  4. Parser Wert auslesen aber wie?
    5.4k
147 Beiträge 5 Kommentatoren 24.7k Aufrufe 3 Beobachtet
  • G G.Hawk
    @mickym
    Aber das Log sagt ja, das es um das Script geht, das es garnicht mehr gibt.
    javascript.0
    2023-06-25 13:31:01.291	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" has to be type "number" but received type "string"
    javascript.0
    2023-06-25 13:31:01.290	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" has to be type "number" but received type "string"
    javascript.0
    2023-06-25 13:31:01.289	info	State value to set for "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" has to be type "number" but received type "string"
    javascript.0
    2023-06-25 13:31:01.099	info	script.js_.Strom.Gesamtstrom.Elmo_auslesen: {}
    javascript.0
    2023-06-25 13:31:01.097	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
    javascript.0
    2023-06-25 13:31:01.097	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
    javascript.0
    2023-06-25 13:31:01.096	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    javascript.0
    2023-06-25 13:31:01.094	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
    javascript.0
    2023-06-25 13:31:01.092	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
    javascript.0
    2023-06-25 13:31:01.092	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
    javascript.0
    2023-06-25 13:31:01.091	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    javascript.0
    2023-06-25 13:31:01.087	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
    javascript.0
    2023-06-25 13:31:01.086	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
    javascript.0
    2023-06-25 13:31:01.086	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
    javascript.0
    2023-06-25 13:31:01.085	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
    javascript.0
    2023-06-25 13:31:01.083	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
    mickymM Offline
    mickymM Offline
    mickym
    #123
    @g-hawk Wie gesagt, wenn Du das Script angehalten hast und es kommen die Meldungen immer noch dann gibts noch was.
    Insofern würde @TT-Tom Rat folgen und entweder die JS Instanz oder den ganzen IOB neu starten. Nochmal wenn Du das Script stoppst und die Meldungen kommen noch, dann ist entweder das Script nicht gestoppt oder ein anderes arbeitet noch.
    Im Blockly kann man leider nur noch Scriptnamen suchen, sonst könntest Du ja nach allen Strings suchen, die Du zum Parsen verwendest.
    G 1 Antwort Letzte Antwort
    • mickymM mickym
      G.Hawk
      #124
      @mickym
      Das ist schon klar, aber ich habe das Script "Elmo_auslesen" gelöscht und es steht aber trotzdem jede Minute im Log.
      Ich mache einen Neustart und guck mal was passiert
      • G G.Hawk
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        #125
        @g-hawk Ja geh mal unter die Ghostbusters. ;) 👻 👻 👻 👻 - Von der Ferne geht das schlecht.
        • mickymM mickym
          G.Hawk
          #126
          @mickym
          javascript.0
          2023-06-25 13:37:01.121	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
          javascript.0
          2023-06-25 13:37:01.121	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:19:3)
          javascript.0
          2023-06-25 13:37:01.121	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
          2023-06-25 13:37:01.119	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Stromverbrauch_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
          javascript.0
          2023-06-25 13:37:01.118	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
          javascript.0
          2023-06-25 13:37:01.118	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:18:3)
          javascript.0
          2023-06-25 13:37:01.117	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
          2023-06-25 13:37:01.116	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Einspeisezaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
          javascript.0
          2023-06-25 13:37:01.115	warn	at processTicksAndRejections (node:internal/process/task_queues:95:5)
          javascript.0
          2023-06-25 13:37:01.115	warn	at Object.<anonymous> (script.js_.Strom.Gesamtstrom.Elmo_auslesen:17:3)
          javascript.0
          2023-06-25 13:37:01.114	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1730:20)
          javascript.0
          2023-06-25 13:37:01.112	warn	You are assigning a object to the state "0_userdata.0.Geraetesteuerung.Strom.Stromzähler_untere_Wohnung.Elmo_EWE.Hauptzaehlerstand_aktuell" which expects a number. Please fix your code to use a number or change the state type to object. This warning might become an error in future versions.
