  4. Bambu lab 3d Drucker MQTT Integration
    apollon77A
121 Beiträge 9 Kommentatoren 42.6k Aufrufe 9 Beobachtet
  • D
    D
    djalexz
    schrieb am zuletzt editiert von djalexz
    #112
    ich hab nochmal bisschen was gebastelt.
    Hiermit könnt ihr den Drucker steuern.
    Verwendung auf eigene Gefahr
    Die MQTT Node muss entsprechend angepasst werden.
            "id": "e4deb3c0f6038918",
            "type": "function",
            "z": "9582121ff81174a6",
            "name": "Druck stoppen",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"sequence_id\": \"1\",\n        \"command\": \"stop\"\n    },\n    \"user_id\": \"1234567890\"\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 460,
            "y": 1000,
            "wires": [
                    "896709af54cf95f3"
            "id": "d719c311cd5fe8ec",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "payloadType": "bool",
            "x": 210,
            "y": 1000,
            "wires": [
                    "e4deb3c0f6038918"
            "id": "da8e98a7bcfc4791",
            "type": "mqtt out",
            "name": "bambu-mqtt-out x1c",
            "topic": "device/Deine-Seriennummer/request",
            "qos": "1",
            "retain": "false",
            "respTopic": "",
            "contentType": "",
            "userProps": "",
            "correl": "",
            "expiry": "",
            "broker": "84f61d394ba2ab34",
            "x": 360,
            "y": 1520,
            "wires": []
            "id": "c23cf05567e62a0d",
            "type": "function",
            "name": "Druck pausieren",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"sequence_id\": \"1\",\n        \"command\": \"pause\"\n    },\n    \"user_id\": \"1234567890\"\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 460,
            "y": 1080,
            "wires": [
                    "896709af54cf95f3"
            "id": "698ef4715c618988",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 210,
            "y": 1080,
            "wires": [
                    "c23cf05567e62a0d"
            "id": "da3ebb8e9395ace1",
            "type": "function",
            "name": "Kammerlicht einschalten",
            "func": "var P1P_Push = {\n    \"system\": {\n        \"sequence_id\": \"0\",\n        \"command\": \"ledctrl\",\n        \"led_node\": \"chamber_light\",\n        \"led_mode\": \"on\",\n        \"led_on_time\": 500,\n        \"led_off_time\": 500,\n        \"loop_times\": 0,\n        \"interval_time\": 0\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 1150,
            "y": 1000,
            "wires": [
                    "1bde76ee31c86b7b"
            "id": "9d65a19652402ab5",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 870,
            "y": 1000,
            "wires": [
                    "da3ebb8e9395ace1"
            "id": "1f169dd6fc7f6387",
            "type": "function",
            "name": "Kammerlicht ausschalten",
            "func": "var P1P_Push = \n{\"system\": { \"sequence_id\": \"0\",\n    \"command\": \"ledctrl\",\n    \"led_node\": \"chamber_light\",\n    \"led_mode\": \"off\",\n    \"led_on_time\": 500,\n    \"led_off_time\": 500,\n    \"loop_times\": 0,\n    \"interval_time\": 0\n    }  }\n\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 1150,
            "y": 1060,
            "wires": [
                    "1bde76ee31c86b7b"
            "id": "02dfb1cf089be4e9",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 870,
            "y": 1060,
            "wires": [
                    "1f169dd6fc7f6387"
            "id": "6b016ea02facbdd4",
            "type": "function",
            "name": "Druck fortsetzen",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"sequence_id\": \"1\",\n        \"command\": \"resume\"\n    },\n    \"user_id\": \"1234567890\"\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 460,
            "y": 1040,
            "wires": [
                    "896709af54cf95f3"
            "id": "b1cee73a8525cbd6",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 210,
            "y": 1040,
            "wires": [
                    "6b016ea02facbdd4"
            "id": "4644dad9484e5ebd",
            "type": "function",
            "name": "Geschwindigkeitsmodus",
            "func": "var P1P_Push = { \"print\": \n{ \"sequence_id\": \"0\",\n \"command\": \"print_speed\",\n  \"param\": msg.payload } }\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 490,
            "y": 1200,
            "wires": [
                    "896709af54cf95f3"
            "id": "6f7b98709d756f1f",
            "type": "inject",
            "name": "Leise",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "1",
            "payloadType": "str",
            "x": 210,
            "y": 1140,
            "wires": [
                    "4644dad9484e5ebd"
            "id": "5f530bccf798a5a0",
            "type": "function",
