    2. Setesh
    Setesh
    @Setesh
    76
    Setesh Follow
    Latest posts made by Setesh
    • RE: js-controller
      nach längeren herumprobieren habe ich es geschafft.
      Habe alle Dateien in /opt/iobroker/node_modules/.bin/iobroker per Hand gelöscht und update Prozess neu gestartet.
      Setesh
    • RE: js-controller
      @arteck said in js-controller:
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log
      1476 verbose cwd /opt/iobroker
      1477 verbose Linux 4.15.0-45-generic
      1478 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@1.5.7" "--unsafe-perm" "--production" "--save" "--prefix" "/opt/iobroker"
      1479 verbose node v8.15.0
      1480 verbose npm  v6.8.0
      1481 error path /opt/iobroker/node_modules/.bin/iobroker
      1482 error code EEXIST
      1483 error Refusing to delete /opt/iobroker/node_modules/.bin/iobroker: is outside /opt/iobroker/node_modules/iobroker.js-controller and not a link
      1484 error File exists: /opt/iobroker/node_modules/.bin/iobroker
      1485 error Move it away, and try again.
      1486 verbose exit [ 1, true ]
      Setesh
    • RE: js-controller
      Hallo, danke für die Hilfe
      setesh@Setesh-Dell:/opt/iobroker$ sudo bash /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log
      [sudo] password for setesh:
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 1: 0: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 2: 1: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 3: 1: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 4: 1: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 5: 1: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 6: 1: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 7: 1: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 8: 1: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 9: 1: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 10: 1: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 11: 2: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 12: 3: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 13: 4: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 14: 5: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 15: 6: command not found
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 16: syntax error near unexpected token `('
      /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log: line 16: `7 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 38ms (from cache)'
      Setesh
    • js-controller
      mein iobroker läuft an sich richtig gut, nur seit tagen macht er probleme beim updaten. Ledier lässt sich der js-controller nicht updaten. Da kommt immer folgende Meldung. Hat jemand eine Idee, Plattfourm ist ubuntu.
      Update js-controller from @1.4.2 to @1.5.7
      NPM version: 6.8.0
      npm install iobroker.js-controller@1.5.7 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
      npm WARN onvif-snapshot@1.0.2 requires a peer of onvif@^0.5.5 but none is installed. You must install peer dependencies yourself.
      npm WARN react-beautiful-dnd@8.0.7 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
      npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN react-redux@5.0.7 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
      npm ERR! path /opt/iobroker/node_modules/.bin/iobroker
      npm ERR! code EEXIST
      npm ERR! Refusing to delete /opt/iobroker/node_modules/.bin/iobroker: is outside /opt/iobroker/node_modules/iobroker.js-controller and not a link
      npm ERR! File exists: /opt/iobroker/node_modules/.bin/iobroker
      npm ERR! Move it away, and try again.
      npm ERR!     /home/setesh/.npm/_logs/2019-02-18T07_24_03_724Z-debug.log
      Host "Setesh-Dell" (linux) updated
      Setesh
    • RE: [Erledigt] Sonoff MQTT Dual / 4CH
      Hallo
      ich habe auch einen Sonoff 4CH gekauft und erfolgreich mit Tasmota geflasht. Über Alexa (Echo) klappt schon alles, alle 4CH. Im iobroker habe ich auch das Problem mit nur einem "Power".
      Könnt ihr mir bitte eine Schritt für Schritt Anweisung geben wie ich Power 2 bis Power 4 in den Broker bekomme.
      lg Setesh
      Setesh
