  4. Huawei Sun2000 & ioBroker via JS script funktioniert
481 Beiträge 62 Kommentatoren 162.2k Aufrufe 63 Beobachtet
  • R R4
    @stoffel67 sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
    47087
    --> Lies mal nur z.B. [47075, 12] aus oder sogar nur [47087, 2] (den ganzen Registerbereich auszulesen hatte bei mir auch Fehler gegeben, hab mich da dann nicht weiter drum gekümmert, weil ich nicht so viel brauchte...)
    stoffel67
    #194
    @r4 scheint auch nicht zu gehen... bekomme den gleichen Fehler:
    14.7.2023, 08:18:43.660                [info ]: javascript.0 (1105) Stop script script.js.Photovoltaik.Huawei_mit_Batterie_V3
    14.7.2023, 08:19:13.079                [info ]: javascript.0 (1105) Start javascript script.js.Photovoltaik.Huawei_mit_Batterie_V3
    14.7.2023, 08:19:13.135                [info ]: javascript.0 (1105) script.js.Photovoltaik.Huawei_mit_Batterie_V3: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    14.7.2023, 08:19:18.114                [error]: javascript.0 (1105)     at Object.<anonymous> (script.js.Photovoltaik.Huawei_mit_Batterie_V3:456:9)
    14.7.2023, 08:19:23.112                [error]: javascript.0 (1105)     at Object.<anonymous> (script.js.Photovoltaik.Huawei_mit_Batterie_V3:456:9)
    14.7.2023, 08:19:28.112                [error]: javascript.0 (1105)     at Object.<anonymous> (script.js.Photovoltaik.Huawei_mit_Batterie_V3:456:9)
    14.7.2023, 08:19:28.120                [warn ]: javascript.0 (1105) script.js.Photovoltaik.Huawei_mit_Batterie_V3: Error received reading address 81 from id: undefined with error: undefined
    14.7.2023, 08:19:29.049                [info ]: javascript.0 (1105) Stop script script.js.Photovoltaik.Huawei_mit_Batterie_V3
    14.7.2023, 08:19:33.110                [warn ]: javascript.0 (1105) script.js.Photovoltaik.Huawei_mit_Batterie_V3: Error received reading address 114 from id: undefined with error: undefined
    14.7.2023, 08:19:38.111                [warn ]: javascript.0 (1105) script.js.Photovoltaik.Huawei_mit_Batterie_V3: Error received reading address 116 from id: undefined with error: undefined
    14.7.2023, 08:19:59.938                [info ]: javascript.0 (1105) Stop script script.js.Photovoltaik.Huawei_mit_Batterie_V3
    14.7.2023, 08:20:06.698                [info ]: javascript.0 (1105) Start javascript script.js.Photovoltaik.Huawei_mit_Batterie_V3
    14.7.2023, 08:20:06.736                [info ]: javascript.0 (1105) script.js.Photovoltaik.Huawei_mit_Batterie_V3: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    14.7.2023, 08:20:11.711                [error]: javascript.0 (1105)     at Object.<anonymous> (script.js.Photovoltaik.Huawei_mit_Batterie_V3:456:9)
    14.7.2023, 08:20:16.712                [error]: javascript.0 (1105)     at Object.<anonymous> (script.js.Photovoltaik.Huawei_mit_Batterie_V3:456:9)
    14.7.2023, 08:20:18.840                [info ]: javascript.0 (1105) Stop script script.js.Photovoltaik.Huawei_mit_Batterie_V3
    14.7.2023, 08:20:21.710                [warn ]: javascript.0 (1105) script.js.Photovoltaik.Huawei_mit_Batterie_V3: Error received reading address 81 from id: undefined with error: undefined
    14.7.2023, 08:20:26.710                [warn ]: javascript.0 (1105) script.js.Photovoltaik.Huawei_mit_Batterie_V3: Error received reading address 114 from id: undefined with error: undefined
    und im log:
    2023-07-14 08:20:16.713
    error at processTimers (node:internal/timers:514:7)
    error at listOnTimeout (node:internal/timers:573:17)
    error at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2723:34)
    2023-07-14 08:20:16.712
    error at Object.<anonymous> (script.js.Photovoltaik.Huawei_mit_Batterie_V3:456:9)
    error Error in callback: ReferenceError: RegisterSpacesToReadPrioLoopCount is not defined
    2023-07-14 08:20:11.712
    2023-07-14 08:20:11.711
    Wäre nett, wenn jemand von euch mit Batteriespeicher mal testen könnte, ob die Werte gelesen werden können?
