  4. Iobroker.js-controller lässt sich nicht installieren
    5.8k
5 Beiträge 3 Kommentatoren 2.3k Aufrufe
    stefan0875
    Hallo
    ich habe nach meinen Fehler node 9.x zu installieren jetzt 6.12.0 laufen.
    Leider kann ich iobroker.js-controller mit folgendem Fehler noch immer nicht installieren.
    hat jemand eine Idee was ich noch versuchen kann?
    root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller --production
    npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
    > ursa@0.9.4 install /opt/iobroker/node_modules/ursa
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/ursa/build'
      CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
      SOLINK_MODULE(target) Release/obj.target/ursaNative.node
      COPY Release/ursaNative.node
    make: Leaving directory '/opt/iobroker/node_modules/ursa/build'
    > iobroker.js-controller@1.2.3 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    module.js:471
        throw err;
    Error: Cannot find module '../../../modules/es6.string.code-point-at'
        at Function.Module._resolveFilename (module.js:469:15)
        at Function.Module._load (module.js:417:25)
        at Module.require (module.js:497:17)
        at require (internal/module.js:20:19)
        at Object. <anonymous>(/opt/iobroker/node_modules/code-point-at.js:1:63)
        at Module._compile (module.js:570:32)
        at Object.Module._extensions..js (module.js:579:10)
        at Module.load (module.js:487:32)
        at tryModuleLoad (module.js:446:12)
        at Function.Module._load (module.js:438:3)
    npm ERR! Linux 4.9.35-v7+
    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
    npm ERR! node v6.12.0
    npm ERR! npm  v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! iobroker.js-controller@1.2.3 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@1.2.3 install script 'node iobroker.js setup first'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the iobroker.js-controller package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node iobroker.js setup first
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs iobroker.js-controller
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls iobroker.js-controller
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log</anonymous>
      @stefan0875:
      hat jemand eine Idee was ich noch versuchen kann? `
      cd /opt/iobroker
      sudo iobroker stop
      sudo npm cache clean
      sudo npm install iobroker.js-controller --unsafe-perm
      …und hoffen.
      Rainer
        stefan0875
        Gleiches Ergebnis :(
            at Function.Module._load (module.js:438:3)</anonymous>
        Wo kommt denn normalerweise dieses Modul "es6.string.code-point-at" her?
        Ich werd noch wahnsinnig 😢 :twisted:
        • arteckA Offline
          arteckA Offline
          arteck
          ich tippe mal auf node ..
          mach mal bitte und poste mal das Ergebniss
          ls -l /usr/local/bin/node*
          ls -l /usr/bin/node*
            stefan0875
            Danke für die Hilfe.
            Ich habe npm von Hand gelöscht und nochmal alles neu installiert.
            Mittlerweile funktioniert endlich wieder alles.
            Musste aber von vorne anfangen und ioBroker neu installieren.
            Zum Glück hatte ich ein aktuelles Backup
