    2. randomuser123
    R
    • Posts 8
    randomuser123
    @randomuser123
    randomuser123 Follow
    Latest posts made by randomuser123
    • RE: Tasmota Steckdosen per MQTT + JavaScript direkt ansteuern
      @bananajoe Hi, bezüglich den 60 scripten: Ich habe für mich eine Lösung gefunden die mit nur einem Script funktioniert. Ist zwar in meinem Fall gedacht für ein zigbee2tasmota Gerät, aber da dieses letztendlich auch "nur" tasmota messages verschickt, könnte es (mit ein paar Anpassungen) auch für dich funktionieren. Kannst es dir bei Gelegenheit ja mal anschauen: https://forum.iobroker.net/topic/64570/full-zigbee2tasmota-integration/3?_=1682971332108
      Viele Grüße
      R
      randomuser123
    • RE: full zigbee2tasmota integration
      Ok, I finally had time to find a solution. Thanks to chatGPT 🙂
      The zigbee2tasmota device is connected to a "regular" mqtt client in iobroker (not the sonoff adapter). When a zigbee message arrives it gets forwarded via mqtt to my iobroker as a json string.
      My script parses that json and creates separate states for each of the key:value pairs in the json.
      For sending commands I automatically add an additional state "PowerSet" to devices that have a "Power" state. When I update the PowerSet state, a script creates a json string and writes it into the "mqtt.0.cmnd.ZigbeeGateway.ZbSend" state (see https://tasmota.github.io/docs/Zigbee/#sending-device-commands)
      The advantage of this approach is that I have nothing to do on the iobroker side when I add new zigbee devices, they are handled automatically.
      That's it 🙂 Seems to work well so far. Here's the script in case anyone has a similar problem with zigbee2tasmota:
      // ############## user config
      // where the mqtt messages arrive
      const zigbee2tasmotaSensorObjectId = 'mqtt.0.tele.ZigbeeGateway.SENSOR';
      // where the states of the zigbee devices should appear
      const zbBaseFolder = '0_userdata.0.zigbee2tasmota';
      // ZbSend state, see https://tasmota.github.io/docs/Zigbee/#sending-device-commands
      const zbsendObjId = 'mqtt.0.cmnd.ZigbeeGateway.ZbSend';
      // ############## end user config
      const regexPowerSetStr = `${zbBaseFolder}\\..*PowerSet$`;
      const regexPowerSet = new RegExp(regexPowerSetStr);
      // receive
      on(zigbee2tasmotaSensorObjectId, (obj) => {
        const jsonString = obj.state.val;
        const jsonData = JSON.parse(jsonString);
        // log(`Received JSON string: ${jsonString}`);
        function createObjectsRecursively(parent, data) {
          for (const key in data) {
            const obj = data[key];
            const stateName = `${parent}.${key}`;
            if (typeof obj === 'object') {
              createObjectsRecursively(stateName, obj);
            } else {
              let value = obj;
              // custom handling of special data types
              if (key.toLowerCase() == 'time') {
                value = new Date(obj);
                log("found time")
              // Check if the state already exists. If it does, just update the value.
              // If it does not exist (-> new zigbee device), create the states.
              if (!existsState(stateName)) {
                // If the state does not exist, create it and set the value
                createState(stateName, value, {
                  type: typeof value,
                  role: "value",
                  read: true,
                  write: true
                log(`Created state ${stateName}`);
                // create additional state to set a new value that will be sent to the zigbee device.
                // If I use the normal "Power" state, I am afraid it will trigger the zbSend command
                // everytime it gets updated from the zigbee device itself.
                if (stateName.endsWith("Power")) {
                  let powerSetStateName = stateName + "Set"
                  createState(powerSetStateName, !!value, {
                    name: key + "Set",
                    type: "boolean",
                    role: "value",
                    read: true,
                    write: true
                  log(`Created state ${powerSetStateName}`);
                // potentially add more custom handling for dimmer values, etc
              } else {
                setState(stateName, value);
              // log(`set state ${parent}.${key} with value ${value}`);
        createObjectsRecursively(zbBaseFolder, jsonData);
      // send power on/off
      on(regexPowerSet, (obj) => {
        const objId = obj.id;
        // probably regex is not needed and we can just take .Device or .Name
        // Define a regular expression to match the substring between "ZbReceived" and "PowerSet"
        const regex = /ZbReceived\.(.*?)\.PowerSet/;
        // Use the regular expression to extract the substring
        const match = objId.match(regex);
        if (match) {
          const zbname = match[1];
          let newValue = obj.state.val;
          let zbsendstring = "\{\"Device\": \"" + zbname + "\"\,\"Send\"\:\{\"Power\"\: "+newValue+"\}}"
          log("zbsend: " + zbsendstring)
          setState(zbsendObjId, zbsendstring)
        } else {
          log(`The substring between "ZbReceived" and "PowerSet" not found in ${objId}`);
      PS: sending zigbee commands is only supported for power on/off. I don't have any zigbee devices that have dimmer or hue values or anything else. I guess the script can be adapted to work with those kind of devices, too.