    Mein Adapter: JUNG/GIRA eNet-Adapter
    R 1 Antwort Letzte Antwort
    • S stoffel67
      und im log:
      R4
      schrieb am zuletzt editiert von R4
      #195
      @stoffel67
      das sieht bei mir so aus:
      const RegisterSpacesToReadContinuously = [[32000, 116],
                                                [37100, 114],
                                                [37700, 100],
                                                [47075, 14],  // MaximumChargingPower,...
                                                [37000, 68],
                                                [37800, 100],
                                                [38200, 100],
                                                [38300, 100],
                                                [38400, 100],
                                                [30000, 81]
      und weiter unten:
      // Battery registers 112-115 (Storage-related)
      forcesetState("Solarpower.Huawei.Inverter.Battery.MaximumChargingPower",                   getU32(GlobalDataBuffer, 47075), {name: "", unit: "W"});
      forcesetState("Solarpower.Huawei.Inverter.Battery.MaximumDischargingPower",                getU32(GlobalDataBuffer, 47077), {name: "", unit: "W"});
      forcesetState("Solarpower.Huawei.Inverter.Battery.ChargingCutoffCapacity",                 getU16(GlobalDataBuffer, 47081) / 10, {name: "", unit: "%"});
      forcesetState("Solarpower.Huawei.Inverter.Battery.DischargeCutoffCapacity",                getU16(GlobalDataBuffer, 47082) / 10, {name: "", unit: "%"});
      forcesetState("Solarpower.Huawei.Inverter.Battery.ChargeFromGridFunction",                 getU16(GlobalDataBuffer, 47087), {name: "", unit: ""});
      forcesetState("Solarpower.Huawei.Inverter.Battery.GridChargeCutoffSOC",                    getU16(GlobalDataBuffer, 47088) / 10, {name: "", unit: "%"});
      nach anfänglichen Warnings (weil Struktur noch nicht angelegt) kommen die Daten im Objektbaum (javascript.0.Solarpower.Huawei.Inverter.Battery.ChargeFromGridFunction = 0, javascript.0.Solarpower.Huawei.Inverter.Battery.GridChargeCutoffSOC = 100%)
      • svenomattS svenomatt
        @chris_b
        Das hat geholfen :), Fehlermeldung sind bei mir komplett Weg.
            // get SOC of all batteries and combine to one string
         var BatOverview = getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery1.BatterySOC").val + "%, " +
        getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery2.BatterySOC").val + "%";
        setState("javascript.0.Solarpower.Derived.BatteryOverview", BatOverview);
        Vielen Dank für deine schnelle Hilfe. Danke
        Gruß Sven
        svenomattS Offline
        svenomattS Offline
        svenomatt
        schrieb am zuletzt editiert von svenomatt
        #196
        @svenomatt sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
        @chris_b
        Gruß Sven
        @road_runner31
        @Chris_B
        Hallo zusammen, nachdem nun das Script (Dank @Chris_b) bei mir läuft wollte ich gerne meine Wallbox (Easse) per PVüberschusss laden. Als für mich ansprechend fand ich evcc, da es alle meine Wünsche erfüllt. Nun zu meinen eigentlichen Fragen.
        Kann ich gleichzeitig per iobroker (mit dem script) und evcc die Daten vom Wechselrichter ohne Probleme abgreifen? Im Netz konnte ich keine klare Antwort dazu finden. Dort wurde immer gesagt, dass sich mehre Anfrager (z.b. iobroker und evcc) an den Wechselrichter problemmatisch auswirken könnten.
        Zudem wird in der Dokumentation von Evcc über eine Möglichkeit gesprochen, die Daten via Modbus Proxy weiter zu geben.
        Ist es möglich das das Script die Daten vom Wechselrichter über den ModbusProxy zu ziehen. Sodass der Wechselrichter nur von evcc angesprochen wird. und somit nur eine Anfrage an den Wechselrichter gestellt wird.
        Vielleicht sind meine Gedankenspiele auch völlig falsch. Im Ergebnis würde ich gerne beides sowohl das script als auch Evcc nutzen.
        Ich hoffe ich konnte mich halbwegs erklären. Für eine Atwort bzw. Hilfestellung wäre ich euch dankbar.
