2022-09-18 17:14:27.621  - info: host.raspberrypi iobroker del hmip.0 --debug
2022-09-18 17:14:29.489  - info: host.raspberrypi iobroker Delete instance "hmip.0"
2022-09-18 17:14:29.522  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 instances of hmip.0
2022-09-18 17:14:29.534  - info: host.raspberrypi iobroker host.raspberrypi Counted 45 devices of hmip.0
2022-09-18 17:14:29.546  - info: host.raspberrypi iobroker host.raspberrypi Counted 28 channels of hmip.0
2022-09-18 17:14:29.587  - info: host.raspberrypi iobroker host.raspberrypi Counted 509 states of hmip.0
2022-09-18 17:14:29.603  - info: host.raspberrypi iobroker host.raspberrypi Counted 15 states of system.adapter.hmip.0
2022-09-18 17:14:29.617  - info: host.raspberrypi iobroker host.raspberrypi Counted 482 states (io.hmip.0.*) from states
2022-09-18 17:14:29.646  - info: host.raspberrypi iobroker host.raspberrypi Counted 15 states (system.adapter.hmip.0.*) from states
2022-09-18 17:14:30.171  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 objects of hmip.0
2022-09-18 17:14:30.173  - info: host.raspberrypi iobroker host.raspberrypi Deleting 599 object(s).
2022-09-18 17:14:31.074  - info: host.raspberrypi iobroker host.raspberrypi: Only 400 objects left to be deleted.
2022-09-18 17:14:31.879  - info: host.raspberrypi iobroker host.raspberrypi: Only 200 objects left to be deleted.
2022-09-18 17:14:32.615  - info: host.raspberrypi object deleted system.adapter.hmip.0
2022-09-18 17:14:32.615  - info: host.raspberrypi stopInstance system.adapter.hmip.0 (force=false, process=true)
2022-09-18 17:14:32.619  - info: host.raspberrypi iobroker host.raspberrypi Deleting 497 state(s).
2022-09-18 17:14:32.624  - info: hmip.0 (1675) Got terminate signal TERMINATE_YOURSELF
2022-09-18 17:14:32.626  - info: host.raspberrypi stopInstance system.adapter.hmip.0 send kill signal
2022-09-18 17:14:32.628  - info: hmip.0 (1675) cleaned everything up...
2022-09-18 17:14:32.629  - info: hmip.0 (1675) terminating
2022-09-18 17:14:32.632  - info: hmip.0 (1675) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2022-09-18 17:14:32.655  - warn: hmip.0 (1675) ws connection closed (0) - code: 1000 - reason:
2022-09-18 17:14:32.914  - info: host.raspberrypi iobroker host.raspberrypi: Only 400 states left to be deleted.
2022-09-18 17:14:33.178  - error: host.raspberrypi instance system.adapter.hmip.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
2022-09-18 17:14:33.179  - info: host.raspberrypi Do not restart adapter system.adapter.hmip.0 because desired by instance
2022-09-18 17:14:33.316  - info: host.raspberrypi iobroker host.raspberrypi: Only 200 states left to be deleted.
2022-09-18 17:14:34.676  - info: host.raspberrypi iobroker exit 0
2022-09-18 17:15:32.654  - info: host.raspberrypi iobroker add hmip 0 --host raspberrypi --debug
2022-09-18 17:15:34.538  - info: host.raspberrypi iobroker host.raspberrypi create instance hmip
2022-09-18 17:15:34.555  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.alive created
2022-09-18 17:15:34.564  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.connected created
2022-09-18 17:15:34.573  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.compactMode created
2022-09-18 17:15:34.582  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.cpu created
2022-09-18 17:15:34.592  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.cputime created
2022-09-18 17:15:34.601  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.memHeapUsed created
2022-09-18 17:15:34.611  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.memHeapTotal created
2022-09-18 17:15:34.620  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.memRss created
2022-09-18 17:15:34.630  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.uptime created
2022-09-18 17:15:34.646  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.inputCount created
2022-09-18 17:15:34.661  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.outputCount created
2022-09-18 17:15:34.674  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.eventLoopLag created
2022-09-18 17:15:34.686  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.sigKill created
2022-09-18 17:15:34.709  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0.logLevel created
2022-09-18 17:15:34.720  - info: host.raspberrypi iobroker host.raspberrypi object hmip.0.info created
2022-09-18 17:15:34.734  - info: host.raspberrypi iobroker host.raspberrypi object hmip.0.info.connection created
2022-09-18 17:15:34.742  - info: host.raspberrypi iobroker host.raspberrypi Set default value of hmip.0.info.connection: false
2022-09-18 17:15:34.757  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.hmip.0 created
2022-09-18 17:15:35.797  - info: host.raspberrypi iobroker exit 0
2022-09-18 17:15:37.494  - info: admin.0 (924) ==> Connected system.user.admin from ::ffff:192.168.178.52
2022-09-18 17:15:37.794  - info: host.raspberrypi instance system.adapter.hmip.0 started with pid 1711
2022-09-18 17:15:40.092  - info: hmip.0 (1711) starting. Version 1.18.0 in /opt/iobroker/node_modules/iobroker.hmip, node: v16.16.0, js-controller: 4.0.23
2022-09-18 17:15:40.132  - info: hmip.0 (1711) token not yet created
2022-09-18 17:15:57.820  - info: host.raspberrypi stopInstance system.adapter.hmip.0 (force=false, process=true)
2022-09-18 17:15:57.828  - info: host.raspberrypi stopInstance system.adapter.hmip.0 send kill signal
2022-09-18 17:15:57.829  - info: hmip.0 (1711) Got terminate signal TERMINATE_YOURSELF
2022-09-18 17:15:57.833  - info: hmip.0 (1711) cleaned everything up...
2022-09-18 17:15:57.835  - info: hmip.0 (1711) terminating
2022-09-18 17:15:57.837  - info: hmip.0 (1711) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2022-09-18 17:15:57.966  - info: admin.0 (924) <== Disconnect system.user.admin from ::ffff:192.168.178.52
2022-09-18 17:15:58.386  - info: host.raspberrypi instance system.adapter.hmip.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2022-09-18 17:16:00.896  - info: host.raspberrypi instance system.adapter.hmip.0 started with pid 1737
2022-09-18 17:16:03.178  - info: hmip.0 (1737) starting. Version 1.18.0 in /opt/iobroker/node_modules/iobroker.hmip, node: v16.16.0, js-controller: 4.0.23
2022-09-18 17:16:03.218  - info: hmip.0 (1737) token not yet created
2022-09-18 17:16:17.310  - info: admin.0 (924) ==> Connected system.user.admin from ::ffff:192.168.178.52
2022-09-18 17:16:27.004  - info: hmip.0 (1737) started token request
2022-09-18 17:16:27.231  - info: hmip.0 (1737) auth step 1
2022-09-18 17:16:27.336  - info: hmip.0 (1737) auth step 2
2022-09-18 17:16:35.933  - info: hmip.0 (1737) auth step 3
2022-09-18 17:16:51.358  - info: host.raspberrypi stopInstance system.adapter.hmip.0 (force=false, process=true)
2022-09-18 17:16:51.368  - info: hmip.0 (1737) Got terminate signal TERMINATE_YOURSELF
2022-09-18 17:16:51.369  - info: host.raspberrypi stopInstance system.adapter.hmip.0 send kill signal
2022-09-18 17:16:51.371  - info: hmip.0 (1737) cleaned everything up...
2022-09-18 17:16:51.373  - info: hmip.0 (1737) terminating
2022-09-18 17:16:51.376  - info: hmip.0 (1737) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2022-09-18 17:16:51.490  - info: admin.0 (924) <== Disconnect system.user.admin from ::ffff:192.168.178.52
2022-09-18 17:16:51.955  - info: host.raspberrypi instance system.adapter.hmip.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2022-09-18 17:16:54.451  - info: host.raspberrypi instance system.adapter.hmip.0 started with pid 1753
2022-09-18 17:16:56.698  - info: hmip.0 (1753) starting. Version 1.18.0 in /opt/iobroker/node_modules/iobroker.hmip, node: v16.16.0, js-controller: 4.0.23
2022-09-18 17:16:59.706  - info: hmip.0 (1753) ws connection opened
2022-09-18 17:17:01.193  - info: hmip.0 (1753) hmip adapter connected and ready
2022-09-18 17:18:19.056  - info: host.raspberrypi stopInstance system.adapter.hmip.0 (force=false, process=true)
2022-09-18 17:18:19.068  - info: host.raspberrypi stopInstance system.adapter.hmip.0 send kill signal
2022-09-18 17:18:19.069  - info: hmip.0 (1753) Got terminate signal TERMINATE_YOURSELF
2022-09-18 17:18:19.075  - info: hmip.0 (1753) cleaned everything up...
