  4. ESPHome - Dashboard will nicht
    6.8k
16 Beiträge 5 Kommentatoren 929 Aufrufe 5 Beobachtet
  • D3ltoroxpD Offline
    D3ltoroxpD Offline
    D3ltoroxp
    schrieb am zuletzt editiert von D3ltoroxp
    ich wollte mir ESPHome installieren, da ich einen Bluetooth Proxy habe.
    Ich wollte das Dashboard aktiveren und starten, aber in der Log kommt folgendes.
    Fatal error starting ESPHomeDashboard | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install esphome==2026.1.2 pillow==10.4.0 ERROR: Cannot install esphome==2026.1.2 and pillow==10.4.0 because these package versions have conflicting dependencies. [notice] A new release of pip is available: 24.3.1 -> 25.3 [notice] To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts Collecting esphome==2026.1.2 Using cached esphome-2026.1.2-py3-none-any.whl.metadata (3.6 kB) Collecting pillow==10.4.0 Using cached pillow-10.4.0-cp313-cp313-manylinux_2_28_x86_64.whl.metadata (9.2 kB) Collecting cryptography==45.0.1 (from esphome==2026.1.2) Using cached cryptography-45.0.1-cp311-abi3-manylinux_2_34_x86_64.whl.metadata (5.7 kB) Collecting voluptuous==0.16.0 (from esphome==2026.1.2) Using cached voluptuous-0.16.0-py3-none-any.whl.metadata (20 kB) Collecting PyYAML==6.0.3 (from esphome==2026.1.2) Using cached pyyaml-6.0.3-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.4 kB) Collecting paho-mqtt==1.6.1 (from esphome==2026.1.2) Using cached paho-mqtt-1.6.1.tar.gz (99 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting colorama==0.4.6 (from esphome==2026.1.2) Using cached colorama-0.4.6-py2.py3-none-any.whl.metadata (17 kB) Collecting icmplib==3.0.4 (from esphome==2026.1.2) Using cached icmplib-3.0.4-py3-none-any.whl.metadata (19 kB) Collecting tornado==6.5.4 (from esphome==2026.1.2) Using cached tornado-6.5.4-cp39-abi3-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.8 kB) Collecting tzlocal==5.3.1 (from esphome==2026.1.2) Using cached tzlocal-5.3.1-py3-none-any.whl.metadata (7.6 kB) Collecting tzdata>=2021.1 (from esphome==2026.1.2) Using cached tzdata-2025.3-py2.py3-none-any.whl.metadata (1.4 kB) Collecting pyserial==3.5 (from esphome==2026.1.2) Using cached pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB) Collecting platformio==6.1.18 (from esphome==2026.1.2) Using cached platformio-6.1.18-py3-none-any.whl.metadata (7.1 kB) Collecting esptool==5.1.0 (from esphome==2026.1.2) Using cached esptool-5.1.0.tar.gz (383 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting click==8.1.7 (from esphome==2026.1.2) Using cached click-8.1.7-py3-none-any.whl.metadata (3.0 kB) Collecting esphome-dashboard==20260110.0 (from esphome==2026.1.2) Using cached esphome_dashboard-20260110.0-py3-none-any.whl.metadata (1.2 kB) Collecting aioesphomeapi==43.13.0 (from esphome==2026.1.2) Using cached aioesphomeapi-43.13.0-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (6.1 kB) Collecting zeroconf==0.148.0 (from esphome==2026.1.2) Using cached zeroconf-0.148.0-cp313-cp313-manylinux_2_36_x86_64.whl.metadata (6.3 kB) Collecting puremagic==1.30 (from esphome==2026.1.2) Using cached puremagic-1.30-py3-none-any.whl.metadata (5.8 kB) Collecting ruamel.yaml==0.19.1 (from esphome==2026.1.2) Using cached ruamel_yaml-0.19.1-py3-none-any.whl.metadata (16 kB) Collecting ruamel.yaml.clib==0.2.15 (from esphome==2026.1.2) Using cached ruamel_yaml_clib-0.2.15-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (3.5 kB) Collecting esphome-glyphsets==0.2.0 (from esphome==2026.1.2) Using cached esphome_glyphsets-0.2.0-py3-none-any.whl.metadata (3.9 kB) INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements. This could take a while. The conflict is caused by: The user requested pillow==10.4.0 esphome 2026.1.2 depends on pillow==11.3.0 To fix this you could try to: 1. loosen the range of package versions you've specified 2. remove package versions to allow pip to attempt to solve the dependency