  4. Zigbee Problem nach Migration
    5.2k
16 Beiträge 4 Kommentatoren 871 Aufrufe 4 Beobachtet
  • D DerRoch
    servus Thomas,
    heute hab ich die Kühlköper installiert und das original Netzteil in Betrieb genommen. Zudem auch noch die letzten Ubuntu Updates installiert.
    aktuell verählt sich Zigbee aber quasi genau wie vorher:
    christian@iobroker:~$ iob logs zigbee | grep -v info
    2023-08-15 21:59:26.737  - error: zigbee.0 (1140) DeviceConfigure:Failed to DeviceConfigure.configure 0x2c1165fffe99b52f TS004F (Error: Read 0x2c1165fffe99b52f/1 genBasic([4,0,1,5,7,65534], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (2))
    2023-08-15 21:59:37.777  - warn: zigbee.0 (1140) DeviceAvailability:Failed to ping 0x842e14fffe5a22f6 TS011F
    2023-08-15 21:59:38.777  - warn: zigbee.0 (1140) DeviceAvailability:Failed to ping 0xa4c138cdb62a8b5d TS011F
    2023-08-15 21:59:38.778  - warn: zigbee.0 (1140) DeviceAvailability:Failed to ping 0x540f57fffe3f5d26 TS011F
    2023-08-15 21:59:39.777  - warn: zigbee.0 (1140) DeviceAvailability:Failed to ping 0xe0798dfffe886e8e A10
    2023-08-15 21:59:39.778  - warn: zigbee.0 (1140) DeviceAvailability:Failed to ping 0x842e14fffeefe9d2 TS011F
    2023-08-15 21:59:40.777  - warn: zigbee.0 (1140) DeviceAvailability:Failed to ping 0xa4c138912df72585 TS011F
    2023-08-15 22:00:05.576  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:00:05.918  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:00:11.627  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:00:11.695  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:01:38.546  - warn: zigbee.0 (1140) Device '0x847127fffe75db97' announced itself
    2023-08-15 22:01:53.284  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:01:55.943  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:01:57.092  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:01:58.885  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:02:06.989  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:03:43.457  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    2023-08-15 22:03:48.291  - error: zigbee.0 (1140) No entity for 0x9035eafffe233190
    		     v.2023-04-16
    Operatingsystem: 	Ubuntu 22.04.3 LTS
    Kernel: 		5.15.0-1035-raspi
    Installation: 		Native
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.1
    			/usr/bin/node 		v18.17.1
    			/usr/bin/npm 		9.6.7
    			/usr/bin/npx 		9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.8G        1.1G        1.9G        3.0M        837M        2.5G
    Swap:             0B          0B          0B
    Total:          3.8G        1.1G        1.9G
    Active iob-Instances: 	13
    Active repo(s): stable
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.3.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 443, bind: 192.168.178.251 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 192.168.178.251 (SSL), run as: admin
    Objects: 		4797
    States: 		3738
    Size of iob-Database:
    14M	/opt/iobroker/iobroker-data/objects.jsonl
    5.8M	/opt/iobroker/iobroker-data/states.jsonl
    was soll mir der Eintrag " No entity for 0x9035eafffe233190 " sagen? das ist bspw. ein Stimmungslicht von Livrano (Lidl)
    noch Ideen was ich tun kann?
    Gruß Chris
    @derroch
    Gib dem System etwas SWAP.
    • D DerRoch
      servus Thomas,
      		     v.2023-04-16
      User-ID: 		1000
      X-Server: 		false
      			/usr/bin/npm 		9.6.7
      			/usr/bin/npx 		9.6.7
      MEMORY:
      Swap:             0B          0B          0B
      			admin 			6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects: 		4797
      States: 		3738
      Gruß Chris
      @derroch sagte in Zigbee Problem nach Migration:
      Moin,
      an welchem USB-Port hängt der Zigbee Stick?
      Ich lese hier immer wieder, dass der RasPI eine Designschwäche hat und auf dem USB3-Port wohl Frequenzstörungen verursacht, welche dann den Stick beeinträchtigen können, daher sollte man den Stick nicht direkt in die Buchse stecken, sondern ein 20-30 cm Kabel dazwischen packen.