        C 1 Antwort Letzte Antwort
        • J Offline
          juggi1962
          schrieb am zuletzt editiert von juggi1962
          #197
          Hallo zusammen.
          Kann mir vielleicht jemand sagen, was ich beim Skript ändern muss wenn ich keinen Akku habe.
          IP und Inverter ID hab ich eingetragen aber beim Akku hab ich keine Ahnung, oder funktioniert es nur mit Akku?
          const BatteryUnits = [[3, 0]];
          Was gehört da ohne Batterie rein?
          Danke im Voraus, Gruß Jürgen.
          R svenomattS 2 Antworten Letzte Antwort
          • J juggi1962
            Hallo zusammen.
            R4
            #198
            @juggi1962
            versuch's doch mal mit [0,0]...
            PS: Und lass [37000, 68], [37700, 100], [37800, 100], [38200, 100], [38300, 100], [38400, 100] weg
            • J juggi1962
              Hallo zusammen.
              svenomattS Offline
              svenomattS Offline
              svenomatt
              #199
              @juggi1962
              Ich sollte damals folgendes Ändern. Ich selbst habe nur 2 Batteriepacks und nicht 3.
              @chris_b sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
              @svenomatt
              Laut Deinem Logist der Fehler bei Dir immer in Zeile 371. Das Skript versucht die dritte Batterie anzusprechen, die gibt es bei Dir nicht. Ich habe das Skript so angepasst, dass das jetzt korrekt sein sollte, möchte das aber erst etwas später ins Forum stellen. Bei Dir sollte (Konjunktiv) folgendes das Problem lösen:
              Das im Skript
                      getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery2.BatterySOC").val + "%, " +
                      getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.1.Battery3.BatterySOC").val + "%";
              durch das ersetzen:
              Ich weiß aber nicht inwiefern das Script sich geändert hat.
                      getState("javascript.0.Solarpower.Huawei.Inverter.1.Batterystack.0.Battery0.BatterySOC").val + "%";
              wie gesagt ohne gewähr!
              • R R4
                @juggi1962
                juggi1962
                #200
                @r4 Zuerst mal Danke.
                Hab das von dir probiert, bekomme aber folgende Warnungen 😞
                10:58:42.475	warn	javascript.0 (6338) script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test: Error received reading address 30000 from id: 1 with error: undefined
                10:58:47.474	warn	javascript.0 (6338) script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test: Error received reading address 37100 from id: 1 with error: undefined
                10:58:52.475	warn	javascript.0 (6338) script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test: Error received reading address 32000 from id: 1 with error: undefined
                10:58:57.476	warn	javascript.0 (6338) script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test: Error received reading address 35300 from id: 1 with error: undefined
                10:59:02.487	warn	javascript.0 (6338) at ProcessData (script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test:785:9)
                10:59:02.487	warn	javascript.0 (6338) at Object.<anonymous> (script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test:863:9)
                10:59:02.489	warn	javascript.0 (6338) at ProcessData (script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test:787:9)
                10:59:02.489	warn	javascript.0 (6338) at Object.<anonymous> (script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test:863:9)
                10:59:02.490	warn	javascript.0 (6338) at ProcessData (script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test:793:66)
                10:59:02.491	warn	javascript.0 (6338) at Object.<anonymous> (script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test:863:9)
                10:59:02.492	warn	javascript.0 (6338) script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test: Error received reading address 30000 from id: 1 with error: undefined
                10:59:07.476	warn	javascript.0 (6338) script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_Test: Error received reading address 37100 from id: 1 with error: undefined
                • A ATARI
                  @kachel
                  Vielen Dank für das Script und Deine Arbeit !
                  Wie kann ich den Abfrage Intervall nach einem Durchlauf verzögern
                  oder nur einmal pro Minute oder alle 5 Minuten starten lassen?
                  Ein Timer mit: von Uhrzeit bis Uhrzeit alle x Minuten wäre auch super.
                  Momentan bekommt das Script irgendwann im Laufe des Tages keine
                  Daten mehr und erzeugt nur noch Fehlermeldungen.
                  In diesem Fall hilft nur: das Script stoppen und nach einigen Minuten
                  wieder starten.