conflict | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install esphome==2026.1.2 pillow==10.4.0 ERROR: Cannot install esphome==2026.1.2 and pillow==10.4.0 because these package versions have conflicting dependencies. [notice] A new release of pip is available: 24.3.1 -> 25.3 [notice] To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts Collecting esphome==2026.1.2 Using cached esphome-2026.1.2-py3-none-any.whl.metadata (3.6 kB) Collecting pillow==10.4.0 Using cached pillow-10.4.0-cp313-cp313-manylinux_2_28_x86_64.whl.metadata (9.2 kB) Collecting cryptography==45.0.1 (from esphome==2026.1.2) Using cached cryptography-45.0.1-cp311-abi3-manylinux_2_34_x86_64.whl.metadata (5.7 kB) Collecting voluptuous==0.16.0 (from esphome==2026.1.2) Using cached voluptuous-0.16.0-py3-none-any.whl.metadata (20 kB) Collecting PyYAML==6.0.3 (from esphome==2026.1.2) Using cached pyyaml-6.0.3-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.4 kB) Collecting paho-mqtt==1.6.1 (from esphome==2026.1.2) Using cached paho-mqtt-1.6.1.tar.gz (99 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting colorama==0.4.6 (from esphome==2026.1.2) Using cached colorama-0.4.6-py2.py3-none-any.whl.metadata (17 kB) Collecting icmplib==3.0.4 (from esphome==2026.1.2) Using cached icmplib-3.0.4-py3-none-any.whl.metadata (19 kB) Collecting tornado==6.5.4 (from esphome==2026.1.2) Using cached tornado-6.5.4-cp39-abi3-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.8 kB) Collecting tzlocal==5.3.1 (from esphome==2026.1.2) Using cached tzlocal-5.3.1-py3-none-any.whl.metadata (7.6 kB) Collecting tzdata>=2021.1 (from esphome==2026.1.2) Using cached tzdata-2025.3-py2.py3-none-any.whl.metadata (1.4 kB) Collecting pyserial==3.5 (from esphome==2026.1.2) Using cached pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB) Collecting platformio==6.1.18 (from esphome==2026.1.2) Using cached platformio-6.1.18-py3-none-any.whl.metadata (7.1 kB) Collecting esptool==5.1.0 (from esphome==2026.1.2) Using cached esptool-5.1.0.tar.gz (383 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting click==8.1.7 (from esphome==2026.1.2) Using cached click-8.1.7-py3-none-any.whl.metadata (3.0 kB) Collecting esphome-dashboard==20260110.0 (from esphome==2026.1.2) Using cached esphome_dashboard-20260110.0-py3-none-any.whl.metadata (1.2 kB) Collecting aioesphomeapi==43.13.0 (from esphome==2026.1.2) Using cached aioesphomeapi-43.13.0-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (6.1 kB) Collecting zeroconf==0.148.0 (from esphome==2026.1.2) Using cached zeroconf-0.148.0-cp313-cp313-manylinux_2_36_x86_64.whl.metadata (6.3 kB) Collecting puremagic==1.30 (from esphome==2026.1.2) Using cached puremagic-1.30-py3-none-any.whl.metadata (5.8 kB) Collecting ruamel.yaml==0.19.1 (from esphome==2026.1.2) Using cached ruamel_yaml-0.19.1-py3-none-any.whl.metadata (16 kB) Collecting ruamel.yaml.clib==0.2.15 (from esphome==2026.1.2) Using cached ruamel_yaml_clib-0.2.15-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (3.5 kB) Collecting esphome-glyphsets==0.2.0 (from esphome==2026.1.2) Using cached esphome_glyphsets-0.2.0-py3-none-any.whl.metadata (3.9 kB) INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements. This could take a while. The conflict is caused by: The user requested pillow==10.4.0 esphome 2026.1.2 depends on pillow==11.3.0 To fix this you could try to: 1. loosen the range of package versions you've specified 2. remove package versions to allow pip to attempt to solve the dependency conflict at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at processTicksAndRejections (node:internal/process/task_queues:105:5) at $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/src/index.ts:257:13) at Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:180:16) at Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)
    Ich denke mal das hier ist das Problem richtig ?
