    2. horido
    H
    • Topics 6
    • Posts 24
    horido
    @horido
    14
    24
    horido Follow
    Best posts made by horido
    • RE: Blockly Trockner Skript
      @guergen das werde ich jetzt mal ausprobieren. Danke!
      H
      horido
    Latest posts made by horido
    • RE: Iobroker Admin lässt sich nicht öffnen
      Ach so, nein ich bin als user pi unterwegs, wie du ja siehst.
      Nächstes Mal werde ich die Befehlsblöcke mitsenden
      H
      horido
      @glasfaser nur who ergibt pi pts/0 2021-12-25 19:27 (192.168.178.99)
      H
      horido
      @homoran ja iob who
      H
      horido
      Also das who bringt folgende Meldung:
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start                                               Starts the js-con troller
        iobroker stop                                                stops the js-cont roller
        iobroker restart                                             Restarts js-contr oller
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js  debugging session for the adapter instance
        iobroker info                                                Shows the host in fo
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of a dapter
        iobroker install <adapter>                                   Installs a specif ied adapter
        iobroker rebuild <adapter>|self                              Rebuilds a specif ied adapter
        iobroker url <url> [<name>]                                  Install adapter f rom specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter fr om system
        iobroker del <adapter>.<instance>                            Remove adapter in stance
        iobroker update [<repositoryUrl>]                            Update repository  and list adapters
        iobroker upgrade                                             Upgrade managemen t
        iobroker upload                                              Upload management
        iobroker object                                              Object management
        iobroker state                                               State management
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to a dapter instance/s
        iobroker list <type> [<filter>]                              List all entries,  like objects
        iobroker chmod <mode> <file>                                 Change file right s
        iobroker chown <user> <group> <file>                         Change file owner ship
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given  hostname
        iobroker set <adapter>.<instance>                            Change settings o f adapter config
        iobroker license <license.file or license.text>              Update license by  given file
        iobroker cert                                                Certificate manag ement
        iobroker clean <yes>                                         Clears all object s and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specifi ed backup
        iobroker validate <backup name or path>                      Validate a specif ied backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroke r or adapter instance
        iobroker repo [<name>]                                       Show repo informa tion
        iobroker uuid                                                Show uuid of the  installation
        iobroker unsetup                                             Reset license, in stallation secret and language
        iobroker fix                                                 Execute the insta llation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost managem ent
        iobroker compact                                             compact group man agement
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of j s-controller or specified adapter
      Options:
            --help     Show help  [boolean]
        -v, --version  Show version  [boolean]
      @Homoran : Ich habe eigentlich nichts weiter gemacht, wollte eigentlich eben mal reinschauen und das System warten und kam leider nicht mehr drauf, daraufhin hatte ich das erst versucht den Admin-Adapter neu zu insatllieren/ wollte eine neue Instanz erstellt und das funktionierte nicht.
      H
      horido
      @glasfaser vielen Dank, es läuft wieder!
      H
      horido
      @glasfaser
      internal/modules/cjs/loader.js:905
        throw err;
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
          at Function.Module._load (internal/modules/cjs/loader.js:746:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
        throw err;
        requireStack: []
      H
      horido
      @glasfaser ich habe deine Befehle genau so durchprobiert, jedoch kann ich den Admin immer noch nicht erreichen.
      H
      horido
      Ah ok, da ist mir das K zu dem M durch die Lappen gegangen.
      H
      horido
      ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 24. Dez 05:04 2021-12-24_05-04_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 24. Dez 11:50 2021-12-24_11-50_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 24. Dez 15:27 2021-12-24_15-27_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 24. Dez 15:36 2021-12-24_15-36_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 24. Dez 15:38 2021-12-24_15-38_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 24. Dez 18:15 2021-12-24_18-15_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 24. Dez 20:22 2021-12-24_20-22_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 25. Dez 00:00 2021-12-25_00-00_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 25. Dez 05:04 2021-12-25_05-04_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 25. Dez 11:51 2021-12-25_11-51_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 25. Dez 17:09 2021-12-25_17-09_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,8M 25. Dez 17:35 2021-12-25_17-35_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:37 2021-12-25_17-37_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:38 2021-12-25_17-38_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:39 2021-12-25_17-39_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:40 2021-12-25_17-40_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:41 2021-12-25_17-41_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:42 2021-12-25_17-42_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:43 2021-12-25_17-43_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:44 2021-12-25_17-44_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:45 2021-12-25_17-45_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 1,1K 25. Dez 17:46 2021-12-25_17-46_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:47 2021-12-25_17-47_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:48 2021-12-25_17-48_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:49 2021-12-25_17-49_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:50 2021-12-25_17-50_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:51 2021-12-25_17-51_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:52 2021-12-25_17-52_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:53 2021-12-25_17-53_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:54 2021-12-25_17-54_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:55 2021-12-25_17-55_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:56 2021-12-25_17-56_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:57 2021-12-25_17-57_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:58 2021-12-25_17-58_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 17:59 2021-12-25_17-59_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:00 2021-12-25_18-00_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:01 2021-12-25_18-01_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:02 2021-12-25_18-02_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:03 2021-12-25_18-03_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:04 2021-12-25_18-04_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:05 2021-12-25_18-05_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:06 2021-12-25_18-06_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:07 2021-12-25_18-07_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:08 2021-12-25_18-08_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:09 