2022-09-18 17:18:19.077  - info: hmip.0 (1753) terminating
2022-09-18 17:18:19.079  - info: hmip.0 (1753) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2022-09-18 17:18:19.108  - warn: hmip.0 (1753) ws connection closed (0) - code: 1000 - reason:
2022-09-18 17:18:19.625  - info: host.raspberrypi instance system.adapter.hmip.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2022-09-18 17:18:22.151  - info: host.raspberrypi instance system.adapter.hmip.0 started with pid 1779
2022-09-18 17:18:23.823  - debug: hmip.0 (1779) Redis Objects: Use Redis connection: 127.0.0.1:9001
2022-09-18 17:18:23.867  - debug: hmip.0 (1779) Objects client ready ... initialize now
2022-09-18 17:18:23.869  - debug: hmip.0 (1779) Objects create System PubSub Client
2022-09-18 17:18:23.871  - debug: hmip.0 (1779) Objects create User PubSub Client
2022-09-18 17:18:23.901  - debug: hmip.0 (1779) Objects client initialize lua scripts
2022-09-18 17:18:23.909  - debug: hmip.0 (1779) Objects connected to redis: 127.0.0.1:9001
2022-09-18 17:18:23.935  - debug: hmip.0 (1779) Redis States: Use Redis connection: 127.0.0.1:9000
2022-09-18 17:18:23.946  - debug: hmip.0 (1779) States create System PubSub Client
2022-09-18 17:18:23.948  - debug: hmip.0 (1779) States create User PubSub Client
2022-09-18 17:18:23.962  - debug: hmip.0 (1779) States connected to redis: 127.0.0.1:9000
2022-09-18 17:18:24.015  - debug: hmip.0 (1779) Plugin sentry Initialize Plugin (enabled=true)
2022-09-18 17:18:24.383  - info: hmip.0 (1779) starting. Version 1.18.0 in /opt/iobroker/node_modules/iobroker.hmip, node: v16.16.0, js-controller: 4.0.23
2022-09-18 17:18:24.420  - debug: hmip.0 (1779) ready
2022-09-18 17:18:24.745  - debug: hmip.0 (1779) createObjectsForDevices
2022-09-18 17:18:26.022  - debug: hmip.0 (1779) createObjectsForGroups
2022-09-18 17:18:27.020  - debug: hmip.0 (1779) createObjectsForClients
2022-09-18 17:18:27.112  - debug: hmip.0 (1779) createObjectsForHomes
2022-09-18 17:18:27.252  - debug: hmip.0 (1779) connectWebsocket
2022-09-18 17:18:27.258  - debug: hmip.0 (1779) updateDeviceStates
2022-09-18 17:18:27.363  - info: hmip.0 (1779) ws connection opened
2022-09-18 17:18:28.543  - debug: hmip.0 (1779) subscribeStates
2022-09-18 17:18:28.544  - info: hmip.0 (1779) hmip adapter connected and ready
Best posts made by FoxDie
    RE: Klingelsignalerkennung HmIP-DSD-PCBposted in ioBroker Allgemein
{"label":"","deviceId":"3014F711A0000A9A49A4C2C7","index":1,"groupIndex":1,"functionalChannelType":"WALL_MOUNTED_THERMOSTAT_PRO_CHANNEL","groups":["04eb9f5a-5088-42f0-8e62-e1255bd9a4e8"],"temperatureOffset":-1,"actualTemperature":17.9,"setPointTemperature":5,"display":"ACTUAL","humidity":65,"vaporAmount":9.902114664147657}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.8.2","updateState":"UP_TO_DATE","firmwareVersionInteger":133122,"availableFirmwareVersion":"2.8.2","serializedGlobalTradeItemNumber":"3014F711A0000A9A49A4C2C7","modelType":"HmIP-WTH-2","modelId":297,"permanentlyReachable":true,"connectionType":"HMIP_RF"} 2022-09-18 18:14:54.482 - silly: hmip.0 (2046) _updateGroupStates - {"id":"ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"Wohnzimmer","lastStatusUpdate":1663521169565,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"META","channels":[{"deviceId":"3014F711A0000A1A49A11344","channelIndex":0},{"deviceId":"3014F711A0000A9A49A7071C","channelIndex":0},{"deviceId":"3014F711A00000DBE996E627","channelIndex":0}],"groups":["f4a7dfe6-3ec6-45a3-b7b2-6f438273185f"],"configPending":false,"sabotage":false,"incorrectPositioned":null,"groupIcon":""} 2022-09-18 18:14:54.532 - silly: hmip.0 (2046) _updateGroupStates - {"id":"04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":"828ecc11-8f2c-4ab0-9499-4d138be5838d","label":"Schlafzimmer","lastStatusUpdate":1663521281064,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"HEATING","channels":[{"deviceId":"3014F711A00000DA49A18AA8","channelIndex":1},{"deviceId":"3014F711A0000A9A49A4C2C7","channelIndex":1},{"deviceId":"3014F711A0000A1A49A133C4","channelIndex":1}],"windowOpenTemperature":12,"setPointTemperature":5,"minTemperature":5,"maxTemperature":30,"windowState":"CLOSED","cooling":false,"partyMode":false,"controlMode":"MANUAL","profiles":{"PROFILE_2":{"profileId":"e2165930-ed38-4326-9f3a-1b2cb413e65e","groupId":"04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","index":"PROFILE_2","name":"","visible":false,"enabled":true},"PROFILE_5":{"profileId":"454a2339-e37d-48f7-a55a-caccb069740f","groupId":"04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","index":"PROFILE_5","name":"","visible":false,"enabled":true},"PROFILE_6":{"profileId":"7f3ba2c7-ae0e-4f58-8d78-b456b0de24ba","groupId":"04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","index":"PROFILE_6","name":"","visible":false,"enabled":true},"PROFILE_4":{"profileId":"f33891d4-5123-4c1f-9ce3-323f2e9edde0","groupId":"04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","index":"PROFILE_4","name":"","visible":true,"enabled":true},"PROFILE_3":{"profileId":"b3ca9d01-cd55-4c12-a82d-1cf321c3b61b","groupId":"04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","index":"PROFILE_3","name":"","visible":false,"enabled":true},"PROFILE_1":{"profileId":"62ec6938-51ba-4311-863e-622eed8868fb","groupId":"04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","index":"PROFILE_1","name":"","visible":true,"enabled":true}},"activeProfile":"PROFILE_1","boostMode":false,"boostDuration":5,"actualTemperature":17.9,"humidity":65,"coolingAllowed":false,"coolingIgnored":false,"ecoAllowed":true,"ecoIgnored":false,"controllable":true,"boostAllowed":true,"floorHeatingMode":"FLOOR_HEATING_STANDARD","humidityLimitEnabled":true,"humidityLimitValue":60,"humidityLimiterAlarm":null,"humidityLimitPreEnabled":true,"humidityLimitPreValue":60,"humidityLimiterPreAlarm":null,"externalClockEnabled":false,"externalClockHeatingTemperature":19,"externalClockCoolingTemperature":23,"valvePosition":0,"sabotage":false,"valveSilentModeSupported":true,"valveSilentModeEnabled":false,"lastSetPointReachedTimestamp":1663521281064,"lastSetPointUpdatedTimestamp":1663521281064,"heatingFailureSupported":true,"switchClimateFunction":"THERMOSTAT","supportedOptionalFeatures":{"IOptionalFeatureHumidityLimitPre":false,"IOptionalFeatureSwitchClimateFunction":false},"processing":null,"ventilationState":null} 2022-09-18 18:14:54.612 - silly: hmip.0 (2046) _updateGroupStates - {"id":"e844ada3-d00e-47c9-ac22-90350d68943c","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":"163598ea-5937-4cae-8e42-2100c2357fbb","label":"Fabi","lastStatusUpdate":1663521182660,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"HEATING","channels":[{"deviceId":"3014F711A0000A1BE989FC10","channelIndex":1},{"deviceId":"3014F711A0000A9BE993BB11","channelIndex":1},{"deviceId":"3014F711A00000DA49A192D3","channelIndex":1}],"windowOpenTemperature":12,"setPointTemperature":5,"minTemperature":5,"maxTemperature":16.5,"windowState":"CLOSED","cooling":false,"partyMode":false,"controlMode":"MANUAL","profiles":{"PROFILE_4":{"profileId":"f8c9727c-ddb8-4bd8-864a-38bcce6a3000","groupId":"e844ada3-d00e-47c9-ac22-90350d68943c","index":"PROFILE_4","name":"","visible":true,"enabled":true},"PROFILE_2":{"profileId":"6e3cca28-868f-47a0-8180-7f1ea23e0174","groupId":"e844ada3-d00e-47c9-ac22-90350d68943c","index":"PROFILE_2","name":"","visible":false,"enabled":true},"PROFILE_5":{"profileId":"6fab7f7a-9089-4b23-a583-e23cf8bfa8ad","groupId":"e844ada3-d00e-47c9-ac22-90350d68943c","index":"PROFILE_5","name":"","visible":false,"enabled":true},"PROFILE_6":{"profileId":"cf7570c4-4da5-4753-a632-00b0bc06a031","groupId":"e844ada3-d00e-47c9-ac22-90350d68943c","index":"PROFILE_6","name":"","visible":false,"enabled":true},"PROFILE_1":{"profileId":"4c120037-5048-4aa2-b0b1-f68a3b3cc7af","groupId":"e844ada3-d00e-47c9-ac22-90350d68943c","index":"PROFILE_1","name":"","visible":true,"enabled":true},"PROFILE_3":{"profileId":"fd8bbadf-9b19-4be2-a6bf-bde694562fbf","groupId":"e844ada3-d00e-47c9-ac22-90350d68943c","index":"PROFILE_3","name":"","visible":false,"enabled":true}},"activeProfile":"PROFILE_1","boostMode":false,"boostDuration":5,"actualTemperature":20.7,"humidity":60,"coolingAllowed":false,"coolingIgnored":false,"ecoAllowed":true,"ecoIgnored":false,"controllable":true,"boostAllowed":true,"floorHeatingMode":"FLOOR_HEATING_STANDARD","humidityLimitEnabled":true,"humidityLimitValue":60,"humidityLimiterAlarm":null,"humidityLimitPreEnabled":true,"humidityLimitPreValue":60,"humidityLimiterPreAlarm":null,"externalClockEnabled":false,"externalClockHeatingTemperature":19,"externalClockCoolingTemperature":23,"valvePosition":0,"sabotage":false,"valveSilentModeSupported":true,"valveSilentModeEnabled":false,"lastSetPointReachedTimestamp":1663521182660,"lastSetPointUpdatedTimestamp":1663521182660,"heatingFailureSupported":true,"switchClimateFunction":"THERMOSTAT","supportedOptionalFeatures":{"IOptionalFeatureHumidityLimitPre":false,"IOptionalFeatureSwitchClimateFunction":false},"processing":null,"ventilationState":null} 2022-09-18 18:14:54.646 - silly: hmip.0 (2046) _updateGroupStates - {"id":"828ecc11-8f2c-4ab0-9499-4d138be5838d","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"Schlafzimmer","lastStatusUpdate":1663521281064,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"META","channels":[{"deviceId":"3014F711A00000DA49A18AA8","channelIndex":0},{"deviceId":"3014F711A0000A1A49A133C4","channelIndex":0},{"deviceId":"3014F711A0000A9A49A4C2C7","channelIndex":0}],"groups":["04eb9f5a-5088-42f0-8e62-e1255bd9a4e8"],"configPending":false,"sabotage":false,"incorrectPositioned":null,"groupIcon":""} 2022-09-18 18:14:54.652 - silly: hmip.0 (2046) _updateGroupStates - {"id":"facde810-c250-4bdd-92b0-bc5bb6cc82b6","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"HEATING_COOLING_DEMAND_PUMP","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"HEATING_COOLING_DEMAND_PUMP","channels":[],"on":null,"pumpLeadTime":2,"pumpFollowUpTime":2,"pumpProtectionDuration":1,"pumpProtectionSwitchingInterval":14,"heatDemand":null} 2022-09-18 18:14:54.664 - silly: hmip.0 (2046) _updateGroupStates - {"id":"cbd1bbf4-399d-4500-bbde-30b30ef43ff7","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"BACKUP_ALARM_SIREN","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"SECURITY_BACKUP_ALARM_SWITCHING","channels":[],"on":null,"dimLevel":null,"onTime":180,"signalAcoustic":"FREQUENCY_RISING","signalOptical":"DOUBLE_FLASHING_REPEATING","smokeDetectorAlarmType":null,"acousticFeedbackEnabled":true} 2022-09-18 18:14:54.722 - silly: hmip.0 (2046) _updateGroupStates - {"id":"82c635c9-94a3-470b-a7ce-9cd37d12150f","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"PANIC","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"LINKED_SWITCHING","channels":[],"on":null,"dimLevel":null} 2022-09-18 18:14:54.729 - silly: hmip.0 (2046) _updateGroupStates - {"id":"260aed81-34ad-42b1-bc5b-96bd2d88094c","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"ALARM","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"ALARM_SWITCHING","channels":[],"on":null,"dimLevel":null,"onTime":7200,"signalAcoustic":"FREQUENCY_RISING","signalOptical":"DOUBLE_FLASHING_REPEATING","smokeDetectorAlarmType":null,"acousticFeedbackEnabled":true} 2022-09-18 18:14:54.736 - silly: hmip.0 (2046) _updateGroupStates - {"id":"280c60fd-7ae4-4cf8-acad-920edf2b4e13","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":"859f2f39-73f5-497e-a4fc-a3e159a80909","label":"Flur","lastStatusUpdate":1663519071982,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"ACCESS_CONTROL","channels":[{"deviceId":"3014F711A00026DD8994356A","channelIndex":1}]} 