  4. Nach Systemaktualisierung Modbus Fehler 25
35 Beiträge 5 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • D Dooley_76
    @djmarc75 said in Nach Systemaktualisierung Modbus Fehler 25:
    iob diag
    Das hier ist die Ausgabe von diag ...
    Holger
    FabioF Offline
    FabioF Offline
    Fabio
    @dooley_76 setze die Ausgabe bitte in die Code Tags </> damit man das lesen kann.
    Iobroker:
    • Matter over Thread Hilfe
    • FabioF Fabio
      Dooley_76
      @fa-bio
      Irgendwas scheint da gerade bei der Übertragung nicht gefunzt zu haben, also hier nochmal
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Architecture    : armv7l
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       11:25:29 up 9 min,  1 user,  load average: 0.26, 0.26, 0.18
      CPU threads: 4
      Raspberry only:
      throttled=0x80000
      Other values than 0x0 hint to temperature/voltage problems
      temp=53.7'C
      volt=1.3875V
      *** Time and Time Zones ***
                     Local time: Tue 2023-08-22 11:25:30 BST
                 Universal time: Tue 2023-08-22 10:25:30 UTC
                       RTC time: n/a
                      Time zone: Europe/London (BST, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            971M         56M        498M        0.0K        415M        849M
      Swap:            99M          0B         99M
      Total:          1.1G         56M        598M
                971 M total memory
                 56 M used memory
                215 M active memory
                165 M inactive memory
                498 M free memory
                 56 M buffer memory
                359 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  3.0G   25G  11% /
      devtmpfs       devtmpfs  358M     0  358M   0% /dev
      tmpfs          tmpfs     486M     0  486M   0% /dev/shm
      tmpfs          tmpfs     195M  920K  194M   1% /run
      /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
      [Tue Aug 22 11:16:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        data mode. Quota mode: none.
      [Tue Aug 22 11:16:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Aug 22 11:16:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      353M    /var/
      94M     /var/lib
      90M     /var/log
      89M     /var/log/journal/97dfd2004a894a86ab647e0fbc98a3a4
      Archived and active journals take up 88.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      251M    /opt/iobroker/iobroker-data/
      245M    /opt/iobroker/iobroker-data/files
      88M     /opt/iobroker/iobroker-data/files/echarts.admin
      57M     /opt/iobroker/iobroker-data/files/echarts
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
      17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
      17M     /opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.8.0
      javascript:     7.0.3
      Adapters from github:   0
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker-pi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                                                 n
        system.adapter.backitup.0               : backitup              : iobroker-pi        -  enabled
        system.adapter.chromecast.0             : chromecast            : iobroker-pi        -  enabled
        system.adapter.discovery.0              : discovery             : iobroker-pi        -  enabled
        system.adapter.echarts.0                : echarts               : iobroker-pi        -  enabled
        system.adapter.influxdb.0               : influxdb              : iobroker-pi        -  enabled, port: 8086
        system.adapter.jarvis.0                 : jarvis                : iobroker-pi        -  enabled
        system.adapter.javascript.0             : javascript            : iobroker-pi        -  enabled
        system.adapter.net-tools.0              : net-tools             : iobroker-pi        - disabled
        system.adapter.ping.0                   : ping                  : iobroker-pi        - disabled
        system.adapter.synology.0               : synology              : iobroker-pi        - disabled, port: 5000
        system.adapter.vis.0                    : vis                   : iobroker-pi        -  enabled
        system.adapter.web.0                    : web                   : iobroker-pi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                                                 n
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.8.0    , installed 6.8.0
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "synology"     : 2.1.13   , installed 2.1.13
      Objects and States
      Objects:        314
      States:         240
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode    PID/Program name
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13764    467/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13766    467/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12641    332/avahi-daemon: r
