  4. Probleme mit dem Device-Watcher
    6.4k
24 Beiträge 3 Kommentatoren 1.5k Aufrufe 5 Beobachtet
  • R Rico Sander
    /etc/apt/sources.list.d/raspi.list:
    #deb [trusted=yes] http://archive.raspberrypi.com/debian trixie main
    # Uncomment line below then 'apt-get update' to enable 'apt-get source'
    deb-src http://archive.raspberrypi.com/debian/ trixie main
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.12.75+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     12:16:11 up 1 day,  2:01,  1 user,  load average: 1.60, 1.20, 1.01
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2026-03-20 12:16:11 CET
               Universal time: Fri 2026-03-20 11:16:11 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/pi
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.2G        2.7G        240M         11M        5.4G        5.5G
    Swap:           536M          0B        536M
    Total:          8.7G        2.7G        777M
    Active iob-Instances:   25
             7820 M total memory
             2579 M used memory
             2617 M active memory
             4614 M inactive memory
              229 M free memory
              124 M buffer memory
             5012 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 12:16:12 up 1 day,  2:01,  1 user,  load average: 1.79, 1.24, 1.03
    Tasks: 219 total,   1 running, 218 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  2.1 sy,  0.0 ni, 95.7 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7820.7 total,    228.4 free,   2580.8 used,   5137.6 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   5239.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     783M   11M  772M   2% /run
    /dev/mmcblk0p2 ext4       29G  9.7G   18G  36% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     3.9G  424K  3.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
    /dev/sda5      ext4       27G   14G   12G  54% /media/USBintern
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
    tmpfs          tmpfs     783M  8.0K  783M   1% /run/user/1000
    [Thu Mar 19 10:14:40 2026] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Thu Mar 19 10:14:42 2026] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
    [Thu Mar 19 10:14:45 2026] EXT4-fs (sda5): mounted filesystem bfb7e6d7-3877-db01-2026-e6d73877db01 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET             SOURCE         FSTYPE OPTIONS
    /                  /dev/mmcblk0p2 ext4   rw,noatime
    |-/boot/firmware   /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/USBintern /dev/sda5      ext4   rw,noatime
    /var:
    1.2G    /var/
    293M    /var/log
    292M    /var/log/journal/486bb6fc0ef2491bae34baf22dc43901
    203M    /var/cache
    Archived and active journals take up 300.4M in the file system.
    /opt/iobroker/backups:
    76K     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    400M    /opt/iobroker/iobroker-data/
    282M    /opt/iobroker/iobroker-data/files
    96M     /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/echarts.admin
    61M     /opt/iobroker/iobroker-data/files/echarts
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
    18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.1
    /usr/bin/node           v22.22.1
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.1-1nodesource1
      Candidate: 22.22.1-1nodesource1
      Version table:
     *** 22.22.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u1 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 93699)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : iobroker                                 -  enabled, port: 8899
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hs100.0                  : hs100                 : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899,554,2020
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "device-watcher": 2.15.5  , installed 2.15.5
    Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.1  [Updatable]
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hs100"        : 3.0.5    , installed 3.0.5
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lovelace"     : 5.0.5    , installed 5.0.5
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "rpi2"         : 2.4.0    , installed 3.0.2
    Adapter    "shelly"       : 10.5.2   , installed 10.5.2
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        5987
    States:         4919
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8367       990/exim4
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8380       715/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5946       715/iobroker.js-con
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       9626       1368/io.sonoff.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       6981       1308/io.mqtt.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       9793       1481/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7402       728/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7715       1006/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11457      1565/io.web.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       11340      1494/io.lovelace.0
    tcp6       0      0 :::8095                 :::*                    LISTEN      1001       9136       1520/io.onvif.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8368       990/exim4
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7404       728/sshd: /usr/sbin
    udp        0      0 0.0.0.0:58240           0.0.0.0:*                           104        5728       514/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8157       1391/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5726       514/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       9604       1348/io.shelly.0
    udp6       0      0 :::40594                :::*                                104        5729       514/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        5727       514/avahi-daemon: r
    2026-03-20 09:16:04.654  - info: device-watcher.0 (68279) Number of selected adapters to monitor devices: 6. Loading data from: fritzdectDevices, fullyMQTTDevices, hamDevices, shellyDevices, sonoffDevices, tapoDevices ...
    2026-03-20 09:17:10.550  - info: lovelace.0 (1494) Unknown request for /lovelace/default_view
    2026-03-20 09:18:08.350  - info: web.0 (1565) ==> Connected system.user.admin from ::ffff:192.168.178.2
    2026-03-20 09:18:10.901  - info: web.0 (1565) ==> Connected system.user.admin from ::ffff:192.168.178.2
    2026-03-20 09:28:32.265  - info: web.0 (1565) <== Disconnect system.user.admin from ::ffff:192.168.178.2
    2026-03-20 09:28:32.266  - info: web.0 (1565) <== Disconnect system.user.admin from ::ffff:192.168.178.2 flot
    2026-03-20 09:28:41.509  - info: web.0 (1565) ==> Connected system.user.admin from ::ffff:192.168.178.2
    2026-03-20 09:28:49.084  - info: web.0 (1565) <== Disconnect system.user.admin from ::ffff:192.168.178.2 energiefluss.0
    2026-03-20 09:29:04.616  - info: jarvis.0 (1481) Client with IP 192.168.178.2 connected.
