  5. Javascript Adapter startet nicht mehr
    6.3k
15 Beiträge 5 Kommentatoren 952 Aufrufe 3 Beobachtet
  • W Offline
    W Offline
    Westfale
    habe das Problem das mein Javascript Adapter nicht mehr grün wird
    Log:
    host.ioBroker-RasPi4
    	2026-01-21 16:15:02.321	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    	2026-01-21 16:15:02.321	error	Caught by controller[0]: Node.js v22.22.0
    	2026-01-21 16:15:02.321	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/build/lib/typescriptSettings.js:4:22)
    	2026-01-21 16:15:02.320	error	Caught by controller[0]: at require (node:internal/modules/helpers:147:16)
    	2026-01-21 16:15:02.320	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
    	2026-01-21 16:15:02.320	error	Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
    	2026-01-21 16:15:02.320	error	Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:328:14)
    	2026-01-21 16:15:02.320	error	Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
    	2026-01-21 16:15:02.320	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
    	2026-01-21 16:15:02.320	error	Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
    	2026-01-21 16:15:02.319	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1680:20)
    	2026-01-21 16:15:02.319	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1638:18)
    	2026-01-21 16:15:02.319	error	Caught by controller[0]: SyntaxError: Unexpected end of input
    	2026-01-21 16:15:02.319	error	Caught by controller[0]: const importOrExport = ((_h = findAncestor(location, isImportDeclaration)) == null ? void 0 : _h.importClause) || findAncestor(location,
    	2026-01-21 16:15:02.318	error	Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:53781
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: ioBroker-RasPi4
           Icon name: computer
              Kernel: Linux 6.12.62+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     16:44:49 up 10 min,  1 user,  load average: 7.07, 9.55, 5.43
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2026-01-21 16:44:49 CET
               Universal time: Wed 2026-01-21 15:44:49 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/pi
    GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        2.9G        306M        5.2M        827M        1.0G
    Swap:           536M        198M        338M
    Total:          4.5G        3.1G        645M
    Active iob-Instances:   23
             3796 M total memory
             2809 M used memory
             3253 M active memory
               57 M inactive memory
              290 M free memory
               73 M buffer memory
              716 M swap cache
              511 M total swap
              189 M used swap
              322 M free swap
    top - 16:44:50 up 10 min,  1 user,  load average: 7.07, 9.55, 5.43
    Tasks: 227 total,   4 running, 223 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 81.1 us, 15.1 sy,  0.0 ni,  3.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3796.7 total,    299.9 free,   2799.9 used,    790.2 buff/cache
    MiB Swap:    512.0 total,    322.8 free,    189.2 used.    996.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  9.8M  750M   2% /run
    /dev/mmcblk0p2 ext4       59G   11G   45G  19% /
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     1.9G  3.2M  1.9G   1% /tmp
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/mmcblk0p1 vfat      510M   74M  437M  15% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     380M  8.0K  380M   1% /run/user/1000
    [Wed Jan 21 16:34:17 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:0A:5B:54 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d2f9a308-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Jan 21 16:34:20 2026] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
    [Wed Jan 21 16:34:22 2026] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.9G    /var/
    1.2G    /var/lib
    969M    /var/lib/mysql
    749M    /var/lib/mysql/iobroker
    177M    /var/cache
    Archived and active journals take up 8.5M in the file system.
    /opt/iobroker/backups:
    19M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    718M    /opt/iobroker/iobroker-data/
    548M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/backup-objects
    115M    /opt/iobroker/iobroker-data/files/vis
    109M    /opt/iobroker/iobroker-data/files/vis-2
    38M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
    8.2M    /opt/iobroker/iobroker-data/files/heatingcontrol.admin/assets/index-D7e4bkMV.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_54ef2b627e12ec11b53520c7bd930c07-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Hat jemand eine Idee ?? Habe den Adapter  schon neu installiert, jedoch ohne Erfolg
    Thomas BraunT P fuzzy1955F 3 Antworten Letzte Antwort
    • W Westfale
      Log:
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/pi
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               3796 M total memory
               2809 M used memory
                290 M free memory
                 73 M buffer memory
                716 M swap cache
                511 M total swap
                189 M used swap
                322 M free swap
      *** FILESYSTEM ***
      /var:
      1.9G    /var/
      1.2G    /var/lib
      969M    /var/lib/mysql
      177M    /var/cache
      USB-Devices by-id:
      HINT:
      /dev/ttyUSB0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      @Westfale
      Die Ausgabe von iob diag ist nicht vollständig.
