  4. Fehlermeldung im DWD Adapter
    1.9k
60 Beiträge 8 Kommentatoren 3.3k Aufrufe 7 Beobachtet
  • L Offline
    Linguistix
    #41
    das sollte der komplette sein
    Gruß René
    • IoBroker auf Windows 10 (Testsystem)
    • IoBroker auf Intel Nuc i3 (Produktivsystem)
    • Homematic IP
    • Rolladenaktor Broll
    • Tür Sensoren
    • Samsung TAB A als Anzeige
    • L Linguistix
      Script v.2026-01-31
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: iobroker
             Icon name: computer-desktop
               Chassis: desktop 🖥️
                Kernel: Linux 6.12.85+deb13-amd64
          Architecture: x86-64
       Hardware Vendor: Intel Corporation
        Hardware Model: D33217CK
      Firmware Version: GKPPT10H.86A.0066.2018.1120.1113
         Firmware Date: Tue 2018-11-20
          Firmware Age: 7y 5month 2w 3d
      OS is similar to:
      model name      : Intel(R) Core(TM) i3-3217U CPU @ 1.80GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       17:32:27 up 59 min,  2 users,  load average: 0.04, 0.20, 0.27
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2026-05-08 17:32:27 CEST
                 Universal time: Fri 2026-05-08 15:32:27 UTC
                       RTC time: Fri 2026-05-08 15:32:27
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      rene
      HOME=/home/rene
      GROUPS=rene adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/rene
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            8.3G        1.3G        4.3G        3.4M        3.0G        6.9G
      Swap:           6.6G          0B        6.6G
      Total:           14G        1.3G         10G
      Active iob-Instances:   9
               7879 M total memory
               1262 M used memory
                872 M active memory
               2526 M inactive memory
               4089 M free memory
                142 M buffer memory
               2688 M swap cache
               6302 M total swap
                  0 M used swap
               6302 M free swap
      top - 17:32:27 up 59 min,  2 users,  load average: 0.04, 0.20, 0.27
      Tasks: 155 total,   1 running, 154 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.2 us,  0.0 sy,  0.0 ni, 97.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7879.6 total,   4087.5 free,   1264.2 used,   2831.3 buff/cache
      MiB Swap:   6303.0 total,   6303.0 free,      0.0 used.   6615.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.8G     0  3.8G   0% /dev
      tmpfs          tmpfs     788M  692K  788M   1% /run
      /dev/sda2      ext4      110G  3.4G  101G   4% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      efivarfs       efivarfs  128K   76K   48K  62% /sys/firmware/efi/efivars
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald        .service
      tmpfs          tmpfs     3.9G  2.6M  3.9G   1% /tmp
      /dev/sda1      vfat      975M  8.8M  966M   1% /boot/efi
      tmpfs          tmpfs     788M  4.0K  788M   1% /run/user/1000
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty6.servi        ce
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.servi        ce
      [Fri May  8 16:32:39 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Fri May  8 16:32:39 2026] EXT4-fs (sda2): mounted filesystem 09472f1d-f53c-4d09        -b9b8-1c6d0b2b3fab ro with ordered data mode. Quota mode: none.
      [Fri May  8 16:32:40 2026] EXT4-fs (sda2): re-mounted 09472f1d-f53c-4d09-b9b8-1c        6d0b2b3fab r/w.
      Show mounted filesystems:
      TARGET      SOURCE    FSTYPE OPTIONS
      /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
      `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,ioch        arset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      514M    /var/
      287M    /var/cache
      280M    /var/cache/apt
      189M    /var/cache/apt/archives
      187M    /var/lib
      Archived and active journals take up 24M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      229M    /opt/iobroker/iobroker-data/
      208M    /opt/iobroker/iobroker-data/files
      57M     /opt/iobroker/iobroker-data/files/vis-2
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      21M     /opt/iobroker/iobroker-data/objects.jsonl
      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
      8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.j        s
      8.0M    /opt/iobroker/iobroker-data/files/daswetter.admin/assets/index-84bRrRlB.        js
      4.1M    /opt/iobroker/iobroker-data/files/vis-2/assets/index-Vp8lqiIh.js
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      No nvbackup.json found.
