  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • W wm20320
    @arteck Sieht extrem gut aus! Klasse!!👏
    023-08-03 13:21:47.725 - debug: bluelink.0 (42536) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-08-03 13:21:47.764 - debug: bluelink.0 (42536) Objects client ready ... initialize now
    2023-08-03 13:21:47.765 - debug: bluelink.0 (42536) Objects create System PubSub Client
    2023-08-03 13:21:47.766 - debug: bluelink.0 (42536) Objects create User PubSub Client
    2023-08-03 13:21:47.816 - debug: bluelink.0 (42536) Objects client initialize lua scripts
    2023-08-03 13:21:47.821 - debug: bluelink.0 (42536) Objects connected to redis: 127.0.0.1:9001
    2023-08-03 13:21:47.858 - debug: bluelink.0 (42536) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-08-03 13:21:47.875 - debug: bluelink.0 (42536) States create System PubSub Client
    2023-08-03 13:21:47.876 - debug: bluelink.0 (42536) States create User PubSub Client
    2023-08-03 13:21:47.906 - debug: bluelink.0 (42536) States connected to redis: 127.0.0.1:9000
    2023-08-03 13:21:48.137 - info: bluelink.0 (42536) starting. Version 2.3.5 (non-npm: Newan/ioBroker.bluelink#master) in /opt/iobroker/node_modules/iobroker.bluelink, node: v18.17.0, js-controller: 5.0.11
    2023-08-03 13:21:48.161 - info: bluelink.0 (42536) Login to api
    2023-08-03 13:21:51.159 - info: bluelink.0 (42536) 1 Vehicles found
    2023-08-03 13:21:51.161 - debug: bluelink.0 (42536) [{"vehicleConfig":{"nickname":"i10","name":"i10","regDate":"2021-02-19 15:21:34.280","brandIndicator":"H","id":"64bd2074-1675-48a1-b845-40567dfaabdd","vin":"NLHDRXXXX","generation":"2021"},"controller":{"userConfig":{"username":"XXXX@XXXX.de","password":"XXXX","region":"EU","brand":"hyundai","autoLogin":true,"pin":"XXXX","vin":"","language":"de"},"session":{"accessToken":"Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJwaWQiOiI1YmIyYzcyMDlhOTk0MzA0MTk0MzZlYzQiLCJ1aWQiOiIxMTZjMjljZi04MTkzLTQyY2YtYWYxMi0zY2EzODYxOTZmNTciLCJzaWQiOiI2ZDQ3N2MzOC0zY2E0LTRjZjMtOTU1Ny0yYTE5MjlhOTQ2NTQiLCJleHAiOjE2OTExNDgxMTAsImlhdCI6MTY5MTA2MTcxMCwiaXNzIjoiYmx1ZWxpbmsifQ.f5kYjKGfkeXfPqfXUqHXI6c0VahnAGvKZDoa7_VthtVzaHhDvClNc39F5-WocAlzaDDS6LjWze_enrkzADjyKl_p8dNUci5dYouBXz4sLvKo_FdFUx7WDK0noE2vKKHz8Je1dgH8K8_n_CAbrVCqeNgW93Ta8hBILYlpes0fr8RiiEGaN2Hs5iIa-c4EwrJLkMAGiLcUFMLJAf_elua7hM0tuhOqYwmp0sZLn5vDgOfnWCRQO5ZBUdoBNZFutdjgh5hryGbIt8dCiUCp9wa0PYkNcKDWShNYIIz9x54cHiOKZM1pfLcM8oaPKJQVWBtYA0QbVWmnABAUBaHfq8CFPw","refreshToken":"SBCBKBVDUS6MFWNDJ9HCPW","deviceId":"c3990e26-80e2-4a1f-8c75-e8c071cd363d","tokenExpiresAt":1691148110,"controlTokenExpiresAt":0},"_environment":{"brand":"hyundai","host":"prd.eu-ccapi.hyundai.com:8080","baseUrl":"https://prd.eu-ccapi.hyundai.com:8080","clientId":"6d477c38-3ca4-4cf3-9557-2a1929a94654","appId":"1eba27d2-9a5b-4eba-8ec7-97eb6c62fb51","endpoints":{"session":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/authorize?response_type=code&state=test&client_id=6d477c38-3ca4-4cf3-9557-2a1929a94654&redirect_uri=https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/redirect","login":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin","language":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/language","redirectUri":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/redirect","token":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/oauth2/token","integration":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/integrationinfo","silentSignIn":"https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/silentsignin"},"basicToken":"Basic NmQ0NzdjMzgtM2NhNC00Y2YzLTk1NTctMmExOTI5YTk0NjU0OktVeTQ5WHhQekxwTHVvSzB4aEJDNzdXNlZYaG10UVI5aVFobUlGampvWTRJcHhzVg==","GCMSenderID":"414998006775"},"authStrategies":{"main":{"language":"de"},"fallback":{"language":"de"}}},"_fullStatus":null,"_status":null,"_location":null,"_odometer":null,"region":"EU","serverRates":{"max":-1,"current":-1}}]
    2023-08-03 13:21:51.299 - debug: bluelink.0 (42536) Read new status from api for NLHDRXXXX
    2023-08-03 13:21:51.303 - info: bluelink.0 (42536) Read new update for NLHDRXXXX directly from the car
