  4. Nodejs Update von 16.x auf 18.x nicht möglich - NPM Fehler
9 Beiträge 3 Kommentatoren 984 Aufrufe 4 Beobachtet
    m0uh
    ich brauch mal bisschen Hilfe. Habe probiert meine Nodejs Version von 16.x auf 18.x zu updaten (wurde Anhand der Anleitung hier im Forum durchgeführt)
    Hier mal die Ausgabe von iob diag:
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v8+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
    /usr/lib/node_modules/npm/lib/cli.js:35
        throw err
    TypeError: Class extends value undefined is not a constructor or null
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-minipass/lib/index.js:136:4)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        at Module.load (node:internal/modules/cjs/loader:1119:32)
        at Module._load (node:internal/modules/cjs/loader:960:12)
        at Module.require (node:internal/modules/cjs/loader:1143:19)
        at require (node:internal/modules/cjs/helpers:121:18)
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
    Node.js v18.17.1
                            /usr/bin/npm
        throw err
    Node.js v18.17.1
                            /usr/bin/npx
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.8G        2.5G        2.4G        1.0M        2.9G        5.2G
    Swap:            99M          0B         99M
    Total:          7.9G        2.5G        2.5G
    Active iob-Instances:   33
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                21210
    States:                 18555
    Size of iob-Database:
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    36M     /opt/iobroker/iobroker-data/states.jsonl
    • M m0uh
                           v.2023-04-16
      Kernel:                 6.1.21-v8+
      User-ID:                1000
      X-Server:               false
          throw err
      Node.js v18.17.1
                              /usr/bin/npm
          throw err
      Node.js v18.17.1
                              /usr/bin/npx
      MEMORY:
      Swap:            99M          0B         99M
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                21210
      States:                 18555
      crunchipC Abwesend
      crunchipC Abwesend
      @m0uh schonmal probiert nodejs zu löschen?
        m0uh
        schrieb am zuletzt editiert von m0uh
        @crunchi habe es mit folgendem Befehl gelöscht und neuinstalliert auch reinstall probiert... alles keine Abhilfe.
        sudo apt purge --autoremove nodejs* npm node-* libnode*
        • M m0uh
          crunchipC Abwesend
          crunchipC Abwesend
          @m0uh sagte in Nodejs Update von 16.x auf 18.x nicht möglich - NPM Fehler:
          mit welchen Meldungen?
            m0uh
            @crunchip also ich hab jetzt folgendes gemacht
            deinstalliert
            reboot
            den Ordner /usr/lib/node_modules/npm gelöscht
            den Ordner /opt/iobroker/node_modules gelöscht
            dann installiert und jetzt läufts...
            Keine Ahnung wo genau jetzt der Haken war
            • M m0uh
              deinstalliert
              reboot
              @m0uh
              Dann schau dir jetzt nochmal
              iob diag
              an. Bevorzugt die Langfassung.
                @m0uh
                iob diag
                m0uh
                @thomas-braun sieht meiner Meinung nach jetzt 1A aus:
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Model           : Raspberry Pi 4 Model B Rev 1.4
                Architecture    : aarch64
                Docker          : false
                Virtualization  : none
                Distributor ID: Debian
                Description:    Debian GNU/Linux 11 (bullseye)
                Release:        11
                Codename:       bullseye
                PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                NAME="Debian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=debian
                HOME_URL="https://www.debian.org/"
                SUPPORT_URL="https://www.debian.org/support"
                BUG_REPORT_URL="https://bugs.debian.org/"
                Systemuptime and Load:
                 08:32:34 up 19:16,  1 user,  load average: 1.79, 1.35, 1.31
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                Other values than 0x0 hint to temperature/voltage problems
                temp=48.7'C
                volt=0.9160V
                *** Time and Time Zones ***
                               Local time: Wed 2023-08-30 08:32:35 CEST
                           Universal time: Wed 2023-08-30 06:32:35 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.8G        3.3G        471M        0.0K        4.0G        4.3G
                Swap:            99M         17M         82M
                Total:          7.9G        3.4G        553M
                         7811 M total memory
                         3338 M used memory
                         3765 M active memory
                         3169 M inactive memory
                          471 M free memory
                          100 M buffer memory
                         3901 M swap cache
                           99 M total swap
                           17 M used swap
                           82 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4      220G   16G  196G   8% /
                devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                /dev/sda1      vfat      255M   31M  225M  13% /boot
                tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                [Tue Aug 29 13:15:42 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:1B:0F:1A vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=42768        ece-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Tue Aug 29 13:15:44 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                [Tue Aug 29 13:15:44 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
                [Tue Aug 29 13:15:46 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                TARGET  SOURCE    FSTYPE OPTIONS
                /       /dev/sda2 ext4   rw,noatime
                `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,errors=remount-ro
                /var:
                du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                8.5G    /var/
                4.0G    /var/log
                3.9G    /var/log/journal/bbfb58ee52124b138fcc8c90c825815f
                2.5G    /var/lib
                Archived and active journals take up 3.8G in the file system.
