    2. stromer66
    • Topics 5
    • Posts 23
    stromer66
    @stromer66
    23
    stromer66 Follow
    Latest posts made by stromer66
    • RE: Start Instanzen im WEB UI dauert sehr lange
      Danke, dann werde ich mal den Raspberry neu aufsetzen
      stromer66
      kann ich das updaten oder muss ich komplett neu installieren?
      stromer66
      Script v.2024-10-26 Raspbian
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      OS is similar to: debian
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       19:50:21 up 3 min,  2 users,  load average: 6.29, 3.04, 1.19
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian Release codenamed 'buster' reached its END OF LIFE and needs to be updated to the latest stable release 'bookworm' NOW!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2024-10-28 19:50:21 CET
                 Universal time: Mon 2024-10-28 18:50:21 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G        1.7G        5.8G         24M        438M        6.0G
      Swap:           99M          0B         99M
      Total:         8.0G        1.7G        5.9G
      Active iob-Instances:   32
               7897 M total memory
               1682 M used memory
                194 M active memory
               1826 M inactive memory
               5775 M free memory
                 59 M buffer memory
                379 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 19:50:22 up 3 min,  2 users,  load average: 6.29, 3.04, 1.19
      Tasks: 182 total,   3 running, 179 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 40.5 us, 15.2 sy,  0.0 ni, 40.5 id,  0.0 wa,  0.0 hi,  3.8 si,  0.0 st
      MiB Mem :   7897.7 total,   5776.2 free,   1681.8 used,    439.7 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5962.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4       59G   24G   33G  42% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G  6.0M  3.9G   1% /dev/shm
      tmpfs          tmpfs     3.9G   17M  3.9G   1% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/999
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      [Mon Oct 28 19:46:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:27:85:0D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=7bd71ff1-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Oct 28 19:46:38 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Mon Oct 28 19:46:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Mon Oct 28 19:46:43 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET        SOURCE    FSTYPE OPTIONS
      /             /dev/sda2 ext4   rw,noatime
      |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.4G    /var/
      992M    /var/cache
      979M    /var/cache/apt
      919M    /var/cache/apt/archives
      148M    /var/lib
      Archived and active journals take up 16.0M in the file system.
      /opt/iobroker/backups:
      8.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AM00E9SY-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      /usr/bin/corepack       0.18.0
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 231)
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     1
      +-- iobroker.renault@0.0.22 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#2f50d0fc1fe0ca6ffac426d01434fd357657723a)
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.drag-indicator.0         : drag-indicator        : iobroker                                 -  enabled
        system.adapter.e3dc-rscp.0              : e3dc-rscp             : iobroker                                 -  enabled
        system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.6                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.7                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.8                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.renault.0                : renault               : iobroker                                 -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wiffi-wz.0               : wiffi-wz              : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │   name   │                           url                           │ auto upgrade │
      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "drag-indicator": 2.2.0   , installed 2.2.0
      Adapter    "e3dc-rscp"    : 1.3.1    , installed 1.3.1
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "go-e"         : 1.0.29   , installed 1.0.29
      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "operating-hours": 1.1.0  , installed 1.1.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "radar2"       : 2.2.0    , installed 2.2.0
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        13036
      States:         9930
      Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          20548      623/lighttpd
      tcp        0      0 192.168.170.100:8181    0.0.0.0:*               LISTEN      1001       22339      1337/io.wiffi-wz.0
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        18947      728/pihole-FTL
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17556      584/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16975      400/cupsd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       22996      1153/io.shelly.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       22273      1098/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       22064      1118/io.sonoff.0
      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        19858      728/pihole-FTL
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17810      519/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19963      519/iobroker.js-con
      tcp6       0      0 :::80                   :::*                    LISTEN      0          20549      623/lighttpd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20082      764/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22343      1329/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24020      1296/io.socketio.0
      tcp6       0      0 :::53                   :::*                    LISTEN      999        18949      728/pihole-FTL
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17558      584/sshd
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          19609      583/xrdp-sesman
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23827      1262/io.simple-api.
