Adapterinstanze hm-rpc.1 (homematic ip) restart(jede h)
@ticaki sagte in Adapterinstanze hm-rpc.1 (homematic ip) restart(jede h):
Keiner einen Tip?
NUC mit Proxmox
sagt leider gar nichts aus.
ist der PI3b zu langsam um mit den Anfragen mit zu kommen?
eher nicht.
Unexpected end
heisst ja das irgendwas kommt, aber defekt.
@homoran sagte in Adapterinstanze hm-rpc.1 (homematic ip) restart(jede h):
NUC mit Proxmox
Beelink S12 N100 16GB
Proxmox v8.0
debian bookworm Container
keine Firewallim Log des Raspmatic finde ich sowas:
Jul 16 17:02:37 homematic-raspi local0.err ReGaHss: ERROR: CallGetValue failed; sVal = [ReadValue():iseDOMdpHSS.cpp:124] Jul 16 17:02:37 homematic-raspi local0.warn ReGaHss: WARNING: XMLRPC 'getValue': rpcClient.isFault() failed (url: xmlrpc://127.0.0.1:32010, params: {"000E60C992B277:1","PARTY_TIME_END"}, result: [faultCode:-5,faultString:"Unknown Parameter value for value key: PARTY_TIME_END"]) [CallXmlrpcMethod():iseXmlRpc.cpp:2618] Jul 16 17:02:37 homematic-raspi local0.err ReGaHss: ERROR: XMLRPC 'getValue' call failed (interface: 1009, params: {"000E60C992B277:1","PARTY_TIME_END"}) [CallGetValue():iseXmlRpc.cpp:1445] Jul 16 17:02:37 homematic-raspi local0.err ReGaHss: ERROR: CallGetValue failed; sVal = [ReadValue():iseDOMdpHSS.cpp:124] Jul 16 17:02:37 homematic-raspi local0.warn ReGaHss: WARNING: XMLRPC 'getValue': rpcClient.isFault() failed (url: xmlrpc://127.0.0.1:32010, params: {"000E60C992B277:1","PARTY_SET_POINT_TEMPERATURE"}, result: [faultCode:-5,faultString:"Unknown Parameter value for value key: PARTY_SET_POINT_TEMPERATURE"]) [CallXmlrpcMethod():iseXmlRpc.cpp:2618] Jul 16 17:02:37 homematic-raspi local0.err ReGaHss: ERROR: XMLRPC 'getValue' call failed (interface: 1009, params: {"000E60C992B277:1","PARTY_SET_POINT_TEMPERATURE"}) [CallGetValue():iseXmlRpc.cpp:1445] Jul 16 17:02:37 homematic-raspi local0.err ReGaHss: ERROR: CallGetValue failed; sVal = 0.000000 [ReadValue():iseDOMdpHSS.cpp:124] Jul 16 17:28:40 homematic-raspi local0.warn ReGaHss: WARNING: XMLRPC 'setValue': rpcClient.isFault() failed (url: xmlrpc://127.0.0.1:32010, params: {"000E5D898E95B2:1","BOOST_MODE",true}, result: [faultCode:-1,faultString:"Generic error (UNREACH)"]) [CallXmlrpcMethod():iseXmlRpc.cpp:2618] Jul 16 17:28:40 homematic-raspi local0.err ReGaHss: ERROR: XMLRPC 'setValue' call failed (interface: 1009, params: {"000E5D898E95B2:1","BOOST_MODE",true}) [CallSetValue():iseXmlRpc.cpp:1515] Jul 16 17:28:40 homematic-raspi local0.err ReGaHss: ERROR: rpc.CallSetValue failed; address = 000E5D898E95B2:1 [WriteValue():iseDOMdpHSS.cpp:76] Jul 16 17:28:45 homematic-raspi local0.warn ReGaHss: WARNING: XMLRPC 'setValue': rpcClient.isFault() failed (url: xmlrpc://127.0.0.1:32010, params: {"000E5D898E95B2:1","BOOST_MODE",true}, result: [faultCode:-1,faultString:"Generic error (UNREACH)"]) [CallXmlrpcMethod():iseXmlRpc.cpp:2618] Jul 16 17:28:45 homematic-raspi local0.err ReGaHss: ERROR: XMLRPC 'setValue' call failed (interface: 1009, params: {"000E5D898E95B2:1","BOOST_MODE",true}) [CallSetValue():iseXmlRpc.cpp:1515] Jul 16 17:28:45 homematic-raspi local0.err ReGaHss: ERROR: rpc.CallSetValue failed; address = 000E5D898E95B2:1 [WriteValue():iseDOMdpHSS.cpp:76]Ich schreibe ausschließlich states für einen Lichtschalter mit Statusbeleuchtung, den ich habe. Logik ist komplet im iobroker. 0 Scripte oder Verknüpfungen auf in HM. Bis auf besagten Lichtschalter, der schaltet sein eigenes Relais Typ: HmIP-BSL
NUC mit Proxmox
Proxmox v8.0
@ticaki sagte: url: xmlrpc://127.0.0.1:32010
hat offenbar nichts mit ioBroker zu tun.