2022-09-18 18:14:54.784 - silly: hmip.0 (2046) _updateGroupStates - {"id":"29caf832-ab2e-47b3-bcd7-cc845213741e","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"Amy","lastStatusUpdate":1663521214132,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"META","channels":[{"deviceId":"3014F711A0000A1A49A12017","channelIndex":0},{"deviceId":"3014F711A00000DBE996E5B0","channelIndex":0},{"deviceId":"3014F711A0000A9BE990DC08","channelIndex":0}],"groups":["8b714e95-e28e-4445-80f8-e1e27e94f918"],"configPending":false,"sabotage":false,"incorrectPositioned":null,"groupIcon":"childroom2"} 2022-09-18 18:14:54.791 - silly: hmip.0 (2046) _updateGroupStates - {"id":"6d57b6d8-f0cb-440c-80f3-d97454345714","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"INBOX","lastStatusUpdate":1662995221866,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"INBOX","channels":[]} 2022-09-18 18:14:54.798 - silly: hmip.0 (2046) _updateGroupStates - {"id":"c49d0f5a-ba97-4ca6-a196-6f94cbe85c1e","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"HEATING_HUMIDITY_LIMITER","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"HEATING_HUMIDITY_LIMITER","channels":[],"humidityLimiterActive":null}2022-09-18 18:14:54.806 - silly: hmip.0 (2046) _updateGroupStates - {"id":"83d9c7dd-69a3-4e08-8d3a-0d5935d40997","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"COMING_HOME","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"LINKED_SWITCHING","channels":[],"on":null,"dimLevel":null} 2022-09-18 18:14:54.812 - silly: hmip.0 (2046) _updateGroupStates - {"id":"a0e7bc5a-561c-46b9-af0e-5724efe814e8","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"EXTERNAL","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"SECURITY_ZONE","channels":[],"active":false,"silent":false,"ignorableDeviceChannels":[],"windowState":null,"motionDetected":null,"presenceDetected":null,"sabotage":null,"zoneAssignmentIndex":"ALARM_MODE_ZONE_2","configPending":null} 2022-09-18 18:14:54.863 - silly: hmip.0 (2046) _updateGroupStates - {"id":"163598ea-5937-4cae-8e42-2100c2357fbb","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"Fabi","lastStatusUpdate":1663521182660,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"META","channels":[{"deviceId":"3014F711A0000A9BE993BB11","channelIndex":0},{"deviceId":"3014F711A0000A1BE989FC10","channelIndex":0},{"deviceId":"3014F711A00000DA49A192D3","channelIndex":0}],"groups":["e844ada3-d00e-47c9-ac22-90350d68943c"],"configPending":false,"sabotage":false,"incorrectPositioned":null,"groupIcon":""} 2022-09-18 18:14:54.870 - silly: hmip.0 (2046) _updateGroupStates - {"id":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":"ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f","label":"Wohnzimmer","lastStatusUpdate":1663521169565,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"HEATING","channels":[{"deviceId":"3014F711A0000A1A49A11344","channelIndex":1},{"deviceId":"3014F711A0000A9A49A7071C","channelIndex":1},{"deviceId":"3014F711A00000DBE996E627","channelIndex":1}],"windowOpenTemperature":12,"setPointTemperature":14,"minTemperature":5,"maxTemperature":30,"windowState":"CLOSED","cooling":false,"partyMode":false,"controlMode":"MANUAL","profiles":{"PROFILE_4":{"profileId":"73a7910b-74eb-4e91-9413-25dfc1ace5f7","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_4","name":"","visible":true,"enabled":true},"PROFILE_5":{"profileId":"956dcdd4-4dcb-4325-971a-da2cd8d3d429","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_5","name":"","visible":false,"enabled":true},"PROFILE_3":{"profileId":"9c9a31d5-5dd7-407e-a1d7-748dec691972","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_3","name":"","visible":false,"enabled":true},"PROFILE_6":{"profileId":"f384462b-88d0-4ef1-b0a3-11028734d1df","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_6","name":"","visible":false,"enabled":true},"PROFILE_1":{"profileId":"bacd78ed-cbe0-4b40-bfff-524108939398","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_1","name":"","visible":true,"enabled":true},"PROFILE_2":{"profileId":"6bff7519-cbb2-4ee3-8eef-6c3e79b4aad8","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_2","name":"","visible":false,"enabled":true}},"activeProfile":"PROFILE_1","boostMode":false,"boostDuration":5,"actualTemperature":18.7,"humidity":64,"coolingAllowed":false,"coolingIgnored":false,"ecoAllowed":true,"ecoIgnored":false,"controllable":true,"boostAllowed":true,"floorHeatingMode":"FLOOR_HEATING_STANDARD","humidityLimitEnabled":true,"humidityLimitValue":60,"humidityLimiterAlarm":null,"humidityLimitPreEnabled":true,"humidityLimitPreValue":60,"humidityLimiterPreAlarm":null,"externalClockEnabled":false,"externalClockHeatingTemperature":19,"externalClockCoolingTemperature":23,"valvePosition":0,"sabotage":false,"valveSilentModeSupported":true,"valveSilentModeEnabled":false,"lastSetPointReachedTimestamp":1663521169565,"lastSetPointUpdatedTimestamp":1663521169565,"heatingFailureSupported":true,"switchClimateFunction":"THERMOSTAT","supportedOptionalFeatures":{"IOptionalFeatureHumidityLimitPre":false,"IOptionalFeatureSwitchClimateFunction":false},"processing":null,"ventilationState":null} 2022-09-18 18:14:54.953 - silly: hmip.0 (2046) _updateGroupStates - {"id":"b60fbafa-44d6-4510-9cc0-74ae9b974f5f","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"HEATING_CHANGEOVER","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"HEATING_CHANGEOVER","channels":[],"on":null,"changeOver":null} 2022-09-18 18:14:54.959 - silly: hmip.0 (2046) _updateGroupStates - {"id":"859f2f39-73f5-497e-a4fc-a3e159a80909","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"Flur","lastStatusUpdate":1663519071982,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"META","channels":[{"deviceId":"3014F711A00026DD8994356A","channelIndex":0}],"groups":["280c60fd-7ae4-4cf8-acad-920edf2b4e13"],"configPending":false,"sabotage":null,"incorrectPositioned":null,"groupIcon":""} 2022-09-18 18:14:54.966 - silly: hmip.0 (2046) _updateGroupStates - {"id":"5dc99514-29c2-4fa3-81b6-a6f4764357fe","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"HEATING_DEHUMIDIFIER","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"HEATING_DEHUMIDIFIER","channels":[],"on":null} 2022-09-18 18:14:54.972 - silly: hmip.0 (2046) _updateGroupStates - {"id":"8b714e95-e28e-4445-80f8-e1e27e94f918","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":"29caf832-ab2e-47b3-bcd7-cc845213741e","label":"Amy","lastStatusUpdate":1663521214132,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"HEATING","channels":[{"deviceId":"3014F711A0000A1A49A12017","channelIndex":1},{"deviceId":"3014F711A00000DBE996E5B0","channelIndex":1},{"deviceId":"3014F711A0000A9BE990DC08","channelIndex":1}],"windowOpenTemperature":12,"setPointTemperature":11.5,"minTemperature":5,"maxTemperature":30,"windowState":"CLOSED","cooling":false,"partyMode":false,"controlMode":"MANUAL","profiles":{"PROFILE_4":{"profileId":"fd063f1d-e9e1-4a45-9f5f-dfe265c5c477","groupId":"8b714e95-e28e-4445-80f8-e1e27e94f918","index":"PROFILE_4","name":"","visible":true,"enabled":true},"PROFILE_5":{"profileId":"82dfdd67-10b8-4898-a4ab-a2e0f7ae5627","groupId":"8b714e95-e28e-4445-80f8-e1e27e94f918","index":"PROFILE_5","name":"","visible":false,"enabled":true},"PROFILE_3":{"profileId":"c97a9066-0062-43c0-a188-859e042f5939","groupId":"8b714e95-e28e-4445-80f8-e1e27e94f918","index":"PROFILE_3","name":"","visible":false,"enabled":true},"PROFILE_6":{"profileId":"bf61f36e-0a02-4cf5-944e-1e9a99cde424","groupId":"8b714e95-e28e-4445-80f8-e1e27e94f918","index":"PROFILE_6","name":"","visible":false,"enabled":true},"PROFILE_1":{"profileId":"97816607-ae53-4997-92ee-7390264e6e91","groupId":"8b714e95-e28e-4445-80f8-e1e27e94f918","index":"PROFILE_1","name":"","visible":true,"enabled":true},"PROFILE_2":{"profileId":"9338a68b-67f2-454a-a45a-846b0040dad8","groupId":"8b714e95-e28e-4445-80f8-e1e27e94f918","index":"PROFILE_2","name":"","visible":false,"enabled":true}},"activeProfile":"PROFILE_1","boostMode":false,"boostDuration":5,"actualTemperature":19.5,"humidity":60,"coolingAllowed":false,"coolingIgnored":false,"ecoAllowed":true,"ecoIgnored":false,"controllable":true,"boostAllowed":true,"floorHeatingMode":"FLOOR_HEATING_STANDARD","humidityLimitEnabled":true,"humidityLimitValue":60,"humidityLimiterAlarm":null,"humidityLimitPreEnabled":true,"humidityLimitPreValue":60,"humidityLimiterPreAlarm":null,"externalClockEnabled":false,"externalClockHeatingTemperature":19,"externalClockCoolingTemperature":23,"valvePosition":0,"sabotage":false,"valveSilentModeSupported":true,"valveSilentModeEnabled":false,"lastSetPointReachedTimestamp":1663521214132,"lastSetPointUpdatedTimestamp":1663521214132,"heatingFailureSupported":true,"switchClimateFunction":"THERMOSTAT","supportedOptionalFeatures":{"IOptionalFeatureHumidityLimitPre":false,"IOptionalFeatureSwitchClimateFunction":false},"processing":null,"ventilationState":null} 2022-09-18 18:14:55.072 - silly: hmip.0 (2046) _updateGroupStates - {"id":"62ec74e5-f601-46e2-9abd-2e5e4c1e7444","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"HEATING_COOLING_DEMAND_BOILER","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"HEATING_COOLING_DEMAND_BOILER","channels":[],"on":null,"boilerLeadTime":0,"boilerFollowUpTime":0,"heatDemand":null} 2022-09-18 18:14:55.078 - silly: hmip.0 (2046) _updateGroupStates - {"id":"b0c0694f-1d7f-4fb2-b2d9-9a6e44d4159b","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"INTERNAL","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"SECURITY_ZONE","channels":[],"active":false,"silent":false,"ignorableDeviceChannels":[],"windowState":null,"motionDetected":null,"presenceDetected":null,"sabotage":null,"zoneAssignmentIndex":"ALARM_MODE_ZONE_3","configPending":null} 2022-09-18 18:14:55.087 - silly: hmip.0 (2046) _updateGroupStates - {"id":"267d773e-9cdb-47ec-bba0-afe322d7978e","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"HEATING_EXTERNAL_CLOCK","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"HEATING_EXTERNAL_CLOCK","channels":[],"externalClockActive":null} 2022-09-18 18:14:55.093 - silly: hmip.0 (2046) _updateGroupStates - {"id":"2afd75b6-b29e-4f2c-948a-74b95a06479a","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"SIREN","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"ALARM_SWITCHING","channels":[],"on":null,"dimLevel":null,"onTime":180,"signalAcoustic":"FREQUENCY_RISING","signalOptical":"DOUBLE_FLASHING_REPEATING","smokeDetectorAlarmType":null,"acousticFeedbackEnabled":true} 2022-09-18 18:14:55.099 - silly: hmip.0 (2046) _updateGroupStates - {"id":"173d34db-7ab2-4487-b292-63e29aee6738","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"Christian","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"ACCESS_AUTHORIZATION_PROFILE","channels":[],"clientIds":[],"profileId":"58f90785-aa59-4a19-aa16-1e6eef95a078","groupVisibility":"VISIBLE","authorizationPinAssigned":false,"authorized":true,"active":true,"onTime":3,"sensorSpecificParameters":{}} 2022-09-18 18:14:55.109 - silly: hmip.0 (2046) _updateGroupStates - {"id":"57197818-7ef7-4fa4-901c-2282658ab312","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"HEATING_TEMPERATURE_LIMITER","lastStatusUpdate":0,"unreach":null,"lowBat":null,"dutyCycle":null,"type":"HEATING_TEMPERATURE_LIMITER","channels":[],"temperatureLimiterActive":null} 2022-09-18 18:14:55.116 - silly: hmip.0 (2046) _updateClientStates - {"clientType":"APP","id":"626a99ba-8b61-491f-a181-d33b7420fd9c","label":"Iphone von