  3. Off Topic
  4. InfluxDB
  5. InfluxDB 2 BackItUp Error
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
40 Beiträge 8 Kommentatoren 3.6k Aufrufe 5 Beobachtet
  • DJMarc75D DJMarc75
    @fredi009sg
    so kommt man hier nicht voran.
    Zeig mal bitte die Ausgabe (Langfassung) von
    iob diag
    hier in Codetags.
    Und lies Dir auch erstmal folgendes durch, als Neuling hier im Forum:
    Fredi009sgF Offline
    Fredi009sgF Offline
    Fredi009sg
    @djmarc75 said in InfluxDB 2 BackItUp Error:
    @fredi009sg
    iob diag
    hier in Codetags.
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     15:33:55 up 54 min,  3 users,  load average: 2.06, 1.83, 1.85
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=65.7'C
    volt=0.8438V
    *** Time and Time Zones ***
                   Local time: Thu 2023-07-13 15:33:55 CEST
               Universal time: Thu 2023-07-13 13:33:55 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        1.0G        578M        390M        2.2G        2.3G
    Swap:           1.0G        888M        135M
    Total:          4.8G        1.9G        714M
             3793 M total memory
             1014 M used memory
             1829 M active memory
              880 M inactive memory
              579 M free memory
                3 M buffer memory
             2195 M swap cache
             1023 M total swap
              888 M used swap
              135 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      118G   22G   91G  19% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G  260M  1.6G  14% /dev/shm
    tmpfs          tmpfs     759M  1.4M  758M   1% /run
    /dev/loop0     squashfs  105M  105M     0 100% /snap/core/15425
    /dev/loop1     squashfs  105M  105M     0 100% /snap/core/15515
    /dev/loop2     squashfs   60M   60M     0 100% /snap/core20/1953
    /dev/loop3     squashfs   60M   60M     0 100% /snap/core20/1977
    /dev/loop4     squashfs  2.2M  2.2M     0 100% /snap/modem-manager/524
    /dev/loop5     squashfs  2.2M  2.2M     0 100% /snap/modem-manager/490
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     380M   24K  380M   1% /run/user/1000
    [Thu Jul 13 14:39:54 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 video=HDMI-A-2:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:BA:49:88 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=bb9f1717-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Jul 13 14:39:56 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Jul 13 14:39:56 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Thu Jul 13 14:39:58 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET                    SOURCE     FSTYPE   OPTIONS
    /                         /dev/sda2  ext4     rw,noatime
    |-/snap/core/15425        /dev/loop0 squashfs ro,nodev,relatime,errors=continue
    |-/snap/core/15515        /dev/loop1 squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/1953       /dev/loop2 squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/1977       /dev/loop3 squashfs ro,nodev,relatime,errors=continue
    |-/snap/modem-manager/524 /dev/loop4 squashfs ro,nodev,relatime,errors=continue
    |-/snap/modem-manager/490 /dev/loop5 squashfs ro,nodev,relatime,errors=continue
    `-/boot                   /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    11G     /var/
    5.1G    /var/log
    3.8G    /var/log/journal/ea825a1e4f9840ffafb11a3068c2f00a
    2.8G    /var/lib
    Archived and active journals take up 3.7G in the file system.