      udp        0      0 0.0.0.0:41423           0.0.0.0:*                           108        12643    332/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11103    663/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        12642    332/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12686    663/dhcpcd
      udp6       0      0 :::34871                :::*                                108        12644    332/avahi-daemon: r
      2023-08-22 11:17:00.108  - warn: host.iobroker-pi instance system.adapter.jarvis.0 terminated due to SIGTERM
      2023-08-22 11:17:00.106  - info: chromecast.0 (770) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-08-22 11:17:00.109  - info: host.iobroker-pi instance system.adapter.jarvis.0 terminated with code null ()
      2023-08-22 11:17:00.114  - info: javascript.0 (750) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-08-22 11:17:00.115  - info: host.iobroker-pi stopInstance system.adapter.admin.0 send kill signal
      2023-08-22 11:17:00.116  - info: host.iobroker-pi stopInstance system.adapter.javascript.0 send kill signal
      2023-08-22 11:17:00.117  - info: host.iobroker-pi stopInstance system.adapter.chromecast.0 send kill signal
      2023-08-22 11:17:00.117  - info: host.iobroker-pi stopInstance system.adapter.discovery.0 send kill signal
      2023-08-22 11:17:00.118  - info: host.iobroker-pi stopInstance system.adapter.backitup.0 send kill signal
      2023-08-22 11:17:00.118  - info: host.iobroker-pi stopInstance system.adapter.web.0 send kill signal
      2023-08-22 11:17:00.119  - info: host.iobroker-pi stopInstance system.adapter.echarts.0 send kill signal
      2023-08-22 11:17:00.119  - info: host.iobroker-pi stopInstance system.adapter.jarvis.0 send kill signal
      2023-08-22 11:17:00.159  - info: web.0 (837) terminated http server on port 8082
      2023-08-22 11:17:00.171  - info: web.0 (837) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-08-22 11:17:00.496  - info: echarts.0 (925) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-08-22 11:17:00.787  - info: host.iobroker-pi instance system.adapter.influxdb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-08-22 11:17:00.819  - info: host.iobroker-pi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-08-22 11:17:00.890  - info: host.iobroker-pi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-08-22 11:17:00.892  - info: host.iobroker-pi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-08-22 11:17:00.893  - info: host.iobroker-pi instance system.adapter.chromecast.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-08-22 11:17:00.929  - info: host.iobroker-pi instance system.adapter.javascript.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-08-22 11:17:00.958  - info: host.iobroker-pi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-08-22 11:17:01.059  - info: host.iobroker-pi instance system.adapter.echarts.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-08-22 11:17:01.060  - info: host.iobroker-pi All instances are stopped.
      2023-08-22 11:17:01.263  - info: host.iobroker-pi terminated
      FabioF Thomas BraunT 2 Antworten Letzte Antwort
      • D Dooley_76
        @fa-bio
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x80000
        temp=53.7'C
        volt=1.3875V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                  971 M total memory
                   56 M used memory
                  215 M active memory
                  498 M free memory
                   56 M buffer memory
                  359 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        353M    /var/
        94M     /var/lib
        90M     /var/log
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.8.0
        javascript:     7.0.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        314
        States:         240
        Pending Updates: 0
        FabioF Offline
        FabioF Offline
        Fabio
        @dooley_76 okay ich glaube da sollte mal @Thomas-Braun drüber schauen.
        Iobroker:
        • D Dooley_76
          @fa-bio
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x80000
          temp=53.7'C
          volt=1.3875V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                    971 M total memory
                     56 M used memory
                    215 M active memory
                    498 M free memory
                     56 M buffer memory
                    359 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          353M    /var/
          94M     /var/lib
          90M     /var/log
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.8.0
          javascript:     7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        314
          States:         240
          Pending Updates: 0
          Thomas BraunT Offline
          @dooley_76 sagte in Nach Systemaktualisierung Modbus Fehler 25:
          Frisch aufgesetzt? Ich hätte da dann die 64bit-Version genommen.
          Raspberry only:
          throttled=0x80000
          Original Netzteil in Verwendung? Das scheint mir zuviel Spannung zu sein.
          Vermutlich die falsche Zeitzone, oder hockst du auf der Insel?
          Ansonsten läuft da keine einzige Instanz.