Christian","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","createdAtTimestamp":1584534726544,"lastSeenAtTimestamp":1663517944922,"userRole":"ADMIN","userRoleChangeStatus":null,"adminInitializationRequired":false} 2022-09-18 18:14:55.120 - silly: hmip.0 (2046) _updateClientStates - {"clientType":"C2C","id":"ed484a01-e883-467e-a2ab-77a36e31051b","label":"Amazon Alexa Client","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","createdAtTimestamp":1584556022412,"lastSeenAtTimestamp":1663400070084,"c2cServiceIdentifier":"hmip_alexa_skill","inactive":null,"hasC2cServiceToken":false} 2022-09-18 18:14:55.127 - silly: hmip.0 (2046) _updateClientStates - {"clientType":"APP","id":"e18fa5c6-c3c2-4469-bd7e-7c52629d2580","label":"CLT-L29","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","createdAtTimestamp":1584536691751,"lastSeenAtTimestamp":1586776707274,"userRole":"USER","userRoleChangeStatus":null,"adminInitializationRequired":false} 2022-09-18 18:14:55.133 - silly: hmip.0 (2046) _updateClientStates - {"clientType":"APP","id":"3694d59c-7cea-4b1b-b2df-138eb7ffad4e","label":"iobroker","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","createdAtTimestamp":1663517796154,"lastSeenAtTimestamp":1663521290977,"userRole":"RESTRICTED_USER","userRoleChangeStatus":null,"adminInitializationRequired":false} 2022-09-18 18:14:55.139 - silly: hmip.0 (2046) _updateClientStates - {"clientType":"APP","id":"4040cda7-ff2e-4911-8da4-047d71ba7a3a","label":"iobroker","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","createdAtTimestamp":1663332649232,"lastSeenAtTimestamp":1663517524652,"userRole":"RESTRICTED_USER","userRoleChangeStatus":null,"adminInitializationRequired":false} 2022-09-18 18:14:55.146 - silly: hmip.0 (2046) _updateHomeStates - {"weather":{"temperature":10.2,"weatherCondition":"HEAVILY_CLOUDY_WITH_RAIN","weatherDayTime":"DAY","minTemperature":9.2,"maxTemperature":11,"humidity":93,"windSpeed":9.648000000000001,"windDirection":265,"vaporAmount":8.836740352932596},"metaGroups":["ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f","163598ea-5937-4cae-8e42-2100c2357fbb","828ecc11-8f2c-4ab0-9499-4d138be5838d","859f2f39-73f5-497e-a4fc-a3e159a80909","29caf832-ab2e-47b3-bcd7-cc845213741e"],"clients":["626a99ba-8b61-491f-a181-d33b7420fd9c","ed484a01-e883-467e-a2ab-77a36e31051b","e18fa5c6-c3c2-4469-bd7e-7c52629d2580","3694d59c-7cea-4b1b-b2df-138eb7ffad4e","4040cda7-ff2e-4911-8da4-047d71ba7a3a"],"connected":true,"currentAPVersion":"2.4.24","availableAPVersion":null,"timeZoneId":"Europe/Berlin","location":{"city":"45896 Gelsenkirchen, Deutschland","latitude":"51.605104914919025","longitude":"7.033617510460317"},"pinAssigned":false,"pinChangeTimestamp":1662995789135,"pinChangeClientLabel":null,"userRightsManagementActive":true,"liveUpdateSupported":true,"dutyCycle":2,"carrierSense":0,"updateState":"UP_TO_DATE","powerMeterUnitPrice":0,"powerMeterCurrency":"EUR","deviceUpdateStrategy":"AUTOMATICALLY_IF_POSSIBLE","lastReadyForUpdateTimestamp":1659791206003,"functionalHomes":{"SECURITY_AND_ALARM":{"functionalGroups":[],"alarmEventTimestamp":null,"alarmEventTriggerId":null,"alarmEventDeviceChannel":null,"alarmSecurityJournalEntryType":null,"alarmActive":false,"safetyAlarmEventTimestamp":null,"safetyAlarmEventDeviceChannel":null,"safetyAlarmSecurityJournalEntryType":null,"safetyAlarmActive":false,"intrusionAlarmEventTimestamp":null,"intrusionAlarmEventTriggerId":null,"intrusionAlarmEventDeviceChannel":null,"intrusionAlarmSecurityJournalEntryType":null,"intrusionAlarmActive":false,"securityZones":{"EXTERNAL":"a0e7bc5a-561c-46b9-af0e-5724efe814e8","INTERNAL":"b0c0694f-1d7f-4fb2-b2d9-9a6e44d4159b"},"securitySwitchingGroups":{"SIREN":"2afd75b6-b29e-4f2c-948a-74b95a06479a","PANIC":"82c635c9-94a3-470b-a7ce-9cd37d12150f","ALARM":"260aed81-34ad-42b1-bc5b-96bd2d88094c","COMING_HOME":"83d9c7dd-69a3-4e08-8d3a-0d5935d40997","BACKUP_ALARM_SIREN":"cbd1bbf4-399d-4500-bbde-30b30ef43ff7"},"zoneActivationDelay":0,"intrusionAlertThroughSmokeDetectors":false,"securityZoneActivationMode":"ACTIVATION_IF_ALL_IN_VALID_STATE","deviceChannelSpecificFunction":{},"solution":"SECURITY_AND_ALARM","activationInProgress":false,"active":false},"INDOOR_CLIMATE":{"functionalGroups":["8b714e95-e28e-4445-80f8-e1e27e94f918","f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","e844ada3-d00e-47c9-ac22-90350d68943c"],"absenceType":"NOT_ABSENT","absenceEndTime":null,"floorHeatingSpecificGroups":{"HEATING_HUMIDITY_LIMITER":"c49d0f5a-ba97-4ca6-a196-6f94cbe85c1e","HEATING_EXTERNAL_CLOCK":"267d773e-9cdb-47ec-bba0-afe322d7978e","HEATING_COOLING_DEMAND_PUMP":"facde810-c250-4bdd-92b0-bc5bb6cc82b6","HEATING_TEMPERATURE_LIMITER":"57197818-7ef7-4fa4-901c-2282658ab312","HEATING_COOLING_DEMAND_BOILER":"62ec74e5-f601-46e2-9abd-2e5e4c1e7444","HEATING_DEHUMIDIFIER":"5dc99514-29c2-4fa3-81b6-a6f4764357fe","HEATING_CHANGEOVER":"b60fbafa-44d6-4510-9cc0-74ae9b974f5f"},"ecoTemperature":17,"coolingEnabled":false,"ecoDuration":"PERMANENT","optimumStartStopEnabled":false,"deviceChannelSpecificFunction":{},"extendedLinkedVentilationGroups":[],"ventilationProfileGroups":[],"solution":"INDOOR_CLIMATE","active":true},"WEATHER_AND_ENVIRONMENT":{"functionalGroups":[],"solution":"WEATHER_AND_ENVIRONMENT","active":false},"LIGHT_AND_SHADOW":{"functionalGroups":[],"extendedLinkedSwitchingGroups":[],"extendedLinkedShutterGroups":[],"switchingProfileGroups":[],"shutterProfileGroups":[],"solution":"LIGHT_AND_SHADOW","active":false},"ACCESS_CONTROL":{"functionalGroups":["280c60fd-7ae4-4cf8-acad-920edf2b4e13"],"accessAuthorizationProfileGroups":["173d34db-7ab2-4487-b292-63e29aee6738"],"lockProfileGroups":[],"autoRelockProfileGroups":[],"extendedLinkedGarageDoorGroups":[],"extendedLinkedNotificationGroups":[],"solution":"ACCESS_CONTROL","active":true}},"inboxGroup":"6d57b6d8-f0cb-440c-80f3-d97454345714","apExchangeClientId":null,"apExchangeState":"NONE","voiceControlSettings":{"language":"GERMAN","allowedActiveSecurityZoneIds":[],"stateReportEnabled":{"hmip_alexa_skill":"YES"}},"ruleGroups":[],"ruleMetaDatas":{},"liveOTAUStatus":{"liveOTAUState":"INACTIVE","progress":0,"deviceId":null},"accessPointUpdateStates":{"3014F711A00003DA49A248DC":{"successfulUpdateTimestamp":1657190785106,"updateStateChangedTimestamp":1657190785106,"accessPointUpdateState":"UP_TO_DATE"}},"accountLinkingStatus":null,"userRightsManagementActiveChangeStatus":{"clientId":"626a99ba-8b61-491f-a181-d33b7420fd9c","clientLabel":"Iphone von Christian","timestamp":1662995789135},"userRightsManagementSupported":true,"id":"c5198d97-8573-4ea1-b3b9-9810103e0824"} 2022-09-18 18:14:55.302 - debug: hmip.0 (2046) subscribeStates 2022-09-18 18:14:55.304 - info: hmip.0 (2046) hmip adapter connected and ready 2022-09-18 18:14:55.312 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.info.connection:{"val":true,"ack":true,"ts":1663521295309,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663521295309} 2022-09-18 18:14:56.048 - silly: hmip.0 (2046) updateDeviceStates - WALL_MOUNTED_THERMOSTAT_PRO - {"id":"3014F711A0000A9A49A7071C","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Wandthermostat","lastStatusUpdate":1663521296064,"type":"WALL_MOUNTED_THERMOSTAT_PRO","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0000A9A49A7071C","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_OPERATIONLOCK","groups":["ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-68,"rssiPeerValue":-64,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"operationLockActive":false},"1":{"label":"","deviceId":"3014F711A0000A9A49A7071C","index":1,"groupIndex":1,"functionalChannelType":"WALL_MOUNTED_THERMOSTAT_PRO_CHANNEL","groups":["f4a7dfe6-3ec6-45a3-b7b2-6f438273185f"],"temperatureOffset":0,"actualTemperature":18.7,"setPointTemperature":14,"display":"ACTUAL","humidity":64,"vaporAmount":10.223057179489487}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.8.2","updateState":"UP_TO_DATE","firmwareVersionInteger":133122,"availableFirmwareVersion":"2.8.2","serializedGlobalTradeItemNumber":"3014F711A0000A9A49A7071C","modelType":"HmIP-WTH-2","modelId":297,"permanentlyReachable":true,"connectionType":"HMIP_RF"} 2022-09-18 18:14:56.050 - silly: hmip.0 (2046) _updateGroupStates - {"id":"ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":null,"label":"Wohnzimmer","lastStatusUpdate":1663521296064,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"META","channels":[{"deviceId":"3014F711A0000A1A49A11344","channelIndex":0},{"deviceId":"3014F711A0000A9A49A7071C","channelIndex":0},{"deviceId":"3014F711A00000DBE996E627","channelIndex":0}],"groups":["f4a7dfe6-3ec6-45a3-b7b2-6f438273185f"],"configPending":false,"sabotage":false,"incorrectPositioned":null,"groupIcon":""} 2022-09-18 18:14:56.051 - silly: hmip.0 (2046) _updateGroupStates - {"id":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","metaGroupId":"ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f","label":"Wohnzimmer","lastStatusUpdate":1663521296064,"unreach":false,"lowBat":false,"dutyCycle":false,"type":"HEATING","channels":[{"deviceId":"3014F711A0000A1A49A11344","channelIndex":1},{"deviceId":"3014F711A0000A9A49A7071C","channelIndex":1},{"deviceId":"3014F711A00000DBE996E627","channelIndex":1}],"windowOpenTemperature":12,"setPointTemperature":14,"minTemperature":5,"maxTemperature":30,"windowState":"CLOSED","cooling":false,"partyMode":false,"controlMode":"MANUAL","profiles":{"PROFILE_4":{"profileId":"73a7910b-74eb-4e91-9413-25dfc1ace5f7","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_4","name":"","visible":true,"enabled":true},"PROFILE_5":{"profileId":"956dcdd4-4dcb-4325-971a-da2cd8d3d429","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_5","name":"","visible":false,"enabled":true},"PROFILE_3":{"profileId":"9c9a31d5-5dd7-407e-a1d7-748dec691972","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_3","name":"","visible":false,"enabled":true},"PROFILE_6":{"profileId":"f384462b-88d0-4ef1-b0a3-11028734d1df","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_6","name":"","visible":false,"enabled":true},"PROFILE_1":{"profileId":"bacd78ed-cbe0-4b40-bfff-524108939398","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_1","name":"","visible":true,"enabled":true},"PROFILE_2":{"profileId":"6bff7519-cbb2-4ee3-8eef-6c3e79b4aad8","groupId":"f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","index":"PROFILE_2","name":"","visible":false,"enabled":true}},"activeProfile":"PROFILE_1","boostMode":false,"boostDuration":5,"actualTemperature":18.7,"humidity":64,"coolingAllowed":false,"coolingIgnored":false,"ecoAllowed":true,"ecoIgnored":false,"controllable":true,"boostAllowed":true,"floorHeatingMode":"FLOOR_HEATING_STANDARD","humidityLimitEnabled":true,"humidityLimitValue":60,"humidityLimiterAlarm":null,"humidityLimitPreEnabled":true,"humidityLimitPreValue":60,"humidityLimiterPreAlarm":null,"externalClockEnabled":false,"externalClockHeatingTemperature":19,"externalClockCoolingTemperature":23,"valvePosition":0,"sabotage":false,"valveSilentModeSupported":true,"valveSilentModeEnabled":false,"lastSetPointReachedTimestamp":1663521296064,"lastSetPointUpdatedTimestamp":1663521296064,"heatingFailureSupported":true,"switchClimateFunction":"THERMOSTAT","supportedOptionalFeatures":{"IOptionalFeatureHumidityLimitPre":false,"IOptionalFeatureSwitchClimateFunction":false},"processing":null,"ventilationState":null} 2022-09-18 18:14:56.081 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.info.type:{"val":"WALL_MOUNTED_THERMOSTAT_PRO","ack":true,"ts":1663521296069,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819738} 2022-09-18 18:14:56.082 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.info.modelType:{"val":"HmIP-WTH-2","ack":true,"ts":1663521296069,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819738} 