pi@raspberrypi:~ $ apt policy udev
udev:
Installed: 247.3-7+deb11u4
Candidate: 247.3-7+deb11u4
Version table:
*** 247.3-7+deb11u4 500
500 http://deb.debian.org/debian bullseye-proposed-updates/main arm64 Packages
100 /var/lib/dpkg/status
247.3-7+deb11u2 500
500 http://deb.debian.org/debian bullseye/main arm64 Packages
A
Latest posts made by armin0676
RE: Zigbee Sonoff 3.0 usb dongle fehlerposted in Installation
@thomas-braun Ja dachte schon mein adapter ist defekt
Thomas und Arteck ich danke euch beide. Direkt über git zu installieren hat geholfen. Thomas habe das letzte aktualisiert jetzt läuft alles "noch"
@thomas-braun said in Zigbee Sonoff 3.0 usb dongle fehler:
apt policy udev
pi@raspberrypi:~ $ apt policy udev udev: Installed: 247.3-7+deb11u2 Candidate: 247.3-7+deb11u2 Version table: *** 247.3-7+deb11u2 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages 100 /var/lib/dpkg/status -
@thomas-braun Ls: cannot access ‘/dev/serial/by-id’: No such file or directory
Ist alles aktuell -
code_text2023-07-12 00:07:32.848 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1599 2023-07-12 00:07:35.236 - info: admin.0 (1599) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.1, js-controller: 4.0.24 2023-07-12 00:07:35.295 - info: admin.0 (1599) requesting all states 2023-07-12 00:07:35.296 - info: admin.0 (1599) requesting all objects 2023-07-12 00:07:35.909 - info: admin.0 (1599) received all objects 2023-07-12 00:07:36.380 - info: admin.0 (1599) http server listening on port 8081 2023-07-12 00:07:36.381 - info: admin.0 (1599) Use link "http://localhost:8081" to configure. 2023-07-12 00:07:36.391 - info: admin.0 (1599) socket.io server listening on port 8081 2023-07-12 00:07:36.463 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:07:36.510 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin 2023-07-12 00:07:37.894 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:07:38.010 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:07:39.686 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 1626 2023-07-12 00:07:40.146 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:07:40.866 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:07:40.875 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin 2023-07-12 00:07:41.736 - info: discovery.0 (1626) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.1, js-controller: 4.0.24 2023-07-12 00:07:43.968 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin 2023-07-12 00:07:43.976 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1641 2023-07-12 00:08:02.963 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:08:03.689 - info: backitup.0 (1641) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.1, js-controller: 4.0.24 2023-07-12 00:08:02.964 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:08:02.990 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:08:03.045 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin 2023-07-12 00:08:03.049 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin 2023-07-12 00:08:03.050 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin 2023-07-12 00:07:47.893 - info: zigbee.0 (1136) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} 2023-07-12 00:08:09.665 - info: zigbee.0 (1136) Unable to disable LED, unsupported function. 2023-07-12 00:08:09.709 - info: zigbee.0 (1136) --> transmitPower : normal 2023-07-12 00:08:09.724 - info: zigbee.0 (1136) Currently no devices. 2023-07-12 00:08:09.726 - info: zigbee.0 (1136) Zigbee started 2023-07-12 00:08:09.729 - error: zigbee.0 (1136) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms 2023-07-12 00:08:09.732 - error: zigbee.0 (1136) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-12 00:08:09.733 - error: zigbee.0 (1136) unhandled promise rejection: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:08:09.782 - error: zigbee.0 (1136) TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:08:09.783 - error: zigbee.0 (1136) Cannot read properties of undefined (reading 'Error') 2023-07-12 00:08:09.794 - info: zigbee.0 (1136) cleaned everything up... 2023-07-12 00:08:09.797 - info: zigbee.0 (1136) Zigbee: disabling joining new devices. 