                  ATARI
                  Edit:
                  Würde Dir für Deine Arbeit 'nen Kaffee oder 'n Bier spendieren.
                  hawkiobroker
                  #201
                  @atari Hallo, ich weiß nicht, ob Deine Frage schon gelöst wurde, ich habe nicht alle Einträger bisher gelesen. Ich stand vor dem selben Problem und habe mir folgende Lösung überlegt (ich muss zugeben, es wird sicherlich einfachere und bessere geben, für meine Zwecke reicht es aber...):
                  1. Ich habe das Skript so angerpasst, dass es immer nur einmal durchläuft.
                  2. Ich habe ein Blockly-Skript ergänzt, dass das JS Skript alle x Minuten (hier 10) startet und nach Durchlauf (bzw. nach einer bestimmten Zeit) wieder beendet.
                  Ist zwar hemdsärmelig, funktioniert aber. Ich habe dazu im Skript folgende Anpassung vorgenommen:
                  code_text
                  // This is the main function triggering a  read via modbus-tcp every two seconds.
                  // Processing of data is triggered as soon as one complete set of registers is copied.
                  var triggerprocessing = 0;
                  var currentinverter = 1;
                    //  setInterval(function() {
                     //     if(triggerprocessing == 1) {
                     //    triggerprocessing = 0;
                     //     processData();
                     var ref = setInterval(function(){
                      console.log("Triggering read of inverter " + currentinverter + " at address " + RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0] + " with length " +  RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
                      readRegisterSpace(currentinverter, RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0], RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
                      RegisterSpacesToReadContinuouslyPtr++;
                      if(RegisterSpacesToReadContinuouslyPtr >= RegisterSpacesToReadContinuously.length) {
                          RegisterSpacesToReadContinuouslyPtr = 0;
                          currentinverter++
                          if(currentinverter > ModBusIDs.length){
                              triggerprocessing = 1
                              processData();
                              clearInterval(ref);
                  },3333);
                  Das Blockly-Skript sieht folgendermaßen aus:
                    @chris_b
                    Gruß Sven
                    @road_runner31
                    @Chris_B
                    Chris_B
                    #202
                    @svenomatt Hallo Sven. Mit Wallboxen kenne ich mich leider gar nicht aus - sorry.
                    Zu Deiner Anpassung: Im neusten Skript von mir, sollte die Anzahl der Batterien korrekt berücksichtigt sein.
                    Ich poste gleich noch eine neuere Variante meines Skripts mit einigen Optimierungen.
                    • C Offline
                      Chris_B
                      #203
                      @r4 und an alle die es interessiert:
                      Ich habe die Anregung der schnell und langsam zu lesenden Registersätze nun auch in 'mein' Skript implementiert - die Idee gefällt mir. Ich habe es allerdings etwas anders umgesetzt:
                      Mein Skript liest total 9 Registersätze; die ersten n = RegFast (in meinem Fall 5) werden schnell gelesen, die restlichen langsam. Über die Variable RegFastMod wird bestimmt, was langsam bedeutet. RegFastMod = 10 bedeutet, dass nur jedes zehnte Mal alle Register gelesen werden.
                      Ich habe im Skript noch einige Detailverbesserungen vorgenommen.
                      In einer nächste Variante möchte ich mich noch dem GlobalDataBuffer[] annehmen. Dieser ist ja (und das steht auch im Skript) nicht optimiert, und benützt eine monströse (sorry) Grösse. Das kommt dann noch.
                      Hier ein Link zu 'meinem' Skript (diesmal als Link, da es mit 'Code' Probleme gab bei 'grossen' Dateien)
                      Sun2000.js
                      Gruss
                      • C Chris_B
                        Sun2000.js
                        Gruss
                        R4
                        #204
                        Top!
                        Darauf warte ich noch ;-)
                        Würde empfehlen, die Verbindungserstellung in eine Funktion auszulagern. War hier glaub ich auch schon beschrieben und bei mir sieht das so aus (ohne die dazugehörenden Variablen):
                        // Funktion zum Herstellen einer Modbus-Verbindung
                        function ConnectModbus()
                            console.log("Init connection to: " + ModBusHost +":" + ModBusPort);
                            // set requests parameters
                            client.setTimeout (10000);
                            // try to connect
                            client.connectTCP (ModBusHost, { port: ModBusPort })
                                .then(function()
                                    console.log("Connected");
                                .catch(function(e)
                                    console.log(e);
                        Damit nämlich kann die Verbindung wieder aufgebaut werden bei Fehler:
                        function readRegisterSpace(address, length)
                            client.setID(ModBusID);
                            client.readHoldingRegisters(address, length, function(err, data) // ModBus FC03
                                if (err)
                                    if (err.modbusCode == null)
                                        console.warn("Lost connection to client. Trying to reconnect...");
                                        ConnectModbus();
                                    else console.warn("Error received reading address " + address + " from id: " + ModBusID + " with error: " + modbusErrorMessages[err.modbusCode]);
                                else
                                    console.debug("Read data from id/address " + ModBusID + "/" + address + "\nData is: " + data.data);
                                    for (var i = 0; i < length; i++) GlobalDataBuffer[address+i] = data.data[i];
                        PS: das {1} im hier angezeigten Code geht (nur) weg, wenn man ein Leerzeichen vor das "{" setzt.