          Was sagt:
          iobroker add modbus --host iobroker-pi --debug
            Dooley_76
            @fa-bio
            Ok, dann warten wir mal ab ...
            Hier noch ein paar Randinformationen, falls die helfen und sich somit hoffentlich keiner unnötig auf einen "Irrweg" begibt:
            Aktuell:
            • Installation des Images von buanet: https://github.com/buanet/ioBroker.raspberry-os/releases
            Nach der Installation des Images habe ich mich dann mit Thomas Braun seiner Anleitung weiter gemacht, was die Installation node betrifft: https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            Leider war es mir nicht möglich, IOBroker manuell zu installieren, da er IMMER mit einem Fehler abgebrochen hat.
            Ich weiß die Meldung nicht mehr aus dem Kopf, aber irgendwas mit ... tree ... Im Zweifel kann ich die SD-Karte noch einmal löschen und den Fehler nachstellen, wenn wir so nicht weiter kommen.
            Gehalten habe ich mich dabei an folgende Anleitung: https://www.iobroker.net/#de/documentation/install/nodejs.md
            Vorher habe ich noch das aktuelle Raspberry Image Lite (64bit) per PI Imager aufgespielt.
            Das hat dann auch alles soweit geklappt, alles war auf aktuellem Stand. Nur die Adapter (alle) lassen sich nicht installieren. Alle brechen mit Code 25 ab.
            Hier übrigens noch die Struktur:
            pi @iobroker-pi: ~$ uname - m && type - P nodejs node npm npx corepack && nodejs - v && node - v && npm - v && npx - v && corepack - v && iob - v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            armv7l
                / usr / bin / nodejs
                / usr / bin / node
                / usr / bin / npm
                / usr / bin / npx
                / usr / bin / corepack
            v18.17.1
            v18.17.1
            9.6.7
            9.6.7
            0.18.0
            4.0.24
            pi
            tty
                / home / pi
            Hit: 1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit: 2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit: 3 https://deb.nodesource.com/node_18.x bullseye InRelease
            Reading package lists...Done
            Building dependency tree...Done
            Reading state information...Done
            All packages are up to date.
                nodejs:
            Installed: 18.17.1 - deb - 1nodesource1
            Candidate: 18.17.1 - deb - 1nodesource1
              Version table:
             *** 18.17.1 - deb - 1nodesource1 500
            100 /var/lib/dpkg / status
            12.22.12~dfsg - 1~deb11u4 500
            Ich hoffe ich habe keinen "Dummy-Fehler" begangen ... ;)
            Danke Euch schon einmal im voraus für Eure Mühen ...
            Holger
              Raspberry only:
              throttled=0x80000
              Was sagt:
              Dooley_76
              Original-Netzteil: Nein, damit habe ich immer Unterspannungsfehler bekommen, welche ich jetzt teilweise auch nocht hatte
              Zeitzone: Hatte ich eigentlich eingestellt, aber ich prüfe es nochmal, vielleicht habe ich ja die falsche erwischt.
              Hier noch die Ausgabe Deiner Anfrage:
              pi @iobroker-pi: ~$ iobroker add modbus--host iobroker - pi--debug
              NPM version: 9.6.7
              Installing iobroker.modbus@5.0.11... (System call)
              npm ERR! code ECONNREFUSED
              npm ERR! syscall connect
              npm ERR! errno ECONNREFUSED
              npm ERR! FetchError: request to https://registry.npmjs.org/iobroker.modbus failed, reason: connect ECONNREFUSED 2606:4700::6810:622:443
              npm ERR!     at ClientRequest.< anonymous > (/usr/lib / node_modules / npm / node_modules / minipass - fetch / lib / index.js: 130: 14)
              npm ERR!     at ClientRequest.emit(node: events: 514: 28)
              npm ERR!     at TLSSocket.socketErrorListener(node: _http_client: 501: 9)
              npm ERR!     at TLSSocket.emit(node: events: 526: 35)
              npm ERR!     at emitErrorNT(node: internal / streams / destroy: 151: 8)
              npm ERR!     at emitErrorCloseNT(node: internal / streams / destroy: 116: 3)
              npm ERR!     at process.processTicksAndRejections(node: internal / process / task_queues: 82: 21)
              npm ERR!     at process.processTicksAndRejections(node: internal / process / task_queues: 82: 21) {
              npm ERR!   code: 'ECONNREFUSED',
                      npm ERR!   errno: 'ECONNREFUSED',
                          npm ERR!   syscall: 'connect',
                              npm ERR!   address: '2606:4700::6810:622',
                                  npm ERR!   port: 443,
                                      npm ERR!   type: 'system',
                                          npm ERR!   requiredBy: '.'