            "name": "Homing",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"G28 \\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20086\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 440,
            "y": 1340,
            "wires": [
                    "896709af54cf95f3"
            "id": "170ca7b1e2747db8",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 210,
            "y": 1340,
            "wires": [
                    "5f530bccf798a5a0"
            "id": "70adf86313f86654",
            "type": "function",
            "name": "x10 (Druckkopf nach rechts)",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 X10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 1160,
            "y": 1160,
            "wires": [
                    "f0a3aa20cb7b1ec7"
            "id": "015cd820c30ac3c1",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 870,
            "y": 1160,
            "wires": [
                    "70adf86313f86654"
            "id": "3c2d33e74b34ba3a",
            "type": "function",
            "name": "x-10 (Druckkopf nach links)",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 X-10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 1160,
            "y": 1220,
            "wires": [
                    "f0a3aa20cb7b1ec7"
            "id": "0741e0b4170ed242",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 870,
            "y": 1220,
            "wires": [
                    "3c2d33e74b34ba3a"
            "id": "4896f4921f935873",
            "type": "function",
            "name": "y10 (Druckkopf nach hinten)",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 Y10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 1160,
            "y": 1320,
            "wires": [
                    "f0a3aa20cb7b1ec7"
            "id": "e0894718eaf714d6",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 870,
            "y": 1320,
            "wires": [
                    "4896f4921f935873"
            "id": "8d19b57b1b50a939",
            "type": "function",
            "name": "y-10 (Druckkopf nach vorne)",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 Y-10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 1160,
            "y": 1380,
            "wires": [
                    "f0a3aa20cb7b1ec7"
            "id": "ec7ef6667698c77b",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 870,
            "y": 1380,
            "wires": [
                    "8d19b57b1b50a939"
            "id": "5666441b74594399",
            "type": "function",
            "name": "z10 (Druckbett nach unten)",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 Z10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 1160,
            "y": 1480,
            "wires": [
                    "f0a3aa20cb7b1ec7"
            "id": "19077e4a51bf2443",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 870,
            "y": 1480,
            "wires": [
                    "5666441b74594399"
            "id": "2e3395031ac16968",
            "type": "function",
            "name": "z-10 z10 (Druckbett nach oben)",
            "func": "var P1P_Push = {\n    \"print\": {\n        \"command\": \"gcode_line\",\n        \"param\": \"M211 S \\nM211 X1 Y1 Z1\\nM1002 push_ref_mode\\nG91 \\nG1 Z-10,0 F3000\\nM1002 pop_ref_mode\\nM211 R\\n\",\n        \"reason\": \"SUCCESS\",\n        \"result\": \"SUCCESS\",\n        \"sequence_id\": \"20014\",\n        \"user_id\": \"1767420324\"\n    }\n}\n\nmsg.payload=P1P_Push;\n\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 1170,
            "y": 1540,
            "wires": [
                    "f0a3aa20cb7b1ec7"
            "id": "68696ed4c9c24eef",
            "type": "inject",
            "name": "True",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "true",
            "x": 870,
            "y": 1540,
            "wires": [
                    "2e3395031ac16968"
            "id": "22d040578162e373",
            "type": "inject",
            "name": "Standard",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "2",
            "x": 220,
            "y": 1180,
            "wires": [
                    "4644dad9484e5ebd"
            "id": "6143cca7c358a854",
            "type": "inject",
            "name": "Sport",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "3",
            "x": 210,
            "y": 1220,
            "wires": [
                    "4644dad9484e5ebd"
            "id": "e8e4bbd46511a0ea",
            "type": "inject",
            "name": "Verrückt",
            "props": [
                    "p": "payload"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "4",
            "x": 220,
            "y": 1260,
            "wires": [
                    "4644dad9484e5ebd"
            "id": "896709af54cf95f3",
            "type": "link out",
            "name": "link out 1",
            "mode": "link",
            "links": [
                "d7996921de135b61"
            "x": 685,
            "y": 1100,
