchenH haselchen
        @ro75
        (die History…..)
        Ro75R Offline
        Ro75R Offline
        Ro75
        #70
        @haselchen sagte in Alexa2 Version 3.24.+:
        Tja das kann man sehen wie man will. Die History ist mir völlig egal. Für mich sind die Lists (Shopping+ToDo) und der Player interessant.
        Ro75.
        • Ro75R Ro75
          Ro75.
          haselchenH Offline
          haselchenH Offline
          haselchen
          #71
          @ro75
          Mal gewinnt man , mal …… 😜
          Aaaaber, das checke ich bei mir auch mal.
          Was genau machst Du das mit den Lists etc. ?
            @ro75
            Ro75R Offline
            Ro75R Offline
            Ro75
            schrieb am zuletzt editiert von Ro75
            #72
            Einkaufsliste und Todo. Ich sage Alexa setze Brot auf die Einkaufsliste. In dem Fall wird Brot auf die Liste gesetzt. Habe so meine Einkaufsliste aufm Handy - ist praktisch. Gleichzeitig auch in der VIS. Habe in der VIS ein virtuelles Einkaufszentrum und kann so die Einkaufsliste gestalten - wenn man mal wieder ideenlos ist, was das Abendbrot am WE angeht.
            Selbiges auch mit der ToDo-List. Erledigung, Erinnerungen.
            Der Adapter ist halt praktisch, weil ich alles drin habe. Ich will mir auch nicht einen weiteren installieren, z.B ToDoist.
            Ro75.
            • haselchenH Offline
              haselchenH Offline
              haselchen
              #73
              @ro75
              Hab mal per Sprache was hinzugefügt.
              Und jetzt wird es tricky :)
              Starte ich Alexa neu , wird ein Ordner angelegt mit dem, was ich hinzugefügt habe.
              Dort steht in jeder Liste ein einzelnes Produkt.
              Soweit so gut.
              Wenn man nun auf die History UND die Liste scharf ist, dann könnte man ein Workaround anwenden.
              Es gibt ja den DP "Answer Text".
              Man könnte nun ein Blockly nehmen und das hinzugefügte Wort rausfiltern.
              Zum Beispiel steht im DP : Ich habe Birnen zu deiner Liste hinzugefügt.
              Man könnte nun Birnen rausfiltern und in die VIS Liste schreiben lassen.
              Ich weiss, mega kompliziert.
              Ist mir nur so auf die Schnelle eingefallen.
                @ro75
                Soweit so gut.
                Ro75R Offline
                Ro75R Offline
                Ro75
                #74
                @haselchen ich habe für mich hier vorerst eine eigene/andere Lösung geschaffen. Ich setze die "Artikel" über den DP "alexa2.0.Lists.SHOPPING_LIST.#New". Damit landen die Artikel in der Alexa-App. Weiterhin überwache ich diesen DP und schreibe meine eigene Liste fort. Da alles was Alexa angeht eine eigene View ist, starte ich den Adapter neu, sobald die View aufgerufen wird. Damit habe ich (wie bisher) die aktuelle Liste die ich manuell weiter füttern kann. Weiterhin habe ich einen Reload-Button drauf, mit dem ich zwischendurch auch mal einen Adapter-Neustart auslöse.
                Das ist bei weitem nicht perfekt, besser aber als ohne PUSH-Funktion.
                Ro75.
                • Ro75R Ro75
                  Ro75.
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #75
                  @ro75
                  Solange solche Hilfen funktionieren, bin ich auch immer froh.
                  Ich hab die ToDo App auf dem Handy und eine Anbindung in die VIS.
                  Aktualisiert sich jede Minute.
                  Da fällt halt die Spracheingabe als Smartes weg.
                  Aber nicht verkehrt, wenn man die Finger auch mal benutzt :)
                  Also Feature kann Frauchen per Telegram bei sich das Wort Einkauf eingeben und dann wird ihr die Liste geschickt.
                    @ro75
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    #76
                    @haselchen würde mich allerdings, wie auch jeder andere, freuen wenn @apollon77 eine Lösung / Trick / etc. finden würde.
                    Ro75.
                    • Ro75R Ro75
                      Ro75.
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      #77
                      @ro75
                      Definitiv, bin ich ganz bei Dir! ✌
                        @ro75
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        #78
                        @apollon77
                        Wenn ich den Bereich wüsste wo ich nach WS-MQTT gucken muss wäre das einfacher.
                        Das Log ist schier unendlich beim Adapterstart.
