  4. RPC1 Keine Datenpunkte sichtbar / Fehlermeldung
23 Beiträge 4 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • N nousefor82
    hallo @Homoran
    • welche callback Adresse hast du eingetragen?
      die des iobrokers: 192.168.188.181
    • muss bei einem Container die Ports weitergereicht werden?
      hab die firewall komplett deaktiviert --> kein Unterschied
    • wenn ja, ist das passiert?
    • was steht im debug-log?
    2023-07-28 17:19:40.984 - info: host.iobroker stopInstance system.adapter.hm-rpc.1 (force=false, process=true)
    2023-07-28 17:19:40.985 - info: hm-rpc.1 (8804) Got terminate signal TERMINATE_YOURSELF
    2023-07-28 17:19:40.985 - info: hm-rpc.1 (8804) xmlrpc -> 192.168.188.48:2010/ init ["http://192.168.188.181:2010",""]
    2023-07-28 17:19:40.997 - info: hm-rpc.1 (8804) Disconnected
    2023-07-28 17:19:40.997 - info: hm-rpc.1 (8804) terminating
    2023-07-28 17:19:40.998 - debug: hm-rpc.1 (8804) Plugin sentry destroyed
    2023-07-28 17:19:40.998 - info: hm-rpc.1 (8804) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-28 17:19:41.026 - info: host.iobroker stopInstance system.adapter.hm-rpc.1 send kill signal
    2023-07-28 17:19:41.507 - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-28 17:19:44.539 - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 8819
    2023-07-28 17:19:44.712 - debug: hm-rpc.1 (8819) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-07-28 17:19:44.719 - debug: hm-rpc.1 (8819) Objects client ready ... initialize now
    2023-07-28 17:19:44.720 - debug: hm-rpc.1 (8819) Objects create System PubSub Client
    2023-07-28 17:19:44.720 - debug: hm-rpc.1 (8819) Objects create User PubSub Client
    2023-07-28 17:19:44.725 - debug: hm-rpc.1 (8819) Objects client initialize lua scripts
    2023-07-28 17:19:44.726 - debug: hm-rpc.1 (8819) Objects connected to redis: 127.0.0.1:9001
    2023-07-28 17:19:44.730 - debug: hm-rpc.1 (8819) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-07-28 17:19:44.732 - debug: hm-rpc.1 (8819) States create System PubSub Client
    2023-07-28 17:19:44.732 - debug: hm-rpc.1 (8819) States create User PubSub Client
    2023-07-28 17:19:44.778 - debug: hm-rpc.1 (8819) States connected to redis: 127.0.0.1:9000
    2023-07-28 17:19:44.786 - debug: hm-rpc.1 (8819) Plugin sentry Initialize Plugin (enabled=true)
    2023-07-28 17:19:44.825 - info: hm-rpc.1 (8819) starting. Version 1.15.18 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.17.0, js-controller: 4.0.24
    2023-07-28 17:19:44.847 - info: hm-rpc.1 (8819) xmlrpc server is trying to listen on 192.168.188.181:2010
    2023-07-28 17:19:44.847 - info: hm-rpc.1 (8819) xmlrpc client is trying to connect to 192.168.188.48:2010/ with ["http://192.168.188.181:2010","iobroker:hm-rpc.1:db745c7845c2066fdf831267bbe00f72"]
    2023-07-28 17:19:44.847 - debug: hm-rpc.1 (8819) Connect...
