  4. Neuer Adapter für Roborock-Staubsauger
    6.3k
1.1k Beiträge 155 Kommentatoren 474.9k Aufrufe 138 Beobachtet
  • A andibr
    Hallo zusammen
    Kleine Frage: "wurde da irgendwo irgendwas verändert?" Seit heute (Samstag 12.08.2023:12.34) macht mein Iob einen auf Terror mit dem Roborock-Adapter. Ich habe ihn jetzt mal deaktiviert.
    host.iobroker
    		2023-08-12 17:24:07.645	info	Do not restart adapter system.adapter.roborock.0 because disabled or deleted
    host.iobroker
    		2023-08-12 17:24:07.645	error	instance system.adapter.roborock.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    roborock.0
    	5273	2023-08-12 17:24:07.047	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    roborock.0
    	5273	2023-08-12 17:24:06.999	error	adapter disabled
    host.iobroker
    		2023-08-12 17:23:49.676	info	"system.adapter.roborock.0" disabled
    mqtt.1
    		2023-08-12 17:23:34.190	info	Restart adapter system.adapter.roborock.0 because enabled
    host.iobroker
    		2023-08-12 17:23:34.190	info	instance system.adapter.roborock.0 terminated with code NaN ()
    host.iobroker
    		2023-08-12 17:23:34.190	warn	instance system.adapter.roborock.0 terminated due to SIGABRT
    host.iobroker
    		2023-08-12 17:23:34.190	error	Caught by controller[7]: 8: 0x17036b9 [io.roborock.0]
    host.iobroker
    		2023-08-12 17:23:34.190	error	Caught by controller[6]: 7: 0xdc3def v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.roborock.0]
    host.iobroker
    		2023-08-12 17:23:34.190	error	Caught by controller[5]: 6: 0xdc28b0 [io.roborock.0]
    host.iobroker
    		2023-08-12 17:23:34.189	error	Caught by controller[4]: 5: 0x7eff119f53d3 [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
    host.iobroker
    		2023-08-12 17:23:34.189	error	Caught by controller[4]: 4: 0x7eff11a0347c Context2d::GetImageData(Nan::FunctionCallbackInfo<v8::Value> const&) [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
    host.iobroker
    		2023-08-12 17:23:34.189	error	Caught by controller[4]: 3: 0xd644da v8::Utils::ReportApiFailure(char const*, char const*) [io.roborock.0]
    host.iobroker
    		2023-08-12 17:23:34.189	error	Caught by controller[3]: 2: 0xa94749 node::OOMErrorHandler(char const*, bool) [io.roborock.0]
    host.iobroker
    		2023-08-12 17:23:34.189	error	Caught by controller[2]: 1: 0xb83f50 node::Abort() [io.roborock.0]
    host.iobroker
    		2023-08-12 17:23:34.189	error	Caught by controller[1]: FATAL ERROR: v8::ToLocalChecked Empty MaybeLocal.
    host.iobroker
    		2023-08-12 17:23:34.188	error	Caught by controller[0]: Downloading AlexxIT/go2rtc@v1.6.2...
    roborock.0
    	5234	2023-08-12 17:23:11.328	info	MQTT initialized
    roborock.0
    	5234	2023-08-12 17:23:09.896	info	starting. Version 0.2.1 (non-npm: copystring/ioBroker.roborock#cea0cc4fa080d5a2041706a71b4190f153c773b4) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.17.1, js-controller: 4.0.24
    Das ganze wiederholt sich alle paar Minuten und füllt das Log. Ich muss auch gestehen, ich habe bis jetzt noch gar nichts mit den Daten gemacht, ausser in den Objekten angeschaut. Auch erst 1x die Map angeschaut und studiert wie ich das verwenden kann.
    Seit ca. 2 Wochen hat das ganze jetzt einfach sauber die Objekte gefüllt und keine Probleme verursacht.
    Ist das auch bei anderen so?
    Andi
    jahnbesJ Offline
    jahnbesJ Offline
    jahnbes
    schrieb am zuletzt editiert von jahnbes
    #119
    Hallo @andibr und andere.
    seit dem Update der roborock-App auf die Version 02.58.40 am 11.8.23 habe ich auch Probleme mit dem roborock und dem Adapter, minütlich kommt die Fehlermeldung
    "Unsported attribute: clean_percent of get_status with value 0. Please contact the dev to add the newly found attribute of your robot."