    /opt/iobroker/backups:
    113M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    412M    /opt/iobroker/iobroker-data/
    287M    /opt/iobroker/iobroker-data/files
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    67M     /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/echarts
    32M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.1
    /usr/bin/node           v16.20.1
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    nodejs:
      Installed: 16.20.1-deb-1nodesource1
      Candidate: 16.20.1-deb-1nodesource1
      Version table:
     *** 16.20.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   0
    Adapter State
    + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 8080
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.openligadb.0             : openligadb            : raspberrypi                              - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              - disabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      system.adapter.sql.0                    : sql                   : raspberrypi                              - disabled, port: 3306
    + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "denon"        : 1.15.2   , installed 1.15.2
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Objects and States
    Objects:        2966
    States:         2690
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 https://repos.influxdata.com/debian bullseye InRelease
    Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:6 https://download.docker.com/linux/debian bullseye InRelease
    Hit:7 http://deb.debian.org/debian bullseye-backports InRelease
    Hit:8 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:9 https://apt.grafana.com stable InRelease
    Hit:10 https://phoscon.de/apt/deconz bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:56433           0.0.0.0:*               LISTEN      107        15967      1029/rpc.statd
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       15616      443/deCONZ
    tcp        0      0 0.0.0.0:2000            0.0.0.0:*               LISTEN      0          17014      1432/docker-proxy
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14991      659/vncserver-x11-c
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       28079      1924/node-red
    tcp        0      0 0.0.0.0:8383            0.0.0.0:*               LISTEN      1000       24162      2407/electron.js
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13797      662/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17840      995/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19669      995/iobroker.js-con
    tcp        0      0 0.0.0.0:43061           0.0.0.0:*               LISTEN      1001       27906      2436/io.yahka.1
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          13843      689/nginx: master p
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          832        1/init
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15018      443/deCONZ
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14959      642/cupsd
    tcp6       0      0 :::40627                :::*                    LISTEN      107        15971      1029/rpc.statd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19789      1789/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25235      2424/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        61310      13292/influxd
    tcp6       0      0 :::2000                 :::*                    LISTEN      0          17019      1440/docker-proxy
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          14990      659/vncserver-x11-c
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14958      642/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13799      662/sshd: /usr/sbin
    tcp6       0      0 :::80                   :::*                    LISTEN      0          13844      689/nginx: master p
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1165       1/init
    tcp6       0      0 :::9115                 :::*                    LISTEN      117        1613       454/prometheus-blac
    tcp6       0      0 :::3000                 :::*                    LISTEN      116        17879      993/grafana
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       19253      2335/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       19251      2335/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       19248      2335/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       2039       443/deCONZ
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13932      982/dhcpcd
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11955      1/init
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14981      676/cups-browsed
    udp        0      0 127.0.0.1:781           0.0.0.0:*                           0          15961      1029/rpc.statd
    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       23036      2602/index.html#Hom
    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       23034      2602/index.html#Hom
    udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       23032      2602/index.html#Hom
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1917       439/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20313      1982/io.shelly.0
    udp        0      0 0.0.0.0:40564           0.0.0.0:*                           108        1919       439/avahi-daemon: r
    udp        0      0 0.0.0.0:34445           0.0.0.0:*                           107        15965      1029/rpc.statd
    udp6       0      0 :::1900                 :::*                                1001       19254      2335/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       19252      2335/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       19250      2335/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       19249      2335/io.deconz.0
    udp6       0      0 :::55184                :::*                                107        15969      1029/rpc.statd
    udp6       0      0 :::47167                :::*                                108        1920       439/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          1168       1/init
    udp6       0      0 :::546                  :::*                                0          13948      982/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        1918       439/avahi-daemon: r
    2023-07-13 15:28:00.037  - info: javascript.0 (1812) script.js.common.Vis_aktualisieren: Vis aktualisiert
    2023-07-13 15:30:00.041  - info: javascript.0 (1812) script.js.common.Vis_aktualisieren: Vis aktualisiert
    2023-07-13 15:30:00.225  - info: web.0 (2424) <== Disconnect system.user.admin from ::ffff:192.168.160.37 vis.0
    2023-07-13 15:30:02.936  - info: web.0 (2424) ==> Connected system.user.admin from ::ffff:192.168.160.37
    2023-07-13 15:32:00.049  - info: javascript.0 (1812) script.js.common.Vis_aktualisieren: Vis aktualisiert
    2023-07-13 15:34:00.028  - info: javascript.0 (1812) script.js.common.Vis_aktualisieren: Vis aktualisiert
    2023-07-13 15:34:00.410  - info: web.0 (2424) <== Disconnect system.user.admin from ::ffff:192.168.160.37 vis.0
    2023-07-13 15:34:03.274  - info: web.0 (2424) ==> Connected system.user.admin from ::ffff:192.168.160.37
    **MOD-EDIT: Code in code-tags gesetzt!``
    • Fredi009sgF Fredi009sg
      @fredi009sg
      iob diag
      hier in Codetags.