2023-07-12 00:08:09.832 - info: backitup.0 (1641) [iobroker] backup will be activated at 02:40 every 1 day(s) 2023-07-12 00:08:10.296 - info: zigbee.0 (1136) terminating 2023-07-12 00:08:10.298 - warn: zigbee.0 (1136) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-07-12 00:08:10.855 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2023-07-12 00:08:10.856 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:08:10.856 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 2023-07-12 00:08:10.856 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) 2023-07-12 00:08:10.857 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) 2023-07-12 00:08:10.857 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) 2023-07-12 00:08:10.858 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:08:10.858 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-07-12 00:08:10.861 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled 2023-07-12 00:08:17.946 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:08:32.643 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:08:40.897 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1670 2023-07-12 00:08:41.277 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:08:45.170 - info: zigbee.0 (1670) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 2023-07-12 00:08:45.298 - info: zigbee.0 (1670) delete old Backup files. keep only last 10 2023-07-12 00:08:45.300 - info: zigbee.0 (1670) Starting Zigbee npm ... 2023-07-12 00:08:45.970 - info: zigbee.0 (1670) Installed Version: iobroker.zigbee@1.8.12 2023-07-12 00:08:46.354 - info: zigbee.0 (1670) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} 2023-07-12 00:08:46.364 - info: zigbee.0 (1670) Unable to disable LED, unsupported function. 2023-07-12 00:08:46.382 - info: zigbee.0 (1670) --> transmitPower : normal 2023-07-12 00:08:46.392 - info: zigbee.0 (1670) Currently no devices. 2023-07-12 00:08:46.394 - info: zigbee.0 (1670) Zigbee started 2023-07-12 00:08:46.397 - error: zigbee.0 (1670) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms 2023-07-12 00:08:46.400 - error: zigbee.0 (1670) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-12 00:08:46.401 - error: zigbee.0 (1670) unhandled promise rejection: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:08:46.441 - error: zigbee.0 (1670) TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:08:46.441 - error: zigbee.0 (1670) Cannot read properties of undefined (reading 'Error') 2023-07-12 00:08:46.450 - info: zigbee.0 (1670) cleaned everything up... 2023-07-12 00:08:46.452 - info: zigbee.0 (1670) Zigbee: disabling joining new devices. 2023-07-12 00:08:46.951 - info: zigbee.0 (1670) terminating 2023-07-12 00:08:46.952 - warn: zigbee.0 (1670) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-07-12 00:08:47.521 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2023-07-12 00:08:47.522 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:08:47.522 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 2023-07-12 00:08:47.523 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) 2023-07-12 00:08:47.523 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) 2023-07-12 00:08:47.523 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) 2023-07-12 00:08:47.523 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:08:47.523 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-07-12 00:08:47.524 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled 2023-07-12 00:09:17.581 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1686 2023-07-12 00:09:21.850 - info: zigbee.0 (1686) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 2023-07-12 00:09:21.979 - info: zigbee.0 (1686) delete old Backup files. keep only last 10 2023-07-12 00:09:21.982 - info: zigbee.0 (1686) Starting Zigbee npm ... 2023-07-12 00:09:22.653 - info: zigbee.0 (1686) Installed Version: iobroker.zigbee@1.8.12 2023-07-12 00:09:23.114 - info: zigbee.0 (1686) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} 2023-07-12 00:09:23.123 - info: zigbee.0 (1686) Unable to disable LED, unsupported function. 2023-07-12 00:09:23.142 - info: zigbee.0 (1686) --> transmitPower : normal 2023-07-12 00:09:23.153 - info: zigbee.0 (1686) Currently no devices. 2023-07-12 00:09:23.154 - info: zigbee.0 (1686) Zigbee started 2023-07-12 00:09:23.157 - error: zigbee.0 (1686) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms 2023-07-12 00:09:23.160 - error: zigbee.0 (1686) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-12 00:09:23.161 - error: zigbee.0 (1686) unhandled promise rejection: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:09:23.200 - error: zigbee.0 (1686) TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:09:23.201 - error: zigbee.0 (1686) Cannot read properties of undefined (reading 'Error') 2023-07-12 00:09:23.212 - info: zigbee.0 (1686) cleaned everything up... 2023-07-12 00:09:23.214 - info: zigbee.0 (1686) Zigbee: disabling joining new devices. 