  4. Sonoff Zigbee Stick - kein Com port ?
    5.2k
15 Beiträge 3 Kommentatoren 1.9k Aufrufe 3 Beobachtet
    @tom10web sagte in Sonoff Zigbee Stick - kein Com port ?:
    aber hinter seinem Namen sollte "port0" oder ähnliches stehen.
    Nö, da kann auch was anderes stehen.
    Wie stellt sich ein Neustart des Adapters im LogFile dar?
    Ausgabe bitte in CodeTags.
    Tom10webT Offline
    Tom10webT Offline
    Tom10web
    .0
    2023-07-01 19:51:44.222	error	Error herdsman start
    zigbee.0
    2023-07-01 19:51:44.221	error	Failed to start Zigbee
    zigbee.0
    2023-07-01 19:51:44.220	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2023-07-01 19:51:44.055	info	Installed Version: iobroker.zigbee@1.8.10
    zigbee.0
    2023-07-01 19:51:44.026	info	Starting Zigbee npm ...
    zigbee.0
    2023-07-01 19:51:44.024	info	Try to reconnect. 1 attempts left
    zigbee.0
    2023-07-01 19:51:34.020	error	Error herdsman start
    zigbee.0
    2023-07-01 19:51:34.019	error	Failed to start Zigbee
    zigbee.0
    2023-07-01 19:51:34.017	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    2023-07-01 19:51:13.868	info	Installed Version: iobroker.zigbee@1.8.10
    zigbee.0
    2023-07-01 19:51:13.314	info	Starting Zigbee npm ...
    zigbee.0
    2023-07-01 19:51:13.311	info	delete old Backup files. keep only last 10
    zigbee.0
    2023-07-01 19:51:13.203	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
    host.BeeSmart
    2023-07-01 19:51:09.770	info	instance system.adapter.zigbee.0 started with pid 206467
    host.BeeSmart
    2023-07-01 19:51:07.333	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zigbee.0
    2023-07-01 19:51:06.692	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    Raspi3
    Beelink Bt3 X
    • Tom10webT Tom10web
      .0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      host.BeeSmart
      host.BeeSmart
      zigbee.0
      @tom10web
      Die Steuerzeichen für CodeTags alleine in eine neue Zeile setzen, dann wird das auch richtig gerendert.
      Wie sehen die Einstellungen im Zigbee-Adapter zu dem Stick aus?
      • Tom10webT Offline
        Tom10webT Offline
        Tom10web
        Ich habe nichts geändert, außer den
        "/dev/serial/by-id/usb
        ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202194746-if00
        habe es aber auch mit dem Standart "/dev/ttyAMA0"
        probiert
        Raspi3
        Beelink Bt3 X
          probiert
          @tom10web
          Tom10webT 1 Antwort Letzte Antwort
            @tom10web
            Tom10webT Offline
            Tom10webT Offline
            Tom10web
            Zigbee-Adapter
            GERÄTE
            NETZWERKKARTE
            BINDING
            AUSSCHLIESSE
            EINSTELLUNGEN
            ENTWICKLER
            /dev/ttyACM0
            COM-Anschlussname	arrow_drop_down
            TI Z-Stack/CCxxxx
            Typ
            60
            Countdown zwischen 0 und 255 Sek während der Kopplung neuer Zigbeekomponenten mit dem Koordinator
            Network
            DDDDDDDDDDDDDDDD
            Erweiterte Pan ID
            Die erweiterte PAN-ID ist die Hauptnetzwerk-ID, vergleichbar mit der SSID von WLAN-Netzwerken. Diese ID darf sich für vorhandene Netzwerke niemals ändern, da Sie sonst deine Geräte zurücksetzen und Sie neu koppeln müssen. Wenn Sie mehrere ZigBee-Adapter verwenden, müssen Sie sicherstellen, dass diese eindeutige ExtPanIDs verwenden. Geben Sie einfach 16 zufällige Hex-Zeichen ein (a-f und 0-9).