                        S C 3 Antworten Letzte Antwort
                        • R R4
                          Top!
                              // try to connect
                                  .then(function()
                                  .catch(function(e)
                                      console.log(e);
                                  if (err)
                                          ConnectModbus();
                                  else
                          stoffel67
                          schrieb am zuletzt editiert von stoffel67
                          #205
                          hallo,
                          ich schaff's einfach nicht Register zu schreiben...
                          bekomme folgende Fehlermeldung:
                          2023-07-17 11:54:49.028
                          error
                          Error: Modbus exception 4: Slave device failure (device reports internal error) at ModbusRTU._onReceive (/opt/iobroker/node_modules/iobroker.javascript/node_modules/modbus-serial/index.js:430:21) at TcpPort.emit (node:events:512:28) at TcpPort.emit (node:domain:489:12) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/modbus-serial/ports/tcpport.js:93:24) at Socket.emit (node:events:512:28) at Socket.emit (node:domain:489:12) at addChunk (node:internal/streams/readable:324:12) at readableAddChunk (node:internal/streams/readable:297:9) at Socket.Readable.push (node:internal/streams/readable:234:10) at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
                          error
                          error
                          An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                          2023-07-17 11:54:48.640
                          error
                          Error: Modbus exception 6: Slave device busy (retry request again later) at ModbusRTU._onReceive (/opt/iobroker/node_modules/iobroker.javascript/node_modules/modbus-serial/index.js:430:21) at TcpPort.emit (node:events:512:28) at TcpPort.emit (node:domain:489:12) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/modbus-serial/ports/tcpport.js:93:24) at Socket.emit (node:events:512:28) at Socket.emit (node:domain:489:12) at addChunk (node:internal/streams/readable:324:12) at readableAddChunk (node:internal/streams/readable:297:9) at Socket.Readable.push (node:internal/streams/readable:234:10) at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
                          error
                          2023-07-17 11:54:48.639
                          error
                          2023-07-17 11:54:48.489
                          info
                          script.js.Photovoltaik.Huawei_mit_Batterie_V7: WriteRegister....
                          Scrip sieht so aus:
                                  processData();
                              if (triggerWriteProcessing == false) // read register (either read or write in one interval)
                                      currentinverter++
                                          triggerprocessing = 1;
                              else // triggerWriteProcessing == true --> write register
                                      console.log("WriteRegister....")
                                      var hBatt=getState("javascript.0.Solarpower.Huawei.Inverter.Battery.ChargeFromGridFunction").val;
                                      var hSOC= getState("javascript.0.Solarpower.Huawei.Inverter.Battery.GridChargeCutoffSOC").val*10;
                                      client.writeRegisters(47087, [0, hBatt]); //
                                      client.writeRegisters(47088, [0, hSOC]); //
                                      triggerWriteProcessing = false;
                          }, 6000);
                          ist das ein Zeitproblem..?
                          was bedeudet hier "Slave device busy"
                          • S stoffel67
                            hallo,
                            error
                            error
                            error
                            error
                            error
                            error
                            info
                            Scrip sieht so aus:
                                    processData();
                                        currentinverter++
                            }, 6000);
                            R4
                            #206
                            @stoffel67
                            jaaa, zweimal Zugriff hintereinander ohne Pause mag Huawei nicht..., dabei ist es egal ob Lesen oder Schreiben gemacht wird (beachte deine 2 einzelne Schreibzugriffe!).
                            // NÖ: client.writeRegisters(47087, [0, hBatt, 0, hSOC]);
                            // JA:
                            client.writeRegisters(47087, [hBatt, hSOC]);
                            könnte klappen (hBatt und hSOC müssen halt immer passen...)
