    2. P. Hegmar
    • Posts 9
    P. Hegmar
    @P. Hegmar
    P. Hegmar Follow
    Latest posts made by P. Hegmar
    • RE: kein adapter lässt sich mehr update oder installieren
      @thomas-braun said in kein adapter lässt sich mehr update oder installieren:
      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      strange... jetzt dürfts laufen... updates erfolgreich 🙄 ich sag einstweilen mal danke
      P. Hegmar
      P. Hegmar
      @thomas-braun nachdem ich das Verzeichnis unbenannt hab, läuft jetzt das upgrade ewig und hört nicht auf 😕
      NACHTRAG: oops jetzt nach ewigen zeiten rührt sich was 🙄
      P. Hegmar
      P. Hegmar
      @thomas-braun ```
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@8.19.2
      2 info using node@v16.18.1
      3 timing npm:load:whichnode Completed in 1ms
      4 timing config:load:defaults Completed in 11ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
      6 timing config:load:builtin Completed in 3ms
      7 timing config:load:cli Completed in 7ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
      10 timing config:load:project Completed in 8ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
      12 timing config:load:user Completed in 1ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:validate Completed in 1ms
      16 timing config:load:credentials Completed in 3ms
      17 timing config:load:setEnvs Completed in 2ms
      18 timing config:load Completed in 42ms
      19 timing npm:load:configload Completed in 43ms
      20 timing npm:load:mkdirpcache Completed in 3ms
      21 timing npm:load:mkdirplogs Completed in 1ms
      22 verbose title npm install iobroker.info@1.9.22
      23 verbose argv "install" "--save-exact" "iobroker.info@1.9.22"
      24 timing npm:load:setTitle Completed in 4ms
      25 timing config:load:flatten Completed in 11ms
      26 timing npm:load:display Completed in 14ms
      27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
      28 verbose logfile /home/iobroker/.npm/_logs/2022-11-25T22_27_02_222Z-debug-0.log
      29 timing npm:load:logFile Completed in 19ms
      30 timing npm:load:timers Completed in 0ms
      31 timing npm:load:configScope Completed in 0ms
      32 timing npm:load Completed in 89ms
      33 timing arborist:ctor Completed in 2ms
      34 silly logfile start cleaning logs, removing 21 files
      35 timing idealTree:init Completed in 3478ms
      36 timing idealTree:userRequests Completed in 22ms
      37 silly idealTree buildDeps
      38 silly fetch manifest iobroker.info@1.9.22
      39 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      40 silly logfile done cleaning log files
      41 http fetch GET 200 https://registry.npmjs.org/iobroker.info 5853ms (cache updated)
      42 silly placeDep ROOT iobroker.info@1.9.22 REPLACE for: iobroker.inst@3.0.0 want: 1.9.22
      43 timing idealTree:#root Completed in 5907ms
      44 timing idealTree:node_modules/iobroker.info Completed in 0ms
      45 timing idealTree:buildDeps Completed in 5911ms
      46 timing idealTree:fixDepFlags Completed in 36ms
      47 timing idealTree Completed in 9544ms
      48 timing reify:loadTrees Completed in 9545ms
      49 timing reify:diffTrees Completed in 173ms
      50 silly reify mark retired [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
      51 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.info' ]
      52 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript' ]
      53 silly reify moves {
      53 silly reify   '/opt/iobroker/node_modules/osx-temperature-sensor': '/opt/iobroker/node_modules/.osx-temperature-sensor-hwc16MPv',
      53 silly reify   '/opt/iobroker/node_modules/iobroker.info': '/opt/iobroker/node_modules/.iobroker.info-OtqXm2hx',
      53 silly reify   '/opt/iobroker/node_modules/iobroker.javascript': '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
      53 silly reify }
      54 timing reify:rollback:retireShallow Completed in 3ms
      55 timing command:install Completed in 9768ms
      56 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
      57 verbose cwd /opt/iobroker
      58 verbose Linux 5.10.103-v7l+
      59 verbose node v16.18.1
      60 verbose npm  v8.19.2
      61 error code ENOTEMPTY
      62 error syscall rename
      63 error path /opt/iobroker/node_modules/iobroker.javascript
      64 error dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
      65 error errno -39
      66 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
      67 verbose exit -39
      68 timing npm Completed in 10228ms
      69 verbose unfinished npm timer reify 1669415222667
      70 verbose unfinished npm timer reify:retireShallow 1669415232402
      71 verbose code -39
      72 error A complete log of this run can be found in:
      72 error     /home/iobroker/.npm/_logs/2022-11-25T22_27_02_222Z-debug-0.log
      du meinst ? error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript'?