      posted in JavaScript
      R
      randomuser123
    • RE: [gelöst] Aufzählungen Toggeln
      Ok, ja dann würde ich auch einen extra Datenpunkt "alleGaragenlichter" erstellen, der den gewünschten Zustand für alle Lichter angibt.
      Sobald dieser geändert wird, werden alle Lichter auf denjenigen Zustand gesetzt, der in "alleGaragenlichter" steht.
      Den "alleGaragenlichter" kannst du dann mit der Zeile die du im ersten Post geschrieben hast toggeln:
      Setstate(stateid,!getState(stateid).val);
      Ich glaube für scripte gibt es eine Funktion, die bei der Änderung eines Datenpunktes aufgerufen wird. Weiß grad leider nicht wie die Syntax davon ist.
      Jedenfalls kannst du dann innerhalb dieser Funktion den Wert von "alleGaragenlichter" auslesen und alle individuellen Licht-Datenpunkte damit aktualisieren.
      R
      randomuser123
      Ich verstehe es leider noch nicht.
      Hast du mehrere Lichter in der Garage, die separat ein/aus geschaltet werden können, aber du möchtest mit einem Knopfdruck alle zusammen in den Zustand "an" schalten, auch wenn vor dem schalten manche Lichter "an" und andere "aus" waren?
      Und was ist der "gewünschte Zustand", wenn du weder true (=an) noch false (=aus) vorgibst?
      R
      randomuser123
      @ben1983
      Ich würde folgendes probieren (pseudo-code):
      let possibleValuesForStateId = ["on", "off", "somethingelse"];
      let currentState = getState(stateid).val;
      let idxOfCurrentState = possibleValuesForStateId.indexOf(currentState);
      let nextIdx = (idxOfCurrentState + 1) % possibleValuesForStateId.size;
      let nextState = possibleValuesForStateId[nextIdx];
      Setstate(stateid, nextState);
      R
      randomuser123
      Maybe this script https://forum.iobroker.net/topic/48945/tasmota-steckdosen-per-mqtt-javascript-direkt-ansteuern/23 can help, but I don't want to modify a script every time I add a new zigbee device...
      R
      randomuser123
    • full zigbee2tasmota integration
      Re: [JSON](Zigbee und ein undefined)
      I recently bought a zigbee2tasmota device. I managed to set it up with the iobroker.sonoff adapter which allows me to read zigbee sensor values nicely.
      But with the sonoff adapter I can not send control commands, for example to turn on a light or a socket.
      To do that I understand that I have to send a mqtt command, but that is not possible with the sonoff adapter (afaik).
      I can use another mqtt client, but then I don't have the feature of the sonoff adapter that splits up the mqtt json string into separate iobroker objects 😕
      Here's what I would like to achieve:
      • receive tasmota mqtt messages and split them up into separate objects
      • send an mqtt command to tasmota. Ideally by setting for example "myFancyMqtt.0.ZigbeeLight.power = true" will send the appropriate command to my zigbee2tasmota device that will turn on the ZigbeeLight.
      Is there any out-of-the-box solution available as of 2023?
      R
      randomuser123
    • RE: nach Apdate Fehler bei InfluxDB
      Der Thread ist zwar alt, aber ich hatte gerade den selben Fehler (Warnung im iobroker log wegen "ALTER RETENTION POLICY autogen ON iobroker DURATION 0s REPLICATION 1 SHARD DURATION 1w DEFAULT", influxDB 1.8.10, InfluxDB iobroker Adapter 3.1.7)
      Ich habe es so gelöst, dass ich über die Kommandozeile influx geöffnet habe, mich dort als admin authentifiziert, und den Befehl aus dem iobroker log dann direkt eingegeben/ausgeführt habe.
      Mein iobroker verwendet weiterhin den influx-user mit eingeschränkten Rechten. Der influx-Adapter schreibt keine Warning mehr ins logfile.
      R
      randomuser123
