  4. Instance javascript.0 stürzt immer ab
    5.4k
23 Beiträge 5 Kommentatoren 2.8k Aufrufe 4 Beobachtet
    @berges01
    Das ist nicht vollständig.
    Berges01B Offline
    Berges01B Offline
    Berges01
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-21-amd64
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     47
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                            /usr/bin/node           v18.15.0
                            /usr/bin/npm            9.5.0
                            /usr/bin/npx            9.5.0
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.9G        2.4G        4.7G        0.0K        709M        5.2G
    Swap:           976M          0B        976M
    Total:          8.8G        2.4G        5.7G
    Active iob-Instances:   34
    Active repo(s): Stable (default), Beta (latest)
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.5.7
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : Strommix-Smart                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : Strommix-Smart                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                17160
    States:                 14542
    Size of iob-Database:
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    14M     /opt/iobroker/iobroker-data/objects.json.migrated
    14M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    4.0K    /opt/iobroker/iobroker-data/objects.json.old
    0       /opt/iobroker/iobroker-data/objects.json.broken
    20M     /opt/iobroker/iobroker-data/states.jsonl
    1.9M    /opt/iobroker/iobroker-data/states.json.migrated
    1.9M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    1.5M    /opt/iobroker/iobroker-data/states.json.old
    0       /opt/iobroker/iobroker-data/states.json.broken
    F.B.
    • Berges01B Berges01
      @thomas-braun said in Instance javascript.0 stürzt immer ab:
      iob diag
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : none
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       13:55:57 up 32 min,  1 user,  load average: 0.42, 0.57, 0.48
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Wed 2023-06-07 13:55:57 CEST
                 Universal time: Wed 2023-06-07 11:55:57 UTC
                       RTC time: Wed 2023-06-07 11:55:57
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      berges01
      /home/berges01
      berges01 cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        2.4G        5.1G        0.0K        411M        5.2G
      Swap:           976M          0B        976M
      Total:          8.8G        2.4G        6.0G
               7865 M total memory
               2393 M used memory
                186 M active memory
               2368 M inactive memory
               5060 M free memory
                 62 M buffer memory
                349 M swap cache
                976 M total swap
                  0 M used swap
                976 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     787M  796K  786M   1% /run
      /dev/sda2      ext4      233G   11G  210G   5% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/sda1      vfat      511M  5.8M  506M   2% /boot/efi
      tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
      DocGame
      @berges01 War bei mir genau das selbe.
      Bin dann 2 Versionen zurück (auf 7.03) zurück uns alles ist wieder gut.
      Werde noch etwas warten.
                             v.2023-04-16
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.5.0
                                /usr/bin/npx            9.5.0
        MEMORY:
        Swap:           976M          0B        976M
                                admin                   6.5.7
        Objects type: jsonl
        States  type: jsonl
        Objects:                17160
        States:                 14542
        @berges01 sagte in Instance javascript.0 stürzt immer ab:
        Ran da...
        System danach rebooten
        Und schieb die Langfassung noch hinterher.
        Berges01B 1 Antwort Letzte Antwort
        • JohGreJ Offline
          JohGreJ Offline
          JohGre
          Muss mit dem heutigen ScripEngine Adapter Update (auf 7.0.5) zusammen hängen. Hatte ich auch, bin zurück auf die 7.0.3 da funkt wieder alles. Bei mir sind's zwei ts Scripte die Auslöser für den Restartloop sind.
          nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
          • D DocGame
            @docgame sagte in Instance javascript.0 stürzt immer ab:
            Issue auf GitHub verewigt? javascript>7 ist ja nur zum Beta-testen gedacht.
              Ran da...
              Berges01B Offline
              Berges01B Offline
              Berges01
              Wenn du dich errinnerst, ich bin der Linux Depp, was soll ich machen ohne alles zu schrotten ?
              F.B.
                Grundlagen:
                iob stop
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                  Grundlagen:
                  iob stop
                  sudo apt update
                  sudo reboot
                  Berges01B Offline
                  Berges01B Offline
                  Berges01
                  sudo reboot
                  Wie gehabt, kein Erfolg, der Adapter bleibt rot.