            "wires": []
            "id": "f0a3aa20cb7b1ec7",
            "type": "link out",
            "name": "link out 2",
            "mode": "link",
            "links": [
                "d7996921de135b61"
            "x": 1365,
            "y": 1380,
            "wires": []
            "id": "d7996921de135b61",
            "type": "link in",
            "name": "link in 1",
            "links": [
                "f0a3aa20cb7b1ec7",
                "896709af54cf95f3",
                "1bde76ee31c86b7b",
                "d1dbc9388bfe6774"
            "x": 175,
            "y": 1520,
            "wires": [
                    "da8e98a7bcfc4791"
            "id": "1bde76ee31c86b7b",
            "type": "link out",
            "name": "link out 3",
            "mode": "link",
            "links": [
                "d7996921de135b61"
            "x": 1335,
            "y": 1080,
            "wires": []
            "id": "84f61d394ba2ab34",
            "type": "mqtt-broker",
            "name": "Bambu X1C MQTT Bambu_X1C",
            "broker": "IP-Deines-Druckers",
            "port": "8883",
            "tls": "",
            "clientid": "",
            "autoConnect": true,
            "usetls": true,
            "protocolVersion": "4",
            "keepalive": "60",
            "cleansession": true,
            "birthTopic": "",
            "birthQos": "0",
            "birthPayload": "",
            "birthMsg": {},
            "closeTopic": "",
            "closeQos": "0",
            "closePayload": "",
            "closeMsg": {},
            "willTopic": "",
            "willQos": "0",
            "willPayload": "",
            "willMsg": {},
            "userProps": "",
            "sessionExpiry": ""
    Das ist natürlich nur ein Beispiel-Flow wie es gehen kann.
    Es geht ja hauptsächlich um die Befehle.
    Damit könnt ihr dann weiterbasteln :-)
    LG Alex
    • D dadonali
      Mal eine Frage zu diesem Github Eintrag:
      https://github.com/greghesp/ha-bambulab
      Hat sich hier schon mal mit dem Thema Buttons beschäftigt? Wenn ich das richtig verstehe sollten zumindest Start, Pause und Cancel realisierbar sein? Das wäre natürlich nice wenn man zumindest den Druck übers VIS im iobroker abbrechen könnte ohne immer das scheiß Bambu Studio öffnen zu müssen.
      Allerdings finde ich nicht wirklich was in meinen Datenpunkten, welche mir NodeRed auswirft.
      D
      D
      djalexz
      #113
      @dadonali
      Sollte was für dich sein :-)
      • D djalexz
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 460,
                "y": 1000,
                "wires": [
                        "896709af54cf95f3"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 210,
                "y": 1000,
                "wires": [
                        "e4deb3c0f6038918"
                "type": "mqtt out",
                "qos": "1",
                "retain": "false",
                "respTopic": "",
                "contentType": "",
                "userProps": "",
                "correl": "",
                "expiry": "",
                "x": 360,
                "y": 1520,
                "wires": []
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 460,
                "y": 1080,
                "wires": [
                        "896709af54cf95f3"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 210,
                "y": 1080,
                "wires": [
                        "c23cf05567e62a0d"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1150,
                "y": 1000,
                "wires": [
                        "1bde76ee31c86b7b"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 870,
                "y": 1000,
                "wires": [
                        "da3ebb8e9395ace1"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1150,
                "y": 1060,
                "wires": [
                        "1bde76ee31c86b7b"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 870,
                "y": 1060,
                "wires": [
                        "1f169dd6fc7f6387"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 460,
                "y": 1040,
                "wires": [
                        "896709af54cf95f3"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 210,
                "y": 1040,
                "wires": [
                        "6b016ea02facbdd4"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 490,
                "y": 1200,
                "wires": [
                        "896709af54cf95f3"
                "type": "inject",
                "name": "Leise",
                "props": [
                        "p": "payload"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "1",
                "x": 210,
                "y": 1140,
                "wires": [
                        "4644dad9484e5ebd"
                "type": "function",