      Bis dahin sehe ich aber keine Auffälligkeiten.
      Bis auf vielleicht den Part mit dem zigbee-Stick. Hat aber mit dem Problem nichts zu tun.
      • W Westfale
        Log:
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        SUDO_HOME=/home/pi
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 3796 M total memory
                 2809 M used memory
                  290 M free memory
                   73 M buffer memory
                  716 M swap cache
                  511 M total swap
                  189 M used swap
                  322 M free swap
        *** FILESYSTEM ***
        /var:
        1.9G    /var/
        1.2G    /var/lib
        969M    /var/lib/mysql
        177M    /var/cache
        USB-Devices by-id:
        HINT:
        /dev/ttyUSB0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        peterfido
        @Westfale sagte in Javascript Adapter startet nicht mehr:
        CPU threads: 4
        4 Kerne und dann so eine load average? Da sollte das Maximum doch 4.00 sein.
        Peterfido
        • W Westfale
          Log:
          Script v.2025-08-09
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          SUDO_HOME=/home/pi
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
                   3796 M total memory
                   2809 M used memory
                    290 M free memory
                     73 M buffer memory
                    716 M swap cache
                    511 M total swap
                    189 M used swap
                    322 M free swap
          *** FILESYSTEM ***
          /var:
          1.9G    /var/
          1.2G    /var/lib
          969M    /var/lib/mysql
          177M    /var/cache
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          fuzzy1955F Offline
          fuzzy1955F Offline
          fuzzy1955
          Hatte ich auch schon. Halte mal alle Skripte an. Wenn der Adapter dann grün wird, schaltest du sie der Reihe nach wieder ein. Evt. siehst du dann , wo es klemmt.
          Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
          Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
          Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
          Großes Danke an alle tatkräftigen Helfer im Forum!
          P 1 Antwort Letzte Antwort
          • P peterfido
            CPU threads: 4
            @peterfido sagte in Javascript Adapter startet nicht mehr:
            Oh, hatte ich übersehen. Das ist natürlich komplett im dunkelroten Bereich.
            • W Offline
              W Offline
              Westfale
              Hier mal ein kompletter Diag
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
               18:18:29 up  8:45,  1 user,  load average: 1.16, 0.53, 0.49
              CPU threads: 4
              Current issues:
                             Local time: Thu 2026-01-22 18:18:29 CET
                         Universal time: Thu 2026-01-22 17:18:29 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              SUDO_HOME=/home/pi
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:            4.0G        3.5G        140M        1.6M        426M        479M
              Swap:           536M        469M         67M
              Total:          4.5G        4.0G        207M
              Active iob-Instances:   49
                       3796 M total memory
                       3340 M used memory
                       1851 M active memory
                       1617 M inactive memory
                        133 M free memory
                         73 M buffer memory
                        333 M swap cache
                        511 M total swap
                        448 M used swap
                         63 M free swap
              top - 18:18:30 up  8:45,  1 user,  load average: 1.16, 0.53, 0.49
              Tasks: 236 total,   1 running, 235 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  2.0 us,  4.0 sy,  0.0 ni, 94.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3796.7 total,    132.3 free,   3340.6 used,    407.7 buff/cache
              MiB Swap:    512.0 total,     63.9 free,    448.0 used.    456.1 avail Mem
              *** FILESYSTEM ***
              tmpfs          tmpfs     760M   11M  750M   2% /run
              [Thu Jan 22 09:33:18 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:0A:5B:54 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d2f9a308-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Thu Jan 22 09:33:21 2026] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
              [Thu Jan 22 09:33:23 2026] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
              /var:
              1.9G    /var/
              1.2G    /var/lib
              969M    /var/lib/mysql
              177M    /var/cache
              Archived and active journals take up 8.9M in the file system.