Das Log bezieht sich auf einen Thermostat.Das gesamt log ist zu groß, da werden 6 Geräte aufgezählt.
5 sind alle meine Thermostate und der oben genannte Lichtschalter
Und die Einträge der Thermostate beziehen sich auf PARTY_TIME_END PARTY_SET_POINT_TEMPERATURE PARTY_TIME_START
@ticaki sagte: Das gesamt log ist zu groß
Kommt irgendwo die IP-Adresse von ioBroker vor?
Im Log des ersten Beitrags sieht man, dass ioBroker und VCCU in verschieden Subnetzen sind.192.168.179.1/23
hab aber dem iobroker eine Adresse im 178er Netz zusätzlich eingestellt um diese Möglichkeit auszuschliessen.
Hab dem Raspy ein 4A Netzteil gegeben, Raspmatic neuinstalliert. Adapter von Github installiert(das mach ich gleich mal wieder rückgängig)
Nein in keiner Fehlermeldung nur sowas:
192.168.179.7 192.168.178.95:48181 Zugriff [16/Jul/2023:17:23:08 +0200] "POST /rega.exe HTTP/1.1" 200 652 "-" "-" 192.168.179.7 192.168.178.95:48181 Zugriff [16/Jul/2023:17:23:08 +0200] "POST /rega.exe HTTP/1.1" 200 300 "-" "-" -
192.168.179.1/23
NUC mit Proxmox
Proxmox v8.0
warum hab ich das vermutet!?
alle Ports weitergereicht?
IP nach aussen via CallbackAdresse bekanntgegeben? -
IP nach aussen via CallbackAdresse bekanntgegeben?@homoran sagte in Adapterinstanze hm-rpc.1 (homematic ip) restart(jede h):
IP nach aussen via CallbackAdresse bekanntgegeben?Soweit ich das bisher sehe sind alle Ports offen, außer ich setzte Regeln auf und aktiviere die firewall. Beides ist nicht der fall und alle Police sind zur Sicherheit auf ACCEPT gesetzt.
Callbackadresse hab ich jetzt mal eingetragen. Glaube aber das hatte ich schon probiert.
immer alles zeigen!
immer alles zeigen!
@ticaki
Als Callback-Adresse die IP des NUC (Container-Host) eintragen. Das ist sicherlich eine 192.168.178.XX? -
das ist die 179.6 mache ichist üblicherweise das Gastnetz.
Darf das mitreden? -
Darf das mitreden?Wie ich oben schon erwähnt habe 192.176.178.1 - 192.176.179.255 ist mein Netzwerk da ist kein Router oder vlan dazwischen. Ich benutze einen Netzmaske 255.255.254.0 bzw. /23 Ich gebe der ccu jetzt mal ne 179er nummer.
mit der callback from host kommen 0 Daten von HM
löschen und neuinstall von RPC.1 hat auch nix gebracht ausser noch mehr Fehlermeldungen. Hab nochmal nachgesehen, auf dem RPI gabs tatsächlich 0 Meldungen. Denke ich setze nochmal alles neu auf und lassen das redis backup weg.
das was hier, da https://forum.iobroker.net/topic/66862/fehlermeldung-verstehen und da https://forum.iobroker.net/topic/66930/probleme-mit-homematic-rpc/32?_=1689633171965
diskutiert wird. Der hm-rpc (homematic ip) verliert laufend die Verbindung und bleibt dann tod.
Nur einen Master mit Slave hat bei mir das Problem gelöst, Slave ist mein alter pi4 und der hat das Problem nicht.