    2023-07-28 17:19:44.848 - debug: hm-rpc.1 (8819) xmlrpc -> 192.168.188.48:2010/ init ["http://192.168.188.181:2010","iobroker:hm-rpc.1:db745c7845c2066fdf831267bbe00f72"]
    2023-07-28 17:19:44.850 - debug: hm-rpc.1 (8819) start connecting interval
    2023-07-28 17:19:44.870 - info: hm-rpc.1 (8819) Connected
    2023-07-28 17:19:44.870 - debug: hm-rpc.1 (8819) clear connecting interval
    2023-07-28 17:19:44.870 - debug: hm-rpc.1 (8819) start ping interval
    2023-07-28 17:19:44.873 - info: hm-rpc.1 (8819) xmlrpc <- listDevices ["iobroker:hm-rpc.1:db745c7845c2066fdf831267bbe00f72"]
    2023-07-28 17:19:44.874 - debug: hm-rpc.1 (8819) No suitable Lua script, fallback to keys!: function(doc) {
    if (doc._id.match(/^hm-rpc\.[0-9]+\.\*?[A-Za-z0-9_-]+(\.[0-9]+)?$/)) {
    emit(doc._id, {ADDRESS:(doc.native?doc.native.ADDRESS:''),VERSION:(doc.native?doc.native.VERSION:'')});
    2023-07-28 17:19:44.883 - info: hm-rpc.1 (8819) xmlrpc -> 0 devices
    2023-07-28 17:19:45.152 - info: hm-rpc.1 (8819) xmlrpc <- newDevices 261
    2023-07-28 17:19:45.153 - debug: hm-rpc.1 (8819) No suitable Lua script, fallback to keys!: function(doc) {
    2023-07-28 17:19:45.161 - info: hm-rpc.1 (8819) new HMIP devices/channels after filter: 0
    2023-07-28 17:19:51.985 - debug: hm-rpc.1 (8819) xml multicall : iobroker:hm-rpc.1:34b738d0d80b5ca36a61b277eeae0011,0003D3C99F137B:0,CONFIG_PENDING,false
    2023-07-28 17:19:51.985 - debug: hm-rpc.1 (8819) xmlrpc <- event ["iobroker:hm-rpc.1:34b738d0d80b5ca36a61b277eeae0011","0003D3C99F137B:0","CONFIG_PENDING",false]
    2023-07-28 17:19:51.985 - debug: hm-rpc.1 (8819) xmlrpc <- event: iobroker:hm-rpc.1:34b738d0d80b5ca36a61b277eeae0011.0003D3C99F137B.0.CONFIG_PENDING:false discarded, no matching device
    2023-07-28 17:19:51.985 - debug: hm-rpc.1 (8819) xml multicall : iobroker:hm-rpc.1:34b738d0d80b5ca36a61b277eeae0011,0003D3C99F137B:0,UNREACH,false
    2023-07-28 17:19:51.985 - debug: hm-rpc.1 (8819) xmlrpc <- event ["iobroker:hm-rpc.1:34b738d0d80b5ca36a61b277eeae0011","0003D3C99F137B:0","UNREACH",false]
    2023-07-28 17:19:51.985 - debug: hm-rpc.1 (8819) xmlrpc <- event: iobroker:hm-rpc.1:34b738d0d80b5ca36a61b277eeae0011.0003D3C99F137B.0.UNREACH:false discarded, no matching device
    2023-07-28 17:19:51.985 - debug: hm-rpc.1 (8819) xml multicall : iobroker:hm-rpc.1:34b738d0d80b5ca36a61b277eeae0011,0003D3C99F137B:0,IP_ADDRESS,192.168.188.27
    2023-07-28 17:19:51.985 - debug: hm-rpc.1 (8819) xmlrpc <- event ["iobroker:hm-rpc.1:34b738d0d80b5ca36a61b277eeae0011","0003D3C99F137B:0","IP_ADDRESS","192.168.188.27"]
    2023-07-28 17:19:51.985 - debug: hm-rpc.1 (8819) xmlrpc <- event: iobroker:hm-rpc.1:34b738d0d80b5ca36a61b277eeae0011.0003D3C99F137B.0.IP_ADDRESS:192.168.188.27 discarded, no matching device
    2023-07-28 17:19:51.988 - debug: hm-rpc.1 (8819) xml multicall : iobroker:hm-rpc.1:ef66a9d77cd30fb73a1cc316c5b76165,0003D3C99F137B:0,CONFIG_PENDING,false
    2023-07-28 17:19:51.988 - debug: hm-rpc.1 (8819) xmlrpc <- event ["iobroker:hm-rpc.1:ef66a9d77cd30fb73a1cc316c5b76165","0003D3C99F137B:0","CONFIG_PENDING",false]
    2023-07-28 17:19:51.988 - debug: hm-rpc.1 (8819) xmlrpc <- event: iobroker:hm-rpc.1:ef66a9d77cd30fb73a1cc316c5b76165.0003D3C99F137B.0.CONFIG_PENDING:false discarded, no matching device
    2023-07-28 17:19:51.988 - debug: hm-rpc.1 (8819) xml multicall : iobroker:hm-rpc.1:ef66a9d77cd30fb73a1cc316c5b76165,0003D3C99F137B:0,UNREACH,false
    Jörg
    @nousefor82 sagte in RPC1 Keine Datenpunkte sichtbar / Fehlermeldung:
    ist das IPv6?
    N 2 Antworten Letzte Antwort
      ist das IPv6?