    2026-03-20 09:29:05.511  - info: admin.0 (1006) <== Disconnect system.user.admin from ::ffff:192.168.178.2 admin
    2026-03-20 09:29:24.116  - info: jarvis.0 (1481) Client with IP 192.168.178.2 disconnected.
    2026-03-20 09:30:00.008  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 09:45:00.014  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 10:00:00.011  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 10:15:00.008  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 10:15:05.139  - info: admin.0 (1006) Adapter rating updated
    2026-03-20 10:30:00.007  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 10:39:54.750  - warn: hs100.0 (1291) Socket connection Timeout 192_168_178_51 HS100-1 please reconnect the Device
    2026-03-20 10:45:00.010  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 11:00:00.009  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 11:15:00.012  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 11:30:00.009  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 11:45:00.009  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 12:00:00.011  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    2026-03-20 12:15:00.006  - info: javascript.0 (1136) script.js.common.Projekte.Shelly-Script: Shelly Verbrauch: Verbrauchswerte aktualisiert: 3 | Reboots korrigiert: 0 | Unveränderte Werte: 2
    Falls noch etwas zu tun ist, erst wieder am Abend...
    Und Danke...
    @Rico-Sander
    Die Ausgabe müsste eigentlich anders aussehen.
    cat /etc/apt/sources.list.d/raspi.sources
    cat /etc/apt/sources.list.d/raspi.list
      Rico Sander
      Nabend Thomas,
      Ich habe gerade ein aktuelles raspiOS mittels Rasperry Pi Imager auf SD Card geschrieben und ebenfalls auf Stand gebracht
      Dann habe ich mir die von Dir genannten Verzeichnisse und Dateien angeschaut. Darin müssten ja die originalen und richtigen Inhalte zu finden sein.
      Ergebnisse:
      Aktuellstes System nach update / full-upgrade
      rs@raspiOS:~ $ sudo apt update
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
      Get:4 http://archive.raspberrypi.com/debian trixie InRelease [54.9 kB]
      Get:5 http://archive.raspberrypi.com/debian trixie/main arm64 Packages [422 kB]
      Fetched 477 kB in 2s (272 kB/s)
      All packages are up to date.
      rs@raspiOS:~ $
      rs@raspiOS:/etc/apt/sources.list.d $ ls -la
      total 16
      drwxr-xr-x 2 root root 4096 Dec  4 15:46 .
      drwxr-xr-x 9 root root 4096 Dec  4 15:41 ..
      -rw-r--r-- 1 root root  378 Dec  4 15:39 debian.sources
      -rw-r--r-- 1 root root  151 Dec  4 15:39 raspi.sources
      rs@raspiOS:/etc/apt/sources.list.d $ nano debian.sources
      Types: deb
      URIs: http://deb.debian.org/debian/
      Suites: trixie trixie-updates
      Components: main contrib non-free non-free-firmware
      Signed-By: /usr/share/keyrings/debian-archive-keyring.pgp
      Types: deb
      URIs: http://deb.debian.org/debian-security/
      Suites: trixie-security
      rs@raspiOS:/etc/apt/sources.list.d $ nano raspi.sources
      Types: deb
      URIs: http://archive.raspberrypi.com/debian/
      Suites: trixie
      Components: main
      Signed-By: /usr/share/keyrings/raspberrypi-archive-keyring.pgp
      Im Original raspiOS gibt es keine raspi.list.
      Soll ich die relevanten Dateien im ioB-Produktivsystem anpassen?
      Schönen Abend derweil...
      Wenns nicht geht, wie man will
      - muss mans tun, wie man kann.
      • R Rico Sander
        Nabend Thomas,
        Ergebnisse:
        rs@raspiOS:~ $
        total 16
        Types: deb
        Types: deb
        Types: deb
        Suites: trixie
        Components: main
        @Rico-Sander sagte in Probleme mit dem Device-Watcher:
        Möglich. Da werden wohl inzwischen die neueren Repo-Defintionen bevorzugt.
        Mach die Dateien in beiden Systemen gleich.
        R 1 Antwort Letzte Antwort
          Rico Sander
          @Thomas-Braun sagte in Probleme mit dem Device-Watcher:
          Es gibt auch noch kleinere Unterschiede zwischen einem puren raspiOS von vor einiger Zeit, welches auf Stand gebracht wurde, und dem heutigen ganz aktuellen System.
          Ich werde dann mal die Daten auf gleichen Stand bringen. Danke für Unterstützung.
          Und ja, da wäre dann ja noch die Ausgangsproblematik :-)
          Inzwischen meldet der Device Watcher auch die DECT-Geräte als Offline. Keine Ahnung, was da schief läuft. Vlt. ein lokales Problem. Kann mir eigentlich nicht vorstellen, dass es mit dem OS zusammenhängt. Falls keiner dazu eine Idee hat, werde ich ihn vermutlich rausschmeißen und die entsprechenden DP der wichtigen Geräte überwachen.
          Schönes Wochenende...
