  4. Sonoff Zigbee Stick - kein Com port ?
    5.2k
15 Beiträge 3 Kommentatoren 1.9k Aufrufe 3 Beobachtet
  • Tom10webT Tom10web
    .0
    2023-07-01 19:51:44.222	error	Error herdsman start
    zigbee.0
    2023-07-01 19:51:44.221	error	Failed to start Zigbee
    zigbee.0
    2023-07-01 19:51:44.220	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2023-07-01 19:51:44.055	info	Installed Version: iobroker.zigbee@1.8.10
    zigbee.0
    2023-07-01 19:51:44.026	info	Starting Zigbee npm ...
    zigbee.0
    2023-07-01 19:51:44.024	info	Try to reconnect. 1 attempts left
    zigbee.0
    2023-07-01 19:51:34.020	error	Error herdsman start
    zigbee.0
    2023-07-01 19:51:34.019	error	Failed to start Zigbee
    zigbee.0
    2023-07-01 19:51:34.017	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    2023-07-01 19:51:13.868	info	Installed Version: iobroker.zigbee@1.8.10
    zigbee.0
    2023-07-01 19:51:13.314	info	Starting Zigbee npm ...
    zigbee.0
    2023-07-01 19:51:13.311	info	delete old Backup files. keep only last 10
    zigbee.0
    2023-07-01 19:51:13.203	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
    host.BeeSmart
    2023-07-01 19:51:09.770	info	instance system.adapter.zigbee.0 started with pid 206467
    host.BeeSmart
    2023-07-01 19:51:07.333	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zigbee.0
    2023-07-01 19:51:06.692	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    @tom10web
    Die Steuerzeichen für CodeTags alleine in eine neue Zeile setzen, dann wird das auch richtig gerendert.
    Wie sehen die Einstellungen im Zigbee-Adapter zu dem Stick aus?
    • Tom10webT Offline
      Tom10webT Offline
      Tom10web
      Ich habe nichts geändert, außer den
      "/dev/serial/by-id/usb
      ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202194746-if00
      habe es aber auch mit dem Standart "/dev/ttyAMA0"
      probiert
      Raspi3
      Beelink Bt3 X
        probiert
        @tom10web
        Tom10webT 1 Antwort Letzte Antwort
          @tom10web
          Tom10webT Offline
          Tom10webT Offline
          Tom10web
          Zigbee-Adapter
          GERÄTE
          NETZWERKKARTE
          BINDING
          AUSSCHLIESSE
          EINSTELLUNGEN
          ENTWICKLER
          /dev/ttyACM0
          COM-Anschlussname	arrow_drop_down
          TI Z-Stack/CCxxxx
          Typ
          60
          Countdown zwischen 0 und 255 Sek während der Kopplung neuer Zigbeekomponenten mit dem Koordinator
          Network
          DDDDDDDDDDDDDDDD
          Erweiterte Pan ID
          Die erweiterte PAN-ID ist die Hauptnetzwerk-ID, vergleichbar mit der SSID von WLAN-Netzwerken. Diese ID darf sich für vorhandene Netzwerke niemals ändern, da Sie sonst deine Geräte zurücksetzen und Sie neu koppeln müssen. Wenn Sie mehrere ZigBee-Adapter verwenden, müssen Sie sicherstellen, dass diese eindeutige ExtPanIDs verwenden. Geben Sie einfach 16 zufällige Hex-Zeichen ein (a-f und 0-9).
          6754
          Pan ID
          Pan ID ist eine vereinfachte ID (wird von Zigbee anstelle von ExtPanID verwendet, wo immer dies möglich ist). Dies sollte auch einzigartig sein. Hinweis: Das ZigBee-Netzwerk wählt möglicherweise eine andere Pan-ID als die hier angegebene, falls ID-Konflikte erkannt werden.
          Kanalgraphic_eq
          Kanal stellt die verwendete Funkfrequenz ein. Es kann geändert werden, um Konflikte mit vorhandenen WLAN-Netzwerken zu vermeiden. Alle Geräte müssen beim Wechsel neu gelernt werden!
          01030507090B0D0F00020406080A0C0D
          Transportschlüssel
          Tranport Key Text
          CC1352P and CC26X2R1 Sendeleistung
          andere Einstellungen
          External converters
          Paths to files, semicolon (;) splitted
          saveSPEICHERN savecloseSPEICHERN UND SCHLIESSEcloseSCHLIESSE
          Raspi3
          Beelink Bt3 X
            Zigbee-Adapter
            GERÄTE
            NETZWERKKARTE
            BINDING
            AUSSCHLIESSE
            EINSTELLUNGEN
            ENTWICKLER
            /dev/ttyACM0
            TI Z-Stack/CCxxxx
            Typ
            60
            Network
            DDDDDDDDDDDDDDDD
            Erweiterte Pan ID
            6754
            Pan ID
            Kanalgraphic_eq
            Transportschlüssel
            Tranport Key Text
            External converters
            @tom10web
            Davon darfst du auch einen Screenshot machen... ;-)
              Zigbee-Adapter
              GERÄTE
              NETZWERKKARTE
              BINDING
              AUSSCHLIESSE
              EINSTELLUNGEN
              ENTWICKLER
              /dev/ttyACM0
              TI Z-Stack/CCxxxx
              Typ
              60
              Network
              DDDDDDDDDDDDDDDD
              Erweiterte Pan ID
              6754
              Pan ID
              Kanalgraphic_eq
              Transportschlüssel
              Tranport Key Text
              External converters
              @tom10web sagte in Sonoff Zigbee Stick - kein Com port ?:
              TI Z-Stack/CCxxxx
              Ist der falsche Stack. Der Stick benöigt EZSP/EFR32
                @tom10web
                Tom10webT Offline
                Tom10webT Offline
                Tom10web
                muss gerade Lachen, - wie ich mich hier anstelle
                Danke für deine Geduld
                Raspi3
                Beelink Bt3 X
                  Tom10webT Offline
                  Tom10webT Offline
                  Tom10web
                  Geht
                  Danke, ist aber nirgends so richtig dokumentiert.
                  Prost, ich mach jetzt ein Bier auf
                  Raspi3
                  Beelink Bt3 X
                    Geht
                    @tom10web
                    Änder die 'erweiterte PAN-ID' auf eine 16stellige HEX-Zahl.
                      @tom10web
                      Tom10webT Offline
                      Tom10webT Offline
                      Tom10web
                      mach ich
                      0xC001D00D
                      natürlich 2mal
                      Raspi3
                      Beelink Bt3 X
                        mach ich
                        0xC001D00D
                        natürlich 2mal
                        Tom10webT Offline
                        Tom10webT Offline
                        Tom10web
                        @tom10web
                        du siehst Zählen kann ich auch nicht
                        Raspi3
                        Beelink Bt3 X
                          @tom10web
                          Stefan1234
                          Hallo, ich möchte mich auf diesme Weg bei Thomas bedanken.
                          Ich hatte das gleiche Problem - den Stick wie im Video von Matthias Kleine installiert und nur Fehler. Dachte anfangs, es liegt am Debian-Bug, dass ich da bei der Behebung etwas falsch gemacht hatte. Dabei war es der falsche Typ.
                          Vielen Danke - ein wirkliches Top Forum 👍 👍