      P. Hegmar
      P. Hegmar
      @p-hegmar keiner eine Idee?
      P. Hegmar
      P. Hegmar
      @thomas-braun aja danke ... ls -a 😉
      4 timing config:load:defaults Completed in 5ms
      10 timing config:load:project Completed in 7ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
      17 timing config:load:setEnvs Completed in 3ms
      18 timing config:load Completed in 35ms
      19 timing npm:load:configload Completed in 36ms
      22 verbose title npm install iobroker.backitup@2.5.6
      23 verbose argv "install" "--save-exact" "iobroker.backitup@2.5.6"
      24 timing npm:load:setTitle Completed in 5ms
      25 timing config:load:flatten Completed in 10ms
      26 timing npm:load:display Completed in 12ms
      28 verbose logfile /home/iobroker/.npm/_logs/2022-11-20T10_34_16_549Z-debug-0.log
      29 timing npm:load:logFile Completed in 18ms
      30 timing npm:load:timers Completed in 1ms
      32 timing npm:load Completed in 79ms
      34 silly logfile start cleaning logs, removing 4 files
      35 silly logfile done cleaning log files
      36 timing idealTree:init Completed in 3621ms
      37 timing idealTree:userRequests Completed in 34ms
      38 silly idealTree buildDeps
      39 silly fetch manifest iobroker.backitup@2.5.6
      40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      41 http fetch GET 200 https://registry.npmjs.org/iobroker.backitup 4889ms (cache revalidated)
      42 silly placeDep ROOT iobroker.backitup@2.5.6 REPLACE for: iobroker.inst@3.0.0 want: 2.5.6
      43 timing idealTree:#root Completed in 4979ms
      44 timing idealTree:node_modules/iobroker.backitup Completed in 1ms
      45 timing idealTree:buildDeps Completed in 4983ms
      46 timing idealTree:fixDepFlags Completed in 68ms
      47 timing idealTree Completed in 8761ms
      48 timing reify:loadTrees Completed in 8764ms
      49 timing reify:diffTrees Completed in 159ms
      51 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.backitup' ]
      53 silly reify   '/opt/iobroker/node_modules/iobroker.backitup': '/opt/iobroker/node_modules/.iobroker.backitup-ZZHwpo6A',
      53 silly reify }
      54 timing reify:rollback:retireShallow Completed in 5ms
      55 timing command:install Completed in 9013ms
      65 error errno -39
      67 verbose exit -39
      68 timing npm Completed in 9395ms
      69 verbose unfinished npm timer reify 1668940456925
      70 verbose unfinished npm timer reify:retireShallow 1668940465910
      71 verbose code -39
      72 error     /home/iobroker/.npm/_logs/2022-11-20T10_34_16_549Z-debug-0.log
      P. Hegmar
      P. Hegmar
      @thomas-braun ah ok danke, kenn mich mit linux nicht so wirklich aus.. was meinst mit angepinnte threads? hast auch ein link?
      P. Hegmar
      P. Hegmar
      @thomas-braun danke für rasche Antwort...
      NPM version: 8.19.2
      Installing iobroker.backitup@2.5.6... (System call)
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
      npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
      npm ERR!     /home/iobroker/.npm/_logs/2022-11-20T10_34_16_549Z-debug-0.log
      host.iobroker-pi Cannot install iobroker.backitup@2.5.6: 217
      Anscheinend bin ich zu blöd dass ich das Logfile finde.... da es das .npm verzeichnis nicht gibt 😕 ?