              739M    /opt/iobroker/iobroker-data/
              549M    /opt/iobroker/iobroker-data/files
              127M    /opt/iobroker/iobroker-data/backup-objects
              63M     /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              HINT:
              /dev/ttyUSB0
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
                   20.19.2+dfsg-1 500
              ioBroker Status
              Objects type: jsonl
              States  type: redis
              Hosts:
              ioBroker-RasPi4     ioBroker-RasPi4 (version: 7.0.7, hostname: ioBroker-RasPi4, alive, uptime: 21718)
              Core adapters versions
              js-controller:  7.0.7
              admin:          7.7.22
              javascript:     9.0.18
              nodejs modules from github:     2
              | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
              +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
              Adapter State
              + system.adapter.admin.0                  : admin                 : ioBroker-RasPi4                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alarm.0                  : alarm                 : ioBroker-RasPi4                          -  enabled
              + system.adapter.alexa2.0                 : alexa2                : ioBroker-RasPi4                          -  enabled
              + system.adapter.backitup.0               : backitup              : ioBroker-RasPi4                          -  enabled
                system.adapter.bambulab.0               : bambulab              : ioBroker-RasPi4                          - disabled, port: 8883
              + system.adapter.cloud.0                  : cloud                 : ioBroker-RasPi4                          -  enabled
              + system.adapter.daswetter.0              : daswetter             : ioBroker-RasPi4                          -  enabled
              + system.adapter.device-reminder.0        : device-reminder       : ioBroker-RasPi4                          -  enabled
              + system.adapter.dreame.0                 : dreame                : ioBroker-RasPi4                          -  enabled
                system.adapter.dwd.0                    : dwd                   : ioBroker-RasPi4                          -  enabled
              + system.adapter.echarts.0                : echarts               : ioBroker-RasPi4                          -  enabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker-RasPi4                          -  enabled
              + system.adapter.envertech-pv.0           : envertech-pv          : ioBroker-RasPi4                          -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker-RasPi4                          -  enabled
                system.adapter.feiertage.0              : feiertage             : ioBroker-RasPi4                          -  enabled
                system.adapter.flot.0                   : flot                  : ioBroker-RasPi4                          - disabled
                system.adapter.fullybrowser.0           : fullybrowser          : ioBroker-RasPi4                          - disabled
                system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker-RasPi4                          - disabled
              + system.adapter.hm-rega.0                : hm-rega               : ioBroker-RasPi4                          - disabled
                system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-RasPi4                          - disabled, port: 18701
              + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-RasPi4                          -  enabled, port: 12001
              + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-RasPi4                          - disabled, port: 12010
              + system.adapter.hmip.0                   : hmip                  : ioBroker-RasPi4                          -  enabled
              + system.adapter.hue.0                    : hue                   : ioBroker-RasPi4                          -  enabled, port: 80
                system.adapter.ical.0                   : ical                  : ioBroker-RasPi4                          -  enabled
                system.adapter.ical.1                   : ical                  : ioBroker-RasPi4                          -  enabled
                system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker-RasPi4                          - disabled
                system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-RasPi4                          - disabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-RasPi4                          - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-RasPi4                          - disabled
              + system.adapter.influxdb.0               : influxdb              : ioBroker-RasPi4                          -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : ioBroker-RasPi4                          -  enabled
                system.adapter.javascript.0             : javascript            : ioBroker-RasPi4                          - disabled
                system.adapter.mobile.0                 : mobile                : ioBroker-RasPi4                          - disabled
              + system.adapter.modbus.0                 : modbus                : ioBroker-RasPi4                          -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : ioBroker-RasPi4                          -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.netatmo.0                : netatmo               : ioBroker-RasPi4                          -  enabled
              + system.adapter.nina.0                   : nina                  : ioBroker-RasPi4                          -  enabled
