    2. rupi619
    R
    • Posts 18
    rupi619
    @rupi619
    rupi619 Follow
    Latest posts made by rupi619
    • RE: Bus Error
                              v.2023-10-10
         Static hostname: iobroker
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                              /usr/bin/node           v18.18.2
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              /usr/bin/corepack       0.19.0
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      MEMORY:
      Mem:            909M        486M         83M        0.0K        339M        359M
      Swap:            99M         28M         71M
      Total:          1.0G        514M        155M
      Active iob-Instances:   7
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.12
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                1203
      States:                 957
      Size of iob-Database:
      9.2M    /opt/iobroker/iobroker-data/objects.jsonl
      1.6M    /opt/iobroker/iobroker-data/states.jsonl
      Gefällt es dir jetzt besser? 🙂
      posted in Einsteigerfragen
      R
      rupi619
    • RE: Bus Error
      @thomas-braun ah ich hätte nicht reinschauen sollen 😄 nodejs ist nicht richtig installiert heißt es:
                              v.2023-10-10
               Icon name: computer
            Architecture: arm64
      Kernel:                 aarch64
      Userland:               arm64
      User-ID:                1000
      X-Server:               true
      /home/iobroker/.diag.sh: line 486: nodejs: command not found
                              /usr/bin/node           v16.20.2
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
                              /usr/bin/corepack       0.17.0
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:            909M        537M         72M        0.0K        298M        307M
      Swap:            99M         99M        0.0K
      Total:          1.0G        637M         73M
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                1203
      States:                 956
      5.1M    /opt/iobroker/iobroker-data/objects.jsonl
      720K    /opt/iobroker/iobroker-data/states.jsonl
      R
      rupi619
    • RE: Bus Error
      @thomas-braun ok ich bin jetzt durch soweit. Vielen lieben Dank für die schnelle Unterstützung!
      R
      rupi619
    • RE: Bus Error
      @thomas-braun vielen vielen Dank. Jetzt klappt es wieder. Wie gesagt ich hab es schon mehrmals versucht upzudaten, aber leider ohne Erfolg. Ich bin jetzt auf folgendem Stand:
      Node.js: v16.20.2
      NPM: v8.19.4
      iobroker version: 4.0.23 (denke das ist der jscontroller)
      Admin.0:
      Verfügbare Version:
      6.12.0
      Installierte Version:
      6.3.5
      Dann würde ich jetzt mal alles updaten. Muss ich da die Reihenfolge beachten? Danke nochmal!
      R
      rupi619
    • RE: Bus Error
      das System hab ich schon länger aufgesetzt aber ich bin froh wenn ich nichts updaten muss, weil ich das Problem schon mal hatte, dass beim updaten nichts mehr gegeangen ist 😄 habs mal versucht auf 18 upzudaten, aber hat nicht geklappt.
      iobroker@iobroker:~ $ apt policy nodejs
      nodejs:
        Installed: 16.18.1-deb-1nodesource1
        Candidate: 16.20.2-deb-1nodesource1
        Version table:
           16.20.2-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
       *** 16.18.1-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      R
      rupi619
    • RE: Bus Error
      tut mir Leid. Ich gebe mir Mühe!
      Ausgabe von "iob diag" ist ebenfalls ein error:
      *** iob diag is starting up, please wait ***
      /usr/bin/iobroker: line 12:  2404 Bus error               node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      das einzige was ich abfragen kann ist "node -v":
      v16.18.1
      R
      rupi619
    • Bus Error
      ich wollte gestern einen Adapter updaten. Seitdem kann ich auf den iobroker nicht mehr vernünftig zugreifen. Alle Befehle dauern sehr lange und als Ausgabe bekomme ich nur einen "xxxxx bus error" Hat jemand eine Idee? Achtung ich bin absoluter Neuling in iobroker. Danke für Tipps 🙂
      R
      rupi619
    • RE: iob startet nicht mehr
      @homoran said in iob startet nicht mehr:
      stellt sich mir die Frage nach welcher Anleitung?
      Das war die hier: https://www.youtube.com/watch?v=iMtFhich54w
      Das ist nett 🙂 dann bitte nur Tipps mit denen ich nichts falsch machen kann. Also wie gehe ich am besten vor?
      Bin ich dann richtig, dass ich das Backup so kopieren muss? Welchen Pfad muss ich dann bei xxx eintragen wenn ich das Backup auf meinem Rechner haben will?
      cp /opt/iobroker/backups/ xxx
      R
      rupi619
      @guergen @crunchip Danke für eure Tipps. Es ist nur so, dass ich mich mit Linux nicht auskenne. Ich habe nur nach Anleitung mein System aufgesetzt. Ich habe keine Ahnung wie man ein Verzeichnis öffnet geschweige denn auf meinen Rechner kopiere. Habt ihr vielleicht eine Anleitung für mich?
      Andere Frage, warum funktioniert das eigentlich nicht, dass ich ganz einfach meine Dateien von der 8GB Karte auf die 16GB Karte kopiere?
      R
      rupi619
      @crunchip wie kann ich denn das Backup zurückspielen wenn ich mit BackItUp nichts erstellen kann? ich hab zwar mit "iobroker backup" eins erstellt aber ich habe keine Ahnung wo das ist und wie ich das verwenden kann.
      Ich werd mal alles auf der 16GB Karte neu aufsetzen.
      R
      rupi619