                            PS: Das "triggerprocessing = 1;" kannst du gleich ersetzen durch "processData();"
                            PPS: Nicht ganz kapiert: Wenn processData() (direkt) vor dem Schreiben ausgeführt wurde werden "ChargeFromGridFunction" und "GridChargeCutoffSOC" ja von den aus dem WR ausgelesenen Daten verwendet (und gleich wieder so geschrieben) und nicht ggf. im Programmablauf geänderte Werte?!
                            • R R4
                              @stoffel67
                              // JA:
                              stoffel67
                              #207
                              @r4
                              stimmt denn die "0" jeweils... [0, hBatt, 0, hSOC]
                              hBatt ist entweder "0" oder "1" , hSOC ist ein Wert zwischen 0%-100%.
                              kann das dann funktionieren?
                              das Schreiben wird scheinbar direkt ausgeführt... hab es mit einem Wert
                              client.writeRegisters(43006, [120, 120]
                              client.writeRegisters(43006, [60, 60]
                              getestet..., es wurde dann immer der richtige Wert 60 bzw. 120 zurückgeliefert, daher ist mir das Array [0, hBatt, 0, hSOC]
                              nicht ganz klar...ist das nun "[AdressenOffset,Wert] oder [min.Wert,max.Wert]
                              • S stoffel67
                                @r4
                                R4
                                #208
                                @stoffel67
                                äh was?, bzw. nö!
                                https://github.com/yaacov/node-modbus-serial/blob/master/README.md
                                hab bei deinem Beispiel nicht bedacht, dass hier ja nur UINT16 angesprochen werden. Also muss es
                                sein.
                                Bsp:
                                client.writeRegisters(47087, [1, 550]);
                                setzt
                                javascript.0.Solarpower.Huawei.Inverter.Battery.ChargeFromGridFunction = 1
                                javascript.0.Solarpower.Huawei.Inverter.Battery.GridChargeCutoffSOC = 55%
                                Beachte, dass du jeweils 16 Bit Werte schreibst (die Zahlen in []) und pass trotzdem auf, wo du deine Werte herbekommst...
                                (mit
                                würdest du Register 47087 mit '0' beschreiben und Register 47088 mit 'hBatt')
                                • R R4
                                  Top!
                                      // try to connect
                                          .then(function()
                                          .catch(function(e)
                                              console.log(e);
                                          if (err)
                                                  ConnectModbus();
                                          else
                                  Chris_B
                                  #209
                                  @r4 Danke für die Tips. Ich schaue mir Deine Änderungen an und implementiere es dann. Das mit dem Leerzeichen vor "{" ist ja schon doof.
                                  Eine Frage:
                                  Meine Anlage ist erst 2 Monate in Betrieb. Hast Du Erfahrung, wie man die Batterie im Winter optimal betreibt? jetzt ladet die Batterie auch an einem relativ schlechten Tag meist auf 100%. Im Winter wird es dafür vermutlich nie reichen. Gibt es ein Forum in welchem ich Tips dazu erhalte?
                                  Ich veröffentliche später eine neue Version des Skript. Finde immer mehr Dinge, die verbessert werden sollten (unbenütze Variable etc.).
                                  • R R4
                                    Top!
                                        // try to connect
                                            .then(function()
                                            .catch(function(e)
                                                console.log(e);
                                            if (err)
                                                    ConnectModbus();
                                            else
                                    Chris_B
                                    #210
                                    @r4 Hallo - ich habe Deinen Vorschlag mit der Funktion ConnectModbus() ausprobiert. Prinzipiell funktioniert das natürlich... Aber: Bei mir kommt es hin und wieder zu Fehlern bei der Abfrage von Registern, das ist aber normalerweise nicht weiter schlimm. Nur führt die Abfrage von
                                    immer zu einem reconnect, obwohl dies eigentlich nicht nötig ist. Bist Du sicher, dass die Bedingung korrekt ist? Kennst Du die Rückgabewerte err.modbusCode?
                                    Gruss
                                    • M meloneA
                                      @road_runner31 evcc hätte einen modbus proxy, ich würde den vorschalten.
                                      svenomattS Offline
                                      svenomattS Offline
                                      svenomatt
                                      #211
                                      @melonea sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
                                      Moin zusammen, Kann mir jemand kurz erläutert wie ich den Modbus Proxy von evcc und das Script zusammen zum laufen bekomme.