      N Offline
      N Offline
      nousefor82
      schrieb am zuletzt editiert von nousefor82
      @homoran :-)
      Ja genau, rpc1 sind hier die HMIP-Geräte auf der CCU.
      hm-rpc.1
      	2023-07-29 16:40:35.690	error	Cannot call init: [http://192.168.188.183:2010, ""] Unexpected endLine: 0Column: 0Char:
      hm-rpc.1
      	2023-07-29 16:40:05.675	error	Init not possible, going to stop: Unexpected endLine: 0Column: 0Char:
      hm-rpc.1
      	2023-07-29 16:39:35.664	error	Ping error [iobrokervm:hm-rpc.1:f2c5482f2897fc4cafed20fa0bacfed9]: Unexpected endLine: 0Column: 0Char:
      hm-rpc.1
      	2023-07-29 16:38:04.031	error	Ping error [iobrokervm:hm-rpc.1:f2c5482f2897fc4cafed20fa0bacfed9]: Unexpected endLine: 0Column: 0Char:
      • N nousefor82
        @homoran :-)
        hm-rpc.1
        hm-rpc.1
        hm-rpc.1
        hm-rpc.1
        Unexpected endLine
        das sieht nach dem Sentry-Bug aus
        N 1 Antwort Letzte Antwort
          ist das IPv6?
          N Offline
          N Offline
          nousefor82
          @homoran sagte in RPC1 Keine Datenpunkte sichtbar / Fehlermeldung:
          ist das IPv6?
          Gute Frage; habe kein IPv6-Netzwerk aktiv
            Unexpected endLine
            N Offline
            N Offline
            nousefor82
            Sentry ist für rpc1 deaktiviert:
            • N nousefor82
              sigi234S Online
              sigi234S Online
              Bei Allen HM deaktivieren
              • sigi234S sigi234
                N Offline
                N Offline
                nousefor82
                @sigi234
                Servus Sigi,
                erldeigt. Leider keine Änderung.
                Das sagt das Protokoll:
                hm-rpc.1
                	2023-07-29 17:37:54.514	debug	xmlrpc <- event: hm-rpc.1.0003D3C99F137B.0.IP_ADDRESS:192.168.188.27 discarded, no matching device
                hm-rpc.1
                	2023-07-29 17:37:54.514	debug	xmlrpc <- event ["iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228","0003D3C99F137B:0","IP_ADDRESS","192.168.188.27"]
                hm-rpc.1
                	2023-07-29 17:37:54.514	debug	xml multicall <event>: iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228,0003D3C99F137B:0,IP_ADDRESS,192.168.188.27
                hm-rpc.1
                	2023-07-29 17:37:54.514	debug	xmlrpc <- event: hm-rpc.1.0003D3C99F137B.0.UNREACH:false discarded, no matching device
                hm-rpc.1
                	2023-07-29 17:37:54.514	debug	xmlrpc <- event ["iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228","0003D3C99F137B:0","UNREACH",false]
                hm-rpc.1
                	2023-07-29 17:37:54.514	debug	xml multicall <event>: iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228,0003D3C99F137B:0,UNREACH,false
                hm-rpc.1
                	2023-07-29 17:37:54.514	debug	xmlrpc <- event: hm-rpc.1.0003D3C99F137B.0.CONFIG_PENDING:false discarded, no matching device
                hm-rpc.1
                	2023-07-29 17:37:54.514	debug	xmlrpc <- event ["iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228","0003D3C99F137B:0","CONFIG_PENDING",false]
                hm-rpc.1
                	2023-07-29 17:37:54.514	debug	xml multicall <event>: iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228,0003D3C99F137B:0,CONFIG_PENDING,false
                hm-rpc.1
                	2023-07-29 17:37:53.914	debug	xmlrpc <- event: hm-rpc.1.CENTRAL.0.PONG:iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228 discarded, no matching device
                hm-rpc.1
                	2023-07-29 17:37:53.914	debug	xmlrpc <- event ["iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228","CENTRAL:0","PONG","iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228"]
                hm-rpc.1
                	2023-07-29 17:37:53.899	debug	PING ok
                hm-rpc.1
                	2023-07-29 17:37:53.883	debug	Send PING...