              npm ERR!
              npm ERR!
              npm ERR! If you are behind a proxy, please make sure that the
              npm ERR! 'proxy' config is set properly.See: 'npm help config'
              npm ERR! A complete log of this run can be found in: /home/iobroker /.npm / _logs / 2023 - 08 - 22T11_21_24_839Z - debug - 0.log
              host.iobroker - pi Cannot install iobroker.modbus@5.0.11: 1
              Danke,
              Gruß Holger
              • D Dooley_76
                @fa-bio
                Aktuell:
                armv7l
                    / usr / bin / node
                    / usr / bin / npm
                    / usr / bin / npx
                v18.17.1
                v18.17.1
                9.6.7
                9.6.7
                0.18.0
                4.0.24
                pi
                tty
                    / home / pi
                    nodejs:
                  Version table:
                Holger
                das wird im von @fa-bio verlinkten Beitrag zum Error 25 gefixt
                  Dooley_76
                  Danke, den hatte ich auch gefunden und probiert: ( https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2 )
                  leider ohne Erfolg :(
                  Holger
                  • D Dooley_76
                    Holger
                    @dooley_76
                    Ich würde die Kiste nochmal ganz neu aufsetzen. Keine iob-Images, keine manuelle Installation von nodejs usw, dafür direkt mit einem user, der weder pi noch iobroker heißt und mit der richtigen Zeitzone:
                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    Da ist auch was beim Netzwerk 'krumm'. Kann sein, dass da schon die falsche Zeitzone reinspielt.
                      @dooley_76
                      Dooley_76
                      Ok, dann mache ich das mal. Hab es jetzt schon so oft gemacht, da kommt es auf einmal mehr auch nicht mehr an ;))
                      Danke und ich melde mich dann wieder zwecks Rückmeldung ...
                      Holger
                      • D Dooley_76
                        Holger
                        @dooley_76
                        Aber irgendwas machst du falsch, denn
                        führt nicht zu armv7l. Das ist die 32bit-Version.
                          @dooley_76
                          Dooley_76
                          Da habe ich mich vielleicht unglücklich bzw. falsch ausgedrückt:
                          Ich habe es einmal mit dem "original" Image per Imager versucht (Raspberry 64bit Lite)
                          und dann versucht IOBroker zu installieren, was dann ja immer nicht funktioniert hat.
                          Danach erst habe ich das Image genommen, welches jetzt läuft und das ist wohl kein 64bit.
                          Holger
                          • D Dooley_76
                            Holger
                            Warum nicht?
                            Hier nach geht das:
                              Warum nicht?
                              Hier nach geht das:
                              Dooley_76
                              Hallo Thomas,
                              vielleicht habe ich bei der letzten Installation eine andere Anleitung bzw. andere Befehle benutzt, die da standen. Ganz sicher bin ich mir aber mittlerweile nicht mehr. Ich habe den Pi jetzt seit heute morgen bestimmt schon 10-15 mal neu installiert, immer wieder mit anderen Anleitungen/Wegen/Versuchen, bis ich mich in meiner Verzweiflung an Euch gewandt habe.
                              Aber ich bin gerade dabei, es jetzt noch einmal nach Deiner Anleitung zu machen und werde ich auch strikt daran halten ;)
                              Ich geb' Bescheid ...