2022-09-18 18:14:56.082 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.info.label:{"val":"Wandthermostat","ack":true,"ts":1663521296069,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819738} 2022-09-18 18:14:56.083 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.info.firmwareVersion:{"val":"2.8.2","ack":true,"ts":1663521296069,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819738} 2022-09-18 18:14:56.084 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.info.updateState:{"val":"UP_TO_DATE","ack":true,"ts":1663521296069,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819739} 2022-09-18 18:14:56.087 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.functionalChannelType:{"val":"DEVICE_OPERATIONLOCK","ack":true,"ts":1663521296070,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819739} 2022-09-18 18:14:56.088 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.configPending:{"val":false,"ack":true,"ts":1663521296070,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819739} 2022-09-18 18:14:56.088 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.dutyCycle:{"val":false,"ack":true,"ts":1663521296070,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819739} 2022-09-18 18:14:56.089 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.lowBat:{"val":false,"ack":true,"ts":1663521296070,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819739} 2022-09-18 18:14:56.092 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.routerModuleEnabled:{"val":false,"ack":true,"ts":1663521296070,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819741} 2022-09-18 18:14:56.093 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.routerModuleSupported:{"val":false,"ack":true,"ts":1663521296072,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819741} 2022-09-18 18:14:56.096 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.rssiDeviceValue:{"val":-68,"ack":true,"ts":1663521296072,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663521296072} 2022-09-18 18:14:56.097 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.rssiPeerValue:{"val":-64,"ack":true,"ts":1663521296073,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819749} 2022-09-18 18:14:56.097 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.unreach:{"val":false,"ack":true,"ts":1663521296073,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819749} 2022-09-18 18:14:56.100 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.0.operationLockActive:{"val":false,"ack":true,"ts":1663521296073,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819749} 2022-09-18 18:14:56.101 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.1.functionalChannelType:{"val":"WALL_MOUNTED_THERMOSTAT_PRO_CHANNEL","ack":true,"ts":1663521296073,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819753} 2022-09-18 18:14:56.104 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.1.actualTemperature:{"val":18.7,"ack":true,"ts":1663521296073,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663519288311} 2022-09-18 18:14:56.106 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.1.humidity:{"val":64,"ack":true,"ts":1663521296074,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663519151807} 2022-09-18 18:14:56.107 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.1.vaporAmount:{"val":10.223057179489487,"ack":true,"ts":1663521296074,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663519288312} 2022-09-18 18:14:56.109 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.1.temperatureOffset:{"val":0,"ack":true,"ts":1663521296075,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819754} 2022-09-18 18:14:56.110 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.1.setPointTemperature:{"val":14,"ack":true,"ts":1663521296075,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819754} 2022-09-18 18:14:56.113 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.devices.3014F711A0000A9A49A7071C.channels.1.display:{"val":"ACTUAL","ack":true,"ts":1663521296075,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517819754} 2022-09-18 18:14:56.114 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f.info.type:{"val":"META","ack":true,"ts":1663521296075,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820411} 2022-09-18 18:14:56.116 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f.info.label:{"val":"Wohnzimmer","ack":true,"ts":1663521296075,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820412} 2022-09-18 18:14:56.117 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.info.type:{"val":"HEATING","ack":true,"ts":1663521296075,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820659} 2022-09-18 18:14:56.120 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.info.label:{"val":"Wohnzimmer","ack":true,"ts":1663521296076,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820659} 2022-09-18 18:14:56.121 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.windowOpenTemperature:{"val":12,"ack":true,"ts":1663521296076,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820659} 2022-09-18 18:14:56.121 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.setPointTemperature:{"val":14,"ack":true,"ts":1663521296076,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820659} 2022-09-18 18:14:56.154 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.minTemperature:{"val":5,"ack":true,"ts":1663521296076,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820661} 2022-09-18 18:14:56.155 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.maxTemperature:{"val":30,"ack":true,"ts":1663521296090,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820662} 2022-09-18 18:14:56.155 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.windowState:{"val":"CLOSED","ack":true,"ts":1663521296118,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820662} 2022-09-18 18:14:56.156 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.windowOpen:{"val":false,"ack":true,"ts":1663521296118,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820662} 2022-09-18 18:14:56.156 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.cooling:{"val":false,"ack":true,"ts":1663521296119,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820662} 2022-09-18 18:14:56.157 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.partyMode:{"val":false,"ack":true,"ts":1663521296119,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820662} 2022-09-18 18:14:56.157 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.controlMode:{"val":"MANUAL","ack":true,"ts":1663521296122,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820662} 2022-09-18 18:14:56.158 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.activeProfile:{"val":"PROFILE_1","ack":true,"ts":1663521296123,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820662} 2022-09-18 18:14:56.158 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.boostMode:{"val":false,"ack":true,"ts":1663521296123,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820665} 2022-09-18 18:14:56.159 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.boostDuration:{"val":5,"ack":true,"ts":1663521296123,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820666} 2022-09-18 18:14:56.159 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.actualTemperature:{"val":18.7,"ack":true,"ts":1663521296123,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663519288328} 2022-09-18 18:14:56.159 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.humidity:{"val":64,"ack":true,"ts":1663521296123,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663519151810} 2022-09-18 18:14:56.160 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.coolingAllowed:{"val":false,"ack":true,"ts":1663521296124,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820666} 2022-09-18 18:14:56.160 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.coolingIgnored:{"val":false,"ack":true,"ts":1663521296124,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820666} 2022-09-18 18:14:56.161 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.ecoAllowed:{"val":true,"ack":true,"ts":1663521296124,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820666} 2022-09-18 18:14:56.161 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.ecoIgnored:{"val":false,"ack":true,"ts":1663521296126,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820666} 2022-09-18 18:14:56.161 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.controllable:{"val":true,"ack":true,"ts":1663521296126,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820666} 2022-09-18 18:14:56.165 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.floorHeatingMode:{"val":"FLOOR_HEATING_STANDARD","ack":true,"ts":1663521296126,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820667} 2022-09-18 18:14:56.168 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.humidityLimitEnabled:{"val":true,"ack":true,"ts":1663521296126,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820667} 2022-09-18 18:14:56.169 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.humidityLimitValue:{"val":60,"ack":true,"ts":1663521296126,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820667} 2022-09-18 18:14:56.169 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.externalClockEnabled:{"val":false,"ack":true,"ts":1663521296127,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820667} 2022-09-18 18:14:56.170 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.externalClockHeatingTemperature:{"val":19,"ack":true,"ts":1663521296127,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820674} 2022-09-18 18:14:56.170 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.externalClockCoolingTemperature:{"val":23,"ack":true,"ts":1663521296127,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820674} 2022-09-18 18:14:56.171 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.valvePosition:{"val":0,"ack":true,"ts":1663521296127,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820674} 2022-09-18 18:14:56.171 - silly: hmip.0 (2046) States user redis pmessage hmip.0.*/hmip.0.groups.f4a7dfe6-3ec6-45a3-b7b2-6f438273185f.sabotage:{"val":false,"ack":true,"ts":1663521296127,"q":0,"from":"system.adapter.hmip.0","user":"system.user.admin","lc":1663517820674} -
Danke für die Unterstützung.Ansonsten bleibt mir nur zu sagen, dass alles wunderbar funktioniert.
Latest posts made by FoxDie
Guten Abend,
ohne Vorwarnung funktioniert das Ganze nicht mehr und ich bekomme keine Telegram Nachricht mehr, aber eine Push Mitteilung von der App die ich nicht konfigurieren kann.
bräuchte da nochmal etwas Hilfe
Ahh also das Blocky noch etwas anpassen, dann wäre das Problem gelöst. -
Scheint beides zu gehen, wo liegt der Vorteil in geändert ? weil der nicht vom System aktualisiert wird sondern beim auslösen?.
Erstmal scheint es zu laufen, es gab eine Fehlauslösung mit einer Nachricht anstatt wie "normal" mit zwei
@ofbeqnpolkkl6mby5e13
Ich hab den GitHub Adapter installiert.Den Zeitstempel hat "glaube" ich kein Datenpunkt bis dahin mit dem Klingeln aktualisiert.
Steht auf "Wahr".
Log daten kann ich erst wieder ausgeben wenn ich zuhause bin, wenn nötig.
danke das du das Projekt voran getrieben hast. ES funktioniert mit dem Zeitstempel
  Mega.Das Blocky was du mir an die Hand gegeben hast erfüllt seinen zweck voll und ganz. Er scheint nur zwei mal zu aktualisieren da 2 Nachrichten ankommen.
Aber das wäre mein kleinster Problem, tausend dank.
Auch dir danke fürs Umsetzten, schneller geht es wirklich nicht.