    2023-08-03 13:22:09.287 - debug: bluelink.0 (42536) Set new full status for NLHDRXXXX
    2023-08-03 13:22:09.288 - debug: bluelink.0 (42536) RAW {"vehicleStatus":{"airCtrlOn":false,"engine":false,"doorLock":true,"doorOpen":{"frontLeft":0,"frontRight":0,"backLeft":0,"backRight":0},"trunkOpen":false,"airTemp":{"value":"00H","unit":0,"hvacTempType":1},"defrost":false,"lowFuelLight":false,"acc":false,"hoodOpen":false,"transCond":false,"steerWheelHeat":0,"sideBackWindowHeat":0,"dte":{"value":328,"unit":1},"tirePressureLamp":{"tirePressureLampAll":0},"battery":{"batSoc":88,"batState":0},"sleepModeCheck":false,"time":"20230803092205","remoteWaitingTimeAlert":{"remoteControlAvailable":1,"remoteControlWaitingTime":168,"elapsedTime":"14:42:23"},"systemCutOffAlert":0,"tailLampStatus":0,"hazardStatus":0},"odometer":{"value":23293,"unit":1}}
    2023-08-03 13:22:09.714 - debug: bluelink.0 (42536) Set 88 battery state for NLHDRXXXX
    2023-08-03 13:22:09.719 - info: bluelink.0 (42536) Update for NLHDRXXXX successfull
    arteckA Offline
    arteckA Offline
    arteck
    #1338
    @wm20320 dann machmal den debug aus..und beobachte mal
    W 1 Antwort Letzte Antwort
    • arteckA arteck
      W Offline
      W Offline
      wm20320
      schrieb am zuletzt editiert von wm20320
      #1339
      @arteck Läuft bisher ohne errors - allerdings seit dem Start vor ca. 1 h keine Aktualisierung trotz (testweise) eingestellter 300 Anfragen pro Tag.
      Ergänzung: weiterhin keine Aktualisierung (3 h) - hab neu gestartet, aber Adapter ruft nur einmal ab - durchgängig aber keoine Errors (Lebenszeichen, Verbindung Host, Verbindung Gerät/Dienst: grüner Haken)
      • W wm20320
        arteckA Offline
        arteckA Offline
        arteck
        #1340
        @wm20320
        warte bis 23 uhr dann hast du die infos.. die werden nur einmal am Tag geholt..
        • arteckA arteck
          @wm20320
          W Offline
          W Offline
          wm20320
          #1341
          @arteck Gestern um 23 Uhr ist nix passiert. Adapter läuft seit gestern 14:01 - seitdem kein log-Eintrag mehr. Timestamp in den Objekten nach wie vor auch 14:01 - ich beobachte mal weiter.
          • W wm20320
            arteckA Offline
            arteckA Offline
            arteck
            #1342
            @wm20320 dan lass mal schauen
            installier nochmal von GIT
            und such morgen im LOG nach
            DriveHistory Update for
            sollte um 23 uhr erscheinen
            ich seh gerade
            if (this.config.evHistory && this.config.motor != 'GAS') {
            für Benziner ist es nicht drin....
            kannst du ein trip verlauf in der App sehen ??
            W 2 Antworten Letzte Antwort
            • arteckA arteck
              ich seh gerade
              W Offline
              W Offline
              wm20320
              #1343
              @arteck 👍
              Du meinst in der offizielen Bluelink-App? Ja, da kann ich sowohl die Trips abrufen, als auch den Fahrzeug-Standort. -- Beim Adapter werden keine Trip-Datenpunkte angelegt und der Datenpunkt vehicleLocation liest bei lat und lon fälschlicherweise "0°" aus. (positionURL und speed bleiben leer)
              Update: "DriveHistory" find ich im LOG nicht, Datenpunkt lastInfoUpdate bleibt auch auf altem Wert, die anderen Werte sind aber trotzdem aktualisiert, scheint also zu passen 😊
              • nik82N Offline
                nik82N Offline
                nik82
                #1344
                @arteck
                Kleinigkeit ist mir gerade aufgefallen, nicht schlimm, aber vielleicht ist es ja nur eine Kleinigkeit zum "fixen".
                Wenn ich einen "Refresh from Server" mache, dann stellt es mir das Ladelimit immer auf 0 im Objekt:
                Mach ich danach einen "Refresh from Car" dann ist es wieder richtig :-)
                • arteckA arteck
                  ich seh gerade
                  W Offline
                  W Offline
                  wm20320
                  #1345
                  @arteck Hi! Ist der Fix in der 2.3.6 schon mit drin? Oder war mein Problem so speziell, dass ich bei der /tarball/master bleiben sollte?
