  5. Wie kommt man an die Alias Verküpfung mit Blockly ran
    6.3k
22 Beiträge 5 Kommentatoren 1.1k Aufrufe 5 Beobachtet
  • Berges01B Berges01
    @Homoran
    zigbee2mqtt.0
    2026-03-26 14:56:43.516	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009b823', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:35+01:00","linkquality":135,"local_temperature":15.3,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":15.3,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:43.516	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":279,"last_seen":"2026-03-26T14:56:35+01:00","linkquality":138,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"move"}'
    zigbee2mqtt.0
    2026-03-26 14:56:43.515	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":293,"last_seen":"2026-03-26T14:56:34+01:00","linkquality":138,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"move"}'
    zigbee2mqtt.0
    2026-03-26 14:56:43.515	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":293,"last_seen":"2026-03-26T14:56:34+01:00","linkquality":135,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"move"}'
    zigbee2mqtt.0
    2026-03-26 14:56:43.515	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":284,"last_seen":"2026-03-26T14:56:33+01:00","linkquality":138,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"move"}'
    zigbee2mqtt.0
    2026-03-26 14:56:43.472	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf84477fffe860f34', payload '{"battery":100,"illuminance":151,"last_seen":"2026-03-26T14:56:30+01:00","linkquality":135,"occupancy":false,"update":{"installed_version":16777316,"latest_version":16777316,"state":"idle"},"voltage":3100}'
    javascript.0
    2026-03-26 14:56:43.266	info	script.js.common.Sonstiges.Gasberechnung: --------------------------------
    javascript.0
    2026-03-26 14:56:43.266	info	script.js.common.Sonstiges.Gasberechnung: Gasleistung = 0 kWh
    javascript.0
    2026-03-26 14:56:43.266	info	script.js.common.Sonstiges.Gasberechnung: Gasmenge = 0 m²
    javascript.0
    2026-03-26 14:56:43.265	info	script.js.common.Sonstiges.Gasberechnung: Impulse = 0
    shelly.0
    2026-03-26 14:56:42.839	info	[Sys.timezone] 192.168.3.121 (shelly1lg3 / shelly1lg3-b08184f704e0 / shelly1lg3#b08184f704e0#1): Configured timezone "America/Chicago" and system timezone "Europe/Berlin" do not match. Please check configuration
    shelly.0
    2026-03-26 14:56:42.221	info	[authEnabled] 192.168.3.121 (shelly1lg3 / shelly1lg3-b08184f704e0 / shelly1lg3#b08184f704e0#1): This device is not protected via restricted login (see adapter documentation for details)
    shelly.0
    2026-03-26 14:56:29.904	info	[authEnabled] 192.168.3.120 (shelly1lg3 / shelly1lg3-b08184ec91c8 / shelly1lg3#b08184ec91c8#1): This device is not protected via restricted login (see adapter documentation for details)
    zigbee2mqtt.0
    2026-03-26 14:56:28.284	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009b823', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:28+01:00","linkquality":138,"local_temperature":16.3,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":15.3,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:28.283	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009b823', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:28+01:00","linkquality":138,"local_temperature":16.3,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":17,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:28.175	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x30e8e40000d26b83', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:28+01:00","linkquality":39,"local_temperature":17,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":15.3,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:28.175	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x30e8e40000d26b83', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:28+01:00","linkquality":39,"local_temperature":17,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":17,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:27.878	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13816ef4d6b90', payload '{"current":0,"energy":0.53,"last_seen":"2026-03-26T14:56:27+01:00","linkquality":135,"power":0,"power_outage_memory":"off","state":"OFF","switch_type":"toggle","voltage":234}'
    zigbee2mqtt.0
    2026-03-26 14:56:27.132	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009ad75', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:27+01:00","linkquality":147,"local_temperature":15.5,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":0,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    shelly.0
    2026-03-26 14:56:27.035	info	[Sys.timezone] 192.168.3.121 (shelly1lg3 / shelly1lg3-b08184f704e0 / shelly1lg3#b08184f704e0#1): Configured timezone "America/Chicago" and system timezone "Europe/Berlin" do not match. Please check configuration
    shelly.0
    2026-03-26 14:56:27.008	info	[authEnabled] 192.168.3.121 (shelly1lg3 / shelly1lg3-b08184f704e0 / shelly1lg3#b08184f704e0#1): This device is not protected via restricted login (see adapter documentation for details)
    zigbee2mqtt.0
    2026-03-26 14:56:25.405	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":284,"last_seen":"2026-03-26T14:56:25+01:00","linkquality":135,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"presence"}'
    zigbee2mqtt.0
    2026-03-26 14:56:25.355	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":284,"last_seen":"2026-03-26T14:56:25+01:00","linkquality":132,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"presence"}'
    zigbee2mqtt.0