                /opt/iobroker/backups:
                799M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                742M    /opt/iobroker/iobroker-data/
                593M    /opt/iobroker/iobroker-data/files
                154M    /opt/iobroker/iobroker-data/files/vis-2
                100M    /opt/iobroker/iobroker-data/files/vis-2-beta
                80M     /opt/iobroker/iobroker-data/backup-objects
                45M     /opt/iobroker/iobroker-data/states.jsonl
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
                25M     /opt/iobroker/iobroker-data/objects.jsonl
                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.3a4244b6.js.m        ap
                19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.3dde8f41.js.map
                *** NodeJS-Installation ***
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Installed: 18.17.1-deb-1nodesource1
                  Candidate: 18.17.1-deb-1nodesource1
                  Version table:
                 *** 18.17.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.12~dfsg-1~deb11u3 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                No problems detected
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.12
                admin:          6.9.1
                javascript:     7.1.4
                Adapters from github:   5
                Adapter State
                + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                  system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
                + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  system.adapter.klipper-moonraker.0      : klipper-moonraker     : iobroker                                 - disabled
                  system.adapter.klipper-moonraker.1      : klipper-moonraker     : iobroker                                 - disabled
                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                  system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                + system.adapter.roomba.0                 : roomba                : iobroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 -  enabled
                + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                  system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                  system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                  system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                  system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                + system.adapter.zigbee.0                 : zigbee                : zigbee                                   -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_e649ed54e993eb11bac3b15b3d98b6d1-if00-port0
                + instance is alive
                ioBroker-Repositories
                Active repo(s): beta
                Installed ioBroker-Instances
                Used repository: beta
                Adapter    "admin"        : 6.9.1    , installed 6.9.1
                Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
                Adapter    "backitup"     : 2.7.0    , installed 2.7.0
                Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                Adapter    "discovery"    : 3.2.0    , installed 3.2.0
                Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                Adapter    "hue"          : 3.10.0   , installed 3.10.0
                Adapter    "ical"         : 1.13.3   , installed 1.13.3
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                Controller "js-controller": 5.0.12   , installed 5.0.12
                Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
                Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                Adapter    "openweathermap": 0.4.2   , installed 0.4.2
                Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
                Adapter    "roomba"       : 1.2.1    , installed 1.2.1
                Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                Adapter    "socketio"     : 6.5.2    , installed 6.5.2
                Adapter    "solarmanpv"   : 0.5.0    , installed 0.5.0
                Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
                Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                Adapter    "vis-2"        : 2.2.2    , installed 2.2.2
                Adapter    "vis-2-widgets-energy": 0.3.0, installed 0.3.0
                Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                Adapter    "vis-2-widgets-material": 1.0.0, installed 1.0.0
                Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                Adapter    "web"          : 6.1.0    , installed 6.1.0
                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                Adapter    "wled"         : 0.7.0    , installed 0.7.0
                Adapter    "ws"           : 2.5.3    , installed 2.5.3
                Objects and States
                Objects:        21225
                States:         18546
                E: The repository 'http://giteduberger.fr rpimonitor/ Release' no longer has a Release file.
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1922669    56542/io.shelly.0
                tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       6216806    173459/io.sonoff.0
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       1913536    56285/io.mqtt.0
                tcp        0      0 192.168.178.67:2001     0.0.0.0:*               LISTEN      1001       1914848    56230/io.hm-rpc.0
                tcp        0      0 192.168.178.67:2010     0.0.0.0:*               LISTEN      1001       1922052    56411/io.hm-rpc.1
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14842      852/sshd: /usr/sbin
                tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14874      911/dnsmasq
                tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          14708      604/perl
                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       1914432    56077/iobroker.js-c
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       1915169    56077/iobroker.js-c
                tcp6       0      0 :::8000                 :::*                    LISTEN      1001       2438591    56807/io.upnp.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1931450    57080/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1925256    56675/io.web.0
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        24583      797/influxd
                tcp6       0      0 :::51989                :::*                    LISTEN      1001       1959234    57735/io.nuki-exten