      P. Hegmar
      P. Hegmar
    • kein adapter lässt sich mehr update oder installieren
      Hallo liebe Leute,
      Hab vor kurzem das Problem das mein ioBroker riesige Log Files produziert... da ich keine Lösung parat hatte spielte ich einfach ein altes Backup ein.
      Jetzt läuft wieder alles ohne große Log Files (wahrscheinlich eine Adapter namens Mii schuld).
      Aber jetzt lässt sich trotz letzten update von iob und node.js (Node.js
      v16.18.1) kein Adapter mehr update oder installieren.
      Fehler: host.iobroker-pi Cannot install iobroker.AdapterNamen
      Weiß hier jemand Rat?
      Danke für Eure Mühen!
      PS.: meine Versionen
      Used repository: Beta (latest)
      Adapter "admin" : 6.2.23 , installed 6.2.23
      Adapter "alexa-timer-vis": 0.1.14 , installed 0.1.14
      Adapter "alexa2" : 3.21.0 , installed 3.21.0
      Adapter "backitup" : 2.5.6 , installed 2.5.5 [Updatable]
      Adapter "cloud" : 4.3.0 , installed 4.3.0
      Adapter "daswetter" : 3.1.4 , installed 3.1.4
      Adapter "discovery" : 3.1.0 , installed 3.1.0
      Adapter "ecovacs-deebot": 1.4.8 , installed 1.4.8
      Adapter "fahrplan" : 1.2.2 , installed 1.2.2
      Adapter "flot" : 1.11.0 , installed 1.11.0
      Adapter "fuelpricemonitor": 0.3.1 , installed 0.3.1
      Adapter "fullybrowser" : 2.1.2 , installed 2.1.2
      Adapter "history" : 2.2.4 , installed 2.2.4
      Adapter "hm-rega" : 3.0.43 , installed 3.0.43
      Adapter "hm-rpc" : 1.15.15 , installed 1.15.15
      Adapter "homeconnect" : 1.1.0 , installed 1.1.0
      Adapter "info" : 1.9.21 , installed 1.9.21
      Adapter "javascript" : 6.1.4 , installed 6.1.4
      Controller "js-controller": 4.0.23 , installed 4.0.23
      Adapter "klf200" : 1.0.1 , installed 1.0.1
      Adapter "kostal-piko-ba": 2.1.0 , installed 2.1.0
      Adapter "luftdaten" : 2.2.4 , installed 2.2.4
      Adapter "mihome-airpurifier": 0.1.8, installed 0.1.8
      Adapter "mihome-vacuum": 3.8.6 , installed 3.8.6
      Adapter "mqtt" : 4.0.7 , installed 4.0.7
      Adapter "node-red" : 4.0.0 , installed 4.0.0
      Adapter "rpi2" : 1.3.2 , installed 1.3.2
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "smartgarden" : 2.0.0 , installed 2.0.0
      Adapter "socketio" : 6.2.0 , installed 6.2.0
      Adapter "statistics" : 2.3.0 , installed 2.3.0
      Adapter "telegram" : 1.15.2 , installed 1.15.2
      Adapter "unifi" : 0.6.3 , installed 0.6.3
      Adapter "unifi-protect": 0.0.12 , installed 0.0.12
      Adapter "vis" : 1.4.15 , installed 1.4.15
      Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
      Adapter "vis-hqwidgets": 1.3.0 , installed 1.3.0
      Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
      Adapter "vis-materialdesign": 0.5.9, installed 0.5.9
      Adapter "vis-metro" : 1.2.0 , installed 1.2.0
      Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
      Adapter "web" : 5.2.12 , installed 5.2.10 [Updatable]
      Adapter "ws" : 2.2.1 , installed 2.2.1
      P. Hegmar
      P. Hegmar
    • Fernzugriff VIS mit 2-Wege Authentifikation möglich?
      Ist es nicht möglich auf VIS extern via mit 2-Wege Authentifikation zuzugreifen?
      Nachtrag: Hab jetzt eine VPN Verbindung gemacht... anders wärs mir lieber, aber besser als ein Stein am Schädl 😉
      lg
      Hegmar
      posted in Cloud Dienste
      P. Hegmar
      P. Hegmar