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.22.2
      /usr/bin/node           v22.22.2
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.22.2-1nodesource1
        Candidate: 22.22.2-1nodesource1
        Version table:
       *** 22.22.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.22.1-1nodesource1 1001
           22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://security.debian.org/debian-security trixie-security/main amd6        4 Packages
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 2117)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.8.23
      javascript:     "javascript" not found
      nodejs modules from github:     0
      Adapter State
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
      + system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        system.adapter.iot.0                    : iot                   : iobroker                                 - disabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
        system.adapter.vis-jsontemplate.0       : vis-jsontemplate      : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.8.23   , installed 7.8.23
      Adapter    "backitup"     : 3.3.14   , installed 3.3.14
      Adapter    "cloud"        : 6.0.1    , installed 5.0.1  [Updatable]
      Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
      Adapter    "history"      : 4.0.0    , installed 4.0.0
      Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "iot"          : 5.0.12   , installed 5.0.12
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "socketio"     : 7.0.8    , installed 7.1.3
      Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
      Adapter    "vis-jsontemplate": 4.4.3 , installed 4.4.3
      Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 8.0.0    , installed 8.0.0
      Adapter    "ws"           : 4.0.0    , installed 4.0.0
      Objects and States
      Objects:        2136
      States:         1153
      Hit:1 http://security.debian.org/debian-security trixie-security InRelease
      Hit:2 http://deb.debian.org/debian trixie InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending systemupdates: 1
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30917      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8301       673/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42257      8869/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42262      8869/iobroker.js-co
      tcp6       0      0 :::111                  :::*                    LISTEN      0          29385      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          8303       673/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       43909      9929/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       47114      9912/io.admin.0
      udp        0      0 192.168.0.86:68         0.0.0.0:*                           0          6714       811/dhcpcd: [BOOTP
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          29383      1/init
      udp6       0      0 :::111                  :::*                                0          29387      1/init
      udp6       0      0 2003:c3:3f3a:9100:5:546 :::*                                0          27393      5559/dhcpcd: [DHCP6
      udp6       0      0 fdd4:279f:7803:0:52:546 :::*                                0          27392      5558/dhcpcd: [DHCP6
      udp6       0      0 fdd4:279f:7803:0:6f:546 :::*                                0          7364       767/dhcpcd: [DHCP6
      udp6       0      0 2003:c3:3f3a:9100:6:546 :::*                                0          7357       751/dhcpcd: [DHCP6
      udp6       0      0 fe80::5043:78fb:8ac:546 :::*                                0          8320       724/dhcpcd: [DHCP6
      2026-05-08 17:26:30.991  - info: host.iobroker iobroker upload [12] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_blue.png splash/splash_new_blue.png image/png
      2026-05-08 17:26:31.000  - info: host.iobroker iobroker upload [11] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_brown.png splash/splash_new_brown.png image/png
      2026-05-08 17:26:31.009  - info: host.iobroker iobroker upload [10] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_green1.png splash/splash_new_green1.png image/png
      2026-05-08 17:26:31.021  - info: host.iobroker iobroker upload [9] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_green2.png splash/splash_new_green2.png image/png