    2026-03-26 14:56:25.264	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":284,"last_seen":"2026-03-26T14:56:25+01:00","linkquality":135,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"presence"}'
    zigbee2mqtt.0
    2026-03-26 14:56:25.203	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":284,"last_seen":"2026-03-26T14:56:25+01:00","linkquality":138,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"presence"}'
    zigbee2mqtt.0
    2026-03-26 14:56:25.104	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":284,"last_seen":"2026-03-26T14:56:25+01:00","linkquality":135,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"presence"}'
    zigbee2mqtt.0
    2026-03-26 14:56:24.275	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x30e8e40000d26b83', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:24+01:00","linkquality":39,"local_temperature":17,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":17,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:24.075	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x0c2a6ffffe765844', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:24+01:00","linkquality":129,"local_temperature":23.3,"local_temperature_calibration":0,"occupied_heating_setpoint":22,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":0,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":318927168,"latest_version":318927168,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:23.916	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":289,"last_seen":"2026-03-26T14:56:23+01:00","linkquality":135,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"presence"}'
    zigbee2mqtt.0
    2026-03-26 14:56:21.960	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x90ab96fffe4539c2', payload '{"brightness":0,"last_seen":"2026-03-26T14:56:21+01:00","level_config":{"on_level":"previous"},"linkquality":54,"state":"OFF","update":{"installed_version":16777220,"latest_version":16777220,"state":"idle"}}'
    zigbee2mqtt.0
    2026-03-26 14:56:21.739	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009b823', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:21+01:00","linkquality":138,"local_temperature":16.3,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":17,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:21.738	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009b823', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:21+01:00","linkquality":138,"local_temperature":16.3,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":15.9,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:21.631	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x30e8e40000d26b83', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:21+01:00","linkquality":39,"local_temperature":14.9,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":17,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:21.631	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x30e8e40000d26b83', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:21+01:00","linkquality":39,"local_temperature":14.9,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":15.9,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:20.356	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf84477fffe860f34', payload '{"battery":100,"illuminance":150,"last_seen":"2026-03-26T14:56:20+01:00","linkquality":138,"occupancy":false,"update":{"installed_version":16777316,"latest_version":16777316,"state":"idle"},"voltage":3100}'
    zigbee2mqtt.0
    2026-03-26 14:56:19.757	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009b823', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:19+01:00","linkquality":135,"local_temperature":16.3,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":15.9,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:19.713	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009b823', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:19+01:00","linkquality":135,"local_temperature":16.3,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18.1,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:19.685	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x30e8e40000d26b83', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:19+01:00","linkquality":39,"local_temperature":14.9,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":15.9,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:19.642	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x30e8e40000d26b83', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:19+01:00","linkquality":39,"local_temperature":14.9,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18.1,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    admin.0
    2026-03-26 14:56:17.313	info	<== Disconnect system.user.admin from ::ffff:192.168.2.109 javascript
    admin.0
    javascript.0
    2026-03-26 14:56:15.006	error	script.js.common.Neu.Test-2: at getAlias (script.js.common.Neu.Test-2:6:12)
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    2026-03-26 14:56:15.005	error	script.js.common.Neu.Test-2: at getAlias (script.js.common.Neu.Test-2:6:12)
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    javascript.0
    2026-03-26 14:56:15.005	error	script.js.common.Neu.Test-2: at getAlias (script.js.common.Neu.Test-2:5:24)
    javascript.0
    2026-03-26 14:56:15.005	error	script.js.common.Neu.Test-2: Error: RangeError: Maximum call stack size exceeded
    javascript.0
    2026-03-26 14:56:14.985	info	script.js.common.Neu.Test-2: start JavaScript (Blockly)
    javascript.0
    2026-03-26 14:56:14.871	info	script.js.common.Neu.Test-2: Stopping script
    zigbee2mqtt.0
