jetzt hat er es gemacht
wieso aber über iobroker selbst nicht ging bei allen anderen 3 Pis die ich am laufen hab
@haselchen ```
Script v.2025-03-08
*** BASE SYSTEM ***
 Static hostname: schopf
       Icon name: computer
          Kernel: Linux 6.12.25+rpt-rpi-v8
    Architecture: arm64
OS is similar to:
Model           : Raspberry Pi 4 Model B Rev 1.5
Docker          : false
Virtualization  : none
Kernel          : aarch64
Userland        : 64 bit
Systemuptime and Load:
 10:57:49 up 52 min,  4 users,  load average: 0.35, 0.18, 0.22
CPU threads: 4
*** LIFE CYCLE STATUS ***
Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** TIME AND TIMEZONES ***
               Local time: Fri 2025-06-13 10:57:49 CEST
           Universal time: Fri 2025-06-13 08:57:49 UTC
                 RTC time: n/a
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
pi
HOME=/home/pi
GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
iobroker
HOME=/home/iobroker
GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
*** DISPLAY-SERVER SETUP ***
Display-Server: true
Desktop:
Terminal:       tty
System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
*** MEMORY ***
Mem:            8.2G        1.1G        5.6G         20M        1.6G        7.1G
Swap:           209M          0B        209M
Total:          8.4G        1.1G        5.8G
Active iob-Instances:   6
         7821 M total memory
         1066 M used memory
         1534 M active memory
          712 M inactive memory
         5369 M free memory
           91 M buffer memory
         1405 M swap cache
          199 M total swap
            0 M used swap
          199 M free swap
top - 10:57:49 up 52 min,  4 users,  load average: 0.35, 0.18, 0.22
Tasks: 228 total,   1 running, 227 sleeping,   0 stopped,   0 zombie
%Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   7821.4 total,   5369.0 free,   1067.2 used,   1496.8 buff/cache
MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6754.2 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  3.6G     0  3.6G   0% /dev
tmpfs          tmpfs     783M  1.5M  781M   1% /run
/dev/mmcblk0p2 ext4      117G   11G  101G  10% /
tmpfs          tmpfs     3.9G  284K  3.9G   1% /dev/shm
tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
/dev/mmcblk0p1 vfat      510M   77M  434M  16% /boot/firmware
tmpfs          tmpfs     783M   44K  783M   1% /run/user/1000
[Fri Jun 13 10:04:53 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:5C:1A:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=75db6b0d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
[Fri Jun 13 10:04:56 2025] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add-4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
[Fri Jun 13 10:04:58 2025] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab98-e9f0235e06b3 r/w. Quota mode: none.
Show mounted filesystems:
TARGET               SOURCE         FSTYPE      OPTIONS
/                    /dev/mmcblk0p2 ext4        rw,noatime
|-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
`-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
4.0G    /var/
1.7G    /var/log/journal/6c35909328ac4489aee7bd431363fcf8
1.7G    /var/log
1.7G    /var/cache/apt
Archived and active journals take up 1.6G in the file system.
/opt/iobroker/backups:
18M     /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
151M    /opt/iobroker/iobroker-data/
97M     /opt/iobroker/iobroker-data/files
47M     /opt/iobroker/iobroker-data/files/admin.admin
46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
6.3M    /opt/iobroker/iobroker-data/states.jsonl
6.0M    /opt/iobroker/iobroker-data/objects.jsonl
USB-Devices by-id:
No Devices found 'by-id'
zigbee.X
Extended Pan ID:
*** MASKED ***
Pan ID:
*** MASKED ***
Channel:
*** MASKED ***
Network Key:
*** MASKED ***
*** NodeJS-Installation ***
/usr/bin/nodejs         v18.20.8
/usr/bin/node           v18.20.8
/usr/bin/npm            10.8.2
/usr/bin/npx            10.8.2
/usr/bin/corepack       0.32.0
nodejs:
  Installed: 18.20.8-1nodesource1
  Candidate: 18.20.8-1nodesource1
  Version table:
 *** 18.20.8-1nodesource1 500
        500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
        100 /var/lib/dpkg/status
     18.20.6-1nodesource1 500
     18.20.5-1nodesource1 500
     18.20.4-1nodesource1 500
     18.20.3-1nodesource1 500
     18.20.2-1nodesource1 500
     18.20.1-1nodesource1 500
     18.20.0-1nodesource1 500
     18.19.1-1nodesource1 500
     18.19.0+dfsg-6~deb12u2 500
        500 http://deb.debian.org/debian bookworm/main arm64 Packages
     18.19.0+dfsg-6~deb12u1 500
        500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
     18.19.0-1nodesource1 500
     18.18.2-1nodesource1 500
     18.18.1-1nodesource1 500
     18.18.0-1nodesource1 500
     18.17.1-1nodesource1 500
     18.17.0-1nodesource1 500
     18.16.1-1nodesource1 500
     18.16.0-1nodesource1 500
     18.15.0-1nodesource1 500
     18.14.2-1nodesource1 500
     18.14.1-1nodesource1 500
     18.14.0-1nodesource1 500
     18.13.0-1nodesource1 500
     18.12.0-1nodesource1 500
     18.11.0-1nodesource1 500
