  4. Test Adapter MercedesMe v0.0.x
mercedes
1.0k Beiträge 122 Kommentatoren 363.2k Aufrufe 107 Beobachtet
  • R reddddich
    @tombox
    Kann es evtl. an node 18.x liegen?
    Ich habe bisher keinen Adapter der nicht läuft auf zwei RPi´s...
    2023-06-16 09:30:29.233 - info: host.raspberrypi2 "system.adapter.mercedesme.0" enabled
    2023-06-16 09:30:29.360 - info: host.raspberrypi2 instance system.adapter.mercedesme.0 started with pid 13244
    2023-06-16 09:30:31.331 - debug: mercedesme.0 (13244) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-06-16 09:30:31.402 - debug: mercedesme.0 (13244) Objects client ready ... initialize now
    2023-06-16 09:30:31.406 - debug: mercedesme.0 (13244) Objects create System PubSub Client
    2023-06-16 09:30:31.408 - debug: mercedesme.0 (13244) Objects create User PubSub Client
    2023-06-16 09:30:31.459 - debug: mercedesme.0 (13244) Objects client initialize lua scripts
    2023-06-16 09:30:31.468 - debug: mercedesme.0 (13244) Objects connected to redis: 127.0.0.1:9001
    2023-06-16 09:30:31.495 - debug: mercedesme.0 (13244) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-06-16 09:30:31.508 - debug: mercedesme.0 (13244) States create System PubSub Client
    2023-06-16 09:30:31.509 - debug: mercedesme.0 (13244) States create User PubSub Client
    2023-06-16 09:30:31.568 - debug: mercedesme.0 (13244) States connected to redis: 127.0.0.1:9000
    2023-06-16 09:30:31.673 - debug: mercedesme.0 (13244) Plugin sentry Initialize Plugin (enabled=true)
    2023-06-16 09:30:32.051 - info: mercedesme.0 (13244) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v18.16.0, js-controller: 4.0.24
    2023-06-16 09:30:32.212 - debug: mercedesme.0 (13244) Login
    2023-06-16 09:30:32.561 - error: mercedesme.0 (13244) Not able to request login code
    2023-06-16 09:30:32.563 - error: mercedesme.0 (13244) AxiosError: Request failed with status code 428
    2023-06-16 09:30:32.563 - error: mercedesme.0 (13244) ""
    2023-06-16 09:30:32.564 - error: mercedesme.0 (13244) Login was not successful.
    tombox
    #616
    @reddddich brauch ich den account zum testen
    R 1 Antwort Letzte Antwort
    • T tombox
      reddddich
      #617
      @tombox pm haste :) Danke
        k_b
        #618
        ich habe das Problem, dass ich keine Werte bei meinem EQA in den Objektbäumen "state" und "history" bekomme. Andere Bäume wie "user" sind komplett befüllt.
        Könnte mir jemand einen Tipp geben, wie ich zumindest zum SoC komme?
        Danke im voraus.
          ThePhantom79
          schrieb am zuletzt editiert von ThePhantom79
          #619
          ich habe iobroker als dicker erst mal nur für den mercedesme adapter installiert. (ich nutze knx / loxone / loxberry - und will die werte über MQTT an die anderen Systeme weiter leiten).
          Leider scheitere ich schon an der Einrichtung des Adapters:
          Installiert Version 0.1.1
          Mail-Adresse eingegeben und gespeichert
          PIN bekommen (!!! - nicht wie im Log steht, dass es nicht möglich war) und eingetragen , gespeichert.
          Danach startet der Adapter zwei mal neu, danach "Verbunden mit Host: grün, Lebenszeichen: Grün, Verbunden mit Gerät/Dienst: Rot"
          Im Log:
          mercedesme.0
          2023-06-28 14:36:28.860	error	Login was not successful.
          mercedesme.0
          2023-06-28 14:36:28.860	error	""
          mercedesme.0
          2023-06-28 14:36:28.860	error	AxiosError: Request failed with status code 429
          mercedesme.0
          2023-06-28 14:36:28.859	error	Not able to request login code
          mercedesme.0
          2023-06-28 14:36:28.535	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v18.16.1, js-controller: 4.0.24
          Hat jemand eine Idee?
          Edit: ES waren zu viele Anmeldeversuche, da ich anfangs was falsch gemacht hatte - nun gehts ...
          Ist nun vom Adpater her alles grün, aber ich bekomme keine Werte ausgelesen - habe ich etwas vergessen?
          Edit 2:
          Nur unter history sehe ich keine Daten ... In den anderen "Unterordnern" sind Wrete vorhanden, insbesondere habe ich die für mich interessanten Werte "Restreichweite Elektro" und "Restreichweite Diesel" gefunden.
          • K k_b
            Danke im voraus.
            turtle1987
            #620
            @k_b said in Test Adapter MercedesMe v0.0.x:
            Hast du da eine Lösung? Bei mir ist History zwar gefüllt aber state auch komplett leer.