2023-07-12 00:09:23.718 - info: zigbee.0 (1686) terminating 2023-07-12 00:09:23.719 - warn: zigbee.0 (1686) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-07-12 00:09:24.283 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2023-07-12 00:09:24.283 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:09:24.284 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 2023-07-12 00:09:24.284 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) 2023-07-12 00:09:24.284 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) 2023-07-12 00:09:24.284 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) 2023-07-12 00:09:24.285 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:09:24.285 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-07-12 00:09:24.288 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled 2023-07-12 00:09:24.289 - warn: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because restart loop detected 2023-07-12 00:09:34.177 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:16:33.798 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:16:37.274 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:16:55.757 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:18:34.317 - info: host.raspberrypi "system.adapter.zigbee.0" disabled 2023-07-12 00:22:49.826 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:50:16.524 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin 2023-07-12 00:50:16.595 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:55:36.055 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 00:56:04.451 - info: host.raspberrypi "system.adapter.zigbee.0" enabled 2023-07-12 00:56:04.560 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2527 2023-07-12 00:56:08.682 - info: zigbee.0 (2527) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 2023-07-12 00:56:08.809 - info: zigbee.0 (2527) delete old Backup files. keep only last 10 2023-07-12 00:56:08.811 - info: zigbee.0 (2527) Starting Zigbee npm ... 2023-07-12 00:56:09.489 - info: zigbee.0 (2527) Installed Version: iobroker.zigbee@1.8.12 2023-07-12 00:56:12.182 - info: zigbee.0 (2527) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} 2023-07-12 00:56:12.191 - info: zigbee.0 (2527) Unable to disable LED, unsupported function. 2023-07-12 00:56:12.209 - info: zigbee.0 (2527) --> transmitPower : normal 2023-07-12 00:56:12.218 - info: zigbee.0 (2527) Currently no devices. 2023-07-12 00:56:12.221 - info: zigbee.0 (2527) Zigbee started 2023-07-12 00:56:12.224 - error: zigbee.0 (2527) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms 2023-07-12 00:56:12.226 - error: zigbee.0 (2527) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-12 00:56:12.228 - error: zigbee.0 (2527) unhandled promise rejection: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:56:12.267 - error: zigbee.0 (2527) TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:56:12.267 - error: zigbee.0 (2527) Cannot read properties of undefined (reading 'Error') 2023-07-12 00:56:12.276 - info: zigbee.0 (2527) cleaned everything up... 2023-07-12 00:56:12.279 - info: zigbee.0 (2527) Zigbee: disabling joining new devices. 2023-07-12 00:56:12.981 - info: zigbee.0 (2527) terminating 2023-07-12 00:56:12.983 - warn: zigbee.0 (2527) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-07-12 00:56:13.624 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2023-07-12 00:56:13.625 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:56:13.626 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 2023-07-12 00:56:13.626 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) 2023-07-12 00:56:13.626 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) 2023-07-12 00:56:13.626 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) 2023-07-12 00:56:13.627 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:56:13.627 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-07-12 00:56:13.627 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled 2023-07-12 00:56:43.688 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2547 2023-07-12 00:56:47.886 - info: zigbee.0 (2547) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 2023-07-12 00:56:48.021 - info: zigbee.0 (2547) delete old Backup files. keep only last 10 2023-07-12 00:56:48.023 - info: zigbee.0 (2547) Starting Zigbee npm ... 2023-07-12 00:56:48.705 - info: zigbee.0 (2547) Installed Version: iobroker.zigbee@1.8.12 2023-07-12 00:56:49.075 - info: zigbee.0 (2547) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} 2023-07-12 00:56:49.085 - info: zigbee.0 (2547) Unable to disable LED, unsupported function. 2023-07-12 00:56:49.103 - info: zigbee.0 (2547) --> transmitPower : normal 2023-07-12 00:56:49.114 - info: zigbee.0 (2547) Currently no devices. 