@thomas-braun @ro75 danke euch. Ich hab mal auf jsonl umgestellt und beobachte weiter. Sonst hilft nur das upgrade der HW
Latest posts made by retostoeckli
RE: Systemabsturz nach Raspi updating repositoryposted in Error/Bug
Schon 2-3 mal beobachtet. Nach dem Updating des repository schiesst sich das System, respektive so wie ich vermute der Redis Server.
Danach läuft mal 1-2 Minuten nichts, bis sich das System irgendwie wieder fängt.2024-12-28 14:50:24.175 - info: admin.0 (66276) Request actual repository... 2024-12-28 14:50:24.797 - info: host.raspberrypi4 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json" 2024-12-28 14:50:30.875 - info: admin.0 (66276) Repository received successfully. 2024-12-28 15:13:57.576 - error: sourceanalytix.0 (66754) States database error: read ECONNRESET 2024-12-28 15:13:57.648 - error: sprinklecontrol.0 (66773) States database error: write ECONNRESET 2024-12-28 15:13:57.669 - error: swiss-weather-api.0 (66790) States database error: write ECONNRESET 2024-12-28 15:13:57.723 - error: broadlink2.0 (66409) States database error: write ECONNRESET 2024-12-28 15:13:57.732 - error: device-watcher.0 (66449) States database error: write ECONNRESET 2024-12-28 15:13:57.732 - error: telegram.0 (264790) States database error: read ECONNRESET 2024-12-28 15:13:57.747 - error: javascript.0 (66332) States database error: write ECONNRESET 2024-12-28 15:13:57.746 - error: history.0 (66303) States database error: read ECONNRESET 2024-12-28 15:13:57.735 - error: device-watcher.0 (66449) Objects database error: read ECONNRESET 2024-12-28 15:13:57.624 - error: echarts.0 (66666) States database error: write ECONNRESET 2024-12-28 15:13:57.873 - error: chromecast.0 (66428) Wohnzimmer - Error disconnecting - TypeError: Cannot read properties of null (reading 'socket') 2024-12-28 15:13:57.572 - error: simple-api.0 (66728) States database error: read ECONNRESET 2024-12-28 15:13:57.626 - error: notification-manager.0 (66494) States database error: write ECONNRESET 2024-12-28 15:13:57.805 - error: backitup.0 (66394) States database error: write ECONNRESET 2024-12-28 15:13:57.684 - error: lgtv.0 (67140) States database error: write ECONNRESET 2024-12-28 15:13:57.722 - error: sainlogic.0 (66709) Objects database error: write EPIPE 2024-12-28 15:13:58.032 - error: sainlogic.0 (66709) States database error: write ECONNRESET 2024-12-28 15:13:57.426 - info: harmony.0 (66464) [CONNECT] lost Connection to Harmony Wohnzimmer Hub (192.168.0.43) 2024-12-28 15:13:58.031 - error: harmony.0 (66464) States database error: write ECONNRESET 2024-12-28 15:13:57.732 - error: text2command.0 (66835) States database error: write ECONNRESET 2024-12-28 15:13:57.670 - error: web.0 (66868) States database error: read ECONNRESET 2024-12-28 15:13:57.883 - error: ping.0 (67117) States database error: write ECONNRESET 2024-12-28 15:13:57.682 - error: iot.0 (66682) States database error: read ECONNRESET 2024-12-28 15:03:20.330 - info: mqtt.0 (66479) Client [SL3P_35736FF4] connection closed: timeout 2024-12-28 15:13:58.197 - error: mqtt.0 (66479) States database error: write ECONNRESET 2024-12-28 15:13:58.198 - info: mqtt.0 (66479) Client [] connection closed: timeout 2024-12-28 15:13:58.236 - info: iot.0 (66682) Connection changed: disconnect 2024-12-28 15:13:58.237 - info: iot.0 (66682) Connection lost 2024-12-28 15:13:57.936 - error: rest-api.0 (66698) States database error: write ECONNRESET 2024-12-28 15:13:57.878 - error: tuya.0 (66587) States