    Ich habe das bereits in github gemeldet.
    Gruß Bert.
    David G.D ch90045C 2 Antworten Letzte Antwort
    • jahnbesJ jahnbes
      Gruß Bert.
      David G.D Online
      David G.D Online
      David G.
      #120
      @jahnbes
      Ist eine neue Funktion in der App. Dort sieht man beim reinigen den Fortschritt in einem Balken.
      jahnbesJ 1 Antwort Letzte Antwort
        maxb
        #121
        Hallo!
        Es wurde ja schon über die Darstellung einer Karte gesprochen und dass das nicht so einfach funktionert, da die Karte nur als Base64-Image vorliegt.
        Ich habe mal etwas getüftelt und vielleicht hilft es dem ein oder anderen:
        Die Base64-Images sind ganz normale HTML-"Bilder", die man z.B. in einer Visu nutzen kann, leider aber nicht einfach so, sondern nur über Umwege.
        Der HTML-Code für die Einbindung eines Bas64-Bildes ist so aufgebaut:
        <img src="[BASE64-CODE]">
        Also eigentlich alles kein Hexenwerk. Wenn man aus dem Datenpunkt den Code kopiert und in ein HTML-Objekt in VIS einfügt, wird die Karte auch wunderbar dargestellt, aber natürlich nicht aktualisiert. Da man über geschweifte Klammern direkt in VIS auf den Inhalt eines Datenpunktes zugreifen kann, dachte ich, dass man das über
        <img src="{roborock.0.Devices.ID.map.mapBase64}">
        lösen kann, das funktioniert aber so nicht. Sollte jemand wissen, wie das funktioniert, gerne melden!
        Ich habe das dann so gelöst, dass ich eine script erstellt habe, was nichts anderes macht, als die spitzen Klammern davor und dahinter zu setzen und das alles in einer neuen Variable zu speichern. Diesen String kann ich dann über die geschweiften Klammern in VIS einbinden, es funktionert alles ohne Probleme!
        Code:
         <block type="control" id="q]VQvq6D3wTA4)@;2Pll" inline="false" x="-12" y="-62">
           <field name="OID">0_userdata.0.own_variables.Bobs_Karte</field>
           <value name="VALUE">
             <block type="text_join" id="5-?y*KQ:Y80!V91Yodb!">
               <value name="ADD0">
                 <block type="text" id="Cc@lc8)Fr2JyKrvP:/Fh">
                   <field name="TEXT">&lt;img  style="width: 80%; height: auto; object-fit: inherit; object-position: 0 0;"  src="</field>
                 </block>
               </value>
               <value name="ADD1">
                 <block type="get_value" id="Z]JX6e;b^dh)cs(P^N=:">
                   <field name="OID">roborock.0.Devices.5qpgK8e1ywan2qsWru9feg.cleaningInfo.Records.0.map.mapBase64</field>
                 </block>
               </value>
               <value name="ADD2">
                 <block type="text" id="8K1rL)_63uZRJ.-{+RG~">
                   <field name="TEXT">"&gt;</field>
                 </block>
               </value>
             </block>
           </value>
           <next>
             <block type="on" id="[oUHwy/QQu*ltlu5id5)">
               <statement name="STATEMENT">
                 <block type="control" id="nAbRG4CNIj(s,5[`9VkO" inline="false">
                     <block type="text_join" id="2k-vFVe8e:a2O76QlkW?">
                       <value name="ADD0">
                         <block type="text" id="AR^b;KZ;H]gW+VYbolQG">
                         </block>
                       </value>
                       <value name="ADD1">
                         <block type="get_value" id="k)(j6}MFVQkeqecTw`Qg">
                         </block>
                       </value>
                       <value name="ADD2">
                         <block type="text" id="HQnyYb)[/{?#394+RKX!">
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </statement>
             </block>
           </next>
         </block>
        </xml>
        Hinweise:
        • In VIS im Editor wird immer nur das Objekt in geschweiften Klammern dargestellt. Geladen wird der Inhalt erst in der feriten VIS!