    2026-03-26 14:56:14.714	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c138bb874a7719', payload '{"battery":100,"fading_time":15,"illuminance":2846,"indicator":"ON","last_seen":"2026-03-26T14:56:14+01:00","linkquality":60,"motion_detection_mode":"pir_and_radar","motion_detection_sensitivity":2,"motion_state":"none","presence":false,"static_detection_distance":3,"static_detection_sensitivity":3}'
    zigbee2mqtt.0
    2026-03-26 14:56:14.648	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c138bb874a7719', payload '{"battery":100,"fading_time":15,"illuminance":2851,"indicator":"ON","last_seen":"2026-03-26T14:56:14+01:00","linkquality":63,"motion_detection_mode":"pir_and_radar","motion_detection_sensitivity":2,"motion_state":"none","presence":false,"static_detection_distance":3,"static_detection_sensitivity":3}'
    shelly.0
    2026-03-26 14:56:14.016	info	[authEnabled] 192.168.3.120 (shelly1lg3 / shelly1lg3-b08184ec91c8 / shelly1lg3#b08184ec91c8#1): This device is not protected via restricted login (see adapter documentation for details)
    zigbee2mqtt.0
    2026-03-26 14:56:13.964	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":289,"last_seen":"2026-03-26T14:56:13+01:00","linkquality":138,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"presence"}'
    zigbee2mqtt.0
    2026-03-26 14:56:13.915	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":289,"last_seen":"2026-03-26T14:56:13+01:00","linkquality":135,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"presence"}'
    zigbee2mqtt.0
    2026-03-26 14:56:13.185	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009b823', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:13+01:00","linkquality":138,"local_temperature":16.3,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18.1,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:13.184	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009b823', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:13+01:00","linkquality":138,"local_temperature":16.3,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":15.3,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:12.572	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x30e8e40000d26b83', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:12+01:00","linkquality":39,"local_temperature":14.9,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18.1,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:12.571	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x30e8e40000d26b83', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:12+01:00","linkquality":39,"local_temperature":14.9,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":15.3,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:12.181	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc26000009ad75', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:12+01:00","linkquality":147,"local_temperature":15.5,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":0,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    shelly.0
    2026-03-26 14:56:11.826	info	[Sys.timezone] 192.168.3.121 (shelly1lg3 / shelly1lg3-b08184f704e0 / shelly1lg3#b08184f704e0#1): Configured timezone "America/Chicago" and system timezone "Europe/Berlin" do not match. Please check configuration
    shelly.0
    2026-03-26 14:56:11.781	info	[authEnabled] 192.168.3.121 (shelly1lg3 / shelly1lg3-b08184f704e0 / shelly1lg3#b08184f704e0#1): This device is not protected via restricted login (see adapter documentation for details)
    zigbee2mqtt.0
    2026-03-26 14:56:11.622	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x70b3d52b6019c6eb', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"energy":0,"last_seen":"2026-03-26T14:56:11+01:00","linkquality":63,"power":0,"state":"OFF","voltage":236}'
    admin.0
    2026-03-26 14:56:11.184	info	==> Connected system.user.admin from ::ffff:192.168.2.109
    zigbee2mqtt.0
    2026-03-26 14:56:10.382	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf84477fffe860f34', payload '{"battery":100,"illuminance":149,"last_seen":"2026-03-26T14:56:10+01:00","linkquality":138,"occupancy":false,"update":{"installed_version":16777316,"latest_version":16777316,"state":"idle"},"voltage":3100}'
    zigbee2mqtt.0
    2026-03-26 14:56:08.143	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c138f46207ded1', payload '{"battery":100,"fading_time":15,"illuminance":2168,"indicator":"ON","last_seen":"2026-03-26T14:56:08+01:00","linkquality":63,"motion_detection_mode":"pir_and_radar","motion_detection_sensitivity":6,"motion_state":"none","presence":false,"static_detection_distance":5.29,"static_detection_sensitivity":4}'
    zigbee2mqtt.0
    2026-03-26 14:56:07.582	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c138f46207ded1', payload '{"battery":100,"fading_time":15,"illuminance":2172,"indicator":"ON","last_seen":"2026-03-26T14:56:07+01:00","linkquality":63,"motion_detection_mode":"pir_and_radar","motion_detection_sensitivity":6,"motion_state":"none","presence":false,"static_detection_distance":5.29,"static_detection_sensitivity":4}'
    zigbee2mqtt.0