                              Holger
                              P.S.: Wenn das dann wirklich gleich laufen sollte mach' ich alles aus, nimm' mir ein Bier, setz' mich nach draußen und heul :D
                              • D Dooley_76
                                Hallo Thomas,
                                Holger
                                Dooley_76
                                @dooley_76
                                Jetzt bin ich ja "beruhigt" ;)) Ich hänge wieder da, wo es vorher auch schon nicht weiter ging, wenn ich IOBroker ( per curl -sLf https://iobroker.net/install.sh | bash - ) aufspiele:
                                Wenn ich nichts mache, geht es nach ~ 5-6 Minuten "weiter" und es kommt dieses hier:
                                Holger @raspberryiobroker: ~$ curl - sLf https://iobroker.net/install.sh | bash -
                                library: loaded
                                Library version = 2022 - 12 - 09
                                    Welcome to the ioBroker installer!
                                    Installer version: 2023-04-16
                                    You might need to enter your password a couple of times.
                                    Installing prerequisites (1/4)
                                Hit:1 http://deb.debian.org/debian bullseye InRelease
                                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                Reading package lists... Done
                                    Node.js not found. Installing...
                                ## Installing the NodeSource Node.js 18.x repo...
                                ## Populating apt-get cache...
                                + apt-get update
                                ## Confirming "bullseye" is supported...
                                + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/bullseye/Re            lease'
                                ## Adding the NodeSource signing key to your keyring...
                                + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor |             tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                                + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesourc            e.com/node_18.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                                + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodes            ource.com/node_18.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                                ## Running `apt-get update` for you...
                                + apt-get update
                                Get:2 https://deb.nodesource.com/node_18.x bullseye InRelease [4,586 B]
                                Hit:4 http://deb.debian.org/debian bullseye InRelease
                                Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                                Get:6 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages [776 B]
                                Get:7 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages [787 B]
                                Fetched 6,149 B in 2s (2,634 B/s)
                                ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                                ## You may also need development tools to build native addons:
                                     sudo apt-get install gcc g++ make
                                ## To install the Yarn package manager, run:
                                     curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo te            e /usr/share/keyrings/yarnkey.gpg >/dev/null
                                     echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.co            m/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                     sudo apt-get update && sudo apt-get install yarn
                                Installed nodejs
                                Node.js Installed successfully!
                                Changing npm registry to https://registry.npmjs.org
                                Installed acl
                                Installed gcc-c++
                                Installed libavahi-compat-libdnssd-dev
                                Installed libudev-dev
                                Installed libpam0g-dev
                                Installed git
                                Installed libcairo2-dev
                                Installed libpango1.0-dev
                                Installed libjpeg-dev
                                Installed libgif-dev
                                Installed librsvg2-dev
                                Installed cmake
                                    Creating ioBroker user and directory (2/4)
                                User iobroker created
                                Directory /opt/iobroker created
                                    Installing ioBroker (3/4)
                                npm ERR! FetchError: request to https://registry.npmjs.org/iobroker.admin failed            , reason: connect ECONNREFUSED 2606:4700::6810:b22:443
                                npm ERR!     at ClientRequest.<anonymous> (/usr/lib/node_modules/npm/node_module            s/minipass-fetch/lib/index.js:130:14)
                                npm ERR!     at ClientRequest.emit (node:events:514:28)
                                npm ERR!     at TLSSocket.socketErrorListener (node:_http_client:501:9)
                                npm ERR!     at TLSSocket.emit (node:events:526:35)
                                npm ERR!     at emitErrorNT (node:internal/streams/destroy:151:8)
                                npm ERR!     at emitErrorCloseNT (node:internal/streams/destroy:116:3)
                                npm ERR!     at process.processTicksAndRejections (node:internal/process/task_qu            eues:82:21)
                                npm ERR!  FetchError: request to https://registry.npmjs.org/iobroker.admin faile            d, reason: connect ECONNREFUSED 2606:4700::6810:b22:443
                                npm ERR!     at process.processTicksAndRejections (node:internal/process/task_qu            eues:82:21) {
                                npm ERR!   address: '2606:4700::6810:b22',
                                npm ERR!   port: 443,
                                npm ERR! }
                                npm ERR!