            • WebrangerW Offline
              WebrangerW Offline
              Webranger
              #621
              Darf ich mal fragen wofür die Tankerkönik Api verwendet wird? Auf welche Daten greift die zurück um was auszurechnen oder anzuzeigen?
              Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
              • WebrangerW Webranger
                amg_666A Offline
                amg_666A Offline
                amg_666
                #622
                @webranger Schau auf Tankerkoenig.de nach, da ist das beschrieben.
                  WebrangerW Offline
                  Webranger
                  #623
                  Was hat tankerkönig mit dem Adapter zu tun?
                  Verstehe ich nicht was du damit sagen willst
                    tombox
                    #624
                    @webranger Er zeichnet deine Tankvorgänge auf mit Liter und Preis
                    FriedhofsblondF 1 Antwort Letzte Antwort
                    • T tombox
                      FriedhofsblondF Offline
                      Friedhofsblond
                      schrieb am zuletzt editiert von Friedhofsblond
                      #625
                      @tombox
                      Moin,
                      mir fehlt leider der komplette Kilometerstand (oder nicht gefunden?)
                      Oder mach ich was falsch??
                      Habe nur den Stand nach Reset ca. 29Tkm (beim Kauf schon 3TKm auf der Uhr)
                      Aber der andere Gesamtkilometer fehlt (ca. 32Tkm):
                      H 1 Antwort Letzte Antwort
                      • FriedhofsblondF Friedhofsblond
                        @tombox
                        Moin,
                        hssk
                        #626
                        @friedhofsblond Also bei mir ist der Gesamt-km-Stand im Ordner odo zu finden. Gruß
                        • H hssk
                          Friedhofsblond
                          #627
                          @hssk
                          Moin, ja stimmt sorry - und Danke :D
                          • B Online
                            B Online
                            bishop9191
                            #628
                            Kann ich bei meinem EQB den Zündungsstatus abfragen?
                            Bei "ignitionstate" tut sich nichts... Oder schaue ich falsch?
                              Amokd0c
                              #629
                              Servus!
                              kann es sein, dass der Dienst down ist?
                              Der Adapter ist verbunden, aber ich kann von der Couch mein Auto nicht zuschließen. Muss ich jetzt aufstehen, das kann es doch nicht sein! 😸
                                sruhsam
                                #630
                                habe eine GLC300e, Adapter funktioniert grundsätzlich (öffnen, schließen etc) Wie kann ich denn aber das Ladeprogramm ändern ?
                                z.b. würde ich gerne vom "Standard" Ladeprogramm in das "Zuhause" wechseln bzw. aktivieren und dort den Max. Ladezustand auf 80% ändern.
                                sehe unter "state.chargePrograms.chargeProgramsValue" nur die eingestellten Werte, kann diese aber nicht ändern/schreiben.
                                Gruß Stephan
                                  tombox
                                  #631
                                  @sruhsam Du kannst nur ändern was unter commands steht und was in der App geht
                                  • T tombox
                                    sruhsam
                                    #632
                                    @tombox
                                    Danke für die Antwort.
                                    In der mercedes me App ist dies natürlich möglich, deshalb versuche ich es ja über den Adapter zu steuern.
                                    im Verzeichnis command stehen ja ganz viele Verzeichnisse, deshalb meine Frage, ob das jemand weis, welcher State hier wie verändert werden muss.
                                    wenn ich diesen auf true setze, wird immer das Standard (default)-Charge-Programm ausgewählt, ich möchte nun aber in das Zuhause (Home) Charge-Program wechseln.
                                    mercedesme.0.W1NKM5GB7PU034353.commands.CHARGE_PROGRAM_CONFIGURE.start
                                    Es geht eigentlich um diesen State:
                                    mercedesme.0.<FIN>.state.chargePrograms.chargeProgramsValue
                                    weis aber wie beschrieben nicht welcher das im Verzeichnis Command ist.
                                    Ich bin mal alle beschreibbaren States durchgegangen, hatte aber leider nichts gefunden und nur probieren möchte ich eigentlich nicht.
                                    Ich dachte hier im Forum Hilfe zu finden.
                                    Vielleicht gibt es auch eine andere Möglichkeit diese State in einem script anzusprechen bzw. zu verändern. bin für jede Hilfe offen.
                                    Stephan
                                    • S sruhsam
                                      @tombox
                                      Stephan
                                      #633
                                      bitte löschen
                                      • H Offline
                                        hssk
                                        #634
                                        suche in den Objekten die Batteriegröße (EQ-Modell). Leider bisher erfolglos.
                                        Hat jemand einen Tipp ob bzw. wo diese Information zu finden ist?
                                        Danke für euren support.
                                        C 1 Antwort Letzte Antwort
                                        • H hssk
                                          CrazyFloyd
                                          #635
                                          Habe heute den Adapter mal installiert. Alles klappt soweit mit dem Login bei Mercedes Me und der Adapter wird auch grün. Leider meldet mir das Log das er keine Fahrzeuge findet und dementsprechend werden auch keine States erzeugt.
                                          Hat irgend jemand einen Tip für mich ???