    2026-03-26 14:56:06.532	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000e98b8', payload '{"automatic_valve_adapt":false,"battery":55,"battery_low":true,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:06+01:00","linkquality":147,"local_temperature":18,"local_temperature_calibration":0,"occupied_heating_setpoint":16,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:04.741	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000e9e72', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:04+01:00","linkquality":60,"local_temperature":16.5,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":16,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:04.697	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000e9e72', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:04+01:00","linkquality":60,"local_temperature":16.5,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":16.5,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:04.572	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000f2144', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:04+01:00","linkquality":42,"local_temperature":18,"local_temperature_calibration":0,"occupied_heating_setpoint":16,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:04.078	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000f2144', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:04+01:00","linkquality":42,"local_temperature":18.1,"local_temperature_calibration":0,"occupied_heating_setpoint":16,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:04.077	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000f2144', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:04+01:00","linkquality":42,"local_temperature":18.1,"local_temperature_calibration":0,"occupied_heating_setpoint":16,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18.1,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:03.924	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13842c12a798f', payload '{"detection_distance_max":4,"detection_distance_min":0.5,"distance":0,"find_switch":"OFF","illuminance":289,"last_seen":"2026-03-26T14:56:03+01:00","linkquality":135,"move_sensitivity":9,"presence":true,"presence_sensitivity":9,"presence_timeout":30,"state":"move"}'
    zigbee2mqtt.0
    2026-03-26 14:56:03.653	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000e9e72', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:03+01:00","linkquality":63,"local_temperature":16.5,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":16.5,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:03.653	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000e9e72', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:03+01:00","linkquality":63,"local_temperature":16.5,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    shelly.0
    2026-03-26 14:56:03.415	info	[MQTT] Client Close: 192.168.3.95 (shellyhtg3 / shellyhtg3-34b7da8cdad0 / shellyhtg3#34b7da8cdad0#1) (false)
    zigbee2mqtt.0
    2026-03-26 14:56:02.637	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000e9e72', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:02+01:00","linkquality":63,"local_temperature":16.5,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":18,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:02.636	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x18fc2600000e9e72', payload '{"automatic_valve_adapt":false,"battery":100,"battery_low":false,"boost_heating":"OFF","child_lock":"UNLOCK","display_brightness":70,"display_orientation":"standard_arrangement","display_switch_on_duration":10,"displayed_temperature":"measured_temperature","error_state":"ok","last_seen":"2026-03-26T14:56:02+01:00","linkquality":63,"local_temperature":16.5,"local_temperature_calibration":0,"occupied_heating_setpoint":8,"operating_mode":"manual","pi_heating_demand":0,"remote_temperature":16.5,"running_state":"idle","setpoint_change_source":"externally","system_mode":"heat","update":{"installed_version":939595028,"latest_version":939595028,"state":"idle"},"valve_adapt_status":"success","window_detection":"OFF"}'
    zigbee2mqtt.0
    2026-03-26 14:56:02.137	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c138b5a4f4c9e2', payload '{"battery":75,"fading_time":10,"illuminance":475,"indicator":"ON","last_seen":"2026-03-26T14:56:02+01:00","linkquality":60,"motion_detection_mode":"pir_and_radar","motion_detection_sensitivity":8,"motion_state":"none","presence":false,"static_detection_distance":5.36,"static_detection_sensitivity":8}'
    shelly.0
    2026-03-26 14:56:02.106	info	[MQTT] D
    Ich hoffe das ist so OK.
    MCU
    @Berges01
    Nimm mal diese Version.
      <variables>
        <variable id="VG%:/Iy]f`:D?^RG|E;D">dp</variable>
      </variables>
      <block type="procedures_defcustomreturn" id="06;h.e/%Z./|{S@#_,_$" x="163" y="63">
        <mutation statements="false">
          <arg name="dp" varid="VG%:/Iy]f`:D?^RG|E;D"></arg>
        </mutation>
        <field name="NAME">getAlias</field>
        <field name="SCRIPT">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</field>
      </block>
      <block type="debug" id="#p?e-vbG)t5Ii#dc|s/?" x="163" y="163">
        <field name="Severity">info</field>
        <value name="TEXT">
          <shadow type="text" id="|K8;#[UoM(oBimq1bvmr">
          </shadow>
          <block type="procedures_callcustomreturn" id="P)J?u.?Y3Y/+UJ-++-uA">
            <mutation name="getAlias">
              <arg name="dp"></arg>
            </mutation>
            <value name="ARG0">
              <block type="text" id="u:(b%y^@lqE|78CC.l5*">
                <field name="TEXT">shelly.0.shellyplusplugs#fcb467258218#1.Relay0.Power</field>
              </block>
            </value>
          </block>
        </value>
      </block>
    </xml>
    Berges01B 1 Antwort Letzte Antwort
    • M MCU
      @Berges01
        <variables>
        </variables>
          </mutation>
        </block>
          <value name="TEXT">
            </shadow>
              </mutation>
              <value name="ARG0">
                </block>
              </value>
            </block>
          </value>
        </block>
      </xml>
      Berges01B Online
      Berges01B Online
      Berges01
      @MCU
      Prima das funktioniert super.
      Damit ist mir erst mal geholfen.
      Den "Rest" versuche ich mir noch zusammen zu bauen.
      DANKESCHÖN !
      F.B.