database error: write EPIPE 2024-12-28 15:13:58.244 - error: mqtt.0 (66479) Objects database error: read ECONNRESET 2024-12-28 15:13:58.445 - error: zigbee.0 (284006) States database error: write ECONNRESET 2024-12-28 15:13:58.424 - error: socketio.0 (66743) States database error: write ECONNRESET 2024-12-28 15:13:58.582 - error: host.raspberrypi4 States database error: write ECONNRESET 2024-12-28 15:13:58.638 - error: host.raspberrypi4 Objects database error: read ECONNRESET 2024-12-28 15:13:58.678 - error: pushover.0 (66349) States database error: write ECONNRESET 2024-12-28 15:13:58.964 - error: scenes.0 (66360) States database error: write ECONNRESET 2024-12-28 15:13:58.991 - error: chromecast.0 (66428) States database error: write EPIPE 2024-12-28 15:13:59.079 - error: dreame.0 (66651) States database error: write ECONNRESET 2024-12-28 15:13:58.879 - error: rpi2.0 (66529) States database error: read ECONNRESET 2024-12-28 15:13:59.406 - error: discovery.0 (66631) States database error: write ECONNRESET 2024-12-28 15:13:59.443 - info: harmony.0 (66464) [CONNECT] Connected to Harmony Wohnzimmer Hub (192.168.0.43) 2024-12-28 15:13:57.667 - error: shelly.0 (177635) Objects database error: write EPIPE 2024-12-28 15:13:58.354 - error: shelly.0 (177635) States database error: write EPIPE 2024-12-28 15:14:00.625 - info: shelly.0 (177635) [MQTT] Client Close: 192.168.0.121 (shellyplus1pm / shellyplus1pm-441793932584 / shellyplus1pm#441793932584#1) (false) 2024-12-28 15:14:02.661 - info: sprinklecontrol.0 (66773) Objects database successfully reconnected 2024-12-28 15:14:02.672 - info: sourceanalytix.0 (66754) Objects database successfully reconnected 2024-12-28 15:14:02.705 - info: swiss-weather-api.0 (66790) Objects database successfully reconnected 2024-12-28 15:14:02.750 - info: device-watcher.0 (66449) Objects database successfully reconnected 2024-12-28 15:14:02.751 - info: device-watcher.0 (66449) Objects database successfully reconnectedDer Redis Server melded jeweils zur gleichen Zeit:
* redis-server.service - Advanced key-value store Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; preset: enabled) Active: active (running) since Sat 2024-12-28 15:14:16 CET; 1h 54min ago Docs: http://redis.io/documentation, man:redis-server(1) Main PID: 287147 (redis-server) Status: "Ready to accept connections" Tasks: 6 (limit: 3916) CPU: 8min 42.178s CGroup: /system.slice/redis-server.service `-287147 "/usr/bin/redis-server 127.0.0.1:6379" Dec 28 15:13:58 raspberrypi4 systemd[1]: redis-server.service: Main process exited, code=killed, status=9/KILL Dec 28 15:13:58 raspberrypi4 systemd[1]: redis-server.service: Failed with result 'signal'. Dec 28 15:13:58 raspberrypi4 systemd[1]: redis-server.service: Consumed 1h 42min 12.683s CPU time. Dec 28 15:13:59 raspberrypi4 systemd[1]: redis-server.service: Scheduled restart job, restart counter is at 4. Dec 28 15:13:59 raspberrypi4 systemd[1]: Stopped redis-server.service - Advanced key-value store. Dec 28 15:13:59 raspberrypi4 systemd[1]: redis-server.service: Consumed 1h 42min 12.683s CPU time. Dec 28 15:13:59 raspberrypi4 systemd[1]: Starting redis-server.service - Advanced key-value store... Dec 28 15:14:16 raspberrypi4 systemd[1]: Started redis-server.service - Advanced key-value store.An was kann das liegen?
Bitte ausfüllen:
- js-controller Version: 7.0.3
- Admin Version: 7.1.5
- Hardwaresystem: Pi4
- Arbeitsspeicher: 4 GB
- Festplattenart: SD-Karte,..
- Betriebssystem: ...
