  4. Node-Red
  5. 2 Werte Subtrtahieren in Node Red
    6.5k
60 Beiträge 3 Kommentatoren 8.1k Aufrufe 3 Beobachtet
  • S siporax
    @mickym said in 2 Werte Subtrtahieren in Node Red:
    @geschild Deine Lösung hat den Vorteil, wenn der Verbrauch nicht triggert, dass dann der Wert sofort angepasst wird. Sollte also auch der Wechelrichter triggern müsste man den Verbrauch extra auslesen und dann brauchst Du ein paar mehr Nodes. Insofern hat Deine Lösung durchaus seine Berechtigung, wenn der Verbrauch nicht oft genug triggert.
    In diesem Fall würde sich meine Lösung wie folgt "verkomplizieren":
           "id": "1abbb3ad15f02df1",
           "type": "ioBroker in",
           "z": "7e6af0015415146d",
           "name": "Teich-Pow",
           "topic": "0_userdata.0.Test.sensor1.power",
           "payloadType": "value",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "false",
           "outFormat": "MQTT",
           "x": 3460,
           "y": 160,
           "wires": [
                   "02a17f5119c5ddeb"
           "id": "db726a38cace8780",
           "type": "ioBroker get",
           "name": "WR-Fritz",
           "topic": "0_userdata.0.Test.sensor2.power",
           "attrname": "wr",
           "errOnInvalidState": "nothing",
           "x": 3860,
           "y": 160,
           "wires": [
                   "5a663fa76121848c"
           "id": "5a663fa76121848c",
           "type": "change",
           "name": "TeichPow - WR",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "verbrauch - wr",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 4040,
           "y": 200,
           "wires": [
                   "086dd9b2dd01f025",
                   "9300e05f3c9f9870"
           "id": "086dd9b2dd01f025",
           "type": "ioBroker out",
           "d": true,
           "name": "Realer_Teichverbrauch",
           "topic": "0_userdata.0.Node_Red_Realer_Teichverbrauch",
           "ack": "true",
           "autoCreate": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 4290,
           "y": 240,
           "wires": []
           "id": "9300e05f3c9f9870",
           "type": "debug",
           "name": "Ergebnis nur payload",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 4280,
           "y": 200,
           "wires": []
           "id": "02a17f5119c5ddeb",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "move",
                   "p": "payload",
                   "pt": "msg",
                   "to": "verbrauch",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 3660,
           "y": 160,
           "wires": [
                   "db726a38cace8780"
           "id": "253e024afd9346ec",
           "name": "WR-Fritz",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "x": 3460,
           "y": 240,
           "wires": [
                   "3cece316d856fc0e"
           "id": "157517622c425fcd",
           "attrname": "verbrauch",
           "x": 3870,
           "y": 240,
           "wires": [
                   "5a663fa76121848c"
           "id": "3cece316d856fc0e",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "move",
                   "p": "payload",
                   "pt": "msg",
                   "to": "wr",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 3660,
           "y": 240,
           "wires": [
                   "157517622c425fcd"
    Danke für die Hilfe ,bin nun doch etwas überfordert aber ich versuche es einfach mal mit dem leztem Beispiel.
    Wenn ich nicht klar komme melde ich mich nochmal hier mit dem Qode hier.
    mickymM Offline
    mickymM Offline
    mickym
    @siporax Wie gesagt das brauchst Du nur, wenn Dir der Tech-Pow trigger nicht ausreicht. ;) Sonst langt die einfache Lösung. ;)
    • mickymM mickym
      siporax
      Setze mich später gleich man dran an das ganze.Melde mich dann wieder.