                                      Würde gerne das Script und evcc zeitgleich laufen lassen.
                                      Gruß Sven
                                      • R Offline
                                        R4
                                        #212
                                        @chris_b
                                        hm, das ist bei mir nicht der Fall. In meinem Log gibt es immer mal
                                        javascript.0
                                        2023-07-18 08:20:13.481	warn	script.js.common.SUN2000.PV-Steuerung: Error received reading address 37100 from id: 1 with error: Slave device busy (retry request again later)
                                        aber ohne Reconnects. Die gibt es praktisch nur bei einem Neustart, bis er sich erfolgreich verbunden hat oder so zwei Mal am Tag auch zwischendurch, dann aber gerne gehäuft bis zu einer Minute lang:
                                        2023-07-17 03:42:13.496 - warn: javascript.0 (25837) script.js.common.SUN2000.PV-Steuerung: Lost connection to client. Trying to reconnect...
                                        2023-07-17 03:42:13.496 - info: javascript.0 (25837) script.js.common.SUN2000.PV-Steuerung: Init connection to: 192.168.0.111:502
                                        2023-07-17 03:42:13.497 - info: javascript.0 (25837) script.js.common.SUN2000.PV-Steuerung: Connected
                                        2023-07-17 03:42:15.493 - info: javascript.0 (25837) script.js.common.SUN2000.PV-Steuerung: ProcessData() 0 3 - PanelPower 0 - bCP 0 - SoC 55 - Loop 15
                                        2023-07-17 03:42:25.491 - warn: javascript.0 (25837) script.js.common.SUN2000.PV-Steuerung: Lost connection to client. Trying to reconnect...
                                        2023-07-17 03:42:25.492 - info: javascript.0 (25837) script.js.common.SUN2000.PV-Steuerung: Init connection to: 192.168.0.111:502
                                        2023-07-17 03:42:25.492 - info: javascript.0 (25837) script.js.common.SUN2000.PV-Steuerung: Connected
                                        2023-07-17 03:42:31.506 - info: javascript.0 (25837) script.js.common.SUN2000.PV-Steuerung: ProcessData() 0 3 - PanelPower 0 - bCP 0 - SoC 55 - Loop 16
                                        2023-07-17 03:42:37.508 - warn: javascript.0 (25837) script.js.common.SUN2000.PV-Steuerung: Lost connection to client. Trying to reconnect...
                                        Error Codes: https://www.simplymodbus.ca/exceptions.htm
                                        Batterie: Naja, kommt immer drauf an ;-)
                                        Wenn du natürlich schon im Sommer Schwierigkeiten hast sie voll zu bekommen wird das in der dunklen Jahreszeit nicht besser. Hört sich nach Fehlplanung an (sorry). (Ich hab knapp 17kWp und einen 5kWh Akku, und der ist schon "schöngerechnet", also fraglich ob er sich wirklich lohnt.)
                                        In dem Fall würde ich zumindest den Mindest-SoC nicht auf 0% belassen (>10%), das stresst den Akku am meisten, auch wenn Huawei da natürlich Vorkehrungen getroffen hat (der lädt sich dann auch mal selbst aus dem Netz auf ein selbstdefiniertes Minimum auf).
                                        Ein informatives Forum ist
                                        https://www.photovoltaikforum.com/thread/160098-what-s-up-huawei/
                                        • R R4
                                          @chris_b
                                          javascript.0
                                          Chris_B
                                          #213
                                          @r4 Danke für den Link zum Huawei Forum. Da kann ich suchen.
                                          Ich glaube nicht, dass es sich um eine Fehlplanung handelt. Ob es sich wirklich 'lohnt' ist eine berechtigte Frage. Ich habe nur 5kWp (kleines Flachdach) und 15 kWh Akku. Der wird an einem normalen Tag in der Sommerzeit locker gefüllt, pendelt zwischen 100% und ca. 60% bis 70% (am frühen Morgen des Folgetages). Ich komme also locker über die Nacht, und auch durch einen 'schlechten' Tag. Brauche ca. 10kWh pro Tag. Da ich im Winter viel weniger Sonne haben werde (auf Grund der Lage) erwarte ich, dass dann der Akku kaum geladen wird (ich habe eine Wärmepumpe als Heizung).
                                          Die Frage war genau, ob ich dann die Mindest SoC auf >0% setzen soll. Ich werde mal im Forum suchen.
