  4. Zigbee keine Verbindung zur Hardware
    5.3k
38 Beiträge 5 Kommentatoren 3.6k Aufrufe 4 Beobachtet
  • M michael_4358
    @djmarc75 said in Zigbee keine Verbindung zur Hardware:
    iob diag
    habe die abfrage mit root gemacht da der user keine Berechtigung hat..
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     19:59:46 up 10 min,  1 user,  load average: 1.00, 0.84, 0.57
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-08 19:59:46 UTC
               Universal time: Tue 2023-08-08 19:59:46 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.1G        2.1G        5.6G        0.0K        442M        6.1G
    Swap:           8.1G          0B        8.1G
    Total:           16G        2.1G         13G
             8144 M total memory
             2052 M used memory
              193 M active memory
             2095 M inactive memory
             5649 M free memory
                0 M buffer memory
              442 M swap cache
             8144 M total swap
                0 M used swap
             8144 M free swap
    *** FILESYSTEM ***
    Filesystem                         Type      Size  Used Avail Use% Mounted on
    /dev/mapper/terra-vm--200--disk--0 ext4      125G  3.4G  116G   3% /
    none                               tmpfs     492K  4.0K  488K   1% /dev
    udev                               devtmpfs   16G     0   16G   0% /dev/tty
    tmpfs                              tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                              tmpfs     6.3G  104K  6.3G   1% /run
    tmpfs                              tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                             FSTYPE OPTIONS
    /      /dev/mapper/terra-vm--200--disk--0 ext4   rw,relatime
    /var:
    420M    /var/
    251M    /var/cache
    246M    /var/cache/apt
    179M    /var/cache/apt/archives
    136M    /var/lib
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    23M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    251M    /opt/iobroker/iobroker-data/
    226M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    45M     /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.0
    /usr/bin/node           v18.17.0
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.0-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
     *** 18.17.0-deb-1nodesource1 100
         14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   3
    Adapter State
      system.adapter.accuweather.0            : accuweather           : broker                                   - disabled
      system.adapter.adguard.0                : adguard               : broker                                   - disabled
    + system.adapter.admin.0                  : admin                 : broker                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.1                 : alexa2                : broker                                   -  enabled
    + system.adapter.backitup.0               : backitup              : broker                                   -  enabled
    + system.adapter.backitup.1               : backitup              : raspberrypi                              -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : broker                                   -  enabled
      system.adapter.devices.0                : devices               : broker                                   - disabled
    + system.adapter.discovery.0              : discovery             : broker                                   -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : broker                                   -  enabled
    + system.adapter.fritzdect.1              : fritzdect             : broker                                   -  enabled
    + system.adapter.history.0                : history               : broker                                   -  enabled
    + system.adapter.hue.0                    : hue                   : broker                                   -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : broker                                   -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : broker                                   - disabled
      system.adapter.influxdb.0               : influxdb              : broker                                   - disabled, port: 8086
    + system.adapter.info.0                   : info                  : broker                                   -  enabled
    + system.adapter.iot.0                    : iot                   : broker                                   -  enabled
    + system.adapter.javascript.0             : javascript            : broker                                   -  enabled
    + system.adapter.kostal-piko-ba.0         : kostal-piko-ba        : broker                                   -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : broker                                   -  enabled
    + system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
    + system.adapter.lovelace.0               : lovelace              : broker                                   -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.modbus.0                 : modbus                : broker                                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : broker                                   -  enabled, port: 1890, bind: 0.0.0.0
    + system.adapter.panasonic-viera.0        : panasonic-viera       : broker                                   -  enabled
    + system.adapter.ping.0                   : ping                  : broker                                   -  enabled
      system.adapter.proxmox.0                : proxmox               : broker                                   - disabled, port: 8006
      system.adapter.repetierserver.0         : repetierserver        : broker                                   - disabled
    + system.adapter.sainlogic.0              : sainlogic             : broker                                   -  enabled, port: 45000, bind: 0.0.0.0
      system.adapter.sbfspot.0                : sbfspot               : broker                                   - disabled
    + system.adapter.shelly.0                 : shelly                : broker                                   -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : broker                                   - disabled
    + system.adapter.simple-api.0             : simple-api            : broker                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : broker                                   -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : broker                                   -  enabled
    + system.adapter.telegram.0               : telegram              : broker                                   -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : broker                                   -  enabled
    + system.adapter.tr-064.0                 : tr-064                : broker                                   -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : broker                                   -  enabled
    + system.adapter.upnp.0                   : upnp                  : broker                                   -  enabled
      system.adapter.vis.0                    : vis                   : broker                                   - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : broker                                   - disabled
    + system.adapter.web.0                    : web                   : broker                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : broker                                   -  enabled
    + system.adapter.yahka.0                  : yahka                 : broker                                   -  enabled
    + system.adapter.zigbee.0                 : zigbee                : broker                                   -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
    Adapter    "adguard"      : 0.0.8    , installed 0.0.8
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hue"          : 3.9.3    , installed 3.9.3
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "kostal-piko-ba": 3.0.3   , installed 3.0.1  [Updatable]
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
    Adapter    "sbfspot"      : 4.1.6    , installed 4.1.4  [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Adapter    "zigbee"       : 1.8.21   , installed 1.8.21
    Objects and States
    Objects:        14558
    States:         11472
    Hit:1 http://security.debian.org bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:42415           0.0.0.0:*               LISTEN      1000       134471     2562/io.yahka.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       123568     1500/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       123561     1500/iobroker.js-co
    tcp        0      0 0.0.0.0:45000           0.0.0.0:*               LISTEN      1000       129949     2435/io.sainlogic.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        115790     88/systemd-resolved
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          115193     310/master
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       125521     1881/io.sonoff.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       127550     1865/io.shelly.0
    tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1000       127410     1834/io.mqtt.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          114843     1/init
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        115783     88/systemd-resolved
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          115194     310/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          113629     1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          114845     1/init
    tcp6       0      0 :::5355                 :::*                    LISTEN      104        115786     88/systemd-resolved
    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       129828     2403/io.lovelace.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       123673     1525/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       133417     2530/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       130037     2451/io.simple-api.