- Nodejs-Version: .20.18.1
- NPM-Version: ...10.8.2
- Installationsart: Skript
- Image, Docker genutzt: Nein
Script v.2024-10-19 *** BASE SYSTEM *** Static hostname: raspberrypi4 Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.62+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 17:29:56 up 5 days, 8:18, 2 users, load average: 0.74, 0.42, 0.43 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred *** TIME AND TIMEZONES *** Local time: Sat 2024-12-28 17:29:56 CET Universal time: Sat 2024-12-28 16:29:56 UTC RTC time: n/a Time zone: Europe/Zurich (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 4.0G 3.2G 587M 286K 280M 790M Swap: 209M 37M 172M Total: 4.2G 3.2G 760M Active iob-Instances: 33 3791 M total memory 3037 M used memory 1763 M active memory 1334 M inactive memory 560 M free memory 29 M buffer memory 238 M swap cache 199 M total swap 35 M used swap 164 M free swap *** top - Table Of Processes *** top - 17:29:57 up 5 days, 8:18, 2 users, load average: 0.74, 0.42, 0.43 Tasks: 198 total, 1 running, 197 sleeping, 0 stopped, 0 zombie %Cpu(s): 14.3 us, 0.0 sy, 0.0 ni, 85.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3791.9 total, 560.5 free, 3037.7 used, 268.1 buff/cache MiB Swap: 200.0 total, 164.5 free, 35.4 used. 754.2 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** 1 CRITICAL ERRORS DETECTED! Check 'sudo dmesg --level=emerg,alert,crit -T' for details *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 380M 1.2M 379M 1% /run /dev/mmcblk0p2 ext4 29G 7.9G 20G 29% / tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 65M 446M 13% /boot/firmware tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Dec 23 09:11:12 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:A2:09:83 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=e6a5e38d-02 rootfstype=ext4 fsck.repair=yes rootwait [Mon Dec 23 09:11:15 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none. [Mon Dec 23 09:11:16 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.7G /var/ 2.1G /var/lib 1.9G /var/lib/redis 226M /var/log 224M /var/log/journal/1f3048c74be54e7dafe9fd893512ef3a Archived and active journals take up 223.7M in the file system. /opt/iobroker/backups: 75M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 196M /opt/iobroker/iobroker-data/ 129M /opt/iobroker/iobroker-data/history 62M /opt/iobroker/iobroker-data/files 31M /opt/iobroker/iobroker-data/files/backitup.admin 31M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js The five largest files in iobroker-data are: 14M /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js 7.0M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map 5.6M /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js 5.5M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map 5.0M /opt/iobroker/iobroker-data/objects.jsonl USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816081001-if00 Your zigbee.0 COM-Port is matching 'by-id'. Very good! *** NodeJS-Installation *** /usr/bin/nodejs v20.18.1 /usr/bin/node v20.18.1 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.29.4 nodejs: Installed: 20.18.1-1nodesource1 Candidate: 20.18.1-1nodesource1 Version table: *** 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. At least one iobroker host is running. Objects type: redis States type: redis Hosts: raspberrypi4 raspberrypi4 (version: 7.0.3, hostname: raspberrypi4 , alive, uptime: 2481) Core adapters versions js-controller: 7.0.3 admin: 7.1.5 javascript: 8.8.3 nodejs modules from github: 3 +-- iobroker.dreame@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.dreame.git#741b3bc2ab551669c0e4a47ae176967518cfca90) +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19) +-- iobroker.sprinklecontrol@0.2.13 (git+ssh://git@github.com/Dirk-Peter-md/ioBroker.sprinklecontrol.git#b9bbf48c1de1215c059d1c653ee5631d448d8cc7) Adapter State + system.adapter.admin.0 : admin : raspberrypi4 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : raspberrypi4 - enabled + system.adapter.broadlink2.0 : broadlink2 : raspberrypi4 - enabled + system.adapter.chromecast.0 : chromecast : raspberrypi4 - enabled + system.adapter.device-watcher.0 : device-watcher : raspberrypi4 - enabled system.adapter.devices.0 : devices : raspberrypi4 - disabled + system.adapter.discovery.0 : discovery : raspberrypi4 - enabled + system.adapter.dreame.0 : dreame : raspberrypi4 - enabled + system.adapter.echarts.0 : echarts : raspberrypi4 - enabled system.adapter.habpanel.0 : habpanel : raspberrypi4 - disabled + system.adapter.harmony.0 : harmony : raspberrypi4 - enabled + system.adapter.history.0 : history : raspberrypi4 - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4 - disabled system.adapter.icons-material-png.0 : icons-material-png : raspberrypi4 - disabled system.adapter.icons-material-svg.0 : icons-material-svg : raspberrypi4 - disabled + system.adapter.iot.0 : iot : raspberrypi4 - enabled + system.adapter.javascript.0 : javascript : raspberrypi4 - enabled + system.adapter.lgtv.0 : lgtv : raspberrypi4 - enabled + system.adapter.mqtt.0 : mqtt : raspberrypi4 - enabled, port: 1883, bind: 192.168.0.54 + system.adapter.notification-manager.0 : notification-manager : raspberrypi4 - enabled + system.adapter.ping.0 : ping : raspberrypi4 - enabled + system.adapter.pushover.0 : pushover : raspberrypi4 - enabled + system.adapter.rest-api.0 : rest-api : raspberrypi4 - enabled, port: 8093, bind: 0.0.0.0, run as: admin + system.adapter.rpi2.0 : rpi2 : raspberrypi4 - enabled + system.adapter.sainlogic.0 : sainlogic : raspberrypi4 - enabled, port: 8099, bind: 0.0.0.0 + system.adapter.scenes.0 : scenes : raspberrypi4 - enabled + system.adapter.shelly.0 : shelly : raspberrypi4 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypi4 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.socketio.0 : socketio : raspberrypi4 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi4 - enabled + system.adapter.sprinklecontrol.0 : sprinklecontrol : raspberrypi4 - enabled + system.adapter.swiss-weather-api.0 : swiss-weather-api : raspberrypi4 - enabled system.adapter.telegram-menu.0 : telegram-menu : raspberrypi4 - disabled + system.adapter.telegram.0 : telegram : raspberrypi4 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : raspberrypi4 - enabled + system.adapter.tuya.0 : tuya : raspberrypi4 - enabled system.adapter.vis.0 : vis : raspberrypi4 - enabled + system.adapter.web.0 : web : raspberrypi4 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi4 - enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816081001-if00 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi4 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : raspberrypi4 - enabled, port: 1883, bind: 192.168.0.54 + system.adapter.rest-api.0 : rest-api : raspberrypi4 - enabled, port: 8093, bind: 0.0.0.0, run as: admin + system.adapter.sainlogic.0 : sainlogic : raspberrypi4 - enabled, port: 8099, bind: 0.0.0.0 + system.adapter.shelly.0 : shelly : raspberrypi4 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypi4 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.socketio.0 : socketio : raspberrypi4 - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : raspberrypi4 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi4 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi4 - enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816081001-if00 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.1.5 , installed 7.1.5 Adapter "backitup" : 3.0.25 , installed 3.0.25 Adapter "broadlink2" : 2.3.0 , installed 2.3.0 Adapter "chromecast" : 4.0.0 , installed 4.0.0 Adapter "device-watcher": 2.12.1 , installed 2.12.1 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "echarts" : 1.9.2 , installed 1.9.2 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "harmony" : 1.5.0 , installed 1.5.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-material-svg": 0.1.0, installed 0.1.0 Adapter "iot" : 3.3.0 , installed 3.3.0 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.3 [Updatable] Adapter "lgtv" : 2.3.1 , installed 2.3.1 Adapter "mqtt" : 6.1.2 , installed 6.1.2 Adapter "notification-manager": 1.2.1, installed 1.2.1 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pushover" : 4.1.0 , installed 4.1.0 Adapter "rest-api" : 2.0.3 , installed 2.0.3 Adapter "rpi2" : 2.2.1 , installed 2.2.1 Adapter "sainlogic" : 0.11.4 , installed 0.11.4 Adapter "scenes" : 3.2.3 , installed 3.0.4 [Updatable] Adapter "shelly" : 8.2.1 , installed 8.2.1 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sprinklecontrol": 0.2.13 , installed 0.2.13 Adapter "swiss-weather-api": 2.2.2, installed 2.2.2 Adapter "telegram" : 3.9.0 , installed 3.9.0 Adapter "telegram-menu": 2.1.3 , installed 2.1.3 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tuya" : 3.16.0 , installed 3.16.