        • die zusätzlichen Inhalte style="" skalieren und beschneiden das Bild, damit es vernünftig dargestllt werden kann. Da muss man je nach Karte schauen wie es passt. Bei mir ist der Bereich oben links des Bildes erstmal sehr viel weiß, weshalb ich da viel wegschneiden muss, bis die eigentliche Karte zu sehen ist, spielt einfach mit den Werten.
        • Die Aktualisierungsrate der Karte ist wirklich mäßig. Ich weiß nicht in welchen Intervallen das passiert, es scheint immer so gegen Ende der Reinigung zu sein, manchmal auch währenddessen, manchmal auch im Dock. Woran das liegt weiß vermutlich nur Roborock.
        Bei Bedarf kann ich das hier gerne noch fürs WIKI auf englisch aufbereiten, ich habe da aber keine Schreibrechte drauf.
        Viel Spaß damit, Anmerkungen oder Fragen sind willkommen!
        copystringC FlexerF 3 Antworten Letzte Antwort
        • M maxb
          Hallo!
          Code:
                 <value name="ADD0">
                   </block>
                 </value>
                 <value name="ADD1">
                   </block>
                 </value>
                 <value name="ADD2">
                   </block>
                 </value>
               </block>
             </value>
             <next>
                         <value name="ADD0">
                           </block>
                         </value>
                         <value name="ADD1">
                           </block>
                         </value>
                         <value name="ADD2">
                           </block>
                         </value>
                       </block>
                     </value>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
          </xml>
          Hinweise:
          copystringC Offline
          copystringC Offline
          copystring
          #122
          @maxb said in Neuer Adapter für Roborock-Staubsauger:
          Da ist eine trimmed base64. Dort sind alle Ränder bereits entfernt.
          Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
          https://paypal.me/copystring
          • David G.D David G.
            @jahnbes
            jahnbesJ Offline
            jahnbesJ Offline
            jahnbes
            #123
            @david-g
            Hallo, das mag ja sein und durchaus vernünftig, bei mir ist es aber ein permanent aufploppender Fehler im Protokoll des ioBrokers:
            https://github.com/copystring/ioBroker.roborock/issues/348
            Und der ist unschön.
            Viele Grüße, Bert.
            • jahnbesJ jahnbes
              @david-g
              Viele Grüße, Bert.
              David G.D Online
              David G.D Online
              David G.
              #124
              @jahnbes
              Ist auch so gewollt.
              So sieht man neue Werte die von Roborock übermittelt werden und kann es dem Dev melden damit es eingebaut wird.
              Der Dev bekommt die Werte ja nicht unbedingt bei einem anderen Staubsaugermodell.
              copystringC 1 Antwort Letzte Antwort
                @jahnbes
                copystringC Offline
                copystringC Offline
                copystring
                #125
                @david-g said in Neuer Adapter für Roborock-Staubsauger:
                @jahnbes
                So ist es. Nur so kann ich sehen, ob neue Werte verfügbar sind.
                Ich kümmere mich darum wenn ich aus dem Urlaub zurück bin.
                • copystringC copystring
                  @jahnbes
                  jahnbesJ Offline
                  jahnbesJ Offline
                  jahnbes
                  #126
                  @copystring Dann wünsche ich Dir vor allem einen schönen Urlaub!
                  • jahnbesJ jahnbes
                    copystringC Offline
                    copystringC Offline
                    copystring
                    #127
                    @jahnbes du hast eine PN von mir bekommen.
                      Matt77CHE
                      #128
                      @tritanium
                      Hallo Tritanium
                      Ich steh gerade gründlich auf dem Schlauch, wie kriege ich es hin, dass zB bei "Start durch" nicht die 3 steht, sondern "App"?
                      Ich habe schon diverse Sachen bei json attribut versucht einzutragen, hat nichts funktioniert.
                      Wenn ich schon dabei bin, wie hast du es hinbekommen, dass bei der Zeit nicht 01:00:00 sondern 13:00:00 steht?
                      Gruss
                      Matt
                        BamBam89
                        #129
                        gibt es denn schon Erfahrungen zum S8 Ultra?
                        Ich habe den Adapter installiert. Die Verbindung zum Roborock steht,
                        allerdings habe ich nicht die Möglichkeit unter "floors" einzelne Räume auszuwählen.