      2026-05-08 17:26:31.032  - info: host.iobroker iobroker upload [8] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_lightblue.png splash/splash_new_lightblue.png image/png
      2026-05-08 17:26:31.041  - info: host.iobroker iobroker upload [7] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_orange.png splash/splash_new_orange.png image/png
      2026-05-08 17:26:31.051  - info: host.iobroker iobroker upload [6] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_pink.png splash/splash_new_pink.png image/png
      2026-05-08 17:26:31.060  - info: host.iobroker iobroker upload [5] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_rose.png splash/splash_new_rose.png image/png
      2026-05-08 17:26:31.069  - info: host.iobroker iobroker upload [4] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_new_violet.png splash/splash_new_violet.png image/png
      2026-05-08 17:26:31.078  - info: host.iobroker iobroker upload [3] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_orange.png splash/splash_orange.png image/png
      2026-05-08 17:26:31.087  - info: host.iobroker iobroker upload [2] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_pink.png splash/splash_pink.png image/png
      2026-05-08 17:26:31.096  - info: host.iobroker iobroker upload [1] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_rose.png splash/splash_rose.png image/png
      2026-05-08 17:26:31.105  - info: host.iobroker iobroker upload [0] icons-addictive-flavour-png /opt/iobroker/node_modules/iobroker.icons-addictive-flavour-png/www/splash/splash_violet.png splash/splash_violet.png image/png
      2026-05-08 17:26:31.154  - info: host.iobroker iobroker host.iobroker object system.adapter.icons-addictive-flavour-png created/updated
      2026-05-08 17:26:31.158  - info: host.iobroker iobroker Updating objects from io-package.json for adapter "icons-addictive-flavour-png" with version "0.1.0"
      2026-05-08 17:26:31.220  - info: host.iobroker iobroker host.iobroker create instance icons-addictive-flavour-png
      2026-05-08 17:26:31.230  - info: host.iobroker iobroker host.iobroker object system.adapter.icons-addictive-flavour-png.upload created
      2026-05-08 17:26:31.236  - info: host.iobroker iobroker host.iobroker object system.adapter.icons-addictive-flavour-png.0 created
      2026-05-08 17:26:32.269  - info: host.iobroker iobroker exit 0
      2026-05-08 17:26:33.678  - info: admin.0 (9912) ==> Connected system.user.admin from ::ffff:192.168.0.42
      2026-05-08 17:30:31.035  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 12342
      2026-05-08 17:30:32.541  - info: dwd.0 (12342) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.2, js-controller: 7.0.7
      2026-05-08 17:30:32.925  - info: dwd.0 (12342) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2026-05-08 17:30:33.465  - info: host.iobroker instance system.adapter.dwd.0 having pid 12342 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2026-05-08 17:32:37.036  - info: admin.0 (9912) <== Disconnect system.user.admin from ::ffff:192.168.0.42
      iob diag has finished.
      HomoranH Offline
      HomoranH Offline
      #42
      @Linguistix sagte:
      rene
      HOME=/home/rene
      Da ist er
      L Thomas BraunT 2 Antworten Letzte Antwort
        @Linguistix sagte:
        rene
        HOME=/home/rene
        Da ist er
        Linguistix
        #43
        @Homoran sagte:
        @Linguistix sagte:
        rene
        HOME=/home/rene
        Da ist er
        gerade auch gesehen :)
        Gruß René
        • Homematic IP
        • Tür Sensoren
          @Linguistix sagte:
          rene
          HOME=/home/rene
          Da ist er
          #44
          @Homoran sagte:
          Da ist er
          Und der Meckerfritze ist auch zufrieden, der Hinweis im Skript ist weg.
          • L Offline
            Linguistix
            #45
            das freut mich, ach meckern darfst ruhig muss mich erst rein fuxen wieder in das ganze gerade was debian angeht, aber der Tip nur Debian zu nutzen war Gold wert und macht auch mega sin. Danke für die echt gute Hilfe
            Gruß René
            • Homematic IP
            • Tür Sensoren
            • L Linguistix
              #46
              @Linguistix
              System auf Stand bringen:
              ioBroker ebenfalls.
              Ansonsten schaut das Setup sehr gut aus.
              • L Offline
                Linguistix
                #47
                ok das klingt ja schon mal nicht schlecht.