                hm-rpc.1
                	2023-07-29 17:37:53.883	debug	[KEEPALIVE] Check if connection is alive
                hm-rpc.1
                	2023-07-29 17:37:50.354	debug	xmlrpc <- event: hm-rpc.1.0003D3C99F137B.0.IP_ADDRESS:192.168.188.27 discarded, no matching device
                hm-rpc.1
                	2023-07-29 17:37:50.353	debug	xmlrpc <- event ["iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228","0003D3C99F137B:0","IP_ADDRESS","192.168.188.27"]
                hm-rpc.1
                	2023-07-29 17:37:50.353	debug	xml multicall <event>: iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228,0003D3C99F137B:0,IP_ADDRESS,192.168.188.27
                hm-rpc.1
                	2023-07-29 17:37:50.353	debug	xmlrpc <- event: hm-rpc.1.0003D3C99F137B.0.UNREACH:false discarded, no matching device
                hm-rpc.1
                	2023-07-29 17:37:50.353	debug	xmlrpc <- event ["iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228","0003D3C99F137B:0","UNREACH",false]
                hm-rpc.1
                	2023-07-29 17:37:50.353	debug	xml multicall <event>: iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228,0003D3C99F137B:0,UNREACH,false
                hm-rpc.1
                	2023-07-29 17:37:50.353	debug	xmlrpc <- event: hm-rpc.1.0003D3C99F137B.0.CONFIG_PENDING:false discarded, no matching device
                hm-rpc.1
                	2023-07-29 17:37:50.353	debug	xmlrpc <- event ["iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228","0003D3C99F137B:0","CONFIG_PENDING",false]
                hm-rpc.1
                	2023-07-29 17:37:50.353	debug	xml multicall <event>: iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228,0003D3C99F137B:0,CONFIG_PENDING,false
                hm-rpc.1
                	2023-07-29 17:37:37.841	debug	xmlrpc <- event: hm-rpc.1.CENTRAL.0.PONG:DESKTOP-2JN8QCP(SmartHome):hm-rpc.1:7b6f96b42868af78a541ce0c33625918 discarded, no matching device
                hm-rpc.1
                	2023-07-29 17:37:37.841	debug	xmlrpc <- event ["iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228","CENTRAL:0","PONG","DESKTOP-2JN8QCP(SmartHome):hm-rpc.1:7b6f96b42868af78a541ce0c33625918"]
                hm-rpc.1
                	2023-07-29 17:37:28.310	debug	xmlrpc <- event: hm-rpc.1.0003D3C99F137B.0.IP_ADDRESS:192.168.188.27 discarded, no matching device
                hm-rpc.1
                	2023-07-29 17:37:28.310	debug	xmlrpc <- event ["iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228","0003D3C99F137B:0","IP_ADDRESS","192.168.188.27"]
                hm-rpc.1
                	2023-07-29 17:37:28.309	debug	xml multicall <event>: iobroker:hm-rpc.1:dd6c26cad561a448e58bb60c0bd85228,0003D3C99F137B:0,IP_ADDRESS,192.168.188.27
                hm-rpc.1
                	2023-07-29 17:37:28.309	debug	xmlrpc <- event: hm-rpc.1.0003D3C99F137B.0.UNREACH:false discarded, no matching device
                Hmm...das ist mein Produktiv-System: (Win10: 192.168.188.120)
                [DESKTOP-2JN8QCP(SmartHome)]]
                GlasfaserG HomoranH 3 Antworten Letzte Antwort
                • N nousefor82
                  @sigi234
                  Servus Sigi,
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  GlasfaserG Offline
                  GlasfaserG Offline
                  192.168.188.27
                  ich habe nicht alles hier gelesen , aber warum ändert sich immer die IP bei dir !?
                  • GlasfaserG Glasfaser
                    192.168.188.27
                    N Offline
                    N Offline
                    nousefor82
                    @glasfaser
                    Servus,
                    ich dachte zuerste es liegt evtl. an der LXC-Umgebung: 192.168.188.181.
                    Daraufhin habe ich eine VM angelegt und ioBroker dort installiert: 192.168.188.183.
                    Bei beiden kommt der Fehler mit den fehlenden states.
                    Bei meiner Produktiv - Umgebung (Win10) mit 192.168.188.120 kommt der Fehler nicht.
                    EDIT: Die 192.168.188.27 ist ein DLAN-Adapter; da hängt die CCU seit 4 Jahren dran... hmmm
                    • N nousefor82
                      @glasfaser
                      Servus,
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @nousefor82
                      das habe ich auch so quer gelesen , erst Container dann VM .....
                      Aber was ist das für eine IP , da sie ja abgefragt wird !?
                        @nousefor82
                        N Offline
                        N Offline
                        nousefor82
                        @glasfaser
                        • N nousefor82
                          @sigi234
                          Servus Sigi,
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          hm-rpc.1
                          GlasfaserG Offline
                          GlasfaserG Offline
                          So mal zum mitschreiben ..
                          Wer greift noch auf die CCU zu , alle Client´s dazu ausgeschaltet.
                          Starte mal die CCU neu !
                            N Offline
                            N Offline
                            nousefor82
                            @glasfaser
                            • iobroker Produktiv: 192.168.188.120
                            • iobroker LXC: 192.168.188.181
                            Die 192.168.188.27 ist der DLan-Adapter mangels Netzwerk-Dose.
                            So Männer,
                            ich habe jetzt nochmal die Adapter komplett rausgeschmissen und neu installiert und auch die CCU neu gestartet:
                            Jetzt ist alles da. Warum auch immer. sentry ist noch aktiviert.
                            Der Eintrag mit dem Dlan_adapter kommt im dbug immer noch.
                            Danke wie immer für eure Geduld.
                            • N nousefor82
                              @sigi234
                              Servus Sigi,
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              hm-rpc.1
                              doch!
                              kein Unexpected end mehr