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.2 , installed 2.6.2 Adapter "zigbee" : 1.10.3 , installed 1.10.3 Objects and States Please stand by - This may take a while Objects: 12761 States: 11090 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease Hit:6 https://packages.redis.io/deb bookworm InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 106 3555271 287147/redis-server tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 3601926 291083/io.shelly.0 tcp 0 0 0.0.0.0:8099 0.0.0.0:* LISTEN 1001 3602063 291221/io.sainlogic tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 5657 672/sshd: /usr/sbin tcp 0 0 192.168.0.54:1883 0.0.0.0:* LISTEN 1001 3603771 290989/io.mqtt.0 tcp6 0 0 ::1:6379 :::* LISTEN 106 3555272 287147/redis-server tcp6 0 0 :::8084 :::* LISTEN 1001 3602097 291255/io.socketio. tcp6 0 0 :::8087 :::* LISTEN 1001 3604724 291240/io.simple-ap tcp6 0 0 :::8081 :::* LISTEN 1001 3600993 290779/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 3602244 291376/io.web.0 tcp6 0 0 :::8093 :::* LISTEN 1001 3603971 291207/io.rest-api. tcp6 0 0 :::22 :::* LISTEN 0 5659 672/sshd: /usr/sbin tcp6 0 0 :::61991 :::* LISTEN 1001 3601824 290974/io.harmony.0 udp 0 0 0.0.0.0:51697 0.0.0.0:* 1001 3623456 290925/io.broadlink udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 3604523 291098/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 3604524 291098/io.tuya.0 udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 3601825 290974/io.harmony.0 udp 0 0 0.0.0.0:15001 0.0.0.0:* 1001 3603660 290925/io.broadlink udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 3603695 290940/io.chromecas udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 6414 540/avahi-daemon: r udp 0 0 0.0.0.0:42359 0.0.0.0:* 1001 3603663 290925/io.broadlink udp 0 0 0.0.0.0:52846 0.0.0.0:* 104 6416 540/avahi-daemon: r udp6 0 0 :::37106 :::* 104 6417 540/avahi-daemon: r udp6 0 0 fe80::b666:a771:981:546 :::* 0 6552 618/NetworkManager udp6 0 0 :::5353 :::* 104 6415 540/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-12-28 17:11:27.217 - info: admin.0 (290779) ==> Connected system.user.admin from ::ffff:192.168.0.49 2024-12-28 17:11:31.663 - info: admin.0 (290779) <== Disconnect system.user.admin from ::ffff:192.168.0.49 admin 2024-12-28 17:13:41.709 - warn: admin.0 (290779) rpi2 has an invalid jsonConfig: [{"instancePath":"/items/_monitoring/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["accordion","alive","autocomplete","autocompleteSendTo","certificate","certificates","checkLicense","checkbox","chips","color","coordinates","cron","custom","datePicker","deviceManager","divider","file","fileSelector","func","header","icon","image","imageSendTo","instance","interface","ip","jsonEditor","language","number","objectId","panel","password","pattern","port","qrCode","room","select","selectSendTo","sendTo","setState","slider","state","staticImage","staticLink","staticText","table","text","textSendTo","timePicker","user","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}] 2024-12-28 17:13:53.876 - info: host.raspberrypi4 stopInstance system.adapter.rpi2.0 (force=false, process=true) 2024-12-28 17:13:53.888 - info: host.raspberrypi4 stopInstance system.adapter.rpi2.0 send kill signal 2024-12-28 17:13:53.889 - info: rpi2.0 (291039) Got terminate signal TERMINATE_YOURSELF 2024-12-28 17:13:53.893 - info: rpi2.0 (291039) terminating 2024-12-28 17:13:53.894 - info: rpi2.0 (291039) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-12-28 17:13:54.392 - info: rpi2.0 (291039) terminating 2024-12-28 17:13:54.449 - info: host.raspberrypi4 instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-12-28 17:13:57.932 - info: host.raspberrypi4 instance system.adapter.rpi2.0 in version "2.2.1" started with pid 292378 2024-12-28 17:14:00.537 - info: rpi2.0 (292378) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3 2024-12-28 17:14:01.027 - info: rpi2.0 (292378) GPIO ports are not configured 2024-12-28 17:14:45.852 - info: history.0 (290794) enabled logging of rpi2.0.memory.memory_free, Alias=false, WriteNulls=true 2024-12-28 17:15:53.928 - info: history.0 (290794) enabled logging of rpi2.0.sdcard.sdcard_boot_used, Alias=false, WriteNulls=true 2024-12-28 17:16:02.572 - warn: zigbee.0 (291437) DeviceAvailability:Failed to ping 0xa4c138b7fd6a2783 