  3. Off Topic
  4. Raspberry / Influx / Grafana - apt update raised NO_PUBKEY
    2.0k
    2.5k
7 Beiträge 3 Kommentatoren 478 Aufrufe 3 Beobachtet
  • mcm1957M Online
    mcm1957M Online
    mcm1957
    Kann mir einer von euch helfen?
    Ich versuche (endlich) mal wieder meinen Pi$ zu aktualisiseren.
    Leider gibt es Probleme mit ein paar repositories:
    pi@pi4:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
    Get:4 https://repos.influxdata.com/debian stretch InRelease [7,039 B]
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Get:6 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
    Err:4 https://repos.influxdata.com/debian stretch InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Err:6 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    Fetched 7,039 B in 2s (4,364 B/s)
    Reading package lists... Done
    193 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Kann mir da wer helfen?
    Und ist bullseye überhaupt noch aktuell / supported oder bin ich da schon am Abstellgleis?
    Mehr Infos gerne - bitte nur um kurze Anweisung wie ich die ggF abfrage.
    Danke euch
    McM1957
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    mcm1957M haus-automatisierungH 2 Antworten Letzte Antwort
    • mcm1957M mcm1957
      Danke euch
      McM1957
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @mcm57
      Upss - grad im ioBroker Forum ne Info dazu gefunden:
      https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
      Wartet mal mit Aufwand - ich arbeit den Thread mal ab.
      Siehe auch:
      https://grafana.com/blog/2023/01/12/grafana-labs-update-regarding-circleci-security-updates/
      https://www.influxdata.com/blog/linux-package-signing-key-rotation/
      • mcm1957M mcm1957
        Danke euch
        McM1957
        haus-automatisierungH Online
        @mcm57 Deine Paketquellen sind ziemlich durcheinander. Du holst einige Sachen für stretch (das ist ja uralt!), andere für bullseye... zieh das doch gerade und mach direkt ein upgrade auf bookworm :)
        Node 14 ist jetzt auch nicht mehr aktuell. Direkt auf 18 gehen.
        Hier geht's lang:
        • https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
        • https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          Hier geht's lang:
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @haus-automatisierung
          Ja node update war das Ziel. Vorher wollte ich nur alles andere bereinigen.
          Frag mich allerdings wieso meine Quellen durcheinander sind. Hab das siche rnix manuell editiert ...
          Wie zieh ich dass denn gerade ? (Sorry für die ev. blöde Frage)
          Egal.
          Ich check mal deine Links.
          Bezüglich bookworm wart ich noch da es derzeit bekannte Probleme mit node20 / bookworm und einigen Adaptern gibt. Da ist noch nicht geklärt was eigentlich klemmt. Klar ist nur, dass bookworm, node 20 und request package mitspielt. (Betrifft z.B. TR-064, influxdb und netatmo). Node upgrade(s) auf node 18 steht am Plan
          • mcm1957M mcm1957
            Egal.
            @mcm57 sagte in Raspberry / Influx / Grafana - apt update raised NO_PUBKEY:
            Die apt sources korrigieren. Wahrscheinlich hast Du die Dateien unter /etc/apt/sources.list.d/ mal vergessen und dann ist das auseinander gelaufen.
              mcm1957M Online
              mcm1957M Online
              mcm1957
              DANKE
              • mcm1957M mcm1957
                DANKE
                @mcm57
                steht so falsch in einer Datei in /etc/apt/sources.list.d/influx* drin.
                Da du die aber am besten ohnehin im Zuge der Umstellung auf das aktuelle Signierverfahren anpackst (löschst) erledigt sich das von alleine.
                So ganz allgemein würde ich DRINGEND empfehlen das System in Gänze aktuell zu halten. Die notwendigen Änderungen bei grafana und influx sind bereits seit Monaten in der Meldung von apt enthalten und dann stauen sich da auch nicht 193 packages can be upgraded auf.
                83.2k