                "name": "Homing",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 440,
                "y": 1340,
                "wires": [
                        "896709af54cf95f3"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 210,
                "y": 1340,
                "wires": [
                        "5f530bccf798a5a0"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1160,
                "y": 1160,
                "wires": [
                        "f0a3aa20cb7b1ec7"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 870,
                "y": 1160,
                "wires": [
                        "70adf86313f86654"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1160,
                "y": 1220,
                "wires": [
                        "f0a3aa20cb7b1ec7"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 870,
                "y": 1220,
                "wires": [
                        "3c2d33e74b34ba3a"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1160,
                "y": 1320,
                "wires": [
                        "f0a3aa20cb7b1ec7"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 870,
                "y": 1320,
                "wires": [
                        "4896f4921f935873"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1160,
                "y": 1380,
                "wires": [
                        "f0a3aa20cb7b1ec7"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 870,
                "y": 1380,
                "wires": [
                        "8d19b57b1b50a939"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1160,
                "y": 1480,
                "wires": [
                        "f0a3aa20cb7b1ec7"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 870,
                "y": 1480,
                "wires": [
                        "5666441b74594399"
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 1170,
                "y": 1540,
                "wires": [
                        "f0a3aa20cb7b1ec7"
                "type": "inject",
                "name": "True",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "true",
                "x": 870,
                "y": 1540,
                "wires": [
                        "2e3395031ac16968"
                "type": "inject",
                "name": "Standard",
                "props": [
                        "p": "payload"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "2",
                "x": 220,
                "y": 1180,
                "wires": [
                        "4644dad9484e5ebd"
                "type": "inject",
                "name": "Sport",
                "props": [
                        "p": "payload"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "3",
                "x": 210,
                "y": 1220,
                "wires": [
                        "4644dad9484e5ebd"
                "type": "inject",
                "name": "Verrückt",
                "props": [
                        "p": "payload"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "4",
                "x": 220,
                "y": 1260,
                "wires": [
                        "4644dad9484e5ebd"
                "type": "link out",
                "mode": "link",
                "links": [
                    "d7996921de135b61"
                "x": 685,
                "y": 1100,
                "wires": []
                "type": "link out",
                "mode": "link",
                "links": [
                    "d7996921de135b61"
                "x": 1365,
                "y": 1380,
                "wires": []
                "type": "link in",
                "links": [
                    "f0a3aa20cb7b1ec7",
                    "896709af54cf95f3",
                    "1bde76ee31c86b7b",
                    "d1dbc9388bfe6774"
                "x": 175,
                "y": 1520,
                "wires": [
                        "da8e98a7bcfc4791"
                "type": "link out",
                "mode": "link",
                "links": [
                    "d7996921de135b61"
                "x": 1335,
                "y": 1080,
                "wires": []
                "port": "8883",
                "tls": "",
                "clientid": "",
                "usetls": true,
                "keepalive": "60",
                "birthTopic": "",
                "birthQos": "0",
                "birthPayload": "",
                "birthMsg": {},
                "closeTopic": "",
                "closeQos": "0",
                "closePayload": "",
                "closeMsg": {},
                "willTopic": "",
                "willQos": "0",
                "willPayload": "",
                "willMsg": {},
                "userProps": "",
                "sessionExpiry": ""
        LG Alex
        D
        D
        dadonali
        #114
        @djalexz
        Kann ich den flow von dir dann einfach hinzufügen?
