  4. Test Adapter Govee via AWS/App
    6.6k
132 Beiträge 29 Kommentatoren 37.4k Aufrufe 34 Beobachtet
  • Server PfunzS Server Pfunz
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID:	Raspbian
    Description:	Raspbian GNU/Linux 10 (buster)
    Release:	10
    Codename:	buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     14:16:09 up 15 days,  2:57,  1 user,  load average: 0.82, 1.52, 2.54
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=55.0'C
    volt=0.8500V
    *** Time and Time Zones ***
                   Local time: Mon 2023-05-08 14:16:09 CEST
               Universal time: Mon 2023-05-08 12:16:09 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           1.9G        758M        907M         32M        206M        1.0G
    Swap:           99M         93M        6.0M
    Total:         2.0G        852M        913M
             1872 M total memory
              760 M used memory
              266 M active memory
              621 M inactive memory
              905 M free memory
               58 M buffer memory
              147 M swap cache
               99 M total swap
               93 M used swap
                6 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  7.3G   21G  27% /
    devtmpfs       devtmpfs  776M     0  776M   0% /dev
    tmpfs          tmpfs     937M     0  937M   0% /dev/shm
    tmpfs          tmpfs     937M   32M  905M   4% /run
    tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     188M  8.0K  188M   1% /run/user/1000
    [Sun Apr 23 11:18:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1E:C1:38 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Apr 23 11:18:27 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sun Apr 23 11:18:27 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sun Apr 23 11:18:27 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Sun Apr 23 11:18:27 2023] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
    [Sun Apr 23 11:18:27 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Sun Apr 23 11:18:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Apr 23 11:18:27 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Apr 23 11:18:30 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET                       SOURCE         FSTYPE            OPTIONS
    /                            /dev/mmcblk0p2 ext4              rw,noatime
    |-/sys/fs/bpf                none           bpf               rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs        gvfsd-fuse     fuse.gvfsd-fuse   rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot                      /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    /var:
    2.3G	/var/
    2.0G	/var/cache/apt/archives
    2.0G	/var/cache/apt
    2.0G	/var/cache
    119M	/var/lib
    Archived and active journals take up 31.4M in the file system.
    /opt/iobroker/backups:
    3.2M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    270M	/opt/iobroker/iobroker-data/
    161M	/opt/iobroker/iobroker-data/files
    78M	/opt/iobroker/iobroker-data/backup-objects
    51M	/opt/iobroker/iobroker-data/files/javascript.admin
    48M	/opt/iobroker/iobroker-data/files/telegram.admin
    15M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    12M	/opt/iobroker/iobroker-data/objects.jsonl
    11M	/opt/iobroker/iobroker-data/files/s7.admin/static/js/main.05e58ebd.js.map
    7.2M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
    6.9M	/opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8fdf8cb7.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.15.0
    /usr/bin/node 		v18.15.0
    /usr/bin/npm 		9.5.0
    /usr/bin/npx 		9.5.0
    nodejs:
      Installed: 18.15.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
         18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
     *** 18.15.0-deb-1nodesource1 100
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	6.1.4
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.govee-app@0.0.6 /opt/iobroker/node_modules/iobroker.govee-app
    npm ERR! invalid: iobroker.gsmsms@0.0.4 /opt/iobroker/node_modules/iobroker.gsmsms
    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR!     /home/pi/.npm/_logs/2023-05-08T12_16_43_550Z-debug-0.log
    Adapters from github: 	2
    Adapter State