     18.10.0-1nodesource1 500
     18.9.1-1nodesource1 500
     18.9.0-1nodesource1 500
     18.8.0-1nodesource1 500
     18.7.0-1nodesource1 500
     18.6.0-1nodesource1 500
     18.5.0-1nodesource1 500
     18.4.0-1nodesource1 500
     18.3.0-1nodesource1 500
     18.2.0-1nodesource1 500
     18.1.0-1nodesource1 500
     18.0.0-1nodesource1 500
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
schopf              schopf (version: 7.0.6, hostname: schopf        , alive, uptime: 1638)
Core adapters versions
js-controller:  7.0.6
admin:          7.6.17
javascript:     "javascript" not found
nodejs modules from github:     0
Adapter State
+ system.adapter.admin.0                  : admin                 : schopf                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.backitup.0               : backitup              : schopf                                   -  enabled
+ system.adapter.discovery.0              : discovery             : schopf                                   -  enabled
+ system.adapter.influxdb.0               : influxdb              : schopf                                   -  enabled, port: 8086
+ system.adapter.modbus.0                 : modbus                : schopf                                   -  enabled
  system.adapter.pvforecast.0             : pvforecast            : schopf                                   - disabled
+ instance is alive
ioBroker-Repositories
│ (index) │   name   │                           url                           │ auto upgrade │
│    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
│    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
Active repo(s): stable
Upgrade policy: none
Installed ioBroker-Adapters
Used repository: stable
Adapter    "admin"        : 7.6.17   , installed 7.6.17
Adapter    "backitup"     : 3.2.2    , installed 3.2.2
Controller "js-controller": 7.0.6    , installed 7.0.6
Adapter    "modbus"       : 6.3.2    , installed 6.3.2
Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
Objects and States
Objects:        256
States:         182
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:4 https://repos.influxdata.com/debian stable InRelease
Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
Hit:6 https://download.docker.com/linux/debian bookworm InRelease
Hit:7 https://apt.grafana.com stable InRelease
Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Pending Updates: 0
*** Listening Ports ***
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7306       777/sshd: /usr/sbin
tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          4788       764/cupsd
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       62269      8146/iobroker.js-co
tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       64546      8146/iobroker.js-co
tcp6       0      0 :::22                   :::*                    LISTEN      0          7308       777/sshd: /usr/sbin
tcp6       0      0 ::1:631                 :::*                    LISTEN      0          4787       764/cupsd
tcp6       0      0 :::3000                 :::*                    LISTEN      112        13097      1182/grafana
tcp6       0      0 :::8086                 :::*                    LISTEN      999        8687       1064/influxd
tcp6       0      0 :::8081                 :::*                    LISTEN      1001       62336      8165/io.admin.0
udp        0      0 0.0.0.0:33514           0.0.0.0:*                           104        7207       560/avahi-daemon: r
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7205       560/avahi-daemon: r
udp6       0      0 :::41089                :::*                                104        7208       560/avahi-daemon: r
udp6       0      0 :::5353                 :::*                                104        7206       560/avahi-daemon: r
2025-06-13 10:30:43.414  - info: influxdb.0 (8199) enabled logging of WDC3, Alias=true, 20 points now activated
2025-06-13 10:30:43.414  - info: influxdb.0 (8199) enabled logging of ADC4, Alias=true, 21 points now activated
2025-06-13 10:30:43.415  - info: influxdb.0 (8199) enabled logging of WDC4, Alias=true, 22 points now activated
2025-06-13 10:30:43.416  - info: influxdb.0 (8199) enabled logging of VDC4, Alias=true, 23 points now activated
2025-06-13 10:30:43.416  - info: influxdb.0 (8199) enabled logging of ErtragGesamt, Alias=true, 24 points now activated
2025-06-13 10:30:43.417  - info: influxdb.0 (8199) enabled logging of ErtagTag, Alias=true, 25 points now activated
2025-06-13 10:30:43.418  - info: influxdb.0 (8199) enabled logging of ErtragJahr, Alias=true, 26 points now activated
2025-06-13 10:30:43.418  - info: influxdb.0 (8199) enabled logging of ErtragMonat, Alias=true, 27 points now activated
2025-06-13 10:30:43.419  - info: influxdb.0 (8199) enabled logging of VDC3, Alias=true, 28 points now activated
2025-06-13 10:30:43.608  - info: influxdb.0 (8199) Applying retention policy for Schopf to 31536000 seconds. Shard Group Duration (calculated): 604800 seconds
2025-06-13 10:30:43.917  - info: influxdb.0 (8199) Connected!