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=65.7'C
      volt=0.8438V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               3793 M total memory
               1014 M used memory
                579 M free memory
                  3 M buffer memory
               2195 M swap cache
               1023 M total swap
                888 M used swap
                135 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      11G     /var/
      5.1G    /var/log
      2.8G    /var/lib
      /usr/bin/npm            8.19.4
      /usr/bin/npx            8.19.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        2966
      States:         2690
      Pending Updates: 0
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @fredi009sg in CODETAGS einsetzen bitte.
      wie das geht steht alles hier drin
      Lehrling seit 1975 !!!
      • Fredi009sgF Offline
        Fredi009sgF Offline
        Fredi009sg
        schrieb am zuletzt editiert von Fredi009sg
        Über den Befehl sudo systemctl status influxdb sehe ich, dass der Service läuft und ich kann über die Webseite die Einrichtung starten.
        Weiterhin kann ich aber über influx setup diese nicht starten.
        Grundsätzlich brauche ich einen Token für BackItUp.
        pi@raspberrypi:~ $ sudo systemctl status influxdb
        ```influxdb.service - InfluxDB is an open-source, distributed, time series database
             Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
             Active: active (running) since Thu 2023-07-13 15:10:47 CEST; 29min ago
               Docs: https://docs.influxdata.com/influxdb/
            Process: 13291 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
           Main PID: 13292 (influxd)
              Tasks: 9 (limit: 3932)
                CPU: 5.189s
             CGroup: /system.slice/influxdb.service
                     └─13292 /usr/bin/influxd
        Jul 13 15:25:20 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:25:20.630612Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
        Jul 13 15:25:30 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:25:30.639551Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
        Jul 13 15:25:40 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:25:40.649854Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
        Jul 13 15:25:50 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:25:50.658906Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
        Jul 13 15:26:00 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:26:00.667691Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
        Jul 13 15:26:10 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:26:10.676095Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
        Jul 13 15:26:20 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:26:20.699380Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
        Jul 13 15:26:30 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:26:30.708714Z lvl=info msg=Unauthorized log_id=0i~qr3v0000 error="authorization not found"
        Jul 13 15:40:47 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:40:47.226212Z lvl=info msg="Retention policy deletion check (start)" log_id=0i~qr3v0000 service=retentio>
        Jul 13 15:40:47 raspberrypi influxd-systemd-start.sh[13292]: ts=2023-07-13T13:40:47.227493Z lvl=info msg="Retention policy deletion check (end)" log_id=0i~qr3v0000 service=retention >
          @djmarc75 sagte in InfluxDB 2 BackItUp Error:
          die sind doch im Output drin, wenn man sie nicht rausoperiert
                    CPU: 5.189s
            TT-Tom
            @fredi009sg
            Warum richtest du sie nicht über Website ein? Da bekommst du auch den Token für Backitup bzw. den Influx Adapter.
            Welche Version von Influx hast du installiert??
            Hast du die influx-cli installiert???
            Gruß Tom
            Public Transport
            NSPanel Adapter Wiki
              Ich habe jetzt nochmal komplett deinstalliert und über die YT Anleitung von Eddy ( https://youtu.be/abV4YRHXb5I ) installiert.
              Über die Webadresse könnte ich jetzt die Konfiguration druchführen.
              Wenn ich aber in putty influx setup eingeben bekomme ich folgenden fehler.
              pi@raspberrypi:~ $ influx setup
              -bash: /usr/local/bin/influx: Kann die Binärdatei nicht ausführen: Fehler im Format der Programmdatei
              @fredi009sg sagte in InfluxDB 2 BackItUp Error:
              Moin,
              Du hast schlicht und ergreifend die falsche Binär Datei installiert, eine die nicht für Dein Raspi ist.
              sudo file /usr/local/bin/influx*
              Da kommt dann eine Ausgabe, die Dir sagt, für welche CPU Architektur diese Datei ist.
