Hier mal mein "iob diag" output:
Script v.2025-08-09
*** BASE SYSTEM ***
 Static hostname: IObrokerPi5
       Icon name: computer
          Kernel: Linux 6.12.34+rpt-rpi-2712
    Architecture: arm64
OS is similar to:
Model           : Raspberry Pi 5 Model B Rev 1.0
Docker          : false
Virtualization  : none
Kernel          : aarch64
Userland        : 64 bit
Systemuptime and Load:
 11:55:24 up  3:44,  2 users,  load average: 0.36, 0.69, 0.48
CPU threads: 4
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'bookworm'!
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
~ Under-voltage has occurred
~ Arm frequency capping has occurred
*** TIME AND TIMEZONES ***
               Local time: Fri 2025-08-22 11:55:24 CEST
           Universal time: Fri 2025-08-22 09:55:24 UTC
                 RTC time: Fri 2025-08-22 09:55:24
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
admin
HOME=/home/admin
GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
iobroker
HOME=/home/iobroker
*** DISPLAY-SERVER SETUP ***
Display-Server:         false
Unit display-manager.service could not be found.
Display-Manager:
Desktop:
Session:                tty
*** MEMORY ***
Mem:            8.5G        2.3G        4.9G        5.5M        1.3G        6.1G
Swap:           209M          0B        209M
Total:          8.7G        2.3G        5.1G
Active iob-Instances:   24
         8063 M total memory
         2218 M used memory
         2010 M active memory
          834 M inactive memory
         4675 M free memory
          261 M buffer memory
         1001 M swap cache
          199 M total swap
            0 M used swap
          199 M free swap
top - 11:55:24 up  3:44,  2 users,  load average: 0.36, 0.69, 0.48
Tasks: 213 total,   1 running, 212 sleeping,   0 stopped,   0 zombie
%Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   8063.2 total,   4674.1 free,   2219.9 used,   1262.3 buff/cache
MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5843.2 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** DMESG CRITICAL ERRORS ***
151 CRITICAL ERRORS DETECTED!
Check 'sudo dmesg --level=emerg,alert,crit -T' for details
*** FILESYSTEM ***
udev           devtmpfs  3.9G     0  3.9G   0% /dev
tmpfs          tmpfs     1.6G  5.3M  1.6G   1% /run
/dev/mmcblk0p2 ext4       59G   17G   39G  31% /
tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
/dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
[Fri Aug 22 08:10:26 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:33:7E:48 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1773a755-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
[Fri Aug 22 08:10:29 2025] EXT4-fs (mmcblk0p2): mounted filesystem 7909438b-2884-423e-aa05-577fdea75c97 ro with ordered data mode. Quota mode: none.
[Fri Aug 22 08:10:30 2025] EXT4-fs (mmcblk0p2): re-mounted 7909438b-2884-423e-aa05-577fdea75c97 r/w.
Show mounted filesystems:
TARGET           SOURCE         FSTYPE OPTIONS
/                /dev/mmcblk0p2 ext4   rw,noatime
`-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
1.2G    /var/
613M    /var/log
612M    /var/log/journal/e004c5c494f24635be857afd2b9c7aee
221M    /var/cache
Archived and active journals take up 611.9M in the file system.