2025-06-13 10:30:45.468  - info: backitup.0 (8239) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.8, js-controller: 7.0.6
2025-06-13 10:30:45.547  - info: backitup.0 (8239) [iobroker] backup will be activated at 02:40 every 1 day(s)
2025-06-13 10:30:46.758  - info: host.schopf instance system.adapter.modbus.0 in version "6.3.2" started with pid 8278
2025-06-13 10:30:49.047  - info: modbus.0 (8278) starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.20.8, js-controller: 7.0.6
2025-06-13 10:30:49.680  - info: modbus.0 (8278) Connected to slave 192.168.188.35
2025-06-13 10:30:50.730  - info: host.schopf instance system.adapter.discovery.0 in version "5.0.0" started with pid 8295
2025-06-13 10:30:52.855  - info: admin.0 (8165) ==> Connected system.user.admin from ::ffff:172.17.0.2
2025-06-13 10:30:52.881  - info: admin.0 (8165) <== Disconnect system.user.admin from ::ffff:172.17.0.2 admin
2025-06-13 10:30:52.937  - info: admin.0 (8165) <== Disconnect system.user.admin from ::ffff:172.17.0.2 admin
2025-06-13 10:30:53.253  - info: discovery.0 (8295) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.20.8, js-controller: 7.0.6
2025-06-13 10:30:54.737  - info: admin.0 (8165) ==> Connected system.user.admin from ::ffff:172.17.0.2
2025-06-13 10:33:42.661  - info: admin.0 (8165) ==> Connected system.user.admin from ::ffff:172.17.0.2
2025-06-13 10:33:48.854  - info: admin.0 (8165) <== Disconnect system.user.admin from ::ffff:172.17.0.2 admin
2025-06-13 10:37:13.152  - info: admin.0 (8165) <== Disconnect system.user.admin from ::ffff:172.17.0.2 admin
iob diag has finished.
        Hallo Zusammen
Habe bei einem meiner Pis ein Problem das ich das Node.js nicht Updaten kann
System ist an sich auf den Neusten stand mit apt update und apt full-upgrade
Im IoBrocker ist folgende Version siehe Bild
Wenn ich dort Aktualisiere kommt Erfolgreich JS Controller startet neu.
Jedoch ist das Node. JS immer noch auf v18.20.8
Meine TK Anlage kann nur einen Sip Proxa also muss ich en Port eingeben nach der IP
Geht das irgendwie auch ?
@mickym Muss leider nochmal Stören
komm hier echt nicht weiter bzw. versteh es warscheinlich einfach nicht.
Meine Werte Hole ich leider nicht über einen IO Brocker sondern habe die Direkt in Node Red und im Endefekt Spukt die Funktion 18 Folgendes Aus was genau so in die CSV muss ! Jedoch nur 1 Mal im Monat !
Crone-Plus soweit verstanden Würde auch Funktionieren gibt ein Payload zur eingestellten Zeit aus !
Aber wie Verknüpf ich das jetzt das ich nur wenn Crone Plus sein Ausgang bringt die SCV Mit dem Inhalt der Function 18 beschrieben wird ?
@mickym soweit verstanden und auch schon eingebaut aber wie verknüpf ich das nun? (wie ein und)
der Ausgang der Funktion 18 schreibt ja immer !
Muss da ja jetzt irgendwie dazwischen das das dann nur zur eingestellten zeit durchgeht in die write file
Hallo Zusammen
stehe gerade vor einem Kleinen Problem und vieleicht hat hier jemand eine Passende Lösung.
Ich Lese Daten von Stromzählern wasserzählern etc. ab.
Diese Daten möchte ich gerne für die Weitere Verarbeitung in eine csv schreiben.
Soweit gut und Funktioniert.
Allerdings werden die Daten ja permanente geschrieben was die csv nur ünnötig Groß macht.
Ich Benötige die Werte nur am 1sten des Monats in der csv.
Weis jemand wie ich das am einfachsten steuern kann ?