2021-12-25_18-09_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:10 2021-12-25_18-10_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:11 2021-12-25_18-11_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:12 2021-12-25_18-12_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:13 2021-12-25_18-13_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:14 2021-12-25_18-14_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:15 2021-12-25_18-15_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:16 2021-12-25_18-16_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:17 2021-12-25_18-17_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:18 2021-12-25_18-18_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:19 2021-12-25_18-19_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:20 2021-12-25_18-20_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:21 2021-12-25_18-21_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:22 2021-12-25_18-22_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:23 2021-12-25_18-23_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:24 2021-12-25_18-24_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:25 2021-12-25_18-25_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:26 2021-12-25_18-26_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:27 2021-12-25_18-27_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:28 2021-12-25_18-28_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:29 2021-12-25_18-29_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:30 2021-12-25_18-30_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:31 2021-12-25_18-31_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:32 2021-12-25_18-32_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:33 2021-12-25_18-33_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:34 2021-12-25_18-34_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:35 2021-12-25_18-35_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:36 2021-12-25_18-36_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:37 2021-12-25_18-37_objects.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 5,3K 25. Dez 18:38 2021-12-25_18-38_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:39 2021-12-25_18-39_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:40 2021-12-25_18-40_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:41 2021-12-25_18-41_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:42 2021-12-25_18-42_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:43 2021-12-25_18-43_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:44 2021-12-25_18-44_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:45 2021-12-25_18-45_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:46 2021-12-25_18-46_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:47 2021-12-25_18-47_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:48 2021-12-25_18-48_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:49 2021-12-25_18-49_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:50 2021-12-25_18-50_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:51 2021-12-25_18-51_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:52 2021-12-25_18-52_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:53 2021-12-25_18-53_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:54 2021-12-25_18-54_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:55 2021-12-25_18-55_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:56 2021-12-25_18-56_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:57 2021-12-25_18-57_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:58 2021-12-25_18-58_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 18:59 2021-12-25_18-59_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:00 2021-12-25_19-00_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:01 2021-12-25_19-01_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:02 2021-12-25_19-02_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:03 2021-12-25_19-03_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:04 2021-12-25_19-04_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:05 2021-12-25_19-05_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:06 2021-12-25_19-06_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:07 2021-12-25_19-07_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:08 2021-12-25_19-08_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:09 2021-12-25_19-09_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:10 2021-12-25_19-10_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:11 2021-12-25_19-11_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:12 2021-12-25_19-12_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:13 2021-12-25_19-13_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:14 2021-12-25_19-14_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:15 2021-12-25_19-15_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:16 2021-12-25_19-16_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:17 2021-12-25_19-17_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:18 2021-12-25_19-18_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:19 2021-12-25_19-19_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:20 2021-12-25_19-20_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:21 2021-12-25_19-21_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:22 2021-12-25_19-22_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:23 2021-12-25_19-23_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:24 2021-12-25_19-24_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:25 2021-12-25_19-25_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:26 2021-12-25_19-26_objects.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 5,3K 25. Dez 19:27 2021-12-25_19-27_objects.json.gz
      ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep states
      -rw-rwxr--+ 1 iobroker iobroker 124K 23. Dez 20:27 2021-12-23_20-27_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 23. Dez 22:27 2021-12-23_22-27_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 24. Dez 00:28 2021-12-24_00-28_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 124K 24. Dez 02:28 2021-12-24_02-28_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 24. Dez 04:29 2021-12-24_04-29_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 124K 24. Dez 06:29 2021-12-24_06-29_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 124K 24. Dez 08:30 2021-12-24_08-30_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 124K 24. Dez 10:30 2021-12-24_10-30_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 124K 24. Dez 12:30 2021-12-24_12-30_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 124K 24. Dez 14:31 2021-12-24_14-31_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 125K 24. Dez 15:36 2021-12-24_15-36_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 125K 24. Dez 15:37 2021-12-24_15-37_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 125K 24. Dez 15:39 2021-12-24_15-39_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 24. Dez 17:39 2021-12-24_17-39_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 24. Dez 19:39 2021-12-24_19-39_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 24. Dez 21:39 2021-12-24_21-39_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 24. Dez 23:40 2021-12-24_23-40_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 25. Dez 01:40 2021-12-25_01-40_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 03:41 2021-12-25_03-41_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 05:41 2021-12-25_05-41_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 07:42 2021-12-25_07-42_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 09:42 2021-12-25_09-42_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 11:43 2021-12-25_11-43_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 25. Dez 13:43 2021-12-25_13-43_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 15:44 2021-12-25_15-44_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 123K 25. Dez 17:35 2021-12-25_17-35_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:37 2021-12-25_17-37_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:38 2021-12-25_17-38_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:39 2021-12-25_17-39_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:40 