              Da Du zwei Pakete brauchst, einmal den Datenbankmanager influxd und einmal den Client, zum Backup machen influx, hast Du die richtige Architektur des Datenbankmanagers genommen und die falsche für den Client.
              Beispiel
              $ file /usr/bin/influx*
              /usr/bin/influx:  ELF 64-bit LSB pie executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=2bc954d6fdfb7d16de125fd391a386f4918b3bbe, for GNU/Linux 4.4.0, stripped
              /usr/bin/influxd: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=8f3719307508ee5ed2625282f0922e3facd89b60, for GNU/Linux 4.4.0, stripped
              Aber ist eh Jacke, wie Hose, Du solltest das richtig über die Repositories installieren.
              Wie man das macht, steht auf der Seite https://docs.influxdata.com/influxdb/v2.2/install/?t=Linux
              Bernd
              Fredi009sgF 1 Antwort Letzte Antwort
                Moin,
                Beispiel
                Bernd
                Fredi009sgF Offline
                Fredi009sgF Offline
                Fredi009sg
                @dp20eic
                pi@raspberrypi:~ $ sudo file /usr/local/bin/influx*
                /usr/local/bin/influx: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), statically linked, Go BuildID=UoS6lY0ZS2TNiFP4F4pw/FR2nKxI-_h3dLdH57lkL/Bry0DcDVLmxJGEisd1QF/qlYlrt6ezD9nJOXQdXED, stripped
                Thomas BraunT ? 2 Antworten Letzte Antwort
                  @dp20eic
                  x86-64
                  Passt halt nicht zu deinem ARM-Rechner.
                  Das ganze Ding ist total schräg, aus meiner Sicht.
                    @dp20eic
                    Moin,
                    wie gesagt, das ist für eine Intel/AMD CPU und nicht für
                    ** BASE SYSTEM ***
                    Erkennst Du den Unterschied?
                    Bernd
                      x86-64
                      @thomas-braun sagte in InfluxDB 2 BackItUp Error:
                      x86-64
                      Moin,
                      Jup, sehe ich auch so, und wieder nach YT, da schaut man nicht wie alt der Quatsch ist, sonder macht einfach drauf los.
                      @Fredi009sg
                      Hast Du schon viel mit influxDB gemacht? Also schon viele Daten erfasst?
                      Du musst uns genau sagen welche Befehle Du genutzt hast um das zu Installieren, dann kann man Dir helfen das zurückzubauen.
                      Ansonsten, Backup und von ganz vorne, dann aber sauber aufsetzen und Backup zurückspielen. <- Habe gelernt, dass das meist die bessere Variante ist :)
                      Bernd
                        x86-64
                        Moin,
                        @Fredi009sg
                        Bernd
                        Fredi009sgF Offline
                        Fredi009sgF Offline
                        Fredi009sg
                        @dp20eic said in InfluxDB 2 BackItUp Error:
                        x86-64
                        Moin,
                        @Fredi009sg
                        Bernd
                        Ich habe anfänglich die Quelle von InfluxDB benutzt. Meine Vermutung ist gerade das ich versehentlich die falsche Version gewählt habe.
                        Was ich mich jetzt allerdings Frage ist, wenn ich es über sudo apt install installiert er immer diese Version. Kann es seine, dass ich hier zufällig die falsche Quelle hinterlegt habe.
                        • Thomas BraunT Online
                          Welche Version und welche Quelle?
                          sudo apt update
                          apt policy influxdb*
                            sudo apt update
                            Fredi009sgF Offline
                            Fredi009sgF Offline
                            Fredi009sg
                            wenn ich jetzt sudo apt install influxdb2 eingebe wird folgendes installiert:
                            pi@raspberrypi:~ $ sudo apt install influxdb2
                            Die folgenden zusätzlichen Pakete werden installiert:
                              influxdb2-cli
                            Die folgenden NEUEN Pakete werden installiert:
                              influxdb2 influxdb2-cli
                            0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                            Es müssen noch 0 B von 54,5 MB an Archiven heruntergeladen werden.