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16974      400/cupsd
      tcp6       0      0 :::3389                 :::*                    LISTEN      115        20505      611/xrdp
      tcp6       0      0 ::1:4711                :::*                    LISTEN      999        19859      728/pihole-FTL
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       23038      1152/io.shelly.0
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        18946      728/pihole-FTL
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18844      453/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          20481      517/cups-browsed
      udp        0      0 0.0.0.0:56478           0.0.0.0:*                           108        12921      387/avahi-daemon: r
      udp        0      0 192.168.170.100:5353    0.0.0.0:*                           1001       23903      1125/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12919      387/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          18929      453/dhcpcd
      udp6       0      0 :::53                   :::*                                999        18948      728/pihole-FTL
      udp6       0      0 :::5353                 :::*                                108        12920      387/avahi-daemon: r
      udp6       0      0 :::33105                :::*                                108        12922      387/avahi-daemon: r
      2024-10-28 19:49:54.690  - info: sonoff.0 (1118) Client [USV_Stecker] connected with secret 1730141394415_2323
      2024-10-28 19:49:54.787  - info: sonoff.0 (1118) Client [Kueche] connected with secret 1730141394725_3915
      2024-10-28 19:49:54.798  - info: sonoff.0 (1118) Client [Bad_unten] connected with secret 1730141394730_6780
      2024-10-28 19:49:54.857  - info: sonoff.0 (1118) Client [Aussentemp_KVS] connected with secret 1730141394815_4407
      2024-10-28 19:49:54.867  - info: sonoff.0 (1118) Client [Heizungstemperaturen] connected with secret 1730141394821_2204
      2024-10-28 19:49:54.912  - info: sonoff.0 (1118) Client [Pferdestall] connected with secret 1730141394884_5258
      2024-10-28 19:49:54.952  - info: sonoff.0 (1118) Client [Schlafzimmer] connected with secret 1730141394930_5764
      2024-10-28 19:49:54.960  - info: sonoff.0 (1118) Client [Temp_Wohnz_Terasse] connected with secret 1730141394933_8161
      2024-10-28 19:49:55.122  - info: sonoff.0 (1118) Client [Sommergarten] connected with secret 1730141395120_3165
      2024-10-28 19:49:56.204  - info: sql.0 (886) enabled logging of Pv mittel, Alias=true, WriteNulls=false
      2024-10-28 19:49:56.902  - info: modbus.7 (1088) Connected to slave 192.168.170.155
      2024-10-28 19:49:57.199  - info: mqtt.0 (1098) Client [ESPClient_CC:50:E3:17:C7:7F] connected with secret 1730141397198_2369
      2024-10-28 19:49:57.218  - info: mqtt.0 (1098) Client [ESPClient_CC:50:E3:17:C7:7F] subscribes on "/Display/#" with regex /^Display\..*/
      2024-10-28 19:49:57.219  - info: mqtt.0 (1098) Client [ESPClient_CC:50:E3:17:C7:7F] subscribes on "/Display/#"  with regex /^mqtt\.0\.Display\..*/
      2024-10-28 19:49:57.420  - info: mqtt.0 (1098) Client [ESPClient_CC:50:E3:17:C7:7F] publishOnSubscribe send all known states
      2024-10-28 19:49:59.888  - info: sql.0 (886) enabled logging of shelly.1.shellyplus1pm#4855199a0d00#1.Relay0.Energy, Alias=false, WriteNulls=false
      2024-10-28 19:50:05.590  - error: shelly.1 (1153) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-4855199a0d00"
      2024-10-28 19:50:12.380  - info: sourceanalytix.0 (1303) Initialization of shelly.1.shellyplus1pm#4855199a0d00#1.Relay0.Power successfully
      2024-10-28 19:50:12.396  - info: sourceanalytix.0 (1303) Successfully activated SourceAnalytix for 1 of 1 states, will do my Job until you stop me!
      2024-10-28 19:50:45.943  - info: shelly.1 (1153) [MQTT] Device with client id "shellyplus1pm-4855199a0d00" connected!
      2024-10-28 19:51:02.637  - info: alexa2.0 (1017) No smart home devices to query
      2024-10-28 19:51:03.582  - info: alexa2.0 (1017) Subscribing to states...
