    2. RalfV
    R
    RalfV
    @RalfV
    RalfV Follow
    Latest posts made by RalfV
    • RE: Shelly Uni Plus nicht per MQTT einbindbar
      @djmarc75 Hallo, ich habe das mal gemacht !
      Ergebnis:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Static hostname: raspberrypi
      Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
      Kernel: Linux 5.15.84-v7+
      Architecture: arm
      Model : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker : false
      Virtualization : none
      Kernel : armv7l
      Userland : armhf
      Systemuptime and Load:
      13:56:58 up 86 days, 9 min, 1 user, load average: 0.60, 0.47, 0.37
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
      Local time: Sun 2024-03-03 13:56:58 GMT
      Universal time: Sun 2024-03-03 13:56:58 UTC
      RTC time: n/a
      Time zone: Europe/London (GMT, +0000)
      NTP service: active
      RTC in local TZ: no
      *** User and Groups ***
      ralf
      /home/ralf
      ralf adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: false
      Desktop:
      Terminal: tty
      Boot Target: multi-user.target
      *** MEMORY ***
      Mem: 922M 688M 50M 0.0K 183M 214M
      Swap: 99M 98M 1.0M
      Total: 1.0G 786M 52M
            922 M total memory
            688 M used memory
            298 M active memory
            500 M inactive memory
             50 M free memory
             47 M buffer memory
            135 M swap cache
             99 M total swap
             98 M used swap
              1 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      /dev/root ext4 15G 6.2G 7.6G 46% /
      devtmpfs devtmpfs 333M 0 333M 0% /dev
      tmpfs tmpfs 462M 0 462M 0% /dev/shm
      tmpfs tmpfs 185M 992K 184M 1% /run
      tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
      /dev/mmcblk0p1 vfat 255M 50M 206M 20% /boot
      tmpfs tmpfs 93M 0 93M 0% /run/user/1000
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/mmcblk0p2 ext4 rw,noatime
      |-/run/owfs OWFS fuse.OWFS rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.0G /var/
      1.5G /var/log
      1.4G /var/log/journal/29575b4fce3442d5b217918a0b31d15d
      331M /var/cache
      Archived and active journals take up 1.3G in the file system.
      /opt/iobroker/backups:
      65M /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.5G /opt/iobroker/iobroker-data/
      1.3G /opt/iobroker/iobroker-data/history
      185M /opt/iobroker/iobroker-data/files
      51M /opt/iobroker/iobroker-data/files/javascript.admin
      37M /opt/iobroker/iobroker-data/backup-objects
      22M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      17M /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
      9.2M /opt/iobroker/iobroker-data/objects.jsonl
      9.2M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js
      8.9M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /home/iobroker/.diag.sh: line 277: nodejs: command not found
      /usr/bin/node v16.19.0
      /usr/bin/npm 8.19.3
      /usr/bin/npx 8.19.3
      /usr/bin/corepack 0.15.1
      /home/iobroker/.diag.sh: line 288: nodejs: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
      *** 16.19.0-deb-1nodesource1 500
      500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
      100 /var/lib/dpkg/status
      12.22.12~dfsg-1~deb11u3 500
      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
      npm ERR! /home/ralf/.npm/_logs/2024-03-03T13_57_19_972Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Core adapters versions
      js-controller: 4.0.24
      admin: 6.13.16
      javascript: 6.1.4
      Adapters from github: 0
      Adapter State
      • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.backitup.0 : backitup : raspberrypi - enabled
      • system.adapter.discovery.0 : discovery : raspberrypi - enabled
        system.adapter.dwd.0 : dwd : raspberrypi - disabled
      • system.adapter.echarts.0 : echarts : raspberrypi - enabled
        system.adapter.fritzdect.0 : fritzdect : raspberrypi - disabled
      • system.adapter.history.0 : history : raspberrypi - enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi - enabled
        system.adapter.influxdb.0 : influxdb : raspberrypi - disabled, port: 8086
      • system.adapter.jarvis.0 : jarvis : raspberrypi - enabled
      • system.adapter.javascript.0 : javascript : raspberrypi - enabled
        system.adapter.net-tools.0 : net-tools : raspberrypi - disabled
      • system.adapter.owfs.0 : owfs : raspberrypi - enabled, port: 4304
        system.adapter.ping.0 : ping : raspberrypi - disabled
      • system.adapter.pvforecast.0 : pvforecast : raspberrypi - enabled
      • system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shelly.1 : shelly : raspberrypi - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.synology.0 : synology : raspberrypi - disabled, port: 5000
        system.adapter.tr-064.0 : tr-064 : raspberrypi - disabled
        system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - enabled
        system.adapter.vis.0 : vis : raspberrypi - disabled
      • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      • instance is alive
      ioBroker-Repositories
      stable : http://download.iobroker.net/sources-dist.json
      beta : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter "admin" : 6.13.16 , installed 6.13.16
      Adapter "backitup" : 2.10.11 , installed 2.6.23 [Updatable]
      Adapter "discovery" : 4.2.0 , installed 4.2.0
      Adapter "dwd" : 2.8.5 , installed 2.8.5
      Adapter "echarts" : 1.7.2 , installed 1.7.2
      Adapter "fritzdect" : 2.5.9 , installed 2.2.6 [Updatable]
      Adapter "history" : 3.0.1 , installed 3.0.1
      Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter "influxdb" : 4.0.2 , installed 4.0.2
      Adapter "jarvis" : 3.1.8 , installed 3.1.8
      Adapter "javascript" : 7.8.0 , installed 6.1.4 [Updatable]
      Controller "js-controller": 5.0.19 , installed 4.0.24 [Updatable]
      Adapter "net-tools" : 0.2.0 , installed 0.2.0
      Adapter "node-red" : 5.1.0 , installed 5.1.0
      Adapter "owfs" : 0.7.0 , installed 0.7.0
      Adapter "ping" : 1.6.2 , installed 1.5.3 [Updatable]
      Adapter "pvforecast" : 2.9.1 , installed 2.9.1
      Adapter "shelly" : 6.6.1 , installed 6.6.1
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "socketio" : 6.6.0 , installed 6.6.0
      Adapter "synology" : 3.0.1 , installed 2.1.13 [Updatable]
      Adapter "tr-064" : 4.2.18 , installed 4.2.17 [Updatable]
      Adapter "vis" : 1.5.4 , installed 1.5.4
      Adapter "vis-icontwo" : 1.3.0 , installed 0.90.0 [Updatable]
      Adapter "web" : 6.2.3 , installed 6.2.3
      Adapter "ws" : 2.5.10 , installed 2.5.10
      Objects and States
      Objects: 820
      States: 666
      R
      RalfV
      @ralfv Schade, der alternative MQTT Adapter kann keine Instanz erzeugen, Error 25. Schade.
      R
      RalfV
      @samson71 Dan nlag ich ja nicht so falsch mit meiner Vermutung. Ist damit zu rechnen, dass das shelly Adapter das in 2 -3 Monaten kann ? Oder braucht es erfahrungsgemäß länger ?
      Mit freundlichen Grüßen
      R
      RalfV
    • Shelly Uni Plus nicht per MQTT einbindbar
      KAnn es ein, dass der Adapter shelly diese neue Hardware nicht konfiguriert hat. Gibt es eine andere Möglichkeit den neuen Shelly uni Plus einzubinden ?
      R
      RalfV