                            Nach dieser Operation werden 123 MB Plattenplatz zusätzlich benutzt.
                            Möchten Sie fortfahren? [J/n] y
                            Vormals nicht ausgewähltes Paket influxdb2 wird gewählt.
                            (Lese Datenbank ... 131343 Dateien und Verzeichnisse sind derzeit installiert.)
                            Vorbereitung zum Entpacken von .../influxdb2_2.7.1-1_arm64.deb ...
                            Entpacken von influxdb2 (2.7.1-1) ...
                            Vormals nicht ausgewähltes Paket influxdb2-cli wird gewählt.
                            Vorbereitung zum Entpacken von .../influxdb2-cli_2.7.3-1_arm64.deb ...
                            Entpacken von influxdb2-cli (2.7.3-1) ...
                            influxdb2 (2.7.1-1) wird eingerichtet ...
                            Config file /etc/influxdb/config.toml already exists, writing defaults to /etc/influxdb/config.toml.defaults
                            influxdb2-cli (2.7.3-1) wird eingerichtet ...
                            Bei apt policy influxdb*
                            pi@raspberrypi:~ $ apt policy influxdb*
                            N: Paket influxdb2-2.7.0.aarch64.rpm kann nicht gefunden werden.
                            N: Mittels des Musters »influxdb2-2.7.0.aarch64.rpm« konnte kein Paket gefunden werden.
                                influxdb2-cli
                              @fredi009sg
                              Lösch das rpm-Paket, das da so unnütz in der Gegend herumliegt.
                              rm influxdb2-2.7.0.aarch64.rpm
                              sudo apt update
                                @fredi009sg
                                sudo apt update
                                Fredi009sgF Offline
                                Fredi009sgF Offline
                                Fredi009sg
                                jetzt bekomme ich folgendes
                                pi@raspberrypi:~ $ sudo apt update
                                OK:1 http://deb.debian.org/debian bullseye InRelease
                                OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                                OK:3 http://deb.debian.org/debian bullseye-backports InRelease
                                OK:4 http://security.debian.org/debian-security bullseye-security InRelease
                                OK:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                OK:6 https://phoscon.de/apt/deconz bullseye InRelease
                                OK:7 https://download.docker.com/linux/debian bullseye InRelease
                                OK:8 https://deb.nodesource.com/node_16.x bullseye InRelease
                                OK:9 https://repos.influxdata.com/debian stable InRelease
                                OK:10 https://apt.grafana.com stable InRelease
                                Alle Pakete sind aktuell.
                                influxdb2-cli:
                                  Installiert:           (keine)
                                  Installationskandidat: 2.7.3-1
                                  Versionstabelle:
                                     2.7.3-1 500
                                        500 https://repos.influxdata.com/debian stable/main arm64 Packages
                                     2.7.1-2 500
                                     2.6.1 500
                                     2.6.0 500
                                     2.5.0 500
                                     2.4.0 500
                                     2.3.0 500
                                influxdb-client:
                                  Installationskandidat: 1.6.7~rc0-1+b5
                                  Versionstabelle:
                                     1.6.7~rc0-1+b5 500
                                influxdb-dev:
                                  Installationskandidat: (keine)
                                  Versionstabelle:
                                influxdb2-client:
                                  Installationskandidat: 2.7.1-1
                                  Versionstabelle:
                                     2.7.1-1 500
                                influxdb:
                                  Installationskandidat: 1.8.10-1
                                  Versionstabelle:
                                     1.8.10-1 500
                                     1.6.7~rc0-1+b5 500
                                influxdb2:
                                  Versionstabelle:
                                     2.7.1-1 500
                                     2.7.0-1 500
                                     2.6.1-1 500
                                     2.6.0-1 500
                                     2.5.1-1 500
                                     2.4.0-1 500
                                     2.3.0-1 500
                                     2.2.0 500
                                  influxdb2-cli:
                                    Versionstabelle:
                                       2.7.3-1 500
                                       2.7.1-2 500
                                       2.6.1 500
                                       2.6.0 500
                                       2.5.0 500
                                       2.4.0 500
                                       2.3.0 500
                                  influxdb-client:
                                    Versionstabelle:
                                       1.6.7~rc0-1+b5 500
                                  influxdb-dev:
                                    Versionstabelle:
                                  influxdb2-client:
                                    Versionstabelle:
                                       2.7.1-1 500
                                  influxdb:
                                    Versionstabelle:
                                       1.8.10-1 500
                                       1.6.7~rc0-1+b5 500
                                  influxdb2:
                                    Versionstabelle:
                                       2.7.1-1 500
                                       2.7.0-1 500
                                       2.6.1-1 500
                                       2.6.0-1 500
                                       2.5.1-1 500
                                       2.4.0-1 500
                                       2.3.0-1 500
                                       2.2.0 500
                                  @fredi009sg
                                  Das ist nicht richtig über den Paketmanager installiert sondern 'irgendwie ins System geprügelt' worden.
