    2. Powerbarzi
    P
    Powerbarzi
    @Powerbarzi
    Powerbarzi Follow
    Latest posts made by Powerbarzi
    • RE: Test Adapter deConz v1.3.x Github/npm
      @Jey-Cee ok, hätte gedacht das die Meldung daher kommt weil ich den Adapter neu gestartet habe, er also erstmal die verbindung trennt, und danach keine mehr aufbaut obwohl er grün wird !
      P
      Powerbarzi
      @Jey-Cee Ich wollte keine beweise anführen, nur behilflich sein 😉 hab da was gefunden, hoffe das richtige !
      2020-03-19 11:15:43.161 - debug: deconz.0 (8887) Websocket connection closed
      etwas weiter noch das,
      2020-03-19 11:15:51.654 - debug: deconz.0 (9173) Code 200: Request succeded get config: {"UTC":"2020-03-19T10:15:51","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF022B84","datastoreversion":"60","devicename":"RaspBee","dhcp":true,"factorynew":false,"fwversion":"0x26520700","gateway":"192.168.0.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.0.17","linkbutton":false,"localtime":"2020-03-19T11:15:51","mac":"dc:a6:32:4d:79:88","modelid":"deCONZ","name":"mein-RaspBee-2","netmask":"255.255.255.0","networkopenduration":60,"ntp":"synced","panid":46081,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2020-03-08T18:22:01","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.75","timeformat":"24h","timezone":"Europe/Berlin","uuid":"c3cbbc69-4e96-4173-aa32-bef178d3b208","websocketnotifyall":true,"websocketport":443,"whitelist":{"04BB84EF55":{"create date":"2020-03-16T17:29:04","last use date":"2020-03-16T19:24:38","name":"Phoscon#B1880x939"},"186B1A528C":{"create date":"2020-03-18T21:41:27","
      Durchaus auch möglich das der Fehler bei mir liegt !
      P
      Powerbarzi
      Bin seit einigen Tagen mit dem Thema am kämpfen.
      Folgende Situation, ioBroker auf Synology im Docker per macvlan, Deconz auf Raspberry 4.
      Lief meine ich alles gut, mit Adapter version 1.3.0
      Adapter grün aber mit der Fehlermeldung (1046) Code 404: Ressource not found get devices: []
      Da ich mich noch am einarbeiten bin beim ioBroker weiß ich nicht ob die Daten richtig kamen.
      Nun hab ich den RaspBee 2 bekommen, weshalb ich Deconz neu aufgesetzt habe und alles neu eingerichtet habe, und seit dem bekam ich den Adapter nicht mehr grün. Nach vielen hin und her und mit direktem installieren von 1.3.1 wird er grün, aber aktualisiert keine werte im ioBroker, die Steuerung von da ist ok.
      Gruß Christian
      P
      Powerbarzi