TS0505B 2024-12-28 17:16:09.736 - info: history.0 (290794) enabled logging of rpi2.0.sdcard.sdcard_root_used, Alias=false, WriteNulls=true 2024-12-28 17:16:21.591 - info: admin.0 (290779) ==> Connected system.user.admin from ::ffff:192.168.0.49 2024-12-28 17:16:23.478 - info: admin.0 (290779) ==> Connected system.user.admin from ::ffff:192.168.0.49 2024-12-28 17:17:38.907 - info: admin.0 (290779) <== Disconnect system.user.admin from ::ffff:192.168.0.49 echarts-show 2024-12-28 17:17:38.914 - info: admin.0 (290779) <== Disconnect system.user.admin from ::ffff:192.168.0.49 echarts 2024-12-28 17:19:14.992 - info: javascript.0 (290834) script.js.Light.Atrium.Atrium: Atrium On 2024-12-28 17:26:03.346 - info: broadlink2.0 (290925) interface to be used: { netmaskBits: 24, address: '192.168.0.54/24', addrs: [ 192, 168, 0, 54 ], cidr: '192.168.0.54/24', bcaddr: '192.168.0.255' }: 2024-12-28 17:26:03.348 - info: broadlink2.0 (290925) discover [ '192.168.0.181' ] from 192.168.0.181:51697 -
RE: influxdb2 install- Paket kann nicht gefunden werdenposted in InfluxDB
Grund: Debian 32bit installiert
Lösung:
- Backup von ioBroker erstellen
- Neuinstallation Debian 64bit light
- Backup von ioBroker zurückspielen
- Installation von InfluxDB2 wie im Forum beschrieben
Danke allen für den Support
Danke dir 1000x für dein support. -
ach ja
heisst dann wohl - backup ziehen - alles flach machen und 64bit installieren -
@crunchip
autoremove gemacht
Es sagt:pi@iobroker-pi:~ $ sudo apt-get autoremove --purge influxdb Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Paket »influxdb« ist nicht installiert, wird also auch nicht entfernt. 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. pi@iobroker-pi:~ $ apt policy influxdb* influxdb-client: Installiert: (keine) Installationskandidat: 1.6.7~rc0-1 Versionstabelle: 1.6.7~rc0-1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages influxdb-dev: Installiert: (keine) Installationskandidat: (keine) Versionstabelle: influxdb: Installiert: (keine) Installationskandidat: 1.8.10-1 Versionstabelle: 1.8.10-1 500 500 https://repos.influxdata.com/debian stable/main armhf Packages 1.6.7~rc0-1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages -
ja deb ist weg
update sagtpi@iobroker-pi:~ $ sudo apt update OK:1 http://archive.raspberrypi.org/debian bullseye InRelease OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease OK:3 https://repos.influxdata.com/debian stable InRelease OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Alle Pakete sind aktuell. -
alle weg!
na ja .. halt gefühlt schon 14 mal probiert um das Ding zum Laufen zu bringen. Angefangen mit dem Kurs von Mathias, in welchem das alte Packet erwähnt wurde. Ist aber nicht seine Schuld, ich hätte einfach weiter lesen müssen.
Aber nachher ist ja man immer schlauer.
Danke für dein Support - ich schätze es sehr und kenn das aus meinem eignen Job, immer diese DAU
insgesamt 132 drwx------ 4 pi pi 4096 25. Apr 18:26 . drwxr-xr-x 4 root root 4096 3. Feb 2022 .. -rw------- 1 pi pi 20469 25. Apr 17:56 .bash_history -rw-r--r-- 1 pi pi 220 3. Feb 2022 .bash_logout -rw-r--r-- 1 pi pi 3716 23. Apr 14:40 .bashrc -rw-r--r-- 1 root root 2223 25. Apr 15:51 'DISTRIB_ID=Raspbian' -rw-r--r-- 1 root root 2223 25. Apr 15:51 export -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.1 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.10 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.11 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.12 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.13 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.2 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.3 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.4 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.5 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.6 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.7 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.8 -rw-r--r-- 1 pi pi 1684 26. Jan 22:11 influxdata-archive_compat.key.9 drwxr-xr-x 2 pi pi 4096 7. Mai 2022 .iobroker -rw-r--r-- 1 pi pi 1067 5. Apr 19:16 LICENSE drwxr-xr-x 3 pi pi 4096 7. Nov 20:31 .npm -rw-r--r-- 1 pi pi 81 7. Nov 20:31 package-lock.json -rw-r--r-- 1 pi pi 807 3. Feb 2022 .profile -rw-r--r-- 1 pi pi 2196 5. Apr 19:16 README.md -rw------- 1 pi pi 236 14. Dez 15:27 .rediscli_historyMOD-EDIT: Code in code-tags gesetzt!