                system.adapter.openweathermap.0         : openweathermap        : ioBroker-RasPi4                          -  enabled
                system.adapter.parcel.0                 : parcel                : ioBroker-RasPi4                          - disabled
              + system.adapter.ping.0                   : ping                  : ioBroker-RasPi4                          -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : ioBroker-RasPi4                          -  enabled
                system.adapter.ring.0                   : ring                  : ioBroker-RasPi4                          - disabled
              + system.adapter.rpi2.0                   : rpi2                  : ioBroker-RasPi4                          - disabled
              + system.adapter.sayit.0                  : sayit                 : ioBroker-RasPi4                          -  enabled
              + system.adapter.scenes.0                 : scenes                : ioBroker-RasPi4                          -  enabled
              + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-RasPi4                          - disabled
              + system.adapter.simple-api.0             : simple-api            : ioBroker-RasPi4                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.socketio.0               : socketio              : ioBroker-RasPi4                          -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.sonoff.0                 : sonoff                : ioBroker-RasPi4                          -  enabled, port: 1884, bind: 0.0.0.0
              + system.adapter.sonos.0                  : sonos                 : ioBroker-RasPi4                          -  enabled
              + system.adapter.sony-bravia.0            : sony-bravia           : ioBroker-RasPi4                          -  enabled
              + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-RasPi4                          -  enabled
              + system.adapter.sql.0                    : sql                   : ioBroker-RasPi4                          -  enabled, port: 3306
              + system.adapter.statistics.0             : statistics            : ioBroker-RasPi4                          -  enabled
              + system.adapter.synology.0               : synology              : ioBroker-RasPi4                          -  enabled, port: 5001
              + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker-RasPi4                          -  enabled
              + system.adapter.telegram.0               : telegram              : ioBroker-RasPi4                          -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.terminal.0               : terminal              : ioBroker-RasPi4                          -  enabled, port: 8090, bind: 127.0.0.1, run as: admin
              + system.adapter.text2command.0           : text2command          : ioBroker-RasPi4                          -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : ioBroker-RasPi4                          -  enabled
              + system.adapter.tuya.0                   : tuya                  : ioBroker-RasPi4                          -  enabled
                system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker-RasPi4                          - disabled
                system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker-RasPi4                          - disabled
                system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-RasPi4                          - disabled
                system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: ioBroker-RasPi4                          -  enabled
                system.adapter.vis-2.0                  : vis-2                 : ioBroker-RasPi4                          - disabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-RasPi4                          - disabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-RasPi4                          - disabled
                system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-RasPi4                          -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-RasPi4                          - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-RasPi4                          - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-RasPi4                          -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-RasPi4                          - disabled
                system.adapter.vis-map.0                : vis-map               : ioBroker-RasPi4                          - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-RasPi4                          - disabled
                system.adapter.vis-metro.0              : vis-metro             : ioBroker-RasPi4                          - disabled
                system.adapter.vis-owl.0                : vis-owl               : ioBroker-RasPi4                          - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-RasPi4                          - disabled
                system.adapter.vis-weather.0            : vis-weather           : ioBroker-RasPi4                          - disabled
                system.adapter.vis.0                    : vis                   : ioBroker-RasPi4                          -  enabled
              + system.adapter.vw-connect.0             : vw-connect            : ioBroker-RasPi4                          -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : ioBroker-RasPi4                          -  enabled
              + system.adapter.web.0                    : web                   : ioBroker-RasPi4                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.zigbee.0                 : zigbee                : ioBroker-RasPi4                          -  enabled, port: /dev/ttyUSB0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): beta