                                    @fredi009sg
                                    Fredi009sgF Offline
                                    Fredi009sgF Offline
                                    Fredi009sg
                                    Eine Idee wie ich es rückgängig machen kann ?
                                      @fredi009sg
                                      Den ganzen Summs so wie der reingeballert worden ist auch wieder rauskratzen.
                                      Da haste aber auch irgendwie alles mal versucht reinzuschrauben...
                                      rpm-Pakete, x386-Pakete...
                                        @fredi009sg
                                        sudo apt install --reinstall influxdb2
                                          @fredi009sg
                                          Fredi009sgF Offline
                                          Fredi009sgF Offline
                                          Fredi009sg
                                          pi@raspberrypi:/ $ apt policy influxdb*
                                          influxdb2-cli:
                                            Versionstabelle:
                                               2.7.3-1 500
                                               2.7.1-2 500
                                               2.6.1 500
                                               2.6.0 500
                                               2.5.0 500
                                               2.4.0 500
                                               2.3.0 500
                                          influxdb-client:
                                            Versionstabelle:
                                               1.6.7~rc0-1+b5 500
                                          influxdb-dev:
                                            Versionstabelle:
                                          influxdb2-client:
                                            Versionstabelle:
                                               2.7.1-1 500
                                          influxdb:
                                            Versionstabelle:
                                               1.8.10-1 500
                                               1.6.7~rc0-1+b5 500
                                          influxdb2:
                                            Versionstabelle:
                                               2.7.1-1 500
                                               2.7.0-1 500
                                               2.6.1-1 500
                                               2.6.0-1 500
                                               2.5.1-1 500
                                               2.4.0-1 500
                                               2.3.0-1 500
                                               2.2.0 500
                                          pi@raspberrypi:/ $ sudo apt install influxdb2
                                            influxdb2-cli
                                          pi@raspberrypi:/ $ sudo service influxdb start
                                          pi@raspberrypi:/ $ sudo service influxdb status
                                          ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                                               Active: active (running) since Thu 2023-07-13 23:00:52 CEST; 5s ago
                                              Process: 19554 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCES>
                                             Main PID: 19555 (influxd)
                                                  CPU: 2.379s
                                                       └─19555 /usr/bin/influxd
                                          Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.384409Z lvl=info msg="Sta>
                                          Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.385799Z lvl=info msg="Sta>
                                          Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.392937Z lvl=info msg="Sta>
                                          Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.421800Z lvl=info msg="Con>
                                          Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.454517Z lvl=info msg=Star>
                                          Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19555]: ts=2023-07-13T21:00:52.456480Z lvl=info msg=List>
                                          Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19572]: Command "print-config" is deprecated, use the in>
                                          Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19583]: Command "print-config" is deprecated, use the in>
                                          Jul 13 23:00:52 raspberrypi influxd-systemd-start.sh[19554]: InfluxDB started
                                          Jul 13 23:00:52 raspberrypi systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
                                          pi@raspberrypi:/ $ influx setup