                                npm ERR! 'proxy' config is set properly.  See: 'npm help config'
                                npm ERR! A complete log of this run can be found in: /home/Holger/.npm/_logs/202            3-08-22T12_14_59_986Z-debug-0.log
                                    Finalizing installation (4/4)
                                Enabling autostart...
                                Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /            lib/systemd/system/iobroker.service.
                                Autostart enabled!
                                    ioBroker was installed successfully
                                    Open http://192.168.0.191:8081 in a browser and start configuring!
                                You need to re-login before doing anything else on the console!
                                Und nu' ... ?
                                Holger
                                D HomoranH 2 Antworten Letzte Antwort
                                • D Dooley_76
                                  @dooley_76
                                  library: loaded
                                  + apt-get update
                                  + apt-get update
                                  Installed nodejs
                                  Installed acl
                                  Installed gcc-c++
                                  Installed git
                                  Installed cmake
                                  npm ERR!   port: 443,
                                  npm ERR! }
                                  npm ERR!
                                  Autostart enabled!
                                  Und nu' ... ?
                                  Holger
                                  Dooley_76
                                  @dooley_76
                                  Hier noch die diag, falls es helfen sollte:
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Architecture    : aarch64
                                  Docker          : false
                                  Distributor ID: Debian
                                  Description:    Debian GNU/Linux 11 (bullseye)
                                  Release:        11
                                  Codename:       bullseye
                                  PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                  NAME="Debian GNU/Linux"
                                  VERSION_ID="11"
                                  ID=debian
                                  HOME_URL="https://www.debian.org/"
                                  SUPPORT_URL="https://www.debian.org/support"
                                  BUG_REPORT_URL="https://bugs.debian.org/"
                                   14:26:08 up 17 min,  1 user,  load average: 0.07, 0.20, 0.28
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=54.8'C
                                  volt=1.3813V
                                                 Local time: Tue 2023-08-22 14:26:08 CEST
                                             Universal time: Tue 2023-08-22 12:26:08 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  Holger
                                  /home/Holger
                                  Holger adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            909M         79M        223M        0.0K        606M        765M
                                  Swap:            99M          0B         99M
                                  Total:          1.0G         79M        323M
                                            909 M total memory
                                             79 M used memory
                                            125 M active memory
                                            445 M inactive memory
                                            223 M free memory
                                             39 M buffer memory
                                            567 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       29G  2.0G   26G   7% /
                                  devtmpfs       devtmpfs  325M     0  325M   0% /dev
                                  tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                                  tmpfs          tmpfs     182M  976K  181M   1% /run
                                  /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                  tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                  [Tue Aug 22 14:08:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=26b2c4cb-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Tue Aug 22 14:08:55 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Tue Aug 22 14:08:55 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [Tue Aug 22 14:08:58 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                  /var:
                                  476M    /var/
                                  180M    /var/cache
                                  174M    /var/cache/apt
                                  147M    /var/lib
                                  123M    /var/lib/apt/lists
                                  Archived and active journals take up 48.0M in the file system.