                        Daraus kann ich auf die Schnelle nix lesen bzw. aktualisiert sich das Teil so schnell , dass mir schwindelig wird :)
                          @apollon77
                          #79
                          @haselchen Debug log ... dauert bissl ... am Ende wird erst alles bis smart home devices initalisiert und erst dann das ... also lass laufen und schau nach 3-5 mins
                          • apollon77A apollon77
                            Ansonsten so als Vorwarnung: es häufen sich gerade erste Meldungen das auch der vor kurzem gefundene und eingebaute fix was die history Themen angeht (also ändern auf den alten Weg) jetzt von Amazon auch deaktiviert wurde.
                            Wie ist es bei euch? Geht noch alles?
                            Ich bin gerade noch im Urlaub und kann so nichts testen.
                            Ingo
                            Arnulf
                            #80
                            Ingo
                            und ich dachte, ich bin total verblödet.
                            Ich musste meine komplette ioBroker-Installation neu machen.
                            Habe auch Alexa2 installiert. Der Adapter selbst erscheint grün und die Datenpunkte wurden angelegt.
                            Ich habe aber die Texte nicht finden können, die ich Alexa gesagt habe.
                            Heute morgen sehe ich, dass in der Alexa-History dioch was steht.
                            Scheint also extrem verspätet oder nach einem Reboot aktualisiert zu werden.
                            (Der Datenpunkt hat die Uhrzeit 3 Uhr nachts)
                            • L Offline
                              lcars
                              schrieb am zuletzt editiert von lcars
                              #81
                              Vielleicht hilft es ja wem, ich habe es so gemacht, in NodeRed, ein neues Amazon Echo Device angelegt was dann nach einer Verzögerung die History triggert.
                              Dann über einen Echo nach neuen Geräten suchen lassen, dann wird der Trigger Schalter gefunden. In jede Echo Routine die spez. Kommandos empfängt, als Aktion diesen Schalter "einschalten" lassen was ihn dann antriggert und die Kette wird ausgelöst.
                              Gefühlt kommt die Antwort jetzt ca. 1-2s später aber es geht erst einmal wieder.
                                Ingo
                                FabioF Offline
                                FabioF Offline
                                Fabio
                                #82
                                @apollon77 kann auch bestätigen, das mein Problem auch wieder da ist. Die Wecker Datenpunkte werden nicht mehr aktualisiert, was ja nach den letzte FIX von dir wieder ging.
                                Herzliche Fabio
                                Iobroker:
                                • Matter over Thread Hilfe
                                • FabioF Fabio
                                  Herzliche Fabio
                                  #83
                                  @fa-bio Naja ohne Push infos ... geht halt nix. Bin dran, wird aber bissl dauern. Nicht so easy
                                  L FabioF 2 Antworten Letzte Antwort
                                    lobito
                                    #84
                                    Die Idee mit der Steckdose (von @falkomfs und @Fuxsism ) scheint sehr gut zu funktionieren.
                                    Um es mal etwas klarer zu beschreiben, einfach eine beliebige Steckdose die es in Alexa unter Geräte gibt und idealerweise nichts drin hat, bei jeder Routine die mit History ausgewertet wird einfügen. Entweder an- oder ausschalten ist egal.
                                    Dann ein Skript anlegen oder das alte Mute-Skript recyclen, wenn Power bei dieser Dose aktualisiert wird den Rescan der History anstossen.
                                    Ich habe mir gespart die Dose dann wieder an- oder auszuschalten, es funktioniert auch so.
                                    Vielleicht hilft das jemanden der auch erstmal auf dem Schlauch stand wie man das realisieren kann, den Tipp mit der Dose habe ich zwar gesehen musste aber erstmal eine Weile überlegen wie das gemeint war.
                                    • L lobito
                                      Kuddel
                                      #85
                                      @lobito es muss nichtmal eine Steckdose sein. Ich habe mir einen DP (workaround_history) erstellt und per IoT Adapter in jeder Alexa Routine hinterlegt.
                                      Wenn die Alexa Routine den DP auf true setzt, aktualisiere ich per Blockly die History und setzte den DP wieder auf false
                                        FabioF Offline
                                        FabioF Offline
                                        Fabio
                                        #86
                                        @apollon77 alles gut mach dir bitte kein Stress.👍
                                        Fabio
                                        Iobroker:
                                        • F Offline
                                          Fuxsism
                                          #87
                                          Also der WorkAround mit der Steckdose funktioniert bisher wirklich einwandfrei.
                                          Das war eine sehr gute Idee.
                                          Es wäre trotzdem schön wenn der Adapter bald wieder laufen würde und sich auch die Routinen direkt wieder aktualisieren...
                                          LG