                  Jedenfalls nochmal Danke für den Fix!
                  • W wm20320
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #1346
                    @wm20320 welcher Fix ?
                    • nik82N nik82
                      @arteck
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #1347
                      @nik82 ich lass es erstaml so.. kann sein dass der Server mal wieder spinnt.. beobachte das mal aber, bitte
                      • arteckA arteck
                        W Offline
                        W Offline
                        wm20320
                        #1348
                        @arteck Bootloop Benziner (Hyundai i10)
                        • W wm20320
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #1349
                          @wm20320 axo ja ist drin
                          • arteckA arteck
                            daNick
                            #1350
                            Neues Subthema / Auswertung der Adapter Daten
                            Ich würde gerne Daten meines Hyundai Ioniq 5 über ioBroker an influxdb geben und dann über grafana auswerten
                            (Entwicklung Batterieladung, Durchschnitsverbrauch, Laufleistung, etc, was auch immer geht :) )
                            Leider bin ich typischer Sekundär-Frickler ("Gib mir eine Vorlage, ich versuche dann was daraus zu bauen/es anzupassen").
                            Meine Frage:
                            Hat jemand schon etwas in der Richtung gebaut und kann "erste Hilfestellung zum späteren selber Weiterfliegen" geben?
                            Danke!
                            daNick
                            Meister MopperM Jackl1stJ 2 Antworten Letzte Antwort
                            • NewanN Newan
                              nachdem unter https://github.com/ioBroker/AdapterRequests/issues/403 ein Adapter Request gestellt wurde, habe ich mich der Sache einmal angenommen.
                              Ich selber besitze kein Auto von Hyundai oder Kia und ein User hat mir Zugangsdaten zur Verfügung gestellt hat. Somit müsstet ihr mehr testen ;-)
                              Pre-Alpha zum testen:
                              https://github.com/Newan/ioBroker.bluelink
                              Freue mich auf Feedback!
                              Shadow79
                              schrieb am zuletzt editiert von Shadow79
                              #1351
                              @newan Hallo, habe seit 3 Tagen auch einen Hyundai. Nutze auch IOBROKER. Bin aber ein NOOB. Ich habe den Adapter installiert und die Nutzerdate eingegeben. Eine Verbindung besteht auch. Aber mir werden unter Objekte keine Datein angezeigt. ? Bei meinen anderen Adapter bekomme ich ich daten angezeigt. WIe bei den Shellys usw. was mache ich falsch?
                              Danke im Voraus
                              NewanN 1 Antwort Letzte Antwort
                              • D daNick
                                Meine Frage:
                                Danke!
                                daNick
                                Meister MopperM Online
                                Meister Mopper
                                #1352
                                @danick sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                Das habe ich auch vor, ein Hexenwerk ist das nicht. Allerdings würde es bei den derzeit unzuverlässigen Servern von Hyundai/Kia zu großen Schwankungen bei den Daten kommen.
                                Deshalb habe ich es zunächst hintangestellt.
                                Proxmox und HA ...
                                Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                                • S Shadow79
                                  Danke im Voraus
                                  NewanN Offline
                                  NewanN Offline
                                  Newan
                                  #1353
                                  @shadow79 Das ist wie Glaskugel lesen.
                                  Ggf wird dein Auto nicht unterstützt? Welches ist es den und stell den Adapter mal auf debug, ggf steht dann da was im log
                                  • D daNick
                                    Meine Frage:
                                    Danke!
                                    daNick
                                    Jackl1stJ Offline
                                    Jackl1stJ Offline
                                    Jackl1st
                                    #1354
                                    @danick , habe ich schon. Leider sind die Daten bei mir sehr unzuverlässig. Der Adapter läuft, aber ich bekomme zB. keine GPS Daten rein. Alles andere auch nur unzuverlässig.
                                    • Jackl1stJ Jackl1st
                                      Jackl1stJ Offline
                                      Jackl1stJ Offline
                                      Jackl1st
                                      #1355
                                        Jackl1stJ Offline
                                        Jackl1stJ Offline
                                        Jackl1st
                                        schrieb am zuletzt editiert von Jackl1st
                                        #1356
                                        Vielleicht weiß jemand warum bei meinem Xceed keine GPS Daten ankommen?
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #1357
                                          @jackl1st sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                          also ich arbeite gerade dran per Handauflegen auf dein Nick und Telepatie mehr Informationen zur deinem Problem zu holen... leider klappts nicht so wirklich... liegt bestimmt am Wetter
                                          ergo... da musst du mehr liefern als nur es geht nicht...
                                          siehst du die Infos in der App... ? was ist das führ ein Auto (genau Bj.. ist es in der App eingebunden)
                                          stell den Adapter auf Debug und zeigmal was der macht.. mal manuell die Daten holen mit einer der force_buttons .. und dann das was kommt Posten
                                          Jackl1stJ 4 Antworten Letzte Antwort