      • S siporax
        mickymM Offline
        mickymM Offline
        mickym
        @siporax Die einfache Lösung nur mit der Trigger des Sonoff - war hier (sind nur 4 Nodes): https://forum.iobroker.net/post/1019849
        • mickymM mickym
          siporax
          So habs soweit übernommen u d angepasst läuft aber nicht bzw schreib keine Daten in den Broker da steht immer Null
                  "id": "78f6b708eb6bd2fe",
                  "type": "tab",
                  "label": "Realer Teichverbrauch",
                  "disabled": false,
                  "info": "",
                  "env": []
                  "id": "4e110ac9e3526a1d",
                  "z": "78f6b708eb6bd2fe",
                  "topic": "sonoff.0.Teich-Verbrauch.ENERGY_Power",
                  "onlyack": "",
                  "func": "all",
                  "gap": "",
                  "x": 120,
                  "y": 100,
                  "wires": [
                          "e6795d8dc9d84fcc"
                  "id": "be61f3942177482d",
                  "name": "WR-Fritz",
                  "topic": "fritzdect.0.DECT_116570079058.power",
                  "attrname": "wr",
                  "x": 520,
                  "y": 100,
                  "wires": [
                          "719b166cf1c4cf56"
                  "id": "719b166cf1c4cf56",
                  "type": "change",
                  "rules": [
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "tot": "jsonata"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 700,
                  "y": 140,
                  "wires": [
                          "2528507974039f88",
                          "ec4528823eccb390"
                  "id": "2528507974039f88",
                  "d": true,
                  "ack": "true",
                  "stateName": "",
                  "role": "",
                  "payloadType": "",
                  "readonly": "",
                  "stateUnit": "",
                  "stateMin": "",
                  "stateMax": "",
                  "x": 950,
                  "y": 180,
                  "wires": []
                  "id": "ec4528823eccb390",
                  "type": "debug",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 940,
                  "y": 140,
                  "wires": []
                  "id": "e6795d8dc9d84fcc",
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "move",
                          "p": "payload",
                          "pt": "msg",
                          "to": "verbrauch",
                          "tot": "msg"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 320,
                  "y": 100,
                  "wires": [
                          "be61f3942177482d"
                  "id": "5413c6e8e87d1659",
                  "name": "WR-Fritz",
                  "onlyack": "",
                  "func": "all",
                  "gap": "",
                  "x": 120,
                  "y": 180,
                  "wires": [
                          "e857e6e86301279a"
                  "id": "8e2c30a2834a5bc7",
                  "x": 530,
                  "y": 180,
                  "wires": [
                          "719b166cf1c4cf56"
                  "id": "e857e6e86301279a",
                  "type": "change",
                  "name": "",
                  "rules": [
                          "t": "move",
                          "p": "payload",
                          "pt": "msg",
                          "to": "wr",
                          "tot": "msg"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 320,
                  "y": 180,
                  "wires": [
                          "8e2c30a2834a5bc7"
          • S siporax
                    "type": "tab",
                    "disabled": false,
                    "info": "",
                    "env": []
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 120,
                    "y": 100,
                    "wires": [
                            "e6795d8dc9d84fcc"
                    "name": "WR-Fritz",
                    "attrname": "wr",
                    "x": 520,
                    "y": 100,
                    "wires": [
                            "719b166cf1c4cf56"
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "tot": "jsonata"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 700,
                    "y": 140,
                    "wires": [
                            "2528507974039f88",
                            "ec4528823eccb390"
                    "d": true,
                    "ack": "true",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 950,
                    "y": 180,
                    "wires": []
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 940,
                    "y": 140,
                    "wires": []
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "move",
                            "p": "payload",
                            "pt": "msg",
                            "to": "verbrauch",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 320,
                    "y": 100,
                    "wires": [
                            "be61f3942177482d"
                    "name": "WR-Fritz",
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 120,
                    "y": 180,
                    "wires": [
                            "e857e6e86301279a"
                    "x": 530,
                    "y": 180,
                    "wires": [
                            "719b166cf1c4cf56"
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "move",
                            "p": "payload",
                            "pt": "msg",
                            "to": "wr",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 320,
                    "y": 180,
                    "wires": [
                            "8e2c30a2834a5bc7"
            siporax
            @siporax said in 2 Werte Subtrtahieren in Node Red:
                    "type": "tab",
                    "disabled": false,
                    "info": "",
                    "env": []
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 120,
                    "y": 100,