    + system.adapter.admin.0                  : admin                 : HomeSys-ioBroker                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : HomeSys-ioBroker                         -  enabled
      system.adapter.asterisk.0               : asterisk              : HomeSys-ioBroker                         - disabled, port: 5038
    + system.adapter.cloud.0                  : cloud                 : HomeSys-ioBroker                         -  enabled
      system.adapter.daswetter.0              : daswetter             : HomeSys-ioBroker                         - disabled
    + system.adapter.discovery.0              : discovery             : HomeSys-ioBroker                         -  enabled
      system.adapter.email.0                  : email                 : HomeSys-ioBroker                         - disabled
      system.adapter.firetv.0                 : firetv                : HomeSys-ioBroker                         - disabled
      system.adapter.fritzbox.0               : fritzbox              : HomeSys-ioBroker                         - disabled
      system.adapter.gsmsms.0                 : gsmsms                : HomeSys-ioBroker                         - disabled, port: /dev/ttyUSB2
      system.adapter.heizoel.0                : heizoel               : HomeSys-ioBroker                         - disabled
    + system.adapter.hm-rega.0                : hm-rega               : HomeSys-ioBroker                         -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : HomeSys-ioBroker                         -  enabled, port: 0
    + system.adapter.hoover.0                 : hoover                : HomeSys-ioBroker                         -  enabled
      system.adapter.hs100.0                  : hs100                 : HomeSys-ioBroker                         - disabled
    + system.adapter.hue.0                    : hue                   : HomeSys-ioBroker                         -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : HomeSys-ioBroker                         -  enabled
    + system.adapter.info.0                   : info                  : HomeSys-ioBroker                         -  enabled
    + system.adapter.javascript.0             : javascript            : HomeSys-ioBroker                         -  enabled
      system.adapter.modbus.0                 : modbus                : HomeSys-ioBroker                         - disabled
      system.adapter.mqtt-client.0            : mqtt-client           : HomeSys-ioBroker                         - disabled, port: 1883
      system.adapter.mqtt.0                   : mqtt                  : HomeSys-ioBroker                         - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.resol.0                  : resol                 : HomeSys-ioBroker                         - disabled
    + system.adapter.s7.0                     : s7                    : HomeSys-ioBroker                         -  enabled
      system.adapter.schoolfree.0             : schoolfree            : HomeSys-ioBroker                         -  enabled
      system.adapter.socketio.0               : socketio              : HomeSys-ioBroker                         - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : HomeSys-ioBroker                         -  enabled
    + system.adapter.tr-064.1                 : tr-064                : HomeSys-ioBroker                         -  enabled
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeSys-ioBroker                         -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.7  [Updatable]
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "firetv"       : 1.0.0    , installed 1.0.0
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "gsmsms"       : 0.0.4    , installed 0.0.4
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "hoover"       : 0.0.7    , installed 0.0.7
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "info"         : 1.9.26   , installed 1.9.19 [Updatable]
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.1.1
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "resol"        : 1.1.6    , installed 1.1.6
    Adapter    "s7"           : 1.3.14   , installed 1.3.14
    Adapter    "schoolfree"   : 1.1.1    , installed 1.1.1
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects: 	7710
    States: 	6568
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
    Reading package lists...