2023-07-12 00:56:49.115 - info: zigbee.0 (2547) Zigbee started 2023-07-12 00:56:49.119 - error: zigbee.0 (2547) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms 2023-07-12 00:56:49.121 - error: zigbee.0 (2547) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-12 00:56:49.122 - error: zigbee.0 (2547) unhandled promise rejection: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:56:49.166 - error: zigbee.0 (2547) TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:56:49.166 - error: zigbee.0 (2547) Cannot read properties of undefined (reading 'Error') 2023-07-12 00:56:49.176 - info: zigbee.0 (2547) cleaned everything up... 2023-07-12 00:56:49.178 - info: zigbee.0 (2547) Zigbee: disabling joining new devices. 2023-07-12 00:56:49.678 - info: zigbee.0 (2547) terminating 2023-07-12 00:56:49.680 - warn: zigbee.0 (2547) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-07-12 00:56:50.241 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2023-07-12 00:56:50.241 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) 2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) 2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) 2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:56:50.242 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-07-12 00:56:50.243 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled 2023-07-12 00:57:20.300 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2564 2023-07-12 00:57:24.478 - info: zigbee.0 (2564) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24 2023-07-12 00:57:24.604 - info: zigbee.0 (2564) delete old Backup files. keep only last 10 2023-07-12 00:57:24.607 - info: zigbee.0 (2564) Starting Zigbee npm ... 2023-07-12 00:57:25.273 - info: zigbee.0 (2564) Installed Version: iobroker.zigbee@1.8.12 2023-07-12 00:57:25.646 - info: zigbee.0 (2564) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}} 2023-07-12 00:57:25.656 - info: zigbee.0 (2564) Unable to disable LED, unsupported function. 2023-07-12 00:57:25.674 - info: zigbee.0 (2564) --> transmitPower : normal 2023-07-12 00:57:25.684 - info: zigbee.0 (2564) Currently no devices. 2023-07-12 00:57:25.685 - info: zigbee.0 (2564) Zigbee started 2023-07-12 00:57:25.689 - error: zigbee.0 (2564) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms 2023-07-12 00:57:25.691 - error: zigbee.0 (2564) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-07-12 00:57:25.692 - error: zigbee.0 (2564) unhandled promise rejection: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:57:25.730 - error: zigbee.0 (2564) TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:57:25.731 - error: zigbee.0 (2564) Cannot read properties of undefined (reading 'Error') 2023-07-12 00:57:25.742 - info: zigbee.0 (2564) cleaned everything up... 2023-07-12 00:57:25.744 - info: zigbee.0 (2564) Zigbee: disabling joining new devices. 2023-07-12 00:57:26.257 - info: zigbee.0 (2564) terminating 2023-07-12 00:57:26.258 - warn: zigbee.0 (2564) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-07-12 00:57:26.822 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error') 2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) 2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) 2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) 2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30) 2023-07-12 00:57:26.824 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-07-12 00:57:26.825 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled 2023-07-12 00:57:26.825 - warn: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because restart loop detected 2023-07-12 01:00:20.538 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 01:09:11.133 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin 2023-07-12 01:09:15.621 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 2023-07-12 10:02:33.406 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 10:02:34.509 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 2023-07-12 10:02:34.539 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 10:02:34.587 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 10:02:38.058 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 2023-07-12 10:02:52.942 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120 2023-07-12 10:02:57.542 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 -
Hallo habe auf neu installierten raspberry pi 4 8gb iobroker installiert schon 4 mal aber, immer wieder gleiche fehler. Habe foto gemacht hoffe kann mir jemand helfen.
RE: Was für hub kaufen?posted in Hardware
Ah ok also gibt es kein universalen hub für alles. Genau das wollte ich wissen. Also ist es ratsam auf homematic zu setzen?