                tcp6       0      0 :::3000                 :::*                    LISTEN      111        26647      1590/grafana
                tcp6       0      0 :::22                   :::*                    LISTEN      0          14844      852/sshd: /usr/sbin
                udp        0      0 0.0.0.0:51913           0.0.0.0:*                           108        14584      424/avahi-daemon: r
                udp        0      0 0.0.0.0:36831           0.0.0.0:*                           1001       1924579    56807/io.upnp.0
                udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14873      911/dnsmasq
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14870      911/dnsmasq
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14738      677/dhclient
                udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       2580782    75474/io.mihome-vac
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1926288    56751/io.wled.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14582      424/avahi-daemon: r
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1926800    56916/io.deconz.0
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1926013    56807/io.upnp.0
                udp6       0      0 :::5353                 :::*                                108        14583      424/avahi-daemon: r
                udp6       0      0 :::54778                :::*                                108        14585      424/avahi-daemon: r
                udp6       0      0 :::1900                 :::*                                1001       1926803    56916/io.deconz.0
                udp6       0      0 :::1900                 :::*                                1001       1926802    56916/io.deconz.0
                udp6       0      0 :::1900                 :::*                                1001       1926801    56916/io.deconz.0
                2023-08-30 08:28:39.398  - info: host.iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                2023-08-30 08:28:47.782  - info: admin.0 (57080) ==> Connected system.user.admin from ::ffff:192.168.178.78
                2023-08-30 08:29:06.610  - info: admin.0 (57080) ==> Connected system.user.admin from ::ffff:192.168.178.78
                2023-08-30 08:29:12.632  - info: admin.0 (57080) <== Disconnect system.user.admin from ::ffff:192.168.178.78
                2023-08-30 08:30:00.051  - info: javascript.0 (74404) script.js.Sonoff_Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 4 | Reboots korrigiert: 0 | Unveränderte Werte: 8
                2023-08-30 08:30:00.097  - info: javascript.0 (74404) script.js.Tasmota_Verbrauch: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 5
                2023-08-30 08:30:00.232  - info: host.iobroker instance system.adapter.solarmanpv.0 started with pid 175421
                2023-08-30 08:30:04.147  - info: solarmanpv.0 (175421) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v18.17.1, js-controller: 5.0.12
                2023-08-30 08:30:04.346  - info: host.iobroker instance system.adapter.ical.0 started with pid 175440
                2023-08-30 08:30:08.428  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 175466
                2023-08-30 08:30:09.380  - info: ical.0 (175440) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
                2023-08-30 08:30:11.536  - info: ical.0 (175440) processing URL: Family https://calendar.google.com/calendar/ical/m0uh.mw%40googlemail.com/private-cc10d4a46ea6efcadeb1da3fb2003fe0/basic.ics
                2023-08-30 08:30:13.034  - info: solarmanpv.0 (175421) State value to set for "solarmanpv.0.3252046.222324249.G_conn_Sd1" has to be type "number" but received type "string"
                2023-08-30 08:30:13.359  - info: daswetter.0 (175466) starting. Version 3.1.10 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.17.1, js-controller: 5.0.12
                2023-08-30 08:30:13.661  - warn: ical.0 (175440) Error reading from URL "http://i.cal.to/ical/83/1_fc_nuernberg/bundesliga-spielplan/d4cd812f.533cc675-995003cd.ics": 500
                2023-08-30 08:30:13.663  - info: ical.0 (175440) Use cached File content for "http://i.cal.to/ical/83/1_fc_nuernberg/bundesliga-spielplan/d4cd812f.533cc675-995003cd.ics" from Wed Aug 30 2023 07:30:19 GMT+0200 (Central European Summer Time)
                2023-08-30 08:30:13.753  - info: ical.0 (175440) processing URL: FCN http://i.cal.to/ical/83/1_fc_nuernberg/bundesliga-spielplan/d4cd812f.533cc675-995003cd.ics
                2023-08-30 08:30:14.397  - info: solarmanpv.0 (175421) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                2023-08-30 08:30:14.951  - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-08-30 08:30:18.943  - info: ical.0 (175440) Terminated (NO_ERROR): Without reason
                2023-08-30 08:30:19.508  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                2023-08-30 08:30:46.729  - info: daswetter.0 (175466) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2023-08-30 08:30:47.257  - info: daswetter.0 (175466) cleaned everything up...
                2023-08-30 08:30:47.290  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-08-30 08:32:00.421  - info: fb-checkpresence.0 (56787) newActive Laura false
                • M m0uh
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=48.7'C
                  volt=0.9160V
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M         17M         82M
                           7811 M total memory
                           3338 M used memory
                            471 M free memory
                            100 M buffer memory
                           3901 M swap cache
                             99 M total swap
                             17 M used swap
                             82 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  8.5G    /var/
                  4.0G    /var/log
                  2.5G    /var/lib
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.9.1
                  javascript:     7.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        21225
                  States:         18546
                  Pending Updates: 0
                  @m0uh
                  Wo kommt das her?
                  Und schmeiß die giteduberger-Quelle aus den Repos raus. Was haste denn da her geangelt?
                    @m0uh
                    Wo kommt das her?
                    m0uh
                    @thomas-braun said in Nodejs Update von 16.x auf 18.x nicht möglich - NPM Fehler:
                    @m0uh
                    Wo kommt das her?
                    Gute Frage wo das her kommt... :(
                    Hab die Quelle raus gehauen, war für RPi-Monitor wo ich bisschen rum gespielt habe.
                    82.9k