      Bernd
        Moin,
        Bernd
        DerRoch
        schrieb am zuletzt editiert von DerRoch
        @dp20eic
        spannende Sache auf jedenfall. ich bin nicht sicher wie die Ports nummeriert werden, aber es sieht so aus als würde der stick nicht am Port 3 hängen
        $ ls -R /dev/bus/usb
        /dev/bus/usb:
        001  002
        /dev/bus/usb/001:
        001  002  003
        /dev/bus/usb/002:
        001
        $ lsusb
        Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
        Bus 001 Device 003: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
        Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
        @thomas-braun sagte in Zigbee Problem nach Migration:
        ich hab den Swap mal von 2GB auf 4GB erweitert. ich bin jetzt nicht so der ober Linux Spezi, aber es sieht so aus als würde der swap nicht verwendet:
        $ free -m
        Mem:            3790        1014        2277           3         497        2613
        Swap:           4095           0        4095
        das war der Zustand kurz nach dem Reboot. vorher (habs leider nicht kopiert) waren es eben 2047 und auch 0 used Swap. Der free-Mem stand glaub ich irgendwo im 3-Stelligen bereich...
        ab wann wird Swap verwendet? ich hab das Tool dphys-swapfile installiert um die Änderungen am Swap umzusetzen.
        Gruß Chris
        Thomas BraunT ? 3 Antworten Letzte Antwort
        • D DerRoch
          @dp20eic
          /dev/bus/usb:
          001  002
          /dev/bus/usb/001:
          001  002  003
          /dev/bus/usb/002:
          001
          $ lsusb
          $ free -m
          Swap:           4095           0        4095
          Gruß Chris
          Oben war überhaupt kein SWAP verfügbar.
          • D DerRoch
            @dp20eic
            /dev/bus/usb:
            001  002
            /dev/bus/usb/001:
            001  002  003
            /dev/bus/usb/002:
            001
            $ lsusb
            $ free -m
            Swap:           4095           0        4095
            Gruß Chris
            Immer dann, wenn der Kernel das für notwendig erachtet. Das kann auch bei ansonsten genügend RAM durchaus mal kurz der Fall sein.
            • D DerRoch
              @dp20eic
              /dev/bus/usb:
              001  002
              /dev/bus/usb/001:
              001  002  003
              /dev/bus/usb/002:
              001
              $ lsusb
              $ free -m
              Swap:           4095           0        4095
              Gruß Chris
              @dp20eic
              Moin,
              Port Übersicht
              Du kannst dir ausführliche Informationen anschauen, mit
              # sudo lsusb -v
              oder
              # usb-device
              Zusätzliche Informationen
              # ls -la /dev/serial/
              total 0
              drwxr-xr-x  4 root root   80 Aug 16 10:37 .
              drwxr-xr-x 21 root root 4960 Aug 16 13:31 ..
              drwxr-xr-x  2 root root  120 Aug 16 10:37 by-id
              drwxr-xr-x  2 root root  120 Aug 16 10:37 by-path
              # ls -la /dev/serial/by-id/
              total 0
              drwxr-xr-x 2 root root 120 Aug 16 10:37 .
              drwxr-xr-x 4 root root  80 Aug 16 10:37 ..
              lrwxrwxrwx 1 root root  13 Aug 16 10:37 usb-0658_0200-if00 -> ../../ttyACM2
              lrwxrwxrwx 1 root root  13 Aug 16 10:37 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001938A67D-if00 -> ../../ttyACM3
              lrwxrwxrwx 1 root root  13 Aug 16 10:37 usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L1100FRC-if00 -> ../../ttyACM0
              lrwxrwxrwx 1 root root  13 Aug 16 10:37 usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L1100FRC-if03 -> ../../ttyACM1
              # ls -la /dev/serial/by-path/
              total 0
              lrwxrwxrwx 1 root root  13 Aug 16 10:37 pci-0000:00:12.0-usb-0:1:1.0 -> ../../ttyACM2
              lrwxrwxrwx 1 root root  13 Aug 16 10:37 pci-0000:00:13.1-usb-0:3:1.0 -> ../../ttyACM3
              lrwxrwxrwx 1 root root  13 Aug 16 10:37 pci-0000:00:13.2-usb-0:1:1.0 -> ../../ttyACM0
              lrwxrwxrwx 1 root root  13 Aug 16 10:37 pci-0000:00:13.2-usb-0:1:1.3 -> ../../ttyACM1
              Aber wie gesagt, wichtig ist, dass da wohl ein Kabel zwischen RasPI und Zigbee-Stick ist, damit der Stick die besten Voraussetzungen hat, um korrekt zu arbeiten.
              Bernd
              P.S.: Du solltest vielleicht auch nicht /dev/ttyACMx nutzen, sondern lieber /dev/serial/by-id/dein_usb-stick das ist eindeutig, auch wenn du den mal an einen anderen Port hängst.
              • arteckA Offline
                arteckA Offline
                arteck
                @dp20eic sagte in Zigbee Problem nach Migration:
                es geht um die USB3 Störstreuung..
                • arteckA arteck
                  @arteck sagte in Zigbee Problem nach Migration:
                  Moin,
                  ja, habe hier immer noch im Hinterkopf, dass wenn der Zigbee Stick direkt am RasPI eingesteckt wird, dass es zu Problemen kommen kann, genau wegen der Störungen, die auf dem USB3 Ports auftauchen, daher das Kabel zwischen RasPI und Zigbee Stick.