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        115789     88/systemd-resolved
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          115112     96/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          114844     1/init
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       133552     2514/io.upnp.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       134468     2562/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       133458     2547/io.wled.0
    udp        0      0 192.168.1.222:5353      0.0.0.0:*                           1000       125734     1897/io.tr-064.0
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        115782     88/systemd-resolved
    udp        0      0 0.0.0.0:43609           0.0.0.0:*                           1000       134315     2514/io.upnp.0
    udp6       0      0 :::111                  :::*                                0          114846     1/init
    udp6       0      0 :::5355                 :::*                                104        115785     88/systemd-resolved
    2023-08-08 20:00:03.969  - info: javascript.0 (1613) script.js.PV_anlage.Autarkie.Eigenverbrauch: Eigenverbrauch
    2023-08-08 20:00:04.911  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.125 (shellyplug-s / shellyplug-s-BB43A5 / SHPLG-S#BB43A5#1): state: SHPLG-S#BB43A5#1.uptime, value: 370958
    2023-08-08 20:00:06.028  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.131 (shellyplug-s / shellyplug-s-7C87CEB4BA36 / SHPLG-S#7C87CEB4BA36#1): state: SHPLG-S#7C87CEB4BA36#1.uptime, value: 2438116
    2023-08-08 20:00:07.715  - info: ical.0 (2912) Terminated (NO_ERROR): Without reason
    2023-08-08 20:00:07.760  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.188 (shelly1pm / shelly1pm-E8DB84D234C9 / SHSW-PM#E8DB84D234C9#1): state: SHSW-PM#E8DB84D234C9#1.uptime, value: 8163485
    2023-08-08 20:00:07.760  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.188 (shelly1pm / shelly1pm-E8DB84D234C9 / SHSW-PM#E8DB84D234C9#1): state: SHSW-PM#E8DB84D234C9#1.rssi, value: -66
    2023-08-08 20:00:07.788  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.187 (shelly1 / shelly1-E8DB84A2206B / SHSW-1#E8DB84A2206B#1): state: SHSW-1#E8DB84A2206B#1.uptime, value: 8382311
    2023-08-08 20:00:07.788  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.187 (shelly1 / shelly1-E8DB84A2206B / SHSW-1#E8DB84A2206B#1): state: SHSW-1#E8DB84A2206B#1.rssi, value: -53
    2023-08-08 20:00:08.165  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.183 (shellyplug-s / shellyplug-s-BB8720 / SHPLG-S#BB8720#1): state: SHPLG-S#BB8720#1.uptime, value: 370962
    2023-08-08 20:00:08.165  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.183 (shellyplug-s / shellyplug-s-BB8720 / SHPLG-S#BB8720#1): state: SHPLG-S#BB8720#1.rssi, value: -74
    2023-08-08 20:00:08.234  - info: host.broker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-08-08 20:00:08.629  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.225 (shellyplug-s / shellyplug-s-885C36 / SHPLG-S#885C36#1): state: SHPLG-S#885C36#1.uptime, value: 7469563
    2023-08-08 20:00:08.630  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.225 (shellyplug-s / shellyplug-s-885C36 / SHPLG-S#885C36#1): state: SHPLG-S#885C36#1.rssi, value: -40
    2023-08-08 20:00:08.836  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.71 (shellyplug-s / shellyplug-s-87EB03 / SHPLG-S#87EB03#1): state: SHPLG-S#87EB03#1.uptime, value: 51253
    2023-08-08 20:00:09.987  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.125 (shellyplug-s / shellyplug-s-BB43A5 / SHPLG-S#BB43A5#1): state: SHPLG-S#BB43A5#1.uptime, value: 370963
    2023-08-08 20:00:11.121  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.131 (shellyplug-s / shellyplug-s-7C87CEB4BA36 / SHPLG-S#7C87CEB4BA36#1): state: SHPLG-S#7C87CEB4BA36#1.uptime, value: 2438121
    2023-08-08 20:00:12.305  - info: tr-064.0 (1897) forEachConfiguredDevice: in GetSpecificHostEntry 1(fritz.box/CC:CE:1E:3A:D1:64) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-08-08 20:00:12.984  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.188 (shelly1pm / shelly1pm-E8DB84D234C9 / SHSW-PM#E8DB84D234C9#1): state: SHSW-PM#E8DB84D234C9#1.uptime, value: 8163491
    2023-08-08 20:00:12.984  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.188 (shelly1pm / shelly1pm-E8DB84D234C9 / SHSW-PM#E8DB84D234C9#1): state: SHSW-PM#E8DB84D234C9#1.rssi, value: -67