    Muss ich das genau so in diesem Pfad ausführen /home/iobroker/.cache/autopy/venv/esphome/bin/python3 ? Oder einfach auf dem ioB Host ?
    Da kommen ja noch einige Fehler mehr, aber das scheint er installiert zu haben oder ?
    EDIT::
    Also das hab ich jetzt mal mit sudo ausgeführt, ohne ging es nicht.
    Der erste Fehler ist weg.
    Aber es gibt noch Probleme mit der dependencies, bei esphome and pillow. Wie ich das aber lösen soll, keine Ahnung.
    -- Ich hab jetzt einfach manuell erst pillow==10.4.0 installiert. Danach den Adapter noch mal neu gestartet. Keine Fehler mehr, Dashboard ist verfügbar. Ob das so der richtige und saubere Weg ist weiß ich nicht. Falls nicht und man hätte das anders lösen sollen, ich hab ein Backup erstellt, ich kann es zurückspielen.
    Hab das alles im angegebenen Pfad installiert, hoffe das war richtig und hätte ich nicht global machen müssen.
    Grüße,
    D3ltoro
    • D3ltoroxpD D3ltoroxp
      EDIT::
      Grüße,
      D3ltoro
      @D3ltoroxp sagte in ESPHome - Dashboard will nicht:
      Der Knackpunkt ist:
      esphome braucht also pillow==11.3.0, dein System baut aber 10.4.0.
      Da müssten die Abhängigkeiten gerichtet werden.
        D3ltoroxpD Offline
        D3ltoroxp
        Hast du das in der Log gefunden, mit dem pillow 11.3 ?
        Müsste das im Adapter korrigiert werden, der stößt ja die Installation an, wenn ich das richtig verstehe.
        Es läuft nun, aber ich könnte ja pillow manuell noch auf die neuste Version updaten oder ?
        Ist das dann was ich alles händisch gemacht habe, pfusch, oder kann man das nur so machen, aktuell ?
        EDIT:
        Habs mal manuell probiert .
        Requirement already satisfied: pillow==11.3.0 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.13/site-packages (11.3.0)
        WARNING: Ignoring invalid distribution ~illow (/home/iobroker/.cache/autopy/venv/esphome/lib/python3.13/site-packages)
        Indem Fall hat er es wohl schon selber auf diese Version angehoben.
        Thomas BraunT simonf04S 2 Antworten Letzte Antwort
          EDIT:
          Ja, steht doch auch in dem Zitat drin...
            D3ltoroxpD Offline
            D3ltoroxp
            Ach ziemlich weit untern, vor lauter gar nicht gesehen. So dann sollte doch jetzt alles passend. Das DB läuft.
            Weg denke ich mal war auch richtig. Warum der Adapter das nicht selber gemacht hat ? Muss man das wahrscheinlich anpassen, mit den Dependances ?
              Ja, ein Paketmaintainer muss da die Dependency anpassen.
              Ich kenne python/pip nicht besonders gut, aber die Dinger (sei es apt, npm oder was auch sonst) funktionieren alle ähnlich. Ein Paket bringt eine Wunschliste mit, welche anderen Pakete in welcher Version installiert sein müssen, damit es funktioniert. Du hast aber unerfüllbare Konstellationen da. Mach mal ein Issue auf, vielleicht kann man da was im iobroker-Adapter schon anpassen.
                D3ltoroxpD Offline
                D3ltoroxp
                Unter github beim ESPHome Adapter ?
                  @D3ltoroxp
                  Ja.
                    BenX5
                    Hallo, ich nutze die Version v0.6.1, leider lädt das Dashboard nicht und der Webservice unter http://localhost:6052 ist ebenfalls nicht erreichbar.