                  Ob das inzwischen durch eine neuere Revision des RasPI schon gelöst wurde, kann ich nicht beantworten, stecke da in der RasPI Entwicklung nicht so tief drin.
                  Bernd
                    @dp20eic
                    Moin,
                    Port Übersicht
                    # sudo lsusb -v
                    oder
                    # usb-device
                    total 0
                    total 0
                    total 0
                    Bernd
                    DerRoch
                    sorry erst mal, das ich solange kein Update gegeben hab. Letzte Woche Gamescom und div. anderer Stress hat mich etwas zurückgeworfen ;-).
                    Leider hat sich grundsätzlich nicht viel geändert. Zahlreiche Geräte wollen einfach nicht mehr antworten. einiges Geht Grundsätzlich. Nachdem ich bspw. mein Stimmungslicht (irgendwie versehentlich) in den Koppelmodus versetzt hab und im Zigbee Adapter angelernt hab hat es auch wieder in meinen Szenen funktioniert.
                    es kommen auch immer wieder Meldungen wie:
                    DeviceAvailability:Stopping to ping 0x540f57fffe3f5d26 TS011F after 4 ping attempts
                    (das ist die Einspeisesteckdose von meinem Balkonkraftwerk)
                    Was bspw. immer noch nicht geht ist die Erfassung meiner Schaltsteckdose von der Solaranlage. Seitdem bekomm ich auch keine Messwerte mehr über die erzeugte Energie. Mittlerweile hab ich mich ja fast damit abgefunden, das ich die Geräte teilweise neu anlernen muss. Aber ich trau mich auch nicht ganz gerade diese neu zu koppeln, da ich bedenken hab, das die akt. gespeicherte Werte dann auch gelöscht werden und der kWh-Zähler wieder bei 0 steht... Habt ihr hier Erfahrungen?
                    ich habe bereits nach dem ersten Hinweis von dir bereits ein USB-Verlängerungskabel dazwischen gehängt. Seit dem leider aber eigentlich keine Änderung im Verhalten.
                    Ich arbeite bereits von Anfang an mit dem String
                    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE26xxxxx-if00
                    # sudo lsusb -v
                    oder
                    # usb-device
                    bei usb-devices kommt für con ConBee folgendes raus:
                    T:  Bus=01 Lev=02 Prnt=02 Port=01 Cnt=01 Dev#=  3 Spd=12  MxCh= 0
                    D:  Ver= 2.01 Cls=02(commc) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
                    P:  Vendor=1cf1 ProdID=0030 Rev=01.00
                    S:  Manufacturer=dresden elektronik ingenieurtechnik GmbH
                    S:  Product=ConBee II
                    S:  SerialNumber=DE26xxxxx
                    C:  #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=100mA
                    I:  If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=01 Driver=cdc_acm
                    E:  Ad=83(I) Atr=03(Int.) MxPS=  64 Ivl=16ms
                    I:  If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
                    E:  Ad=02(O) Atr=02(Bulk) MxPS=  64 Ivl=0ms
                    E:  Ad=81(I) Atr=02(Bulk) MxPS=  64 Ivl=0ms
                    Und bei "lsusb -v" folgendes
                    Device Descriptor:
                      bLength                18
                      bDescriptorType         1
                      bcdUSB               2.01
                      bDeviceClass            2 Communications
                      bDeviceSubClass         0
                      bDeviceProtocol         0
                      bMaxPacketSize0        64
                      idVendor           0x1cf1 Dresden Elektronik
                      idProduct          0x0030 ZigBee gateway [ConBee II]
                      bcdDevice            1.00
                      iManufacturer           1 dresden elektronik ingenieurtechnik GmbH
                      iProduct                2 ConBee II
                      iSerial                 3 DE26xxxxx
                      bNumConfigurations      1
                      Configuration Descriptor:
                        bLength                 9
                        bDescriptorType         2
                        wTotalLength       0x0043
                        bNumInterfaces          2
                        bConfigurationValue     1
                        iConfiguration          0
                        bmAttributes         0x80
                          (Bus Powered)
                        MaxPower              100mA
                        Interface Descriptor:
                          bLength                 9
                          bDescriptorType         4
                          bInterfaceNumber        0
                          bAlternateSetting       0
                          bNumEndpoints           1
                          bInterfaceClass         2 Communications
                          bInterfaceSubClass      2 Abstract (modem)
                          bInterfaceProtocol      1 AT-commands (v.25ter)
                          iInterface              0
                          CDC Header:
                            bcdCDC               1.10
                          CDC ACM:
                            bmCapabilities       0x02
                              line coding and serial state
                          CDC Union:
                            bMasterInterface        0
                            bSlaveInterface         1
                          CDC Call Management:
                            bmCapabilities       0x03
                              call management
                              use DataInterface
                            bDataInterface          1
                          Endpoint Descriptor:
                            bLength                 7
                            bDescriptorType         5
                            bEndpointAddress     0x83  EP 3 IN
                            bmAttributes            3
                              Transfer Type            Interrupt
                              Synch Type               None
                              Usage Type               Data
                            wMaxPacketSize     0x0040  1x 64 bytes
                            bInterval              16
                          bLength                 9
                          bDescriptorType         4
                          bInterfaceNumber        1
                          bAlternateSetting       0
                          bNumEndpoints           2
                          bInterfaceClass        10 CDC Data