    Pending Updates: 14
    *** Listening Ports ***
    tcp        0      0 192.168.166.175:2001    0.0.0.0:*               LISTEN      1001       98314560   6669/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18045      647/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          94163738   23021/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       98313774   6563/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       98311882   6563/iobroker.js-co
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       98311936   6588/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18047      647/sshd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18690      648/xrdp-sesman
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          94163737   23021/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      116        21642      664/xrdp
    udp        0      0 0.0.0.0:59884           0.0.0.0:*                           108        17470      392/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15213      635/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          94165502   23023/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17468      392/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        17469      392/avahi-daemon: r
    udp6       0      0 :::45909                :::*                                108        17471      392/avahi-daemon: r
    2023-05-08 14:06:32.800  - info: host.HomeSys-ioBroker iobroker npm-install: added 4 packages, removed 865 packages, and changed 930 packages in 10m102 packages are looking for funding  run `npm fund` for details
    2023-05-08 14:06:33.140  - info: host.HomeSys-ioBroker iobroker npm-install: upload [16] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/blockly.js blockly.js application/javascript
    2023-05-08 14:06:33.240  - info: host.HomeSys-ioBroker iobroker npm-install: upload [15] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/gsmsms.png gsmsms.png image/png
    2023-05-08 14:06:33.252  - info: host.HomeSys-ioBroker iobroker npm-install: upload [14] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/gsmsms_2.png gsmsms_2.png image/png
    2023-05-08 14:06:33.263  - info: host.HomeSys-ioBroker iobroker npm-install: upload [13] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/de/translations.json i18n/de/translations.json application/json
    2023-05-08 14:06:33.275  - info: host.HomeSys-ioBroker iobroker npm-install: upload [12] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/en/translations.json i18n/en/translations.json application/json
    2023-05-08 14:06:33.286  - info: host.HomeSys-ioBroker iobroker npm-install: upload [11] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/es/translations.json i18n/es/translations.json application/json
    2023-05-08 14:06:33.298  - info: host.HomeSys-ioBroker iobroker npm-install: upload [10] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    2023-05-08 14:06:33.312  - info: host.HomeSys-ioBroker iobroker npm-install: upload [9] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/it/translations.json i18n/it/translations.json application/json
    2023-05-08 14:06:33.324  - info: host.HomeSys-ioBroker iobroker npm-install: upload [8] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    2023-05-08 14:06:33.335  - info: host.HomeSys-ioBroker iobroker npm-install: upload [7] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    2023-05-08 14:06:33.347  - info: host.HomeSys-ioBroker iobroker npm-install: upload [6] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    2023-05-08 14:06:33.358  - info: host.HomeSys-ioBroker iobroker npm-install: upload [5] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    2023-05-08 14:06:33.369  - info: host.HomeSys-ioBroker iobroker npm-install: upload [4] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    2023-05-08 14:06:33.380  - info: host.HomeSys-ioBroker iobroker npm-install: upload [3] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    2023-05-08 14:06:33.390  - info: host.HomeSys-ioBroker iobroker npm-install: upload [2] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/index_m.html index_m.html text/html
    2023-05-08 14:06:33.402  - info: host.HomeSys-ioBroker iobroker npm-install: upload [1] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/style.css style.css text/css
    2023-05-08 14:06:33.417  - info: host.HomeSys-ioBroker iobroker npm-install: upload [0] gsmsms.admin /opt/iobroker/node_modules/iobroker.gsmsms/admin/words.js words.js application/javascript
    2023-05-08 14:06:34.551  - info: host.HomeSys-ioBroker iobroker npm-install: exit 0
    2023-05-08 14:08:45.675  - error: alexa2.0 (6731) Error deleting crashCheck file: ENOENT: no such file or directory, unlink '/opt/iobroker/node_modules/iobroker.alexa2/crashCheck-alexa2.0.json'
    2023-05-08 14:14:37.456  - error: hoover.0 (7080) Login step #2 failed
    2023-05-08 14:14:37.459  - error: hoover.0 (7080) Error: read ETIMEDOUT
    2023-05-08 14:14:37.825  - error: hoover.0 (7080) Login step #3 failed
    2023-05-08 14:14:37.826  - error: hoover.0 (7080) AxiosError: Request failed with status code 400
    2023-05-08 14:14:37.827  - error: hoover.0 (7080) {"message":"[AuraClientInputException from server] Unexpected request input. Expected input format: \"Data in a request must be a valid JSON Object.\"."}
    Summary
    		     v.2023-04-16
    Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
    Kernel: 		5.10.103-v7l+
    Installation: 		Native
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    X-Server: 		true
    Pending OS-Updates: 	14
    Pending iob updates: 	2
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.15.0
    			/usr/bin/npm 		9.5.0
    			/usr/bin/npx 		9.5.0
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           1.9G        787M        646M         32M        438M        926M
    Swap:           99M         91M        8.0M
    Total:         2.0G        879M        654M
    Active iob-Instances: 	15
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.3.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		7710
    States: 		6568
    Size of iob-Database:
    6.3M	/opt/iobroker/iobroker-data/objects.json.migrated
    6.3M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    4.8M	/opt/iobroker/iobroker-data/states.jsonl
    1.2M	/opt/iobroker/iobroker-data/states.json.migrated
    1.2M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    #83
    @server-pfunz
    buster ist tot, installier da das 'bullseye'-Release / Debian 11.