                        Alles andere scheint soweit zu funktionieren.
                        Danke euch
                        Gruß Christian
                        • B BamBam89
                          Danke euch
                          Gruß Christian
                          copystringC Offline
                          copystringC Offline
                          copystring
                          #130
                          @bambam89 meistens geht das nicht weil entweder die Etage oder ein oder mehrere Räume keinen Namen haben
                            BamBam89
                            #131
                            @copystring
                            Das wars. Die Karte war nicht benannt.... Oh man.
                            Danke dir
                              BamBam89
                              #132
                              Ich hätte dann doch noch eine Frage.
                              Sowie läuft die Sache. Was mich jedoch wunder, ich habe ein Script geschrieben,
                              das dafür sorgt, das bi Klick auf Button der Wert Charge vacuum (Zurück zur Ladestation) kurzzeitig auf true gesetzt wird um den Sauger zurück zur Ladestation fahren zu lassen.
                              In diesem Skript wird auch der Wert "Sunction power" (Saugstärke) auf Normal (102) gesetzt und der Wert Scrub intensity (Wischintensität) auf aus (200). Beide Werte werden auch in den Objekten entsprechend gesetzt. Aber immer wenn ich den
                              Sauger das nächste mal starte, wird zwar der Wert zum Saugen angenommen der im Objekt steht aber er fängt auch an zu wischen, obwohl das Objekt Scrub intensity (Wischintensität) auf aus (200) steht.
                              Hat jemand eine Idee, was das sein könnte?
                              Gruß Christian
                              • jahnbesJ jahnbes
                                Gruß Bert.
                                ch90045C Offline
                                ch90045C Offline
                                ch90045
                                #133
                                @jahnbes Guten Morgen, wie hast du den DEV Branch installiert?
                                Danke, Christian
                                  DeeKay 0
                                  #134
                                  @copystring
                                  Eine Idee was es damit auf sich hat? Ich habe einen S7 MaxV.
                                  roborock.0
                                  2023-08-29 09:42:41.433 error Unsported attribute: clean_percent of get_status with value 0. Please contact the dev to add the newly found attribute of your robot.
                                  • D DeeKay 0
                                    @copystring
                                    roborock.0
                                    SpacerX
                                    #135
                                    @deekay-0 Siehe 10 Beiträge höher. Sagt das aus was da steht. Unbekannter Parameter gefunden, dem Entwickler melden damit er diesen ins Projekt einfügen kann.
                                    DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
                                    • S SpacerX
                                      DeeKay 0
                                      schrieb am zuletzt editiert von DeeKay 0
                                      #136
                                      @spacerx Danke, Captain obvious. Reicht hier über das Forum (daher hab ich ja ein mention an copystring gemacht) oder wird ein Github-Issue gewünscht?
                                      • D DeeKay 0
                                        jahnbesJ Offline
                                        jahnbesJ Offline
                                        jahnbes
                                        #137
                                        @deekay-0
                                        Hallo deekay,
                                        nein, es ist kein Github-Issue notwendig, das ist schon erfolgt (von mir):
                                        Und copystring hat auch schon das Problem gelöst, in der dev-Branch von Github ist der Fehler weg.
                                        Bei Gelegenheit wird copystring es in die stable-Version stellen.
                                        Wenn Du die Dev-branch haben willst, die findest Du im obigen Github.
                                        Viele Grüße, Bert.
                                        • ch90045C ch90045
                                          Danke, Christian
                                          jahnbesJ Offline
                                          jahnbesJ Offline
                                          jahnbes
                                          #138
                                          @ch90045
                                          Ebenfalls einen guten Morgen!
                                          Die DEV Branch installierst Du, wie im obigen Screenshot angedeutet:
                                          • iobroker aufrufen
                                          • auf [Adapter] gehen
                                          • Handling auf [Admin] setzen (1)
                                          • [Github] einstellen (2)
                                          • [benutzerdefinierte] Installation aufrufen (3)
                                          • DEV Branch link eintragen (4)
                                          • Naja, und zum Schluß auf [Installieren] drücken
                                          Den DEV Branch link findest Du in Github unter
                                          Viele Grüße, Bert.