2022-09-18 18:14:53.413 - silly: hmip.0 (2046) createObjectsForClient - {"clientType":"C2C","id":"ed484a01-e883-467e-a2ab-77a36e31051b","label":"Amazon Alexa Client","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","createdAtTimestamp":1584556022412,"lastSeenAtTimestamp":1663400070084,"c2cServiceIdentifier":"hmip_alexa_skill","inactive":null,"hasC2cServiceToken":false} 2022-09-18 18:14:53.472 - silly: hmip.0 (2046) createObjectsForClient - {"clientType":"APP","id":"e18fa5c6-c3c2-4469-bd7e-7c52629d2580","label":"CLT-L29","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","createdAtTimestamp":1584536691751,"lastSeenAtTimestamp":1586776707274,"userRole":"USER","userRoleChangeStatus":null,"adminInitializationRequired":false} 2022-09-18 18:14:53.482 - silly: hmip.0 (2046) createObjectsForClient - {"clientType":"APP","id":"3694d59c-7cea-4b1b-b2df-138eb7ffad4e","label":"iobroker","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","createdAtTimestamp":1663517796154,"lastSeenAtTimestamp":1663521290977,"userRole":"RESTRICTED_USER","userRoleChangeStatus":null,"adminInitializationRequired":false} 2022-09-18 18:14:53.492 - silly: hmip.0 (2046) createObjectsForClient - {"clientType":"APP","id":"4040cda7-ff2e-4911-8da4-047d71ba7a3a","label":"iobroker","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","createdAtTimestamp":1663332649232,"lastSeenAtTimestamp":1663517524652,"userRole":"RESTRICTED_USER","userRoleChangeStatus":null,"adminInitializationRequired":false} 2022-09-18 18:14:53.552 - debug: hmip.0 (2046) createObjectsForHomes 2022-09-18 18:14:53.553 - silly: hmip.0 (2046) Home: {"weather":{"temperature":10.2,"weatherCondition":"HEAVILY_CLOUDY_WITH_RAIN","weatherDayTime":"DAY","minTemperature":9.2,"maxTemperature":11,"humidity":93,"windSpeed":9.648000000000001,"windDirection":265,"vaporAmount":8.836740352932596},"metaGroups":["ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f","163598ea-5937-4cae-8e42-2100c2357fbb","828ecc11-8f2c-4ab0-9499-4d138be5838d","859f2f39-73f5-497e-a4fc-a3e159a80909","29caf832-ab2e-47b3-bcd7-cc845213741e"],"clients":["626a99ba-8b61-491f-a181-d33b7420fd9c","ed484a01-e883-467e-a2ab-77a36e31051b","e18fa5c6-c3c2-4469-bd7e-7c52629d2580","3694d59c-7cea-4b1b-b2df-138eb7ffad4e","4040cda7-ff2e-4911-8da4-047d71ba7a3a"],"connected":true,"currentAPVersion":"2.4.24","availableAPVersion":null,"timeZoneId":"Europe/Berlin","location":{"city":"45896 Gelsenkirchen, Deutschland","latitude":"51.605104914919025","longitude":"7.033617510460317"},"pinAssigned":false,"pinChangeTimestamp":1662995789135,"pinChangeClientLabel":null,"userRightsManagementActive":true,"liveUpdateSupported":true,"dutyCycle":2,"carrierSense":0,"updateState":"UP_TO_DATE","powerMeterUnitPrice":0,"powerMeterCurrency":"EUR","deviceUpdateStrategy":"AUTOMATICALLY_IF_POSSIBLE","lastReadyForUpdateTimestamp":1659791206003,"functionalHomes":{"SECURITY_AND_ALARM":{"functionalGroups":[],"alarmEventTimestamp":null,"alarmEventTriggerId":null,"alarmEventDeviceChannel":null,"alarmSecurityJournalEntryType":null,"alarmActive":false,"safetyAlarmEventTimestamp":null,"safetyAlarmEventDeviceChannel":null,"safetyAlarmSecurityJournalEntryType":null,"safetyAlarmActive":false,"intrusionAlarmEventTimestamp":null,"intrusionAlarmEventTriggerId":null,"intrusionAlarmEventDeviceChannel":null,"intrusionAlarmSecurityJournalEntryType":null,"intrusionAlarmActive":false,"securityZones":{"EXTERNAL":"a0e7bc5a-561c-46b9-af0e-5724efe814e8","INTERNAL":"b0c0694f-1d7f-4fb2-b2d9-9a6e44d4159b"},"securitySwitchingGroups":{"SIREN":"2afd75b6-b29e-4f2c-948a-74b95a06479a","PANIC":"82c635c9-94a3-470b-a7ce-9cd37d12150f","ALARM":"260aed81-34ad-42b1-bc5b-96bd2d88094c","COMING_HOME":"83d9c7dd-69a3-4e08-8d3a-0d5935d40997","BACKUP_ALARM_SIREN":"cbd1bbf4-399d-4500-bbde-30b30ef43ff7"},"zoneActivationDelay":0,"intrusionAlertThroughSmokeDetectors":false,"securityZoneActivationMode":"ACTIVATION_IF_ALL_IN_VALID_STATE","deviceChannelSpecificFunction":{},"solution":"SECURITY_AND_ALARM","activationInProgress":false,"active":false},"INDOOR_CLIMATE":{"functionalGroups":["8b714e95-e28e-4445-80f8-e1e27e94f918","f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","e844ada3-d00e-47c9-ac22-90350d68943c"],"absenceType":"NOT_ABSENT","absenceEndTime":null,"floorHeatingSpecificGroups":{"HEATING_HUMIDITY_LIMITER":"c49d0f5a-ba97-4ca6-a196-6f94cbe85c1e","HEATING_EXTERNAL_CLOCK":"267d773e-9cdb-47ec-bba0-afe322d7978e","HEATING_COOLING_DEMAND_PUMP":"facde810-c250-4bdd-92b0-bc5bb6cc82b6","HEATING_TEMPERATURE_LIMITER":"57197818-7ef7-4fa4-901c-2282658ab312","HEATING_COOLING_DEMAND_BOILER":"62ec74e5-f601-46e2-9abd-2e5e4c1e7444","HEATING_DEHUMIDIFIER":"5dc99514-29c2-4fa3-81b6-a6f4764357fe","HEATING_CHANGEOVER":"b60fbafa-44d6-4510-9cc0-74ae9b974f5f"},"ecoTemperature":17,"coolingEnabled":false,"ecoDuration":"PERMANENT","optimumStartStopEnabled":false,"deviceChannelSpecificFunction":{},"extendedLinkedVentilationGroups":[],"ventilationProfileGroups":[],"solution":"INDOOR_CLIMATE","active":true},"WEATHER_AND_ENVIRONMENT":{"functionalGroups":[],"solution":"WEATHER_AND_ENVIRONMENT","active":false},"LIGHT_AND_SHADOW":{"functionalGroups":[],"extendedLinkedSwitchingGroups":[],"extendedLinkedShutterGroups":[],"switchingProfileGroups":[],"shutterProfileGroups":[],"solution":"LIGHT_AND_SHADOW","active":false},"ACCESS_CONTROL":{"functionalGroups":["280c60fd-7ae4-4cf8-acad-920edf2b4e13"],"accessAuthorizationProfileGroups":["173d34db-7ab2-4487-b292-63e29aee6738"],"lockProfileGroups":[],"autoRelockProfileGroups":[],"extendedLinkedGarageDoorGroups":[],"extendedLinkedNotificationGroups":[],"solution":"ACCESS_CONTROL","active":true}},"inboxGroup":"6d57b6d8-f0cb-440c-80f3-d97454345714","apExchangeClientId":null,"apExchangeState":"NONE","voiceControlSettings":{"language":"GERMAN","allowedActiveSecurityZoneIds":[],"stateReportEnabled":{"hmip_alexa_skill":"YES"}},"ruleGroups":[],"ruleMetaDatas":{},"liveOTAUStatus":{"liveOTAUState":"INACTIVE","progress":0,"deviceId":null},"accessPointUpdateStates":{"3014F711A00003DA49A248DC":{"successfulUpdateTimestamp":1657190785106,"updateStateChangedTimestamp":1657190785106,"accessPointUpdateState":"UP_TO_DATE"}},"accountLinkingStatus":null,"userRightsManagementActiveChangeStatus":{"clientId":"626a99ba-8b61-491f-a181-d33b7420fd9c","clientLabel":"Iphone von Christian","timestamp":1662995789135},"userRightsManagementSupported":true,"id":"c5198d97-8573-4ea1-b3b9-9810103e0824"} 2022-09-18 18:14:53.557 - silly: hmip.0 (2046) createObjectsForHome - {"weather":{"temperature":10.2,"weatherCondition":"HEAVILY_CLOUDY_WITH_RAIN","weatherDayTime":"DAY","minTemperature":9.2,"maxTemperature":11,"humidity":93,"windSpeed":9.648000000000001,"windDirection":265,"vaporAmount":8.836740352932596},"metaGroups":["ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f","163598ea-5937-4cae-8e42-2100c2357fbb","828ecc11-8f2c-4ab0-9499-4d138be5838d","859f2f39-73f5-497e-a4fc-a3e159a80909","29caf832-ab2e-47b3-bcd7-cc845213741e"],"clients":["626a99ba-8b61-491f-a181-d33b7420fd9c","ed484a01-e883-467e-a2ab-77a36e31051b","e18fa5c6-c3c2-4469-bd7e-7c52629d2580","3694d59c-7cea-4b1b-b2df-138eb7ffad4e","4040cda7-ff2e-4911-8da4-047d71ba7a3a"],"connected":true,"currentAPVersion":"2.4.24","availableAPVersion":null,"timeZoneId":"Europe/Berlin","location":{"city":"45896 Gelsenkirchen, Deutschland","latitude":"51.605104914919025","longitude":"7.033617510460317"},"pinAssigned":false,"pinChangeTimestamp":1662995789135,"pinChangeClientLabel":null,"userRightsManagementActive":true,"liveUpdateSupported":true,"dutyCycle":2,"carrierSense":0,"updateState":"UP_TO_DATE","powerMeterUnitPrice":0,"powerMeterCurrency":"EUR","deviceUpdateStrategy":"AUTOMATICALLY_IF_POSSIBLE","lastReadyForUpdateTimestamp":1659791206003,"functionalHomes":{"SECURITY_AND_ALARM":{"functionalGroups":[],"alarmEventTimestamp":null,"alarmEventTriggerId":null,"alarmEventDeviceChannel":null,"alarmSecurityJournalEntryType":null,"alarmActive":false,"safetyAlarmEventTimestamp":null,"safetyAlarmEventDeviceChannel":null,"safetyAlarmSecurityJournalEntryType":null,"safetyAlarmActive":false,"intrusionAlarmEventTimestamp":null,"intrusionAlarmEventTriggerId":null,"intrusionAlarmEventDeviceChannel":null,"intrusionAlarmSecurityJournalEntryType":null,"intrusionAlarmActive":false,"securityZones":{"EXTERNAL":"a0e7bc5a-561c-46b9-af0e-5724efe814e8","INTERNAL":"b0c0694f-1d7f-4fb2-b2d9-9a6e44d4159b"},"securitySwitchingGroups":{"SIREN":"2afd75b6-b29e-4f2c-948a-74b95a06479a","PANIC":"82c635c9-94a3-470b-a7ce-9cd37d12150f","ALARM":"260aed81-34ad-42b1-bc5b-96bd2d88094c","COMING_HOME":"83d9c7dd-69a3-4e08-8d3a-0d5935d40997","BACKUP_ALARM_SIREN":"cbd1bbf4-399d-4500-bbde-30b30ef43ff7"},"zoneActivationDelay":0,"intrusionAlertThroughSmokeDetectors":false,"securityZoneActivationMode":"ACTIVATION_IF_ALL_IN_VALID_STATE","deviceChannelSpecificFunction":{},"solution":"SECURITY_AND_ALARM","activationInProgress":false,"active":false},"INDOOR_CLIMATE":{"functionalGroups":["8b714e95-e28e-4445-80f8-e1e27e94f918","f4a7dfe6-3ec6-45a3-b7b2-6f438273185f","04eb9f5a-5088-42f0-8e62-e1255bd9a4e8","e844ada3-d00e-47c9-ac22-90350d68943c"],"absenceType":"NOT_ABSENT","absenceEndTime":null,"floorHeatingSpecificGroups":{"HEATING_HUMIDITY_LIMITER":"c49d0f5a-ba97-4ca6-a196-6f94cbe85c1e","HEATING_EXTERNAL_CLOCK":"267d773e-9cdb-47ec-bba0-afe322d7978e","HEATING_COOLING_DEMAND_PUMP":"facde810-c250-4bdd-92b0-bc5bb6cc82b6","HEATING_TEMPERATURE_LIMITER":"57197818-7ef7-4fa4-901c-2282658ab312","HEATING_COOLING_DEMAND_BOILER":"62ec74e5-f601-46e2-9abd-2e5e4c1e7444","HEATING_DEHUMIDIFIER":"5dc99514-29c2-4fa3-81b6-a6f4764357fe","HEATING_CHANGEOVER":"b60fbafa-44d6-4510-9cc0-74ae9b974f5f"},"ecoTemperature":17,"coolingEnabled":false,"ecoDuration":"PERMANENT","optimumStartStopEnabled":false,"deviceChannelSpecificFunction":{},"extendedLinkedVentilationGroups":[],"ventilationProfileGroups":[],"solution":"INDOOR_CLIMATE","active":true},"WEATHER_AND_ENVIRONMENT":{"functionalGroups":[],"solution":"WEATHER_AND_ENVIRONMENT","active":false},"LIGHT_AND_SHADOW":{"functionalGroups":[],"extendedLinkedSwitchingGroups":[],"extendedLinkedShutterGroups":[],"switchingProfileGroups":[],"shutterProfileGroups":[],"solution":"LIGHT_AND_SHADOW","active":false},"ACCESS_CONTROL":{"functionalGroups":["280c60fd-7ae4-4cf8-acad-920edf2b4e13"],"accessAuthorizationProfileGroups":["173d34db-7ab2-4487-b292-63e29aee6738"],"lockProfileGroups":[],"autoRelockProfileGroups":[],"extendedLinkedGarageDoorGroups":[],"extendedLinkedNotificationGroups":[],"solution":"ACCESS_CONTROL","active":true}},"inboxGroup":"6d57b6d8-f0cb-440c-80f3-d97454345714","apExchangeClientId":null,"apExchangeState":"NONE","voiceControlSettings":{"language":"GERMAN","allowedActiveSecurityZoneIds":[],"stateReportEnabled":{"hmip_alexa_skill":"YES"}},"ruleGroups":[],"ruleMetaDatas":{},"liveOTAUStatus":{"liveOTAUState":"INACTIVE","progress":0,"deviceId":null},"accessPointUpdateStates":{"3014F711A00003DA49A248DC":{"successfulUpdateTimestamp":1657190785106,"updateStateChangedTimestamp":1657190785106,"accessPointUpdateState":"UP_TO_DATE"}},"accountLinkingStatus":null,"userRightsManagementActiveChangeStatus":{"clientId":"626a99ba-8b61-491f-a181-d33b7420fd9c","clientLabel":"Iphone