    X-Server: true
    Schalt den Desktop aus.
    Halt dein System auf Stand.
    Dein Dateisystem hat einen Treffer abbekommen.
    Dein npm tree ist nicht sauber.
    • W Offline
      W Offline
      warhammer73
      #84
      ich habe den Adapter aus https://github.com/TA2k/ioBroker.govee-app installiert und mit User/Passwort bekomme ich auch meine Leuchten zu sehen.
      Allerdings fehlt mir irgendwie die Dokumentation der einzelnen Werte. Also habe ich etwas herumprobiert um ein/aus zu finden.
      Der On/Off Wert springt auf 1 wenn ich die Leuchten per App anschalte und auf 0 wenn ich sie ausschalte.
      Allerdings hat das manuelle setzen keinen Einfluss auf die Leuchten.
      ... wie kann ich die Leuchten per iobroker anschalten?
      • W warhammer73
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        #85
        @warhammer73 sagte in Test Adapter Govee via AWS/App:
        Datenpunkte mit einem Schloss im Symbol sind "read-only" und nicht manuell änderbar.
        Klapp mal den Ordner "remote" auf und schau Dir die dortigen Datenpunkte an.
        Lehrling seit 1975 !!!
        W 1 Antwort Letzte Antwort
        • DJMarc75D DJMarc75
          W Offline
          W Offline
          warhammer73
          #86
          @djmarc75
          Ok, danke. brauchte einen Adapterneustart das er "remote" angezeigt hat.
          • S Online
            S Online
            spike2
            schrieb am zuletzt editiert von spike2
            #87
            Geht das Govee H617A, hat das jemand zufällig ?
            Bei mir scheint er sich nicht richtig zu verbinden...
            Bluetooth ist aktiviert, die Softwareversion etc. wird vom Adapter korrekt abgerufen, allerdings ist der Ordner Status/ Snapshots leer und der Datenpunkt
            govee-app.0.82:BC:D9:32:39:36:--:--.deviceExt.lastDeviceData steht auf false.
            Unter anderem lässt sich durch die Remote Datenpunkte natürlich nichts steuern.
            govee-app.0
            	2023-07-17 11:57:41.984	debug	MQTT send: turn to 82:BC:D9:32:39:36:--:-- data {"val":0}
            govee-app.0
            	2023-07-17 11:56:46.789	debug	MQTT subscribe to GA/bbd4e261961d3----------------------
            govee-app.0
            	2023-07-17 11:56:46.788	debug	MQTT connected
            govee-app.0
            	2023-07-17 11:56:46.210	debug	MQTT publish to 82:BC:D9:32:39:36:--:--
            • S spike2
              govee-app.0
              govee-app.0
              govee-app.0
              govee-app.0
              #88
              @spike2 sagte in Test Adapter Govee via AWS/App:
              H617A
              ups, da hast du wohl ein Bluetooth-Device erwischt... ???
                H617A
                S Online
                S Online
                spike2
                #89
                @ilovegym ja, ist ein Bluetooth Device.
                In der Version 0.0.6 steht der Support für BLE Devices drin.
                Ich ginge von aus, dass dies kein Problem ist ;)
                • S spike2
                  #90
                  @spike2
                  Hab ich auch gelesen, aber wie soll der iobroker die Bluetooth Verbindung mit dem Adapter herstellen..?
                    @spike2
                    S Online
                    S Online
                    spike2
                    #91
                    @ilovegym Mein Broker läuft auf dem Raspberry Pi4 und der hat eine Bluetooth Schnittstelle.