            6754
            Pan ID
            Pan ID ist eine vereinfachte ID (wird von Zigbee anstelle von ExtPanID verwendet, wo immer dies möglich ist). Dies sollte auch einzigartig sein. Hinweis: Das ZigBee-Netzwerk wählt möglicherweise eine andere Pan-ID als die hier angegebene, falls ID-Konflikte erkannt werden.
            Kanalgraphic_eq
            Kanal stellt die verwendete Funkfrequenz ein. Es kann geändert werden, um Konflikte mit vorhandenen WLAN-Netzwerken zu vermeiden. Alle Geräte müssen beim Wechsel neu gelernt werden!
            01030507090B0D0F00020406080A0C0D
            Transportschlüssel
            Tranport Key Text
            CC1352P and CC26X2R1 Sendeleistung
            andere Einstellungen
            External converters
            Paths to files, semicolon (;) splitted
            saveSPEICHERN savecloseSPEICHERN UND SCHLIESSEcloseSCHLIESSE
            Raspi3
            Beelink Bt3 X
              Zigbee-Adapter
              GERÄTE
              NETZWERKKARTE
              BINDING
              AUSSCHLIESSE
              EINSTELLUNGEN
              ENTWICKLER
              /dev/ttyACM0
              TI Z-Stack/CCxxxx
              Typ
              60
              Network
              DDDDDDDDDDDDDDDD
              Erweiterte Pan ID
              6754
              Pan ID
              Kanalgraphic_eq
              Transportschlüssel
              Tranport Key Text
              External converters
              @tom10web
              Davon darfst du auch einen Screenshot machen... ;-)
                Zigbee-Adapter
                GERÄTE
                NETZWERKKARTE
                BINDING
                AUSSCHLIESSE
                EINSTELLUNGEN
                ENTWICKLER
                /dev/ttyACM0
                TI Z-Stack/CCxxxx
                Typ
                60
                Network
                DDDDDDDDDDDDDDDD
                Erweiterte Pan ID
                6754
                Pan ID
                Kanalgraphic_eq
                Transportschlüssel
                Tranport Key Text
                External converters
                TI Z-Stack/CCxxxx
                Ist der falsche Stack. Der Stick benöigt EZSP/EFR32
                  @tom10web
                  Tom10webT Offline
                  Tom10webT Offline
                  Tom10web
                  muss gerade Lachen, - wie ich mich hier anstelle
                  Danke für deine Geduld
                  Raspi3
                  Beelink Bt3 X
                    Tom10webT Offline
                    Tom10webT Offline
                    Tom10web
                    Geht
                    Danke, ist aber nirgends so richtig dokumentiert.
                    Prost, ich mach jetzt ein Bier auf
                    Raspi3
                    Beelink Bt3 X
                      Geht
                      @tom10web
                      Änder die 'erweiterte PAN-ID' auf eine 16stellige HEX-Zahl.
                        @tom10web
                        Tom10webT Offline
                        Tom10webT Offline
                        Tom10web
                        mach ich
                        0xC001D00D
                        natürlich 2mal
                        Raspi3
                        Beelink Bt3 X
                          mach ich
                          0xC001D00D
                          natürlich 2mal
                          Tom10webT Offline
                          Tom10webT Offline
                          Tom10web
                          @tom10web
                          du siehst Zählen kann ich auch nicht
                          Raspi3
                          Beelink Bt3 X
                            @tom10web
                            Stefan1234
                            Hallo, ich möchte mich auf diesme Weg bei Thomas bedanken.
                            Ich hatte das gleiche Problem - den Stick wie im Video von Matthias Kleine installiert und nur Fehler. Dachte anfangs, es liegt am Debian-Bug, dass ich da bei der Behebung etwas falsch gemacht hatte. Dabei war es der falsche Typ.
                            Vielen Danke - ein wirkliches Top Forum 👍 👍