          Diesen Eintrag:
          javascript.0
          kann es doch garnicht mehr geben
          HomoranH mickymM 2 Antworten Letzte Antwort
          • G G.Hawk
            @mickym
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            Diesen Eintrag:
            javascript.0
            HomoranH Offline
            HomoranH Offline
            #127
            @g-hawk sagte in Parser Wert auslesen aber wie?:
            warum nicht?
            zeig mal die script enabled Datepunkte unter system (experte)
            • G G.Hawk
              @mickym
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              Diesen Eintrag:
              javascript.0
              mickymM Offline
              mickymM Offline
              mickym
              #128
              Hast Du schon mal gesucht?
              Ich bin da aber eigentlich raus, da ich kein Blockly oder Javascript nutze - da sind andere VIEL schlauer 🤓 🤓 🤓 als ich.
                warum nicht?
                G.Hawk
                #129
                weil ich das Script gelöscht habe um zu teste, was dann passiert.
                Ich mache jetzt einen Reboot und guck was dann passiert.
                • G G.Hawk
                  HomoranH Offline
                  HomoranH Offline
                  #130
                  hattest du noch nicht?
                  deswegen ja
                  @homoran sagte in Parser Wert auslesen aber wie?:
                  ob es wirklich weg ist
                    deswegen ja
                    G.Hawk
                    #131
                    doch iob restart habe ich gemacht
                    jetzt sudo reboot
                    • G G.Hawk
                      jetzt sudo reboot
                      HomoranH Offline
                      HomoranH Offline
                      #132
                      @g-hawk falscher Pfad!
                      da steht nix von Gerätesteuerung
                        G.Hawk
                        schrieb am zuletzt editiert von G.Hawk
                        #133
                        Es gibt einen Ordner ohne Namen in dem Scripte drin sind, der wird mir aber nicht angezeigt.
                        • G Offline
                          G.Hawk
                          #134
                          So wie es aussieht, gibt es diesen unbenannten Ordner in dem Skripte drin sind, die es auch in anderen Ordnern gibt, kann ich denn Ordner ohne Namen einfach löschen?
                          • G G.Hawk
                            HomoranH Offline
                            HomoranH Offline
                            #135
                            Filter aktiv?
                              Filter aktiv?
                              G.Hawk
                              #136
                              nein alles grau
                              Unter dem Ordner js gab es auch diesen unbenannten Ordner ich habe beide unbenannten Ordner unter Javascript und js gelöscht und der Fehler schein weg zu sein.
                              Irgendwann habe ich mal meine Scripte neu sortiert, kann es sein, das da irgendwas schief gelaufen ist?
                              • G G.Hawk
                                nein alles grau
                                HomoranH Offline
                                HomoranH Offline
                                #137
                                nein alles grau
                                zeigen! zeigen! zeigen!
                                und zwar immer und vollständig
                                auch den gesamten Überblick von Script enabled habe ich noch nicht gesehen, immer nur Schnipsel.
                                man weiß nie wo man da gerade ist.
                                • G G.Hawk
                                  nein alles grau
                                  HomoranH Offline
                                  HomoranH Offline
                                  #138
                                  Glückwunsch!
                                  da waren noch einige aktive Scripte drin.
                                  jetzt bra6chst du gar nichts mehr zu zeigen 😡
                                    nein alles grau
                                    G.Hawk
                                    #139
                                    • G G.Hawk
                                      HomoranH Offline
                                      HomoranH Offline
                                      #140
                                      @g-hawk ist unten der f7lter für blockly aktiv?
                                        G.Hawk
                                        #141
                                        nein
                                        • G G.Hawk
                                          nein
                                          HomoranH Offline
                                          HomoranH Offline
                                          #142
                                          @g-hawk was ist denn script für ein Adapter?