        • X
          X
          XSDiver
          schrieb am zuletzt editiert von XSDiver
          #115
          geht auch alles über den MQTT Adapter ohne Node Red,
          der liest euch eine JSON aus dem Drucker aus und legt die unter MQTT in einem Datenpunkt ab:
          sieht dann ungefähr so aus:
              "print": {
                  "ams": {
                      "ams": [
                              "humidity": "4",
                              "id": "0",
                              "temp": "30.9",
                              "tray": [
                                      "bed_temp": "0",
                                      "bed_temp_type": "2",
                                      "cols": [
                                          "FFC600FF"
                                      "drying_temp": "55",
                                      "drying_time": "8",
                                      "id": "0",
                                      "nozzle_temp_max": "240",
                                      "nozzle_temp_min": "200",
                                      "remain": 0,
                                      "tag_uid": "DDDE769400000100",
                                      "tray_color": "FFC600FF",
                                      "tray_diameter": "1.75",
                                      "tray_id_name": "A05-Y4",
                                      "tray_info_idx": "GFA05",
                                      "tray_sub_brands": "PLA Silk",
                                      "tray_type": "PLA",
                                      "tray_uuid": "325DA7506BCE447B9F34D1CDC94658DA",
                                      "tray_weight": "1000",
                                      "xcam_info": "A438803EE803E8033333333F"
                                  }, //... weiter AMS Slots
                      "ams_exist_bits": "1",
                      "insert_flag": true,
                      "power_on_flag": false,
                      "tray_exist_bits": "f",
                      "tray_is_bbl_bits": "f",
                      "tray_now": "255",
                      "tray_pre": "255",
                      "tray_read_done_bits": "f",
                      "tray_reading_bits": "0",
                      "tray_tar": "255",
                      "version": 5
                  "ams_rfid_status": 0,
                  "ams_status": 0,
                  "aux_part_fan": true,
                  "bed_target_temper": 0.0,
                  "bed_temper": 37.0,
                  "big_fan1_speed": "0",
                  "big_fan2_speed": "0",
                  "chamber_temper": 35.0,
                  "command": "push_status",
                  "cooling_fan_speed": "0",
                  "fail_reason": "0",
                  "fan_gear": 0,
                  "filam_bak": [],
                  "force_upgrade": false,
                  "gcode_file": "Name des DruckFiles",
                  "gcode_file_prepare_percent": "100",
                  "gcode_start_time": "1687977739",
                  "gcode_state": "FINISH",
                  "heatbreak_fan_speed": "0",
                  "hms": [],
                  "home_flag": 16648,
                  "hw_switch_state": 0,
                  "ipcam": {
                      "ipcam_dev": "1",
                      "ipcam_record": "enable",
                      "resolution": "1080p",
                      "timelapse": "disable"
                  "layer_num": 360,
                  "lifecycle": "product",
                  "lights_report": [
                          "mode": "on",
                          "node": "chamber_light"
                          "mode": "flashing",
                          "node": "work_light"
                  "maintain": 3,
                  "mc_percent": 100,
                  "mc_print_error_code": "0",
                  "mc_print_stage": "1",
                  "mc_print_sub_stage": 0,
                  "mc_remaining_time": 0,
                  "mess_production_state": "active",
                  "nozzle_diameter": "0.4",
                  "nozzle_target_temper": 0.0,
                  "nozzle_temper": 39.0,
                  "online": {
                      "ahb": false,
                      "rfid": false,
                      "version": 9
                  "print_error": 0,
                  "print_gcode_action": 255,
          Ich hab mir dann die Datenpunkte die ich gebrauchen kann manuell angelegt:
          und dann mit einem Blockly ausgelesen und in den Datenpunkt geschrieben.
          • z. B. Nozzle - Temp:
          setState("0_userdata.0.X1C.Temp_Nozzle"/*Temp_Nozzle*/, parseFloat((await jsonataExpression((function () { try {return JSON.parse(getState("mqtt.0.device.00M09A340700121.report").val);} catch(e) {return {};}})(),'print.nozzle_temper'))), true);
          Hier ein noch angefangenes VIS Beispiel:
          Mit Bindings lassen sich auch die Farben im AMS auslesen,
          die einzelnen Lüfter Geschwindigkeiten und einiges mehr...
          Vielleicht interessiert das ja jemanden.
          Wenn man sich z.B. im MQTT Adapter einen Datenpunkt: "Request" anlegt:
          kann man auch Befehle schicken:
            "print": {
              "command": "gcode_line",
              "param": "M960 S5 P1",
              "sequence_id": "0"
          mit diesem gCode schaltet man das ToolHead Logo ein. Funktioniert auch wärend des Drucks.