                    Ich habe mir den BLE Adapter installiert um zu schauen ob das Bluetooth funktioniert und siehe da, der Govee Lightstrip wird gefunden.
                    • S spike2
                      #92
                      @spike2
                      Ah ok..
                      @tombox kannst du uns bitte erleuchten? 😂
                        @spike2
                        Ah ok..
                        tombox
                        #93
                        @ilovegym das war support für BLE geräte die nur Daten lesen aber nicht senden.
                        • T tombox
                          S Online
                          S Online
                          spike2
                          #94
                          @tombox ach schade, dann ist er ja mein Lightstrip nicht dafür geeignet.
                          Gibt es eine Möglichkeit über die API/ Adapter Daten zu senden?
                          • R Offline
                            Ralf
                            #95
                            ich habe den Govee Adapter V0.05 installiert und möchte die smart Bodenleuchte damit schalten. Bezeichnung " H7050 ". Habe den API-Key von Govee eingefügt. Leider läßt sich damit nichts schalten.
                            Kann vielleicht jemand helfen ?
                            2023-07-20 12_42_15-Govee Smart Bodenleuchte, 10m RGBICW WiFi Außenleuchte, IP67 wasserdichte Bodens.jpg
                            T ? 2 Antworten Letzte Antwort
                            • R Ralf
                              tombox
                              #96
                              @ralf der adapter ist aktuell in 0.0.6 und braucht kein api key
                              R 1 Antwort Letzte Antwort
                              • R Ralf
                                #97
                                @ralf
                                Hi, ich glaube du hattest in dem anderen Thread vom Govee-Adapter mich gefragt, wo du den Adapter Govee-App findest..
                                den findest du hier im ersten Beitrag, da steht auch, wie man ihn installiert.
                                  @ralf
                                  Ralf
                                  #98
                                  @ilovegym vielen Dank für den Tipp, hab´s schon gefunden und funktioniert !!!
                                  • T tombox
                                    Ralf
                                    #99
                                    @tombox ich find die Version 0.0.6 leider nicht. Kannst du helfen ?
                                    • R Ralf
                                      #100
                                      @ralf
                                      Liegt im GitHub
                                      • I Offline
                                        I Offline
                                        IOMax
                                        #101
                                        Danke!! Klappt auf Anhieb schonmal sehr gut ! Ich habe eine Stehlampe H6076. Heute kommen noch 2 LED Strips H615A3A2DE hinzu. Damit kann ich dann endlich die Komponenten auch über ioBroker steuern.
                                        Crazy32C 1 Antwort Letzte Antwort
                                          sunny9999
                                          schrieb am zuletzt editiert von sunny9999
                                          #102
                                          Hey zusammen...
                                          vorab SUPER Adapter...läuft soweit aber _benutze Version 0.0.6
                                          JS Host 5.0.12
                                          hab mal ein paar Default Settings geladen, die unter Object auch gelistet und mit true/false geschaltet werden können....
                                          Beim schalten kommt folgender Error im Log und Instanz verabschiedet sich........
                                          govee-app.0
                                          2023-09-21 18:29:44.783	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          govee-app.0
                                          2023-09-21 18:29:44.782	info	terminating
                                          govee-app.0
                                          2023-09-21 18:29:44.775	error	defaultItem.iotRules is not iterable
                                          govee-app.0
                                          2023-09-21 18:29:44.775	error	TypeError: defaultItem.iotRules is not iterable at GoveeApp.onStateChange (/opt/iobroker/node_modules/iobroker.govee-app/main.js:682:47) at GoveeApp.emit (node:events:513:28) at GoveeApp.emit (node:domain:489:12) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11181:53) at processImmediate (node:internal/timers:476:21)
                                          govee-app.0
                                          2023-09-21 18:29:44.658	error	unhandled promise rejection: defaultItem.iotRules is not iterable
                                          govee-app.0
                                          2023-09-21 18:29:44.658	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          Jemand ne Idee wo das Problem liegen könnte ?
                                          Greets
                                          Sunny