                                  du: cannot access '/opt/iobroker/backups/': No such file or directory
                                  du: cannot access '/opt/iobroker/iobroker-data/': No such file or directory
                                  find: '/opt/iobroker/iobroker-data': No such file or directory
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
                                  nodejs:
                                    Version table:
                                          500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                       12.22.12~dfsg-1~deb11u3 500
                                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                  find: '/opt/iobroker/node_modules': No such file or directory
                                  ioBroker Status
                                  node:internal/modules/cjs/loader:1080
                                    throw err;
                                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                      at Module._load (node:internal/modules/cjs/loader:922:27)
                                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                      at node:internal/main/run_main_module:23:47 {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: []
                                  Node.js v18.17.1
                                    throw err;
                                    requireStack: []
                                  Node.js v18.17.1
                                    throw err;
                                    requireStack: []
                                  Node.js v18.17.1
                                  js-controller:
                                    throw err;
                                    requireStack: []
                                  Node.js v18.17.1
                                  admin:
                                    throw err;
                                    requireStack: []
                                  Node.js v18.17.1
                                  javascript:
                                  npm ERR! code ELSPROBLEMS
                                  npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
                                  npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
                                  npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
                                  npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
                                  npm ERR! A complete log of this run can be found in: /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
                                  Adapter State
                                    throw err;
                                    requireStack: []
                                  Node.js v18.17.1
                                    throw err;
                                    requireStack: []
                                  Node.js v18.17.1
                                    throw err;
                                    requireStack: []
                                  Node.js v18.17.1
                                    throw err;
                                    requireStack: []
                                  Node.js v18.17.1
                                  Objects and States
                                  Objects:        0
                                  States:         0
                                  Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12883      474/sshd: /usr/sbin
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          12885      474/sshd: /usr/sbin
                                  udp        0      0 0.0.0.0:60377           0.0.0.0:*                           108        13975      354/avahi-daemon: r
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14343      602/dhcpcd
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13973      354/avahi-daemon: r
                                  udp6       0      0 :::546                  :::*                                0          1654       602/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        13974      354/avahi-daemon: r
                                  udp6       0      0 :::43804                :::*                                108        13976      354/avahi-daemon: r
                                  tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory
                                  • D Dooley_76
                                    @dooley_76
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:        11
                                    Codename:       bullseye
                                    VERSION_ID="11"
                                    ID=debian
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=54.8'C
                                    volt=1.3813V
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    Holger
                                    /home/Holger
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                              909 M total memory
                                               79 M used memory
                                              125 M active memory
                                              223 M free memory
                                               39 M buffer memory
                                              567 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    476M    /var/
                                    180M    /var/cache
                                    174M    /var/cache/apt
                                    147M    /var/lib
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    js-controller:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    admin:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    javascript:
                                    Adapter State
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    Objects and States
                                    Objects:        0
                                    States:         0
                                    Pending Updates: 0
                                    Dooley_76
                                    @dooley_76
                                    und hier noch das komplette Log-File:
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:        11
                                    Codename:       bullseye
                                    VERSION_ID="11"
                                    ID=debian
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=54.8'C
                                    volt=1.3813V
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    Holger
                                    /home/Holger
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                              909 M total memory
                                               79 M used memory
                                              125 M active memory
                                              223 M free memory
                                               39 M buffer memory
                                              567 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    476M    /var/
                                    180M    /var/cache
                                    174M    /var/cache/apt
                                    147M    /var/lib
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    js-controller:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    admin:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    javascript:
                                    Adapter State
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                      throw err;
                                      requireStack: []
                                    Node.js v18.17.1
                                    Objects and States
                                    Objects:        0
                                    States:         0
                                    Pending Updates: 0
                                    iob diag has finished.
                                    Press any key for a summary
                                    Holger@raspberryiobroker:~ $ cd /home/Holger/.npm/_logs
                                    Holger@raspberryiobroker:~/.npm/_logs $ dir -a
                                    .                                     2023-08-22T12_26_10_875Z-debug-0.log
