iobroker.js-controller version 1.4.0 js-controller starting
1.4.2 ist aktuell
mach mal
iobroker stop npm cache clean npm install iobroker.js-controller@1.4.2 iobroker start ```` `
/opt/iobroker $ npm install iobroker.js-controller@1.4.2
npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/cli ui
npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/lru -cache
npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/mom ent
npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/p-l imit
npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/whi ch
npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yar gs
npm ERR! path /opt/iobroker/node_modules/cliui
npm ERR! code EACCES
npm ERR! errno -13
npm ERR! syscall access
npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/cl iui'
npm ERR! { Error: EACCES: permission denied, access '/opt/iobroker/node_modules /cliui'
npm ERR! stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node _modules/cliui\'',
npm ERR! errno: -13,
npm ERR! code: 'EACCES',
npm ERR! syscall: 'access',
npm ERR! path: '/opt/iobroker/node_modules/cliui' }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check t he
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator (though this is not recommended ).
npm ERR! /home/pi/.npm/_logs/2018-09-20T19_02_32_340Z-debug.log
das ganze nochmal mit sudo probiert
pi@RPiMain:/opt/iobroker $ sudo npm install iobroker.js-controller@1.4.2
npm ERR! write after end
npm ERR! /root/.npm/_logs/2018-09-20T19_08_23_151Z-debug.log
Keine Ahnung wo der Wurm drin steckt :?
Hi Enno,
Es wurde von mir nur ein neuer Hostname und SSH aktiviert weiter nichts. `
wenn Du schreibst „… weiter nichts“, hast Du dann diesen Schritt aus der Readme auch nicht ausgeführt?~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201809 ... 652cdb.jpg">https://uploads.tapatalk-cdn.com/20180920/e9ea9d5fb672e953914eff197d652cdb.jpg</link_text>" />
Eric
Von unterwegs getippert~~ `
Das hat auch leider nichts ergeben.