                    "wires": [
                            "e6795d8dc9d84fcc"
                    "name": "WR-Fritz",
                    "attrname": "wr",
                    "x": 520,
                    "y": 100,
                    "wires": [
                            "719b166cf1c4cf56"
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "tot": "jsonata"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 700,
                    "y": 140,
                    "wires": [
                            "2528507974039f88",
                            "ec4528823eccb390"
                    "d": true,
                    "ack": "true",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 950,
                    "y": 180,
                    "wires": []
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 940,
                    "y": 140,
                    "wires": []
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "move",
                            "p": "payload",
                            "pt": "msg",
                            "to": "verbrauch",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 320,
                    "y": 100,
                    "wires": [
                            "be61f3942177482d"
                    "name": "WR-Fritz",
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 120,
                    "y": 180,
                    "wires": [
                            "e857e6e86301279a"
                    "x": 530,
                    "y": 180,
                    "wires": [
                            "719b166cf1c4cf56"
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "move",
                            "p": "payload",
                            "pt": "msg",
                            "to": "wr",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 320,
                    "y": 180,
                    "wires": [
                            "8e2c30a2834a5bc7"
            • S siporax
                      "type": "tab",
                      "disabled": false,
                      "info": "",
                      "env": []
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 120,
                      "y": 100,
                      "wires": [
                              "e6795d8dc9d84fcc"
                      "name": "WR-Fritz",
                      "attrname": "wr",
                      "x": 520,
                      "y": 100,
                      "wires": [
                              "719b166cf1c4cf56"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 700,
                      "y": 140,
                      "wires": [
                              "2528507974039f88",
                              "ec4528823eccb390"
                      "d": true,
                      "ack": "true",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 950,
                      "y": 180,
                      "wires": []
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 940,
                      "y": 140,
                      "wires": []
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "move",
                              "p": "payload",
                              "pt": "msg",
                              "to": "verbrauch",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 320,
                      "y": 100,
                      "wires": [
                              "be61f3942177482d"
                      "name": "WR-Fritz",
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 120,
                      "y": 180,
                      "wires": [
                              "e857e6e86301279a"
                      "x": 530,
                      "y": 180,
                      "wires": [
                              "719b166cf1c4cf56"
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "move",
                              "p": "payload",
                              "pt": "msg",
                              "to": "wr",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 320,
                      "y": 180,
                      "wires": [
                              "8e2c30a2834a5bc7"
              mickymM Offline
              mickymM Offline
              mickym
              @siporax Ja dann mach mal ein Screenshot und zeig den Status bzw. mach Debug Nodes dran. Wenn 100-100 = 0 rauskommt, dann ist das ja richtig.
              Und es stimmt ja nicht, dass er nichts schreibt:
              Der Datenpunkt wurde um 14:34 heute beschrieben.
              S geschildG 2 Antworten Letzte Antwort
              • mickymM mickym
                siporax
                • S siporax
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @siporax Na dann kommt doch das Ergebnis raus. Du musst doch nur die iobroker-Out Node wieder aktivieren.
                  Die Debug Node kannst wieder wegschmeissen - das ist doch nur zur Fehlersuche bzw. zur Demonstration. Und wie gesagt - ich sehe die Sonoff Node trigger meistens - dann könntest auch die einfache Lösung mit den 4 Nodes nehmen:
                        "z": "289f539dcc33814e",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 2440,
                        "y": 4320,
                        "wires": [
                                "db726a38cace8780"
                        "name": "WR-Fritz",
                        "attrname": "wr",
                        "x": 2600,
                        "y": 4320,
                        "wires": [
                                "5a663fa76121848c"
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "payload - wr",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 2780,
                        "y": 4320,
                        "wires": [
                                "086dd9b2dd01f025"
                        "ack": "true",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 3010,
                        "y": 4320,
                        "wires": []
                  • mickymM mickym
                    geschildG Offline
                    geschildG Offline
                    geschild
                    @mickym
                    Sorry: </> Code einfügen hab ich kapiert, aber wie daraus einen Spoiler macht ???