      2024-10-28 19:51:03.590  - info: alexa2.0 (1017) Deleting the following states: ["Smart-Home-Devices.98fac3f0-6981-4de0-8973-88a886ad70bd","Smart-Home-Devices.df8e297d-72ae-4520-aa7f-f7c115919db3","Smart-Home-Devices.98fac3f0-6981-4de0-8973-88a886ad70bd.#enabled","Smart-Home-Devices.98fac3f0-6981-4de0-8973-88a886ad70bd.#delete","Smart-Home-Devices.98fac3f0-6981-4de0-8973-88a886ad70bd.powerState","Smart-Home-Devices.98fac3f0-6981-4de0-8973-88a886ad70bd.brightness","Smart-Home-Devices.98fac3f0-6981-4de0-8973-88a886ad70bd.connectivity","Smart-Home-Devices.98fac3f0-6981-4de0-8973-88a886ad70bd.connectivity-reason","Smart-Home-Devices.98fac3f0-6981-4de0-8973-88a886ad70bd.#query","Smart-Home-Devices.98fac3f0-6981-4de0-8973-88a886ad70bd.#includeInAllQuery","Smart-Home-Devices.df8e297d-72ae-4520-aa7f-f7c115919db3.#enabled","Smart-Home-Devices.df8e297d-72ae-4520-aa7f-f7c115919db3.#delete","Smart-Home-Devices.df8e297d-72ae-4520-aa7f-f7c115919db3.powerState","Smart-Home-Devices.df8e297d-72ae-4520-aa7f-f7c115919db3.connectivity","Smart-Home-Devices.df8e297d-72ae-4520-aa7f-f7c115919db3.connectivity-reason","Smart-Home-Devices.df8e297d-72ae-4520-aa7f-f7c115919db3.#query","Smart-Home-Devices.df8e297d-72ae-4520-aa7f-f7c115919db3.#includeInAllQuery"]
      2024-10-28 19:51:05.928  - info: alexa2.0 (1017) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2024-10-28 19:51:19.739  - info: alexa2.0 (1017) Initialization Done ...
      stromer66
      pi@iobroker:~ $ distro-info
      -bash: distro-info: Kommando nicht gefunden.
      stromer66
      ja pi4 mit 8gb Ram und als Laufwerk einen 64 GB USB Stick
      stromer66
      Irgendwie möchte er das nicht. Wenn ich iob diag eingebe erscheint die folgende Meldung:
      *** iob diag is starting up, please wait ***
      iob diag needs to be updated. Please execute 'iobroker fix' first.
      iobroker fix habe ich laufen lassen, aber trotzdem erscheint die Meldung. wie kann ich iob diag denn updaten?
      stromer66
      @crunchip
      Cannot get Tab instances Error Timeout erscheint unten links.
      stromer66
      @ilovegym
      Hallo
      auf dem pi läuft noch pihole sonst nichts
      stromer66
    • Start Instanzen im WEB UI dauert sehr lange
      Hallo zusammen
      ich habe ein Problem in der WEB UI wenn ich den Tab Instanzen öffnen möchte dauert es sehr lange manchmal über eine Minute. Das System läuft auf einem Raspberry pi 4 mit 8 GB Speicher. Eigentlich ist das System komplett aktuell, es werden mir keine Updates angeboten..
      Alle anderen Tabs starten eigentlich recht schnell, nur bei Instanzen dauert es ewig. Laut Anzeige liegt meine Ram Auslastung bei 3583 MB und es sind 35 Instanzen aktiv.
      Hat jemand eine Idee woran das liegen könnte?
      Danke im Voraus.
      stromer66
    • Shelly RGBW2 Schalteingang nutzen
      Hallo zusammen
      ich habe einen Shelly RGBW2 mit Tasmota geflasht. Das soweit auch gut funktioniert.
      Jetzt zu meinem Problem, ich möchte gerne den SW1 Eingang des Shelly nutzen um den Shelly mit den zuletzt eingestellten Werten einzuschalten. Ich habe in der Objektauflistung im Sonoff Adapter das Objekt "Switch1" gefunden ,das steht allerdings immer auf True und ändert sich nicht.
      Außerdem habe ich nirgendwo eine Erklärung gefunden wofür die ganzen Parameter stehen die im IOBroker für den Shelly RGBW2 im Sonoff Adapter auftauchen.
      Vielleicht weiß ja auch jemand wie ich den Schalter direkt in Tasmota verknüpfen kann, damit ich auch bei WLAN Ausfall das Licht einschalten kann.
      Gruß Uwe
      stromer66