    2023-08-08 20:00:13.215  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.187 (shelly1 / shelly1-E8DB84A2206B / SHSW-1#E8DB84A2206B#1): state: SHSW-1#E8DB84A2206B#1.uptime, value: 8382316
    2023-08-08 20:00:13.241  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.183 (shellyplug-s / shellyplug-s-BB8720 / SHPLG-S#BB8720#1): state: SHPLG-S#BB8720#1.uptime, value: 370967
    2023-08-08 20:00:13.242  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.183 (shellyplug-s / shellyplug-s-BB8720 / SHPLG-S#BB8720#1): state: SHPLG-S#BB8720#1.rssi, value: -75
    2023-08-08 20:00:13.703  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.225 (shellyplug-s / shellyplug-s-885C36 / SHPLG-S#885C36#1): state: SHPLG-S#885C36#1.uptime, value: 7469568
    2023-08-08 20:00:13.703  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.225 (shellyplug-s / shellyplug-s-885C36 / SHPLG-S#885C36#1): state: SHPLG-S#885C36#1.rssi, value: -41
    2023-08-08 20:00:13.968  - debug: shelly.0 (1865) [httpIoBrokerState] State change 192.168.1.71 (shellyplug-s / shellyplug-s-87EB03 / SHPLG-S#87EB03#1): state: SHPLG-S#87EB03#1.uptime, value: 51258
    iob diag has finished.
    Press any key for a summary
    @michael_4358 sagte in Zigbee keine Verbindung zur Hardware:
    Dann ist dein user falsch angelegt. Der muss in die Gruppen 'iobroker' und 'sudo' rein, dann darf der das auch.
    Was ist eigentlich an dem Satz:
    Der root wird NIE verwendet.
    so schwer zu verstehen? Die user werden mit den entsprechenden Rechten ausgestattet, hier fehlt vermutlich die Zugehörigkeit zur Gruppe 'iobroker'.
    Steht auch so in der Anleitung zur Installation von iobroker unter Proxmox drin.
    Die nodesource.list ist falsch bzw. unvollständig. Wie kommst du an die v18 ohne Repo-Eintrag? Dafür ist die v14 aber eingetragen. Verstehe ich nicht, eine frische Installation vom iobroker schleppt die eigentlich richtig an.
    M DJMarc75D 2 Antworten Letzte Antwort
      michael_4358
      Ich gebe dir recht..
      Werde das ändern…
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @thomas-braun sagte in Zigbee keine Verbindung zur Hardware:
        Ganz einfach - wenn man nicht die offizielle Anleitung nimmt un den Rest an guten Tips hier auch "umgeht" 😁 🤡
        Lehrling seit 1975 !!!
          michael_4358
          es ist doch die scheinbar richtige Version..
          oder verstehe ich das falsch❓
          • M michael_4358
            Die hängt aber statisch da drin (wo auch immer die hergezaubert wurde), weil über die entsprechende Quelle nur nodejs v14 angeboten wird. Und v14 ist abgekündigt, da kommt also nix mehr. Die /etc/apt/sources.list.d/nodesource.list auf 18 anpassen.
              michael_4358
              schrieb am zuletzt editiert von michael_4358
              @thomas-braun said in Zigbee keine Verbindung zur Hardware:
              deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bullseye main
              das is der Inhalt...
              es kann sein das der Inhalt aus dem slave ist ( mit v14)
              • M michael_4358
                @michael_4358
                Das sollte natürlich alles gleich sein.
                • M michael_4358
                  ich habe den lxc nun neu auf gesetzt und diesmal mit Debian als user
                  bekomme aber immer noch die gleiche Meldung...
                  davon war nie die Rede!
                  muss man da nicht Ports Mappen?
                  bei bullseye wirst du möglicherweise in den udev bug gelaufen sein.
                    @homoran sagte in [Zigbee keine Verbindung zur Hardware](/p ost/1027418):
                    Nope, der ist passé, gibt ein funktionierendes Update für udev über die offiziellen Update-Repos. Nur bei einem 32bit Raspberry müsste man mal schauen, ob die da die Versionierung richtig haben.
                      Meister MopperM Online
                      Meister Mopper
                      Nö, ham se nicht.
                      Bei 32bit wird noch immer
                      libudev1 247.3-7+rpi1+deb11u2
                      udev 247.3-7+rpi1+deb11u2
                      angeboten.
                      Proxmox und HA ...
                      Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                        Nö, ham se nicht.
                        angeboten.
                        @meister-mopper
                        Kannst du mal die vollständige Ausgabe posten?