                    Im Log finde ich folgende Infos, bin aber Newbie was das angeht.
                    der admin.0 meldet:
                    sphome has an invalid jsonConfig: [{"instancePath":"/items/devices/items/encryptionKey","schemaPath":"#/definitions/passwordProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"freeSolo"},"message":"must NOT have additional properties"},{"instancePath":"/items/devices","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/11/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match "then" schema"}]
                    der esphome.0 meldet:
                    Fatal error starting ESPHomeDashboard | Error: No checksum URL for Python 3.13.13 found. | Error: No checksum URL for Python 3.13.13 found. at $df9eabe9bda49ea8$export$83db838be0f7727 (file:///opt/iobroker/node_modules/autopy/src/index.ts:127:29) at $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/src/index.ts:224:27) at Esphome.espHomeDashboard (/Users/nl69zh/Developer/community/opensource/ioBroker.esphome/main.js:180:7) at Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)
                    Weiß jemand Rat? Vielen Dank im Voraus für euren input.
                    Samson71S simonf04S 2 Antworten Letzte Antwort
                    • B BenX5
                      der admin.0 meldet:
                      Samson71S Offline
                      Samson71S Offline
                      Samson71
                      @BenX5
                      Erstes Gebot wäre mal keine Cross-Posts. Sowas ist hier nicht gewünscht.
                      https://forum.iobroker.net/topic/69974/esphome-weboberfläche-nicht-erreichbar/6
                      Für das Posten von Logs bitte Code-Tags </> benutzen.
                      Markus
                      Bitte beachten:
                      B 1 Antwort Letzte Antwort
                      • B BenX5
                        der admin.0 meldet:
                        simonf04S Offline
                        simonf04S Offline
                        simonf04
                        @BenX5 sagte:
                        der admin.0 meldet:
                        http://localhost:6052 ist sehr sicher nicht richtig. Braucht schon die ip von deinem iobroker
                        bitte mal mit 0.7.0-beta.4 testen
                          simonf04S Offline
                          simonf04S Offline
                          simonf04
                          @D3ltoroxp sagte:
                          Mittlerweile kann man in den adaptereinstellungen pillow version auswählen.
                          Dass der adapter sich drum kümmert das versionen passen ist etwas mühsam (immer neuste geht auch nicht)
                          Wird aber was kommen, wenn @dutchman mal Zeit hat den aktuellen Stand zu testen ist geplant den Adapter dann mal endlich ins stable zu bringen.
                          Dann kommt ein größeres Refactoring beim Adapter wo unter anderem auch das pillow Problem angegangen wird.
                          • Samson71S Samson71
                            @BenX5
                            BenX5
                            @Samson71 danke für den Hinweis, das wusste ich nicht.
                            • simonf04S simonf04
                              @BenX5 sagte:
                              der admin.0 meldet:
                              BenX5
                              @simonf04
                              1.) auch mit eingetragener IP Adresse, funktioniert es nicht.
                              2.) ich finde gar keine 0.7.0 beta version. v0.6.1 ist die einzig verfügbare im Beta Repository bei mir.
                              simonf04S 1 Antwort Letzte Antwort
                              • B BenX5
                                @simonf04
                                simonf04S Offline
                                simonf04S Offline
                                simonf04
                                @BenX5
                                1.
                                Solang das Fehler im Log kommt, wirds auch nicht funktionieren. Aber danach ist es notwendig.
                                Siehe auch: https://github.com/DrozmotiX/ioBroker.esphome#how-do-i-configure-the-dashboard-ip-selector
                                Ist eine Beta version, daher von NPM installieren.
                                Bitte auch beachten: https://github.com/DrozmotiX/ioBroker.esphome/issues/435 - pillow Version muss eventuell in den Adaptereinstellungen angepasst werden.
                                  EDIT:
                                  simonf04S Offline
                                  simonf04S Offline
                                  simonf04
                                  schrieb am zuletzt editiert von simonf04
                                  @D3ltoroxp sagte:
                                  Bitte in Zukunft nicht mit manuellen Befehlen herumpfuschen, das führt nur immer wieder zu Problemen!
                                  In den Adaptereinstellungen gibt es mittlerweile eine Option die Pillow Version anzupassen.