                                    ..                                    2023-08-22T12_26_12_556Z-debug-0.log
                                    2023-08-22T12_11_53_157Z-debug-0.log  2023-08-22T12_26_14_191Z-debug-0.log
                                    2023-08-22T12_11_54_801Z-debug-0.log  2023-08-22T12_26_15_825Z-debug-0.log
                                    2023-08-22T12_14_59_986Z-debug-0.log  2023-08-22T12_26_18_961Z-debug-0.log
                                    Holger@raspberryiobroker:~/.npm/_logs $ mcedit 2023-08-22T12_26_18_961Z-debug-0.log
                                    -bash: mcedit: command not found
                                    Holger@raspberryiobroker:~/.npm/_logs $ ^C
                                    Holger@raspberryiobroker:~/.npm/_logs $ sudo edit 2023-08-22T12_26_18_961Z-debug-0.log
                                    0 verbose cli /usr/bin/node /usr/bin/npm
                                    1 info using npm@9.6.7
                                    2 info using node@v18.17.1
                                    3 timing npm:load:whichnode Completed in 6ms
                                    4 timing config:load:defaults Completed in 11ms
                                    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
                                    6 timing config:load:builtin Completed in 6ms
                                    7 timing config:load:cli Completed in 14ms
                                    8 timing config:load:env Completed in 3ms
                                    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 9ms
                                    10 timing config:load:project Completed in 32ms
                                    11 timing config:load:file:/home/Holger/.npmrc Completed in 2ms
                                    12 timing config:load:user Completed in 3ms
                                    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                    14 timing config:load:global Completed in 1ms
                                    15 timing config:load:setEnvs Completed in 6ms
                                    16 timing config:load Completed in 80ms
                                    17 timing npm:load:configload Completed in 81ms
                                    18 timing npm:load:mkdirpcache Completed in 2ms
                                    19 timing npm:load:mkdirplogs Completed in 1ms
                                    20 verbose title npm ls
                                    21 verbose argv "ls"
                                    22 timing npm:load:setTitle Completed in 6ms
                                    23 timing config:load:flatten Completed in 16ms
                                    24 timing npm:load:display Completed in 21ms
                                    25 verbose logfile logs-max:10 dir:/home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-
                                    26 verbose logfile /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
                                    27 timing npm:load:logFile Completed in 50ms
                                    28 timing npm:load:timers Completed in 1ms
                                    29 timing npm:load:configScope Completed in 0ms
                                    30 timing npm:load Completed in 171ms
                                    31 timing arborist:ctor Completed in 4ms
                                    32 silly logfile done cleaning log files
                                    33 timing command:ls Completed in 1010ms
                                    34 verbose stack Error: missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
                                    34 verbose stack missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
                                    34 verbose stack missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
                                    34 verbose stack missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
                                    34 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:202:9)
                                    34 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:89:5)
                                    35 verbose cwd /opt/iobroker
                                    36 verbose Linux 6.1.21-v8+
                                    37 verbose node v18.17.1
                                    38 verbose npm  v9.6.7
                                    39 error code ELSPROBLEMS
                                    40 error missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
                                    40 error missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
                                    40 error missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
                                    40 error missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
                                    41 verbose exit 1
                                    42 timing npm Completed in 1352ms
                                    43 verbose code 1
                                    44 error A complete log of this run can be found in: /home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log
                                    "/home/Holger/.npm/_logs/2023-08-22T12_26_18_961Z-debug-0.log" 53 lines, 2732 bytes
                                    • D Dooley_76
                                      @dooley_76
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        11
                                      Codename:       bullseye
                                      VERSION_ID="11"
                                      ID=debian
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=54.8'C
                                      volt=1.3813V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      Holger
                                      /home/Holger
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                                909 M total memory
                                                 79 M used memory
                                                125 M active memory
                                                223 M free memory
                                                 39 M buffer memory
                                                567 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      476M    /var/
                                      180M    /var/cache
                                      174M    /var/cache/apt
                                      147M    /var/lib
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                      js-controller:
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                      admin:
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                      javascript:
                                      Adapter State
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                        throw err;
                                        requireStack: []
                                      Node.js v18.17.1
                                      Objects and States
                                      Objects:        0
                                      States:         0
                                      Pending Updates: 0
                                      41 verbose exit 1
                                      43 verbose code 1
                                      @dooley_76
                                      Der Server lässt dich nicht, warum auch immer.
                                        @dooley_76
                                        Dooley_76
                                        Ok, Danke für die Info. Noch eine Idee, was ich hier bei mir probieren könnte oder bin ich
                                        jetzt erst einmal "lahmgelegt"?
                                        Oder doch wieder ein Image nehmen und dann nicht auf die aktuellsten Versionen gehen? Wobei
                                        das ja eigentlich genau der Grund war ...
                                        Auf jeden Fall nochmal Danke für die Mühen :)
                                        • D Dooley_76
                                          Das nutzt dir natürlich bei 'Netzwerktrouble' nix.
                                          Hast du irgendwas 'ungewöhnliches' da bei dir laufen?
                                          pihole? Sonst irgendwas in der Richtung?