          • D dadonali
            @djalexz
            D
            D
            djalexz
            #116
            @dadonali
            Moin, ja sollte gehen.
            • B baeri
              danke für die tolle Anleitung von @djalexz !!
              Damit hab ich es sogar geschafft, als absoluter NodeRed DAU den X1C-Status in den ioBroker zu bekommen.
              Ein "Problem" habe ich noch. Der Drucker wird bei mir immer als offline angezeigt. Hat jemand eine Idee, woran das liegen könnte?
              Ich habe auch mal einen Adapter-Request gemacht, vielleicht findet sich ja jemand, der das ganze in einen Adapter adaptieren kann (schöner Satz :D ) - vielleicht hilft ja ein Like von dem ein oder anderen, dass sich jemand findet: https://github.com/ioBroker/AdapterRequests/issues/829
              DutchmanD
              DutchmanD
              Dutchman
              schrieb am zuletzt editiert von Dutchman
              #117
              @baeri sagte in Bambu lab 3d Drucker MQTT Integration:
              Habe es nun als DAU tatsächlich mit der NodeRed Instanz hinbekommen.
              Ein Adapter wäre natürlich schöner, vielleicht findet sich ja jemand, der Anhand dieses NodeRed Ablaufs einen Adapter bauen kann?
              Da ich auch einen Bambulab X1 habe konnte ich das hier nicht liegen lassen, mit dank an den Informationen hier im forum habe ich einen adapter erstellt der alle Daten per MQTT Verbindung live bekommt. Man muss nur in den Einstellungen die IP Adresse, token und serial hinterlegen
              Schalten werden ich im laufe des tages/morgen implementieren, soweit mir bekannt kann man aber nur start/stop/resume und die Lampe schalten
              Wen jemand die anderen MQTT befehle zum steuern kennt gerne her damit dan ergänze ich das.
              Der adapter ist in einem beta status, die erste version kann über git und NPM installiert werden.
              Wen alles einigermassen läuft mache ich einen PR zur aufnähme in den admin
              Hier zum adapter: ioBroker.bambulab
              wunensche, Anregungen etc gerne als git issue. Möchte diese post hier auch nicht damit sprengen eventuell doch noch einen tester thread erstellen.
              Beim starten des adapters (v0.1.0) kommen noch warnings das Definitionen fehlen, die arbeite ich noch nach. Ist im Grunde nicht wichtig aber sorgt dafür das grad Celsius use richtig dargestellt wird
              • D dadonali
                DutchmanD
                DutchmanD
                Dutchman
                #118
                @dadonali sagte in Bambu lab 3d Drucker MQTT Integration:
                das wird in der 0.1.1 versions meines adapters funktionieren, start/stop/resume und schalten der Lampe
                • D
                  D
                  DarkDevil
                  #119
                  Super, dass es nun einen Adapter gibt :)
                  Funktioniert die Kommunikation denn nur, wenn der Drucker im "LAN only" Mode konfiguriert ist?
                  • D DarkDevil
                    DutchmanD
                    DutchmanD
                    Dutchman
                    #120
                    @darkdevil sagte in Bambu lab 3d Drucker MQTT Integration:
                    nope geht in beiden Varianten, LAN only modus bedeutet das man die cloud ausschaltet es geht sowohl mit als ohne cloud da der adapter sich local verbindet :)
                    PS: in der jetzigen version auf git ist auch das steuern der lampe, start/stop/resume implementiert
                    sobald ich die states fertig habe kommt eine versions 0.2.0
                    • DutchmanD
                      DutchmanD
                      Dutchman
                      #121
                      da der adapter stabiel läuft und ich es auch, mit ein wenig Hilfe, geschafft habe die Steuerung der lampen, des Lüfter und custom g-code zu implantieren habe ich dazu ein neuen thread erstellt.
                      Ich würde mich sehr über tester und feedback freuen !
                      https://forum.iobroker.net/topic/67178/bambulab-3d-drucker-adapter?_=1690472648517
                      84.0k