von Christian","timestamp":1662995789135},"userRightsManagementSupported":true,"id":"c5198d97-8573-4ea1-b3b9-9810103e0824"} 2022-09-18 18:14:53.712 - debug: hmip.0 (2046) connectWebsocket 2022-09-18 18:14:53.718 - debug: hmip.0 (2046) updateDeviceStates 2022-09-18 18:14:53.720 - silly: hmip.0 (2046) updateDeviceStates - SHUTTER_CONTACT - {"id":"3014F711A00000DBE996E5B0","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Fensterkontakt","lastStatusUpdate":1663519532698,"type":"SHUTTER_CONTACT","functionalChannels":{"0":{"label":"","deviceId":"3014F711A00000DBE996E5B0","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_SABOTAGE","groups":["29caf832-ab2e-47b3-bcd7-cc845213741e"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-57,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"sabotage":false},"1":{"label":"","deviceId":"3014F711A00000DBE996E5B0","index":1,"groupIndex":1,"functionalChannelType":"SHUTTER_CONTACT_CHANNEL","groups":["8b714e95-e28e-4445-80f8-e1e27e94f918"],"windowState":"CLOSED","eventDelay":0}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"1.16.8","updateState":"UP_TO_DATE","firmwareVersionInteger":69640,"availableFirmwareVersion":"1.16.8","serializedGlobalTradeItemNumber":"3014F711A00000DBE996E5B0","modelType":"HMIP-SWDO","modelId":258,"permanentlyReachable":false,"connectionType":"HMIP_RF"} 2022-09-18 18:14:53.792 - silly: hmip.0 (2046) updateDeviceStates - WALL_MOUNTED_THERMOSTAT_PRO - {"id":"3014F711A0000A9BE993BB11","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Wandthermostat","lastStatusUpdate":1663521182660,"type":"WALL_MOUNTED_THERMOSTAT_PRO","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0000A9BE993BB11","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_OPERATIONLOCK","groups":["163598ea-5937-4cae-8e42-2100c2357fbb"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-52,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"operationLockActive":false},"1":{"label":"","deviceId":"3014F711A0000A9BE993BB11","index":1,"groupIndex":1,"functionalChannelType":"WALL_MOUNTED_THERMOSTAT_PRO_CHANNEL","groups":["e844ada3-d00e-47c9-ac22-90350d68943c"],"temperatureOffset":0,"actualTemperature":20.7,"setPointTemperature":5,"display":"ACTUAL_HUMIDITY","humidity":60,"vaporAmount":10.775911311502737}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.8.2","updateState":"UP_TO_DATE","firmwareVersionInteger":133122,"availableFirmwareVersion":"2.8.2","serializedGlobalTradeItemNumber":"3014F711A0000A9BE993BB11","modelType":"HmIP-WTH-2","modelId":297,"permanentlyReachable":true,"connectionType":"HMIP_RF"} 2022-09-18 18:14:53.821 - info: hmip.0 (2046) ws connection opened 2022-09-18 18:14:53.825 - silly: hmip.0 (2046) updateDeviceStates - SHUTTER_CONTACT - {"id":"3014F711A00000DA49A18AA8","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Fenster- und Türkontakt","lastStatusUpdate":1663521103701,"type":"SHUTTER_CONTACT","functionalChannels":{"0":{"label":"","deviceId":"3014F711A00000DA49A18AA8","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_SABOTAGE","groups":["828ecc11-8f2c-4ab0-9499-4d138be5838d"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-68,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"sabotage":false},"1":{"label":"","deviceId":"3014F711A00000DA49A18AA8","index":1,"groupIndex":1,"functionalChannelType":"SHUTTER_CONTACT_CHANNEL","groups":["04eb9f5a-5088-42f0-8e62-e1255bd9a4e8"],"windowState":"CLOSED","eventDelay":0}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"1.16.8","updateState":"UP_TO_DATE","firmwareVersionInteger":69640,"availableFirmwareVersion":"1.16.8","serializedGlobalTradeItemNumber":"3014F711A00000DA49A18AA8","modelType":"HMIP-SWDO","modelId":258,"permanentlyReachable":false,"connectionType":"HMIP_RF"} 2022-09-18 18:14:53.893 - silly: hmip.0 (2046) updateDeviceStates - WALL_MOUNTED_THERMOSTAT_PRO - {"id":"3014F711A0000A9A49A7071C","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Wandthermostat","lastStatusUpdate":1663521169565,"type":"WALL_MOUNTED_THERMOSTAT_PRO","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0000A9A49A7071C","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_OPERATIONLOCK","groups":["ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-70,"rssiPeerValue":-64,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"operationLockActive":false},"1":{"label":"","deviceId":"3014F711A0000A9A49A7071C","index":1,"groupIndex":1,"functionalChannelType":"WALL_MOUNTED_THERMOSTAT_PRO_CHANNEL","groups":["f4a7dfe6-3ec6-45a3-b7b2-6f438273185f"],"temperatureOffset":0,"actualTemperature":18.7,"setPointTemperature":14,"display":"ACTUAL","humidity":64,"vaporAmount":10.223057179489487}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.8.2","updateState":"UP_TO_DATE","firmwareVersionInteger":133122,"availableFirmwareVersion":"2.8.2","serializedGlobalTradeItemNumber":"3014F711A0000A9A49A7071C","modelType":"HmIP-WTH-2","modelId":297,"permanentlyReachable":true,"connectionType":"HMIP_RF"} 2022-09-18 18:14:53.921 - silly: hmip.0 (2046) updateDeviceStates - SHUTTER_CONTACT - {"id":"3014F711A00000DBE996E627","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Fenster- und Türkontakt","lastStatusUpdate":1663521099405,"type":"SHUTTER_CONTACT","functionalChannels":{"0":{"label":"","deviceId":"3014F711A00000DBE996E627","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_SABOTAGE","groups":["ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-69,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"sabotage":false},"1":{"label":"","deviceId":"3014F711A00000DBE996E627","index":1,"groupIndex":1,"functionalChannelType":"SHUTTER_CONTACT_CHANNEL","groups":["f4a7dfe6-3ec6-45a3-b7b2-6f438273185f"],"windowState":"CLOSED","eventDelay":0}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"1.16.8","updateState":"UP_TO_DATE","firmwareVersionInteger":69640,"availableFirmwareVersion":"1.16.8","serializedGlobalTradeItemNumber":"3014F711A00000DBE996E627","modelType":"HMIP-SWDO","modelId":258,"permanentlyReachable":false,"connectionType":"HMIP_RF"} 2022-09-18 18:14:53.948 - silly: hmip.0 (2046) updateDeviceStates - SHUTTER_CONTACT - {"id":"3014F711A00000DA49A192D3","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Fenster- und Türkontakt","lastStatusUpdate":1663519979110,"type":"SHUTTER_CONTACT","functionalChannels":{"0":{"label":"","deviceId":"3014F711A00000DA49A192D3","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_SABOTAGE","groups":["163598ea-5937-4cae-8e42-2100c2357fbb"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-58,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"sabotage":false},"1":{"label":"","deviceId":"3014F711A00000DA49A192D3","index":1,"groupIndex":1,"functionalChannelType":"SHUTTER_CONTACT_CHANNEL","groups":["e844ada3-d00e-47c9-ac22-90350d68943c"],"windowState":"CLOSED","eventDelay":0}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"1.16.8","updateState":"UP_TO_DATE","firmwareVersionInteger":69640,"availableFirmwareVersion":"1.16.8","serializedGlobalTradeItemNumber":"3014F711A00000DA49A192D3","modelType":"HMIP-SWDO","modelId":258,"permanentlyReachable":false,"connectionType":"HMIP_RF"} 2022-09-18 18:14:54.032 - silly: hmip.0 (2046) updateDeviceStates - HEATING_THERMOSTAT - {"id":"3014F711A0000A1A49A133C4","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Heizung Schlafzimmer","lastStatusUpdate":1663520353122,"type":"HEATING_THERMOSTAT","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0000A1A49A133C4","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_OPERATIONLOCK","groups":["828ecc11-8f2c-4ab0-9499-4d138be5838d"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-60,"rssiPeerValue":-63,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"operationLockActive":true},"1":{"label":"","deviceId":"3014F711A0000A1A49A133C4","index":1,"groupIndex":1,"functionalChannelType":"HEATING_THERMOSTAT_CHANNEL","groups":["04eb9f5a-5088-42f0-8e62-e1255bd9a4e8"],"temperatureOffset":0,"valvePosition":0,"setPointTemperature":5,"valveState":"ADAPTION_DONE","valveActualTemperature":17.9}},"automaticValveAdaptionNeeded":false,"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.2.8","updateState":"UP_TO_DATE","firmwareVersionInteger":131592,"availableFirmwareVersion":"2.2.8","serializedGlobalTradeItemNumber":"3014F711A0000A1A49A133C4","modelType":"HmIP-eTRV-2","modelId":295,"permanentlyReachable":true,"connectionType":"HMIP_RF"} 2022-09-18 18:14:54.060 - silly: hmip.0 (2046) updateDeviceStates - WALL_MOUNTED_THERMOSTAT_PRO - {"id":"3014F711A0000A9BE990DC08","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Wandthermostat","lastStatusUpdate":1663521214132,"type":"WALL_MOUNTED_THERMOSTAT_PRO","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0000A9BE990DC08","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_OPERATIONLOCK","groups":["29caf832-ab2e-47b3-bcd7-cc845213741e"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-56,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"operationLockActive":false},"1":{"label":"","deviceId":"3014F711A0000A9BE990DC08","index":1,"groupIndex":1,"functionalChannelType":"WALL_MOUNTED_THERMOSTAT_PRO_CHANNEL","groups":["8b714e95-e28e-4445-80f8-e1e27e94f918"],"temperatureOffset":-0.5,"actualTemperature":19.5,"setPointTemperature":11.5,"display":"ACTUAL","humidity":60,"vaporAmount":10.046363032530428}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.8.2","updateState":"UP_TO_DATE","firmwareVersionInteger":133122,"availableFirmwareVersion":"2.8.2","serializedGlobalTradeItemNumber":"3014F711A0000A9BE990DC08","modelType":"HmIP-WTH-2","modelId":297,"permanentlyReachable":true,"connectionType":"HMIP_RF"} 2022-09-18 18:14:54.142 - silly: hmip.0 (2046) updateDeviceStates - DOOR_BELL_CONTACT_INTERFACE - {"id":"3014F711A00026DD8994356A","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Klingel","lastStatusUpdate":1663519071982,"type":"DOOR_BELL_CONTACT_INTERFACE","functionalChannels":{"0":{"label":"","deviceId":"3014F711A00026DD8994356A","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_BASE","groups":["859f2f39-73f5-497e-a4fc-a3e159a80909"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-49,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null},"1":{"label":"","deviceId":"3014F711A00026DD8994356A","index":1,"groupIndex":1,"functionalChannelType":"MULTI_MODE_INPUT_CHANNEL","groups":["280c60fd-7ae4-4cf8-acad-920edf2b4e13"],"multiModeInputMode":"SWITCH_BEHAVIOR","binaryBehaviorType":"NORMALLY_CLOSE","windowState":"CLOSED","corrosionPreventionActive":false,"doorBellSensorEventTimestamp":1663519066963,"supportedOptionalFeatures":{"IOptionalFeatureLongPressSupported":false,"IOptionalFeatureDoorBellSensorEventTimestamp":true,"IOptionalFeatureWindowState":false}}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"1.0.6","updateState":"UP_TO_DATE","firmwareVersionInteger":65542,"availableFirmwareVersion":"1.0.6","serializedGlobalTradeItemNumber":"3014F711A00026DD8994356A","modelType":"HmIP-DSD-PCB","modelId":410,"permanentlyReachable":false,"connectionType":"HMIP_RF"} 2022-09-18 18:14:54.242 - silly: hmip.0 (2046) updateDeviceStates - HEATING_THERMOSTAT - {"id":"3014F711A0000A1A49A12017","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Heizung Amy","lastStatusUpdate":1663519665112,"type":"HEATING_THERMOSTAT","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0000A1A49A12017","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_OPERATIONLOCK","groups":["29caf832-ab2e-47b3-bcd7-cc845213741e"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-54,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"operationLockActive":true},"1":{"label":"","deviceId":"3014F711A0000A1A49A12017","index":1,"groupIndex":1,"functionalChannelType":"HEATING_THERMOSTAT_CHANNEL","groups":["8b714e95-e28e-4445-80f8-e1e27e94f918"],"temperatureOffset":0,"valvePosition":0,"setPointTemperature":11.5,"valveState":"ADAPTION_DONE","valveActualTemperature":19.5}},"automaticValveAdaptionNeeded":false,"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.2.8","updateState":"UP_TO_DATE","firmwareVersionInteger":131592,"availableFirmwareVersion":"2.2.8","serializedGlobalTradeItemNumber":"3014F711A0000A1A49A12017","modelType":"HmIP-eTRV-2","modelId":295,"permanentlyReachable":true,"connectionType":"HMIP_RF"} 2022-09-18 18:14:54.272 - silly: hmip.0 (2046) updateDeviceStates - HEATING_THERMOSTAT - {"id":"3014F711A0000A1BE989FC10","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Heizkörperthermostat","lastStatusUpdate":1663521064400,"type":"HEATING_THERMOSTAT","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0000A1BE989FC10","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_OPERATIONLOCK","groups":["163598ea-5937-4cae-8e42-2100c2357fbb"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-63,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"operationLockActive":false},"1":{"label":"","deviceId":"3014F711A0000A1BE989FC10","index":1,"groupIndex":1,"functionalChannelType":"HEATING_THERMOSTAT_CHANNEL","groups":["e844ada3-d00e-47c9-ac22-90350d68943c"],"temperatureOffset":0,"valvePosition":0,"setPointTemperature":5,"valveState":"ADAPTION_DONE","valveActualTemperature":20.6}},"automaticValveAdaptionNeeded":false,"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.2.8","updateState":"UP_TO_DATE","firmwareVersionInteger":131592,"availableFirmwareVersion":"2.2.8","serializedGlobalTradeItemNumber":"3014F711A0000A1BE989FC10","modelType":"HmIP-eTRV-2","modelId":295,"permanentlyReachable":true,"connectionType":"HMIP_RF"} 2022-09-18 18:14:54.344 - silly: hmip.0 (2046) updateDeviceStates - HEATING_THERMOSTAT - {"id":"3014F711A0000A1A49A11344","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Heizung Wohnzimmer","lastStatusUpdate":1663520481674,"type":"HEATING_THERMOSTAT","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0000A1A49A11344","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_OPERATIONLOCK","groups":["ad00b7e6-9f6e-4314-b66a-dd5d7cd9ca2f"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-63,"rssiPeerValue":-54,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"operationLockActive":false},"1":{"label":"","deviceId":"3014F711A0000A1A49A11344","index":1,"groupIndex":1,"functionalChannelType":"HEATING_THERMOSTAT_CHANNEL","groups":["f4a7dfe6-3ec6-45a3-b7b2-6f438273185f"],"temperatureOffset":0,"valvePosition":0,"setPointTemperature":14,"valveState":"ADAPTION_DONE","valveActualTemperature":18.7}},"automaticValveAdaptionNeeded":false,"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.2.8","updateState":"UP_TO_DATE","firmwareVersionInteger":131592,"availableFirmwareVersion":"2.2.8","serializedGlobalTradeItemNumber":"3014F711A0000A1A49A11344","modelType":"HmIP-eTRV-2","modelId":295,"permanentlyReachable":true,"connectionType":"HMIP_RF"} 2022-09-18 18:14:54.384 - silly: hmip.0 (2046) updateDeviceStates - HOME_CONTROL_ACCESS_POINT - {"id":"3014F711A00003DA49A248DC","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"HOME_CONTROL_ACCESS_POINT","lastStatusUpdate":1663521118105,"type":"HOME_CONTROL_ACCESS_POINT","functionalChannels":{"0":{"label":"","deviceId":"3014F711A00003DA49A248DC","index":0,"groupIndex":0,"functionalChannelType":"ACCESS_CONTROLLER_CHANNEL","groups":[],"unreach":false,"lowBat":null,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":null,"rssiPeerValue":null,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":false,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":false,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"signalBrightness":0.5,"accessPointPriority":1,"dutyCycleLevel":2,"carrierSenseLevel":0}},"manufacturerCode":1,"oem":"eQ-3","liveUpdateState":"LIVE_UPDATE_NOT_SUPPORTED","firmwareVersion":"2.4.24","updateState":"BACKGROUND_UPDATE_NOT_SUPPORTED","firmwareVersionInteger":132120,"availableFirmwareVersion":"2.4.24","serializedGlobalTradeItemNumber":"3014F711A00003DA49A248DC","modelType":"HmIP-HAP","modelId":270,"permanentlyReachable":true,"connectionType":"HMIP_LAN"} 2022-09-18 18:14:54.453 - silly: hmip.0 (2046) updateDeviceStates - WALL_MOUNTED_THERMOSTAT_PRO - {"id":"3014F711A0000A9A49A4C2C7","homeId":"c5198d97-8573-4ea1-b3b9-9810103e0824","label":"Wandthermostat","lastStatusUpdate":1663521281064,"type":"WALL_MOUNTED_THERMOSTAT_PRO","functionalChannels":{"0":{"label":"","deviceId":"3014F711A0000A9A49A4C2C7","index":0,"groupIndex":0,"functionalChannelType":"DEVICE_OPERATIONLOCK","groups":["828ecc11-8f2c-4ab0-9499-4d138be5838d"],"unreach":false,"lowBat":false,"routerModuleEnabled":false,"multicastRoutingEnabled":false,"routerModuleSupported":false,"rssiDeviceValue":-67,"rssiPeerValue":-62,"configPending":false,"dutyCycle":false,"deviceOverloaded":false,"coProUpdateFailure":false,"coProFaulty":false,"coProRestartNeeded":false,"deviceUndervoltage":false,"deviceOverheated":false,"temperatureOutOfRange":false,"devicePowerFailureDetected":false,"supportedOptionalFeatures":{"IFeatureDeviceParticulateMatterSensorCommunicationError":false,"IFeatureDeviceCoProRestart":false,"IFeatureDeviceOverheated":false,"IOptionalFeatureDutyCycle":true,"IFeatureMulticastRouter":false,"IFeaturePowerShortCircuit":false,"IFeatureDeviceDriveModeError":false,"IFeatureDeviceTemperatureHumiditySensorCommunicationError":false,"IFeatureDeviceDriveError":false,"IFeatureRssiValue":true,"IFeatureBusConfigMismatch":false,"IFeatureDeviceOverloaded":false,"IOptionalFeatureDisplayContrast":false,"IFeatureDeviceIdentify":false,"IOptionalFeatureLowBat":true,"IOptionalFeatureMountingOrientation":false,"IFeatureDeviceTemperatureHumiditySensorError":false,"IFeatureDeviceTemperatureOutOfRange":false,"IOptionalFeatureDeviceErrorLockJammed":false,"IFeatureProfilePeriodLimit":false,"IFeatureDeviceCoProUpdate":false,"IFeatureDevicePowerFailure":false,"IFeatureShortCircuitDataLine":false,"IFeatureDeviceCommunicationError":false,"IFeatureDeviceUndervoltage":false,"IFeatureDeviceParticulateMatterSensorError":false,"IFeatureDeviceCoProError":false},"busConfigMismatch":null,"powerShortCircuit":null,"shortCircuitDataLine":null,"profilePeriodLimitReached":null,"mountingOrientation":null,"temperatureHumiditySensorError":null,"temperatureHumiditySensorCommunicationError":null,"particulateMatterSensorError":null,"particulateMatterSensorCommunicationError":null,"displayContrast":null,"lockJammed":null,"deviceDriveError":null,"deviceDriveModeError":null,"deviceCommunicationError":null,"operationLockActive":false},"1": -
    RE: Klingelsignalerkennung HmIP-DSD-PCBposted in ioBroker Allgemein
ok.... Geklingelt, ausgegeben und kein neuer Log.