2021-12-25_17-40_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:41 2021-12-25_17-41_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:42 2021-12-25_17-42_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:43 2021-12-25_17-43_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:44 2021-12-25_17-44_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:45 2021-12-25_17-45_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:46 2021-12-25_17-46_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:47 2021-12-25_17-47_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:48 2021-12-25_17-48_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:49 2021-12-25_17-49_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:50 2021-12-25_17-50_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:51 2021-12-25_17-51_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:52 2021-12-25_17-52_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:53 2021-12-25_17-53_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:54 2021-12-25_17-54_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:55 2021-12-25_17-55_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:56 2021-12-25_17-56_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:57 2021-12-25_17-57_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:58 2021-12-25_17-58_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 17:59 2021-12-25_17-59_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:00 2021-12-25_18-00_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:01 2021-12-25_18-01_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:02 2021-12-25_18-02_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:03 2021-12-25_18-03_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:04 2021-12-25_18-04_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:05 2021-12-25_18-05_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:06 2021-12-25_18-06_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:07 2021-12-25_18-07_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:08 2021-12-25_18-08_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:09 2021-12-25_18-09_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:10 2021-12-25_18-10_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:11 2021-12-25_18-11_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:12 2021-12-25_18-12_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:13 2021-12-25_18-13_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:14 2021-12-25_18-14_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:15 2021-12-25_18-15_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:16 2021-12-25_18-16_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:17 2021-12-25_18-17_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:18 2021-12-25_18-18_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:19 2021-12-25_18-19_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:20 2021-12-25_18-20_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:21 2021-12-25_18-21_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:22 2021-12-25_18-22_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:23 2021-12-25_18-23_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:24 2021-12-25_18-24_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:25 2021-12-25_18-25_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:26 2021-12-25_18-26_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:27 2021-12-25_18-27_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:28 2021-12-25_18-28_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:29 2021-12-25_18-29_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:30 2021-12-25_18-30_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:31 2021-12-25_18-31_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:32 2021-12-25_18-32_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:33 2021-12-25_18-33_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:34 2021-12-25_18-34_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:35 2021-12-25_18-35_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:36 2021-12-25_18-36_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:37 2021-12-25_18-37_states.json.gz
      -rw-rwxr--+ 1 iobroker iobroker 122K 25. Dez 18:38 2021-12-25_18-38_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:39 2021-12-25_18-39_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:40 2021-12-25_18-40_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:41 2021-12-25_18-41_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:42 2021-12-25_18-42_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:43 2021-12-25_18-43_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:44 2021-12-25_18-44_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:45 2021-12-25_18-45_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:46 2021-12-25_18-46_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:47 2021-12-25_18-47_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:48 2021-12-25_18-48_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:49 2021-12-25_18-49_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:50 2021-12-25_18-50_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:51 2021-12-25_18-51_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:52 2021-12-25_18-52_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:53 2021-12-25_18-53_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:54 2021-12-25_18-54_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:55 2021-12-25_18-55_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:56 2021-12-25_18-56_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:57 2021-12-25_18-57_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:58 2021-12-25_18-58_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 18:59 2021-12-25_18-59_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:00 2021-12-25_19-00_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:01 2021-12-25_19-01_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:02 2021-12-25_19-02_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:03 2021-12-25_19-03_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:04 2021-12-25_19-04_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:05 2021-12-25_19-05_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:06 2021-12-25_19-06_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:07 2021-12-25_19-07_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:08 2021-12-25_19-08_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:09 2021-12-25_19-09_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:10 2021-12-25_19-10_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:11 2021-12-25_19-11_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:12 2021-12-25_19-12_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:13 2021-12-25_19-13_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:14 2021-12-25_19-14_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:15 2021-12-25_19-15_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:16 2021-12-25_19-16_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:17 2021-12-25_19-17_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:18 2021-12-25_19-18_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:19 2021-12-25_19-19_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:20 2021-12-25_19-20_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:21 2021-12-25_19-21_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:22 2021-12-25_19-22_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:23 2021-12-25_19-23_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:24 2021-12-25_19-24_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:25 2021-12-25_19-25_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:26 2021-12-25_19-26_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:27 2021-12-25_19-27_states.json.gz
      -rw-rw-r--+ 1 iobroker iobroker 122K 25. Dez 19:28 2021-12-25_19-28_states.json.gz
      H
      horido
      @homoran also ich habe das besagte How-to gesehen, Problem bei mir ist nur, dass meine Dateien nicht wirklich "auffällig" sind, so wie in dem How-to beschrieben.
      Ach so und ein Back up ist natürlich vorhanden, hatte jetzt nur keine Lust, die gesamte Installation neu aufzusetzen und das Backup einzuspielen.
      H
      horido