                    Egal. Code in .txt. Habe mal die topics in flow Variable gepackt. Jetzt braucht man die iobrokerIn/Out nur noch wie gewohnt mit den DP verbinden.
                    Könnte man das so machen. (Ich lerne gern dazu)
                    • geschildG geschild
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @geschild Den Spoiler machst Du mit dem Auge. ;)
                      code_text
                      Dann innerhalb des Spoilers die Code Tags:
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @geschild So nun zu Deinem Flow. ;)
                        Das wird zwar so funktionieren - aber in dem Fall finde ich es übertrieben Flow variablen zu setzen, nur um das topic zu vereinfachen. Insbesondere ändert sich der Wert dieser Flowvariablen ja nie. Das würde nur Sinn machen, wenn Du unabhängig die Initialisierung triggern würdest. Dann lieber wieder das topic direkt setzen:
                               "id": "c32a0a1f4a2b9221",
                               "topic": "0_userdata.0.TeichMinus.Teich-Pow",
                               "onlyack": "",
                               "func": "all",
                               "gap": "",
                               "outFormat": "ioBroker",
                               "x": 180,
                               "y": 560,
                               "wires": [
                                       "f85da542bcf883c8"
                               "id": "eceba02fa565ce76",
                               "name": "WR-Fritz",
                               "topic": "0_userdata.0.TeichMinus.WR-Fritz",
                               "onlyack": "",
                               "func": "all",
                               "gap": "",
                               "x": 180,
                               "y": 640,
                               "wires": [
                                       "363c25994833957b"
                               "id": "11f59eb25158b200",
                               "name": "Ergebnis",
                               "topic": "0_userdata.0.TeichMinus.Ergebnis",
                               "ack": "false",
                               "stateName": "",
                               "role": "",
                               "payloadType": "",
                               "readonly": "",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 840,
                               "y": 600,
                               "wires": []
                               "id": "9a2bda7d9bbb1ca2",
                               "type": "function",
                               "name": "wrFritz - teichPow",
                               "func": "var topic = msg.topic;\nvar teichPow;\nvar wrFritz;\nvar ergebnis;\n\nvar teichPow = context.get('teichPowData') || 0;;\nvar wrFritz = context.get('wrFritzData') || 0;;\n\n\nif (topic == 'teichPowTopic') {\n//if (topic == \"0_userdata.0.TeichMinus.Teich-Pow\") {\n    teichPow = parseInt(msg.payload);\n    context.set('teichPowData', teichPow)\n}\n\nif (topic == 'wrFritzTopic') {\n//if (topic == \"0_userdata/0/TeichMinus/WR-Fritz\") {\n    wrFritz = parseInt(msg.payload);\n    context.set('wrFritzData', wrFritz) \n}\n\nergebnis = wrFritz - teichPow;\nmsg.payload = ergebnis;\nreturn msg;\n\n\n",
                               "outputs": 1,
                               "noerr": 0,
                               "initialize": "",
                               "finalize": "",
                               "libs": [],
                               "x": 610,
                               "y": 600,
                               "wires": [
                                       "11f59eb25158b200"
                               "id": "f85da542bcf883c8",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "teichPowTopic",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 380,
                               "y": 560,
                               "wires": [
                                       "9a2bda7d9bbb1ca2"
                               "id": "363c25994833957b",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "wrFritzTopic",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 380,
                               "y": 640,
                               "wires": [
                                       "9a2bda7d9bbb1ca2"
                        geschildG 1 Antwort Letzte Antwort
                        • mickymM mickym
                                 "onlyack": "",
                                 "func": "all",
                                 "gap": "",
                                 "x": 180,
                                 "y": 560,
                                 "wires": [
                                         "f85da542bcf883c8"
                                 "name": "WR-Fritz",
                                 "onlyack": "",
                                 "func": "all",
                                 "gap": "",
                                 "x": 180,
                                 "y": 640,
                                 "wires": [
                                         "363c25994833957b"
                                 "name": "Ergebnis",
                                 "ack": "false",
                                 "stateName": "",
                                 "role": "",
                                 "payloadType": "",
                                 "readonly": "",
                                 "stateUnit": "",
                                 "stateMin": "",
                                 "stateMax": "",
                                 "x": 840,
                                 "y": 600,
                                 "wires": []
                                 "type": "function",
                                 "outputs": 1,
                                 "noerr": 0,
                                 "initialize": "",
                                 "finalize": "",
                                 "libs": [],
                                 "x": 610,
                                 "y": 600,
                                 "wires": [
                                         "11f59eb25158b200"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 380,
                                 "y": 560,
                                 "wires": [
                                         "9a2bda7d9bbb1ca2"
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "topic",
                                         "pt": "msg",
                                         "tot": "str"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 380,
                                 "y": 640,
                                 "wires": [
                                         "9a2bda7d9bbb1ca2"
                          geschildG Offline
                          geschildG Offline
                          geschild
                          @mickym Ist klar, aber wollte @siporax das Leben leichter machen.
