  4. Jarvis v3.1.8, Datenpunkte in Diagramm ohne history möglich?
    3.2k
    3.1k
41 Beiträge 2 Kommentatoren 4.6k Aufrufe 1 Beobachtet
  • M MCU
    @flkontakt Da kann ich leider nichts machen. Wünsche Dir auch einen erfolgreichen Start in die Woche .
    Eine Bitte habe ich noch.
    Von einem eChart hätte ich gerne die Objektdaten in Codetags. Also auf den Stift klicken und den Inhalt kopieren. Danke.
    flkontaktF Online
    flkontaktF Online
    flkontakt
    @mcu
      "common": {
        "name": "forecastfutureTotal",
        "expert": true
      "native": {
        "data": {
          "marks": [
              "color": "#e21c1c",
              "lineId": "0",
              "upperValueOrId": "250",
              "lowerValueOrId": "0",
              "text": "Grundverbrauch",
              "textPosition": "insideStartTop",
              "fill": 0.4,
              "ol": "5",
              "textSize": "15"
              "color": "#5cd810",
              "lineId": "0",
              "upperValueOrId": "1200",
              "lowerValueOrId": "250",
              "text": "",
              "ol": "5",
              "fill": 0.4,
              "textSize": "15"
          "lines": [
              "id": "0_userdata.0.pvForecastHistory.futureTotal",
              "instance": "system.adapter.history.0",
              "thickness": 4,
              "chartType": "line",
              "aggregate": "max",
              "isBoolean": false,
              "symbolSize": 3,
              "validTime": 35,
              "color": "#ebb508",
              "fill": 0.4,
              "unit": " Wh"
          "zoom": true,
          "hoverDetail": true,
          "aggregate": "minmax",
          "live": "300",
          "timeType": "static",
          "aggregateType": "step",
          "aggregateSpan": 300,
          "ticks": "",
          "range": "4320",
          "relativeEnd": "weekEurope",
          "start": "2023-07-31",
          "end": "2023-08-02",
          "start_time": "00:00",
          "end_time": "00:00",
          "noBorder": "noborder",
          "noedit": false,
          "animation": 0,
          "legend": "",
          "timeFormat": "ddd HH:mm",
          "timeFormatCustom": true,
          "aggregateBar": "60",
          "title": "PV-Gesamt",
          "titleSize": "20",
          "grid_hideX": true,
          "grid_hideY": true
      "type": "chart",
      "_id": "echarts.0.forecastfutureTotal",
      "acl": {
        "object": 1638,
        "owner": "system.user.admin",
      "from": "system.adapter.admin.1",
      "user": "system.user.admin",
      "ts": 1690783361085
    • M MCU
      @flkontakt
      https://mcuiobroker.gitbook.io/jarvis-infos/tipps/scripte-blockly-javascript/javascript/history-adapter/daswetter-futurehistory#todo
      Wo siehst du DPs vom YR?
      Der Wert soll als Future angezeigt werden?
      flkontaktF Online
      flkontaktF Online
      flkontakt
      @mcu Hallo, nochmal eine Frage: Du hast hier ein kleines Script verlinkt, Diagramm per Telegram senden. Bin leider nicht sattelfest in Sachen Java, wo müsste hier ein CRON eingetragen werden, wenn ich mir z.B. Abends um 19 Uhr ein Bild senden lassen möchte? Oder hättest du ein Blockly-Beispiel? Mit Blockly würde ich den Trigger selber einbauen können.... ;-)
      Danke!!!
      • flkontaktF flkontakt
        Danke!!!
        M Online
        M Online
        MCU
        @flkontakt Im Blockly gibt es doch die Funktionen
        Auf die 3 Punkte klicken und das kleine "Script" einfügen und anpassen.
        flkontaktF 1 Antwort Letzte Antwort
        • M MCU
          flkontaktF Online
          flkontaktF Online
          flkontakt
          @mcu wieder was gelernt................ Danke!!!!
            @mcu in der PV-Forecast-Instanz habe ich den Haken rausgenommen, mal sehen ob sich was ändern. Ist Version 1.01 schon verlinkt? Hier finde ich die Version 1.0.0 https://mcuiobroker.gitbook.io/jarvis-infos/tipps/scripte-blockly-javascript/javascript/history-adapter/pvforecast-futurehistory#javascript-setfuturehistorypvforecast
            flkontaktF Online
            flkontaktF Online
            flkontakt
            @flkontakt mal ganz vorsichtig gefragt: Geht das auch mit Grafana? Bitte nicht zu tief eingraben, wenn aktuell Nein wäre das okay.
            Gute Woche noch!
            • M Online
              M Online
              MCU
              @flkontakt Das sollte auch mit Grafana funktionieren. Die Daten sind ja in der History vorhanden. Kann da aber nicht helfen.
              • M MCU
                flkontaktF Online
                flkontaktF Online
                flkontakt
                @mcu danke für die Rückmeldung, werde mich mal einlesen, aktuell kommt die Meldung No data in Response .
                Ich bin optimistisch im Forum im Bedarfsfall Unterstützung zu finden.
                  M Online
                  M Online
                  MCU
                  @flkontakt Welchen DP gibst du denn an?
                  • M MCU
                    flkontaktF Online
                    flkontaktF Online
                    flkontakt
                    @mcu wie in echarts
                      @mcu wie in echarts
                      M Online
                      M Online
                      MCU
                      @flkontakt ok