                  Copy text starting here:
                                       v.2023-04-16
                  Kernel:                 5.10.0-23-amd64
                  User-ID:                1000
                  X-Server:               false
                  Pending OS-Updates:     0
                  Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                                          /usr/bin/node           v18.16.0
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                  MEMORY:
                  Mem:            7.9G        2.2G        5.0G        0.0K        630M        5.4G
                  Swap:           976M          0B        976M
                  Total:          8.8G        2.2G        6.0G
                                          admin                   6.5.7
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                17160
                  States:                 14542
                  22M     /opt/iobroker/iobroker-data/objects.jsonl
                  25M     /opt/iobroker/iobroker-data/states.jsonl
                  berges01@Strommix-Smart:~$
                  F.B.
                    sudo reboot
                                         v.2023-04-16
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            9.5.1
                                            /usr/bin/npx            9.5.1
                    MEMORY:
                    Swap:           976M          0B        976M
                                            admin                   6.5.7
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                17160
                    States:                 14542
                    Dann kannst du ja jetzt wie auch @DocGame und @JohGre das Ergebnis deines Beta-Testings in ein Issue gießen:
                    https://github.com/ioBroker/ioBroker.javascript/issues
                    Oder deinen ioBroker auf eine stabile Basis setzen, wenn du auf beta-testen eigentlich gar keine Lust hast.
                    Berges01B JohGreJ 2 Antworten Letzte Antwort
                      Berges01B Offline
                      Berges01B Offline
                      Berges01
                      Eigentlich wollte ich kein Betatester sein !
                      Wo warum usw. ich Betta bin keine Ahnung.
                      Wie komme ich denn da von auf Release?
                      Wie das mit github geht weis ich auch nicht, somit ist Betta eigentlich Obsolet.
                      Mein System soll stabil laufen und nicht rumzicken.
                      F.B.
                        Weil du das Beta-Repository aktiviert hast:
                          Berges01B Offline
                          Berges01B Offline
                          Berges01
                          schrieb am zuletzt editiert von Berges01
                          Oh ha Sch...... !
                          Wo ist der Schalter und wie rudere ich zurück?
                          Ah glaube ich habe den Schalter
                          F.B.
                            Oh ha Sch...... !
                            @berges01
                            Deaktivier das Repo im Admin.
                            Oder per Kommandzeile
                            iob repo unset 'Beta (latest)'
                              @berges01
                              Berges01B Offline
                              Berges01B Offline
                              Berges01
                              berges01@Strommix-Smart:~$ ^C
                              berges01@Strommix-Smart:~$ iob repo unset 'Beta (latest)'
                              Repository "Beta (latest)" deactivated.
                              Stable (default): http://download.iobroker.net/sources-dist.json
                              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                              Erledigt, und nun wie auf die Release
                              F.B.
                                @berges01
                                iob update
                                iob upgrade javascript@6.1.4
                                  @berges01
                                  iob update
                                  Berges01B Offline
                                  Berges01B Offline
                                  Berges01
                                  Ui Super es läuft wieder !
                                                       v.2023-04-16
                                  User-ID:                1000
                                  X-Server:               false
                                                          /usr/bin/npm            9.5.1
                                                          /usr/bin/npx            9.5.1
                                  MEMORY:
                                  Mem:            7.9G        3.2G        3.8G        0.0K        883M        4.4G
                                  Swap:           976M          0B        976M
                                  Total:          8.8G        3.2G        4.8G
                                  Active iob-Instances:   35
                                                          admin                   6.5.7
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                17160
                                  States:                 14588
                                  31M     /opt/iobroker/iobroker-data/objects.jsonl
                                  11M     /opt/iobroker/iobroker-data/states.jsonl
                                  BESTEN DANK mal wieder !
                                  F.B.
                                    JohGreJ Offline
                                    JohGreJ Offline
                                    JohGre
                                    @thomas-braun sagte in Instance javascript.0 stürzt immer ab:
                                    Issue ist angelegt
                                                           v.2023-04-16
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            9.5.1
                                                              /usr/bin/npx            9.5.1
                                      MEMORY:
                                      Swap:           976M          0B        976M
                                                              admin                   6.5.7
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                17160
                                      States:                 14588
                                      Die Version ist ja auch 'stabil'.
                                        Hallo
                                        Nach dem ich Heute die 3 Updates eingespielt habe, stürzt nun mein javascript V7.0.5 Adapter ab.
