  4. Fehler mit serial Port und Zigbee
56 Beiträge 4 Kommentatoren 6.2k Aufrufe 3 Beobachtet
  • F firestone
    sudo apt update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Ign:6 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.6 InRelease
    Get:7 http://ftp.nl.debian.org/debian bullseye InRelease [116 kB]
    Get:8 https://repos.influxdata.com/debian stable InRelease [6,892 B]
    Hit:9 https://deb.nodesource.com/node_16.x bullseye InRelease
    Get:10 https://packages.grafana.com/enterprise/deb stable InRelease [5,983 B]
    Hit:11 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.6 Release
    Err:8 https://repos.influxdata.com/debian stable InRelease
     The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Err:10 https://packages.grafana.com/enterprise/deb stable InRelease
     The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    Get:12 http://ftp.nl.debian.org/debian bullseye/main armhf Packages [7,949 kB]
    Get:14 http://ftp.nl.debian.org/debian bullseye/main arm64 Packages [8,071 kB]
    Get:15 http://ftp.nl.debian.org/debian bullseye/main Translation-en [6,240 kB]
    Fetched 22.4 MB in 12s (1,809 kB/s)
    Reading package lists... Done
    13 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    mickymM Offline
    mickymM Offline
    mickym
    @firestone Liest eigentlich niemand mal das Eingangsposting komplett?
    Also führ halt die Befehle mit den Keys aus, die bei Dir angemeckert werden.
    F Thomas BraunT 2 Antworten Letzte Antwort
    • mickymM mickym
      firestone
      @mickym sorry, ich sagte ja ich kenne mich nicht gut aus, deshalb verstehe ich das nicht wirklich, was du schreibst.
      • Thomas BraunT Online
        @firestone sagte in Fehler mit serial Port und Zigbee:
        Ist mit Sicherheit auch falsch. Das ist eine Quelle für ubuntu xenial. Also falsch und veraltet.
        Wenn mongodb eingesetzt wird, passe die Quelle an, wenn nicht schmeiß die Datei raus.
        • mickymM mickym
          https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
          Im weiteren gibt es in dem Thread auch noch was zum influxdb-Repo
          • F firestone
            mickymM Offline
            mickymM Offline
            mickym
            Na ich habe es aber eigentlich so geschrieben, dass man es eigentlich nur durchführen muss. Vielleicht kannst Du mir ja helfen, es noch verständlicher zu schreiben.
            Das ist eigentlich mein Anliegen, weil ich mit dem Beitrag ja helfen wollte.
            Aber ich halte mich wieder raus - bei @Thomas-Braun bist Du in guten Händen.
            F 1 Antwort Letzte Antwort
            • mickymM mickym
              firestone
              @mickym
              ich verstehe dich so, dass ich jetzt folgendes ausführen müsste, ist das korrekt?
              sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys D8FF8E1F7DF8B07E
              sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9E439B102CF3C0C6
              sudo apt update
              • F firestone
                @mickym
                sudo apt update
                mickymM Offline
                mickymM Offline
                mickym
                @firestone Genau! 👍 - Dann hab ich mich ja doch nicht zu missverständlich ausgedrückt. :)
                • mickymM mickym
                  firestone
                  @mickym
                  hast du nicht, wenn dann liegt das an mir :-)
                  hat er auch ausgeführt, aber die Warnungen bleiben:
                  • F firestone
                    @mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @firestone das hat aber mit dem eigentlichen Problem nichts zu tun. Hier gehts um Influx und da hat @Thomas-Braun einen Thread erstellt, in dem beschrieben wird,
                    Führ halt mal die Befehle aus, die zur Influx DB aufgeführt sind:
                    https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                    • mickymM mickym
                      firestone
                      @mickym
                      für Grafana hat das funktioniert, der Fehler ist weg. Für Influx leider nicht.
                      Vielleicht lösche ich das ganze VIS mit Grafana und Influx einfach wieder, dann brauche ich das nicht.
                      • F firestone
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @firestone Wie gesagt Du musst mal Deine anderen Ressourcen bereinigen. Ich hab nicht den ganzen Thread verfolgt. Wenn Du ein Backup von der Influx DB hast, kannst ja dann wenn Du die Befehle ausgeführt hast die Influx von Deinem System runter zu schmeissen und neu zu installieren.Ich weiss ja nicht mal welche Version von Influx Du nutzt.
                          @firestone
                          ls -lAh /etc/apt/sources.list.d/
                          sagt?
                          • F Offline
                            firestone
                            @thomas-braun said in Fehler mit serial Port und Zigbee:
                            total 28K
                            -rw-r--r-- 1 root root  92 Jul  2 21:13 bullseye-proposed-updates.list
                            -rw-r--r-- 1 root root  50 Jul  2 21:57 glennr-install-script.list
                            -rw-r--r-- 1 root root  84 Jul  2 22:39 grafana.list
                            -rw-r--r-- 1 root root 114 Jul  2 22:40 influxdata.list
                            -rw-r--r-- 1 root root  95 Aug 30  2022 mongodb-org-3.6.list
                            -rw-r--r-- 1 root root 208 Aug 30  2022 nodesource.list
                            -rw-r--r-- 1 root root 191 Apr  4  2022 raspi.list
                            • F firestone
                              total 28K
                              @firestone
                              sudo apt update
                                @firestone
                                sudo apt update
                                firestone
                                sudo apt update
                                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:2 http://deb.debian.org/debian bullseye InRelease
                                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                                Hit:5 http://ftp.nl.debian.org/debian bullseye InRelease
                                Get:6 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
                                Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Ign:8 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.6 InRelease
                                Get:9 https://repos.influxdata.com/debian stable InRelease [6,892 B]
                                Hit:10 https://apt.grafana.com stable InRelease
                                Err:9 https://repos.influxdata.com/debian stable InRelease
                                Fetched 105 kB in 3s (33.9 kB/s)
                                14 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                • F firestone
                                  sudo apt update
                                  @firestone
                                  cat /etc/apt/sources.list.d/influxdata.list
                                    @firestone
                                    firestone
                                    deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
                                    • F firestone
                                      @firestone
                                      sudo rm /etc/apt/sources.list.d/influxdata.list
                                      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                                      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                      rm influxdata-archive_compat.key
                                        @firestone
                                        firestone
                                        das hatte ich schon probiert und jetzt nochmal.
                                        pi@ioBUniFi:/ $ sudo rm /etc/apt/sources.list.d/influxdata.list
                                        pi@ioBUniFi:/ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                        pi@ioBUniFi:/ $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                                        sha256sum: influxdata-archive_compat.key: No such file or directory
                                        influxdata-archive_compat.key: FAILED open or read
                                        sha256sum: WARNING: 1 listed file could not be read
                                        pi@ioBUniFi:/ $ echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                        pi@ioBUniFi:/ $ rm influxdata-archive_compat.key
                                        rm: cannot remove 'influxdata-archive_compat.key': No such file or directory
                                        pi@ioBUniFi:/ $
                                        • F firestone
                                          pi@ioBUniFi:/ $
                                          @firestone Du stehst im falschen Verzeichnis für diese Aktionen.
                                          cd ~
                                          In / hast du nix zu suchen.