                          bInterfaceSubClass      0
                          bInterfaceProtocol      0
                          iInterface              0
                            bLength                 7
                            bDescriptorType         5
                            bEndpointAddress     0x81  EP 1 IN
                            bmAttributes            2
                              Transfer Type            Bulk
                              Synch Type               None
                              Usage Type               Data
                            bInterval               0
                            bLength                 7
                            bDescriptorType         5
                            bEndpointAddress     0x02  EP 2 OUT
                            bmAttributes            2
                              Transfer Type            Bulk
                              Synch Type               None
                              Usage Type               Data
                            bInterval               0
                    Binary Object Store Descriptor:
                      bLength                 5
                      bDescriptorType        15
                      wTotalLength       0x000c
                      bNumDeviceCaps          1
                      USB 2.0 Extension Device Capability:
                        bLength                 7
                        bDescriptorType        16
                        bDevCapabilityType      2
                        bmAttributes   0x00000002
                          HIRD Link Power Management (LPM) Supported
                    Device Status:     0x0000
                      (Bus Powered)
                    Gruß Christian
                    • D DerRoch
                      # sudo lsusb -v
                      oder
                      # usb-device
                      Device Descriptor:
                        bLength                18
                        bDescriptorType         1
                        bcdUSB               2.01
                        bDeviceSubClass         0
                        bDeviceProtocol         0
                        bMaxPacketSize0        64
                        bcdDevice            1.00
                        iSerial                 3 DE26xxxxx
                          bLength                 9
                          bDescriptorType         2
                          wTotalLength       0x0043
                          bNumInterfaces          2
                          iConfiguration          0
                          bmAttributes         0x80
                            (Bus Powered)
                          MaxPower              100mA
                            bLength                 9
                            bDescriptorType         4
                            bInterfaceNumber        0
                            bAlternateSetting       0
                            bNumEndpoints           1
                            iInterface              0
                            CDC Header:
                              bcdCDC               1.10
                            CDC ACM:
                              bmCapabilities       0x02
                            CDC Union:
                              bMasterInterface        0
                              bSlaveInterface         1
                              bmCapabilities       0x03
                                call management
                                use DataInterface
                              bDataInterface          1
                              bLength                 7
                              bDescriptorType         5
                              bmAttributes            3
                                Synch Type               None
                                Usage Type               Data
                              bInterval              16
                            bLength                 9
                            bDescriptorType         4
                            bInterfaceNumber        1
                            bAlternateSetting       0
                            bNumEndpoints           2
                            iInterface              0
                              bLength                 7
                              bDescriptorType         5
                              bmAttributes            2
                                Transfer Type            Bulk
                                Synch Type               None
                                Usage Type               Data
                              bInterval               0
                              bLength                 7
                              bDescriptorType         5
                              bmAttributes            2
                                Transfer Type            Bulk
                                Synch Type               None
                                Usage Type               Data
                              bInterval               0
                        bLength                 5
                        bDescriptorType        15
                        wTotalLength       0x000c
                        bNumDeviceCaps          1
                          bLength                 7
                          bDescriptorType        16
                        (Bus Powered)
                      Gruß Christian
                      Moin,
                      also ich würde den Stick noch am zweiten USB 2 Port probieren, das sind die Linken, wenn man draufschaut, oder schwarz, die Blauen sind USB3.
                      Dann mal den Adapter auf Debug stellen und schauen, ob da noch etwas an zusätzlicher Information kommt.
                      Welchen Kanal nutzt Du im Adapter? Vielleicht nutzt Du ein Kanal, der nicht so gut von den Geräten unterstützt wird.
                      Ich kenne den von Dir verwendeten Zwischenstecker nicht, ich nutze Tasmota geflaschte Zwischenstecker, da kann ich die einzeln Werte Löschen und auch wieder einen Anfangswert hineinschreiben, ob das bei Deinen geht, musst Du mal nachlesen.
                      Hat sich der Standort, geändert, sodass der Stick jetzt vielleicht ungünstiger positioniert ist?
                      Wenn das alles nicht hilft, dann auch mal eine oder zwei Versionen zurückgehen und testen, oder wenn es gar nicht geht, dann neu anlernen oder auf zigbee2mqtt umsteigen.
                      Bernd