/opt/iobroker/backups:
76M     /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
803M    /opt/iobroker/iobroker-data/
456M    /opt/iobroker/iobroker-data/history
252M    /opt/iobroker/iobroker-data/files
79M     /opt/iobroker/iobroker-data/backup-objects
52M     /opt/iobroker/iobroker-data/files/vis-2
19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
15M     /opt/iobroker/iobroker-data/objects.jsonl
9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CjzUbllv.js
8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
USB-Devices by-id:
/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
zigbee.X
Extended Pan ID:
*** MASKED ***
Pan ID:
*** MASKED ***
Channel:
*** MASKED ***
Network Key:
*** MASKED ***
*** NodeJS-Installation ***
/usr/bin/nodejs         v22.18.0
/usr/bin/node           v22.18.0
/usr/bin/npm            11.5.2
/usr/bin/npx            11.5.2
/usr/bin/corepack       0.33.0
nodejs:
  Installed: 22.18.0-1nodesource1
  Candidate: 22.18.0-1nodesource1
  Version table:
 *** 22.18.0-1nodesource1 1001
        500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
        100 /var/lib/dpkg/status
     22.17.1-1nodesource1 1001
     22.17.0-1nodesource1 1001
     22.16.0-1nodesource1 1001
     22.15.1-1nodesource1 1001
     22.15.0-1nodesource1 1001
     22.14.0-1nodesource1 1001
     22.13.1-1nodesource1 1001
     22.13.0-1nodesource1 1001
     22.12.0-1nodesource1 1001
     22.11.0-1nodesource1 1001
     22.10.0-1nodesource1 1001
     22.9.0-1nodesource1 1001
     22.8.0-1nodesource1 1001
     22.7.0-1nodesource1 1001
     22.6.0-1nodesource1 1001
     22.5.1-1nodesource1 1001
     22.5.0-1nodesource1 1001
     22.4.1-1nodesource1 1001
     22.4.0-1nodesource1 1001
     22.3.0-1nodesource1 1001
     22.2.0-1nodesource1 1001
     22.1.0-1nodesource1 1001
     22.0.0-1nodesource1 1001
     18.19.0+dfsg-6~deb12u2 500
        500 http://deb.debian.org/debian bookworm/main arm64 Packages
     18.19.0+dfsg-6~deb12u1 500
        500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
IObrokerPi5         IObrokerPi5 (version: 7.0.7, hostname: IObrokerPi5   , alive, uptime: 376)
Core adapters versions
js-controller:  7.0.7
admin:          7.7.2
javascript:     9.0.11
nodejs modules from github:     1
+-- iobroker.deconz@2.0.7 (git+ssh://git@github.com/Jey-Cee/ioBroker.deconz.git#8af7464adc2de2241a4d0136e2189a9825d38105)
Adapter State
+ system.adapter.admin.0                  : admin                 : IObrokerPi5                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.alexa2.0                 : alexa2                : IObrokerPi5                              -  enabled
+ system.adapter.backitup.0               : backitup              : IObrokerPi5                              -  enabled
+ system.adapter.cloud.0                  : cloud                 : IObrokerPi5                              -  enabled
+ system.adapter.deconz.0                 : deconz                : IObrokerPi5                              -  enabled, port: 80
  system.adapter.devices.0                : devices               : IObrokerPi5                              - disabled
+ system.adapter.discovery.0              : discovery             : IObrokerPi5                              -  enabled
  system.adapter.echarts.0                : echarts               : IObrokerPi5                              - disabled
  system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IObrokerPi5                              - disabled
+ system.adapter.email.0                  : email                 : IObrokerPi5                              -  enabled
+ system.adapter.energiefluss.0           : energiefluss          : IObrokerPi5                              -  enabled
  system.adapter.eusec.0                  : eusec                 : IObrokerPi5                              - disabled
  system.adapter.feiertage.0              : feiertage             : IObrokerPi5                              -  enabled
+ system.adapter.history.0                : history               : IObrokerPi5                              -  enabled
+ system.adapter.hmip.0                   : hmip                  : IObrokerPi5                              -  enabled
  system.adapter.ical.0                   : ical                  : IObrokerPi5                              -  enabled
+ system.adapter.iot.0                    : iot                   : IObrokerPi5                              -  enabled
+ system.adapter.javascript.0             : javascript            : IObrokerPi5                              -  enabled
+ system.adapter.matter.0                 : matter                : IObrokerPi5                              -  enabled
+ system.adapter.mielecloudservice.0      : mielecloudservice     : IObrokerPi5                              -  enabled
+ system.adapter.mqtt.0                   : mqtt                  : IObrokerPi5                              -  enabled, port: 1883, bind: 0.0.0.0
+ system.adapter.pvforecast.0             : pvforecast            : IObrokerPi5                              -  enabled
+ system.adapter.shelly.0                 : shelly                : IObrokerPi5                              -  enabled, port: 1882, bind: 0.0.0.0
+ system.adapter.smartmeter.0             : smartmeter            : IObrokerPi5                              -  enabled
+ system.adapter.telegram.0               : telegram              : IObrokerPi5                              -  enabled, port: 8443, bind: 0.0.0.0
+ system.adapter.text2command.0           : text2command          : IObrokerPi5                              -  enabled
+ system.adapter.tr-064.0                 : tr-064                : IObrokerPi5                              -  enabled
  system.adapter.twinkly.0                : twinkly               : IObrokerPi5                              - disabled
+ system.adapter.vis-2.0                  : vis-2                 : IObrokerPi5                              -  enabled
  system.adapter.weatherunderground.0     : weatherunderground    : IObrokerPi5                              -  enabled