                Gruß René
                • Homematic IP
                • Tür Sensoren
                • L Offline
                  Linguistix
                  #48
                  ich hab bei host eine kleine 1 aber sehe nicht wieso, nach update schaut das nicht aus
                  Gruß René
                  • Homematic IP
                  • Tür Sensoren
                  • L Linguistix
                    #49
                    @Linguistix sagte:
                    Die Ziffern kann man anklicken.
                    • L Offline
                      Linguistix
                      #50
                      ah jetzt betriebssystem update, geht das über apt-get update?
                      Gruß René
                      • Homematic IP
                      • Tür Sensoren
                      • L Offline
                        Linguistix
                        #51
                        eine Fehlermeldung hab ich jetzt doch noch bekommen:
                        2026-05-08 17:58:56.519 - warn: host.iobroker instance system.adapter.vis.0 already running with pid 14628
                        Gruß René
                        • Homematic IP
                        • Tür Sensoren
                        • L Linguistix
                          #52
                          @Linguistix
                          sudo apt update
                          sudo apt full-upgrade
                          • hotspot_2H Offline
                            hotspot_2H Offline
                            hotspot_2
                            #53
                            Hallo, ich hoffe das passt hier. Ich habe auch die Fehlermeldungen vom dwd Adapter seit längerer Zeit. Habe nun gesehen das es eine neue Version (2.8.6) des Adapters auf Github zu geben scheint (zumindest in den Release Notes). Leider kann ich kein Release sehen. Habt ihr mir einen Tipp wie ich die von @arteck gefixte Version mal ausprobieren kann? Danke schon mal.
                            HomoranH Samson71S 2 Antworten Letzte Antwort
                            • hotspot_2H hotspot_2
                              HomoranH Offline
                              HomoranH Offline
                              #54
                              @hotspot_2 sagte:
                              Einfach über den URL installieren.
                              Das "behebt" aber nur die Meldung, nicht die Ursache
                                Samson71S Offline
                                Samson71S Offline
                                Samson71
                                #55
                                @hotspot_2
                                Die Version ist scheinbar auch nicht für manuelle Vorgabe verfügbar. Das hat der Bot auch schon bemerkt und ein Issue erstellt
                                https://github.com/ioBroker/ioBroker.dwd/issues/273
                                Markus
                                Bitte beachten:
                                  hotspot_2H Offline
                                  hotspot_2
                                  #56
                                  Ich konnte sie über die URL installieren und die Fehlermeldung ist nun weg, kam bei mir so alle 20 Minuten. Meldungen vom DWD gehen mit der Version bei mir auch wieder rein, das hat die letzten Wochen mit der 2.8.5 nicht mehr funktioniert.
                                  • Samson71S Samson71
                                    @hotspot_2
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #57
                                    @Samson71 sagte in Fehlermeldung im DWD Adapter:
                                    doch ist halt kein npm paket da.. installierbar nur direkt von GIT
                                    • MichaelFM Offline
                                      MichaelFM Offline
                                      MichaelF
                                      #58
                                      Hi, ich habe auch grade mal die Version installiert. Gibt eine 2.8.7 Fehlermeldung ist weg und es kommen auch wieder Daten soweit ich das sehen konnte bis jetzt.
                                      • jolicJ Offline
                                        jolicJ Offline
                                        jolic
                                        #59
                                        Hi, ich verwende noch die v2.8.5 und erhalte derzeit ca 2 mal täglich diese Fehlermeldung (leere oder ungültige json-datei). Soweit ich es verstehe, liegt das Problem beim DWD selbst, und die v2.8.7 unterdrückt diese Meldung einfach. Richtig?
                                        ioBroker | RPi 4 (SSD) | EndeavourOS (headless)
                                        • jolicJ jolic
                                          HomoranH Offline
                                          HomoranH Offline
                                          #60
                                          @jolic sagte:
                                          Richtig
                                          Ja!