                            mickymM Offline
                            mickymM Offline
                            mickym
                            Übrigens Deine Function Node ;)
                            flow.set('teichPowTopic', topic);
                            msg.payload = flow.get('teichPowTopic');
                            return msg;
                            kann man auch mit einer ChangeNode ohne Codieren machen. ;)
                            Das macht das Gleiche:
                            • mickymM mickym
                              return msg;
                              siporax
                              schrieb am zuletzt editiert von siporax
                              return msg;
                              So habs zum rechnen gebracht steht zwar ein minus davor im Zielordner beim Ergebnis aber damit kann ich leben.
                                     "type": "tab",
                                     "disabled": false,
                                     "info": "",
                                     "env": []
                                     "onlyack": "",
                                     "func": "all",
                                     "gap": "",
                                     "x": 120,
                                     "y": 100,
                                     "wires": [
                                             "e6795d8dc9d84fcc"
                                     "name": "WR-Fritz",
                                     "attrname": "wr",
                                     "x": 520,
                                     "y": 100,
                                     "wires": [
                                             "719b166cf1c4cf56"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "tot": "jsonata"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 700,
                                     "y": 140,
                                     "wires": [
                                             "2528507974039f88"
                                     "ack": "true",
                                     "stateName": "",
                                     "role": "",
                                     "payloadType": "",
                                     "readonly": "",
                                     "stateUnit": "",
                                     "stateMin": "",
                                     "stateMax": "",
                                     "x": 950,
                                     "y": 140,
                                     "wires": []
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "move",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "verbrauch",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 320,
                                     "y": 100,
                                     "wires": [
                                             "be61f3942177482d"
                                     "name": "WR-Fritz",
                                     "onlyack": "",
                                     "func": "all",
                                     "gap": "",
                                     "x": 120,
                                     "y": 180,
                                     "wires": [
                                             "e857e6e86301279a"
                                     "x": 530,
                                     "y": 180,
                                     "wires": [
                                             "719b166cf1c4cf56"
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "move",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "wr",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 320,
                                     "y": 180,
                                     "wires": [
                                             "8e2c30a2834a5bc7"
                              • mickymM mickym
                                return msg;
                                geschildG Offline
                                geschildG Offline
                                geschild
                                schrieb am zuletzt editiert von geschild
                                @mickym Danke. Wie gesagt, komme vom Script und muss mir die Möglichkeiten von nodered erst aneignen. Schönen Sonntag noch.
                                PS. Kannst du mir den elektrischen Aufbau von @siporax erklären?