                                        Anzeige der Info:
                                        Plattform: linux
                                        Betriebssystem: linux
                                        Architektur: x64
                                        CPUs: 4
                                        Geschwindigkeit: 1583 MHz
                                        Modell: Intel(R) Core(TM) i7-4650U CPU @ 1.70GHz
                                        RAM: 7.6 GB
                                        System-Betriebszeit: 63 T. 01:42:57
                                        Node.js: v18.15.0
                                        time: 1686136130559
                                        timeOffset: -120
                                        Adapter-Anzahl: 563
                                        NPM: 9.5.0
                                        Datenträgergröße: 232.2 GB
                                        Freier Festplattenspeicher: 209.9 GB
                                        Betriebszeit: 1 T. 04:01:17
                                        Aktive Instanzen: 34
                                        Pfad: /opt/iobroker/
                                        aktiv:
                                        Folgende Meldung bekomme ich im Protokoll:
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: at processImmediate (node:internal/timers:478:21)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1123:67)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: at transformScriptBeforeCompilation (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:447:23)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: at Object.transform (/opt/iobroker/node_modules/typescript/lib/typescript.js:141644:20)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: at transformNodes (/opt/iobroker/node_modules/typescript/lib/typescript.js:109621:72)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: at transformation (/opt/iobroker/node_modules/typescript/lib/typescript.js:109613:16)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:359:16
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: at Object.visitNode (/opt/iobroker/node_modules/typescript/lib/typescript.js:85924:21)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:368:138
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[1]: TypeError: ts.createNodeArray is not a function
                                        host.Strommix-Smart
                                        2023-06-07 13:30:49.444	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                        javascript.0
                                        1829	2023-06-07 13:30:48.858	error	ts.createNodeArray is not a function
                                        javascript.0
                                        1829	2023-06-07 13:30:48.858	error	TypeError: ts.createNodeArray is not a function at /opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:368:138 at Object.visitNode (/opt/iobroker/node_modules/typescript/lib/typescript.js:85924:21) at /opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:359:16 at transformation (/opt/iobroker/node_modules/typescript/lib/typescript.js:109613:16) at transformNodes (/opt/iobroker/node_modules/typescript/lib/typescript.js:109621:72) at Object.transform (/opt/iobroker/node_modules/typescript/lib/typescript.js:141644:20) at transformScriptBeforeCompilation (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:447:23) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1123:67) at processImmediate (node:internal/timers:478:21)
                                        javascript.0
                                        1829	2023-06-07 13:30:48.857	error	unhandled promise rejection: ts.createNodeArray is not a function
                                        javascript.0
                                        1829	2023-06-07 13:30:48.857	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.655	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.655	error	Caught by controller[1]: at processImmediate (node:internal/timers:478:21)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.655	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1123:67)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.655	error	Caught by controller[1]: at transformScriptBeforeCompilation (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:447:23)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.655	error	Caught by controller[1]: at Object.transform (/opt/iobroker/node_modules/typescript/lib/typescript.js:141644:20)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.654	error	Caught by controller[1]: at transformNodes (/opt/iobroker/node_modules/typescript/lib/typescript.js:109621:72)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.654	error	Caught by controller[1]: at transformation (/opt/iobroker/node_modules/typescript/lib/typescript.js:109613:16)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.654	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:359:16
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.654	error	Caught by controller[1]: at Object.visitNode (/opt/iobroker/node_modules/typescript/lib/typescript.js:85924:21)
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.654	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:368:138
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.654	error	Caught by controller[1]: TypeError: ts.createNodeArray is not a function
                                        host.Strommix-Smart
                                        2023-06-07 13:30:13.654	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                        javascript.0
                                        1800	2023-06-07 13:30:13.079	error	ts.createNodeArray is not a function
                                        javascript.0
                                        1800	2023-06-07 13:30:13.079	error	TypeError: ts.createNodeArray is not a function at /opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:368:138 at Object.visitNode (/opt/iobroker/node_modules/typescript/lib/typescript.js:85924:21) at /opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:359:16 at transformation (/opt/iobroker/node_modules/typescript/lib/typescript.js:109613:16) at transformNodes (/opt/iobroker/node_modules/typescript/lib/typescript.js:109621:72) at Object.transform (/opt/iobroker/node_modules/typescript/lib/typescript.js:141644:20) at transformScriptBeforeCompilation (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:447:23) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:1123:67) at processImmediate (node:internal/timers:478:21)
                                        javascript.0
                                        1800	2023-06-07 13:30:13.079	error	unhandled promise rejection: ts.createNodeArray is not a function
                                        javascript.0
                                        1800	2023-06-07 13:30:13.079	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        Wie bekomme ich den wieder zum laufen ?
                                        Der Versuch eines Neustart vom ioBroker brachte keinen Erfolg.
                                        haus-automatisierungH Offline
                                        Nachdem ich das wohl verbrochen habe mit dem Update, würde ich mich ein Export vom Blockly / JavaScript wünschen, damit ich mir das anschauen kann.
