    2. Bj 0
    B
    • Posts 6
    Bj 0
    @Bj 0
    Bj 0 Follow
    Latest posts made by Bj 0
    • RE: js-controller läuft nicht mehr nach Update ioBroker
      @thomas-braun sagte in js-controller läuft nicht mehr nach Update ioBroker:
      @bj-0
      Schaut nicht gut aus. Was sagt
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      nodejs
      v12.22.0
      node
      v12.22.0
      npm
      6.14.11
      nodejs:
      12.22.0-1nodesource1
      B
      Bj 0
      Also so:
      host.raspberrypi	2021-04-03 01:44:56.174	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2021-04-03 01:44:56.174	error	Caught by controller[0]: }
      host.raspberrypi	2021-04-03 01:44:56.174	error	Caught by controller[0]: ]
      host.raspberrypi	2021-04-03 01:44:56.174	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
      host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
      host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: requireStack: [
      host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: {
      host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
      host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
      host.raspberrypi	2021-04-03 01:44:56.173	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
      host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-04-03 01:44:56.172	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
      host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-04-03 01:44:56.171	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
      host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
      host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
      host.raspberrypi	2021-04-03 01:44:56.170	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
      host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
      host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: Require stack:
      host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: Error: Cannot find module 'typescript'
      host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: ^
      host.raspberrypi	2021-04-03 01:44:56.169	error	Caught by controller[0]: throw err;
      host.raspberrypi	2021-04-03 01:44:56.168	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
      host.raspberrypi	2021-04-03 01:44:55.764	info	instance system.adapter.javascript.0 started with pid 5968
      B
      Bj 0
      @crunchip sagte in js-controller läuft nicht mehr nach Update ioBroker:
      @bj-0 sagte in js-controller läuft nicht mehr nach Update ioBroker:
      Habe heute auf die neusten Versionen upgedatet
      die da wären?
      und:
      ioBroker.admin 4.2.1
      B
      Bj 0
      Ich bin neu hier. Wie packe ich Text in CodeTags?
      B
      Bj 0
      die da wären?
      auf diese Versionen:
      Node.js: v12.22.0
      NPM: 6.14.11
      B
      Bj 0
    • js-controller läuft nicht mehr nach Update ioBroker
      Habe heute auf die neusten Versionen upgedatet und javascript.0 steht immer auf rot. Alles andere läuft, ioBroker fix, Neuinstallation js usw. ausgeführt ohne Erfolg.
      Folgendes steht im Log:
      host.raspberrypi	2021-04-03 00:33:54.826	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2021-04-03 00:33:54.826	error	Caught by controller[0]: }
      host.raspberrypi	2021-04-03 00:33:54.826	error	Caught by controller[0]: ]
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: requireStack: [
      host.raspberrypi	2021-04-03 00:33:54.825	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: {
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-04-03 00:33:54.824	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
      host.raspberrypi	2021-04-03 00:33:54.823	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-04-03 00:33:54.822	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-04-03 00:33:54.821	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-04-03 00:33:54.820	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
      host.raspberrypi	2021-04-03 00:33:54.819	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
      host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
      host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: Require stack:
      host.raspberrypi	2021-04-03 00:33:54.818	error	Caught by controller[0]: Error: Cannot find module 'typescript'
      host.raspberrypi	2021-04-03 00:33:54.817	error	Caught by controller[0]: ^
      host.raspberrypi	2021-04-03 00:33:54.817	error	Caught by controller[0]: throw err;
      host.raspberrypi	2021-04-03 00:33:54.816	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
      host.raspberrypi	2021-04-03 00:33:54.412	info	instance system.adapter.javascript.0 started with pid 4402
      host.raspberrypi	2021-04-02 23:33:24.376	info	Restart adapter system.adapter.javascript.0 because enabled
      Hat jemand eine Lösung?
      MOD EDIT: LOG IN CODE TAGS </> GESETZT
      B
      Bj 0