+ system.adapter.web.0                    : web                   : IObrokerPi5                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ instance is alive
ioBroker-Repositories
Active repo(s): beta
Upgrade policy: none
Installed ioBroker-Adapters
Used repository: beta
Adapter    "admin"        : 7.7.2    , installed 7.7.2
Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
Adapter    "backitup"     : 3.3.5    , installed 3.3.5
Adapter    "cloud"        : 5.0.1    , installed 5.0.1
Adapter    "deconz"       : 1.6.4    , installed 2.0.7
Adapter    "devices"      : 1.2.8    , installed 1.2.8
Adapter    "echarts"      : 2.0.8    , installed 2.0.8
Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
Adapter    "email"        : 2.0.4    , installed 2.0.4
Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
Adapter    "eusec"        : 1.3.3    , installed 1.3.3
Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
Adapter    "hmip"         : 1.27.0   , installed 1.27.0
Adapter    "ical"         : 1.16.2   , installed 1.16.2
Adapter    "iot"          : 3.6.0    , installed 3.6.0
Adapter    "javascript"   : 9.0.11   , installed 9.0.11
Controller "js-controller": 7.0.7    , installed 7.0.7
Adapter    "matter"       : 0.5.2    , installed 0.5.2
Adapter    "mielecloudservice": 6.5.11, installed 6.5.11
Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
Adapter    "shelly"       : 10.1.0   , installed 10.1.0
Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
Adapter    "socketio"     : 7.0.8    , installed 7.0.8
Adapter    "text2command" : 3.0.3    , installed 3.0.3
Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
Adapter    "weatherunderground": 3.7.0, installed 3.7.0
Adapter    "web"          : 7.0.9    , installed 7.0.9
Adapter    "ws"           : 3.0.19   , installed 3.0.19
Objects and States
Objects:        7118
States:         5656
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
Reading package lists...
Pending Updates: 0
*** Listening Ports ***
tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       94899      5398/iobroker.js-co
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       94905      5398/iobroker.js-co
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6392       795/sshd: /usr/sbin
tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       98428      5744/io.mqtt.0
tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       100534     6160/io.shelly.0
tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       98429      5744/io.mqtt.0
tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96036      5416/io.admin.0
tcp6       0      0 :::8082                 :::*                    LISTEN      1001       102630     7035/io.web.0
tcp6       0      0 :::22                   :::*                    LISTEN      0          6394       795/sshd: /usr/sbin
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105124     7067/io.matter.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105114     7067/io.matter.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105109     7067/io.matter.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6127       664/avahi-daemon: r
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       102576     6970/io.deconz.0
udp        0      0 0.0.0.0:44612           0.0.0.0:*                           1001       105120     7067/io.matter.0
udp        0      0 0.0.0.0:49878           0.0.0.0:*                           104        6129       664/avahi-daemon: r
udp6       0      0 :::5353                 :::*                                1001       105125     7067/io.matter.0
udp6       0      0 :::5353                 :::*                                1001       105115     7067/io.matter.0
udp6       0      0 :::5353                 :::*                                1001       105110     7067/io.matter.0
udp6       0      0 :::5353                 :::*                                104        6128       664/avahi-daemon: r
udp6       0      0 :::1900                 :::*                                1001       102579     6970/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       102578     6970/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       102577     6970/io.deconz.0
udp6       0      0 :::56347                :::*                                104        6130       664/avahi-daemon: r
udp6       0      0 :::44612                :::*                                1001       105119     7067/io.matter.0
udp6       0      0 fe80::e5be:3ac1:ac2:546 :::*                                0          6476       755/NetworkManager
2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.erdgeschoss.command.rollosrauf"
2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.hobbyraum.dimmer.licht"
2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.schrank.switch.licht"
2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.bastelzimmer.switch.licht"
2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.gästebad.dimmer.licht"
2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.gästebad.dimmer.spiegellicht"
2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]: node:internal/modules/cjs/loader:1846
2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]:                  ^
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object..node (node:internal/modules/cjs/loader:1846:18)
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1423:32)
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1246:12)
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1445:12)
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at require (node:internal/modules/helpers:135:16)
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1688:14)
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object..js (node:internal/modules/cjs/loader:1820:10) {
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: }
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: Node.js v22.18.0
2025-08-22 11:54:20.396  - error: host.IObrokerPi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
2025-08-22 11:54:20.396  - info: host.IObrokerPi5 Do not restart adapter system.adapter.echarts.0 because disabled or deleted