                                • S siporax
                                  return msg;
                                         "type": "tab",
                                         "disabled": false,
                                         "info": "",
                                         "env": []
                                         "onlyack": "",
                                         "func": "all",
                                         "gap": "",
                                         "x": 120,
                                         "y": 100,
                                         "wires": [
                                                 "e6795d8dc9d84fcc"
                                         "name": "WR-Fritz",
                                         "attrname": "wr",
                                         "x": 520,
                                         "y": 100,
                                         "wires": [
                                                 "719b166cf1c4cf56"
                                         "type": "change",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 700,
                                         "y": 140,
                                         "wires": [
                                                 "2528507974039f88"
                                         "ack": "true",
                                         "stateName": "",
                                         "role": "",
                                         "payloadType": "",
                                         "readonly": "",
                                         "stateUnit": "",
                                         "stateMin": "",
                                         "stateMax": "",
                                         "x": 950,
                                         "y": 140,
                                         "wires": []
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "move",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "to": "verbrauch",
                                                 "tot": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 320,
                                         "y": 100,
                                         "wires": [
                                                 "be61f3942177482d"
                                         "name": "WR-Fritz",
                                         "onlyack": "",
                                         "func": "all",
                                         "gap": "",
                                         "x": 120,
                                         "y": 180,
                                         "wires": [
                                                 "e857e6e86301279a"
                                         "x": 530,
                                         "y": 180,
                                         "wires": [
                                                 "719b166cf1c4cf56"
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "move",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "to": "wr",
                                                 "tot": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 320,
                                         "y": 180,
                                         "wires": [
                                                 "8e2c30a2834a5bc7"
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @siporax Das Minus kannst Du eliminieren, wenn Du die Subtraktion umdrehst oder halt den absoluten Wert nimmst.
                                  Um den absoluten Wert zu erhalten - einfach die ChangeNode wie folgt ändern:
                                  Oder alternativ mit -1 multiplizieren also
                                  (payload-wr) * -1
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @geschild sagte in 2 Werte Subtrtahieren in Node Red:
                                    Nee - das muss @siporax selbst machen - ich bin nur für die Logik in NodeRed zuständig. ;)
                                    • mickymM mickym
                                      siporax
                                      Habe eine Warnmeldungen
                                      • S siporax
                                        siporax
                                        Wenn Wechselrichter ausgeschaltet ist hat der Teich dennoch Verbrauch der wird mir nicht dan angezeigt ?
                                        • S siporax
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @siporax
                                          1. Also Du musst halt vorher mit der Logik klar kommen. Die Warnmeldungen kommen, weil Du versucht hast einen schreibgeschützten Wert im Sonoff Adapter zu beschreiben - das darfst Du halt nicht. Überprüfe Deine iobroker-Out Nodes. Bis auf die Werte, die Du zum Steuern verwendest, darf sonst nur der Adapter was reinschreiben.
                                          Schreibgeschütze Werte erkennst Du an dem Schloss:
                                          1. Ich hab Dir ja gesagt Du sollst die einfache Variante nehmen und dann kannst Du wenn Du keinen Verbrauch auch 0 schreiben und den Wechselrichter ignorieren.
                                                 "id": "18edda87f3b39f3e",
                                                 "onlyack": "",
                                                 "func": "all",
                                                 "gap": "",
                                                 "x": 2080,
                                                 "y": 3600,
                                                 "wires": [
                                                         "0ebf71f32dd2b609"
                                                 "id": "f0133d29a83f3d17",
                                                 "name": "WR-Fritz",
                                                 "attrname": "wr",
                                                 "x": 2400,
                                                 "y": 3660,
                                                 "wires": [
                                                         "746280ddaeb139a2"
                                                 "id": "746280ddaeb139a2",
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "(payload - wr) * -1",
                                                         "tot": "jsonata"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 2580,
                                                 "y": 3660,
                                                 "wires": [
                                                         "1e4d02d4327046e2"
                                                 "id": "1e4d02d4327046e2",
                                                 "ack": "true",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 2810,
                                                 "y": 3580,
                                                 "wires": []
                                                 "id": "0ebf71f32dd2b609",
                                                 "type": "switch",
                                                 "name": "Verbrauch > 0",
                                                 "property": "payload",
                                                 "propertyType": "msg",
                                                 "rules": [
                                                         "t": "eq",
                                                         "v": "0",
                                                         "vt": "num"
                                                         "t": "gt",
                                                         "v": "0",
                                                         "vt": "num"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 2260,
                                                 "y": 3600,
                                                 "wires": [
                                                         "1e4d02d4327046e2"
                                                         "f0133d29a83f3d17"