              Upgrade policy: none
              Installed ioBroker-Adapters
              Used repository: beta
               Objects database error: connect ECONNREFUSED 127.0.0.1:9001
              Adapter    "admin"        : 7.7.22   , installed 7.7.22
              Adapter    "alarm"        : 3.7.6    , installed 3.7.6
              Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
              Adapter    "backitup"     : 3.3.13   , installed 3.3.13
              Adapter    "bambulab"     : 0.4.3    , installed 0.4.3
              Adapter    "cloud"        : 5.1.2    , installed 5.1.2
              Adapter    "daswetter"    : 4.4.1    , installed 4.3.0  [Updatable]
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "dreame"       : 0.2.2    , installed 0.2.2
              Adapter    "echarts"      : 2.0.10   , installed 2.0.10
              Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
              Adapter    "envertech-pv" : 1.5.0    , installed 1.5.0
              Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
              Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
              Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
              Adapter    "heatingcontrol": 3.0.3   , installed 3.0.3
              Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
              Adapter    "hmip"         : 1.27.0   , installed 1.27.0
              Adapter    "hue"          : 3.16.2   , installed 3.16.2
              Adapter    "ical"         : 1.19.2   , installed 1.19.2
              Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
              Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
              Adapter    "iot"          : 5.0.12   , installed 5.0.12
              Adapter    "javascript"   : 9.0.18   , installed 9.0.18
              Controller "js-controller": 7.1.0    , installed 7.0.7  [Updatable]
              Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
              Adapter    "mobile"       : 1.0.1    , installed 1.0.1
              Adapter    "modbus"       : 7.0.6    , installed 6.4.0  [Updatable]
              Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
              Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
              Adapter    "nina"         : 0.0.26   , installed 0.0.26
              Adapter    "openweathermap": 1.4.0   , installed 1.4.0
              Adapter    "parcel"       : 0.2.10   , installed 0.2.10
              Adapter    "ping"         : 1.7.9    , installed 1.7.9
              Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
              Adapter    "ring"         : 6.4.0    , installed 6.4.0
              Adapter    "sayit"        : 5.1.0    , installed 5.1.0
              Adapter    "scenes"       : 4.0.4    , installed 4.0.4
              Adapter    "shuttercontrol": 2.0.11  , installed 2.0.11
              Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
              Adapter    "socketio"     : 7.0.8    , installed 7.0.8
              Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
              Adapter    "sql"          : 3.0.1    , installed 3.0.1
              Adapter    "statistics"   : 4.0.0    , installed 4.0.0
              Adapter    "synology"     : 3.1.0    , installed 3.1.0
              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "text2command" : 4.0.0    , installed 4.0.0
              Adapter    "trashschedule": 5.2.1    , installed 5.2.1
              Adapter    "tuya"         : 3.17.0   , installed 3.17.0
              Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
              Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
              Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
              Adapter    "vis-2-widgets-material": 1.6.0, installed 1.6.0
              Adapter    "vis-2-widgets-weather-and-heating": 1.3.0, installed 1.3.0
              Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
              Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
              Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
              Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
              Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
              Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
              Adapter    "vw-connect"   : 0.7.15   , installed 0.7.15
              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
              Adapter    "web"          : 7.0.9    , installed 7.0.9
              Adapter    "ws"           : 3.0.19   , installed 3.0.19
              Adapter    "zigbee"       : 3.3.3    , installed 3.3.3
              Objects and States
              Objects:        34460
              States:         32880
              Hit:1 http://deb.debian.org/debian trixie InRelease
              Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
              Hit:3 http://deb.debian.org/debian trixie-updates InRelease
              Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 https://apt.grafana.com stable InRelease
              Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       544240     25941/iobroker.js-c
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6703       731/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7512       1059/exim4
              tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      105        7371       711/redis-server 12
              tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      106        8314       779/mariadbd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          6705       731/sshd: /usr/sbin
              tcp6       0      0 :::3000                 :::*                    LISTEN      108        6977       1124/grafana
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7513       1059/exim4
              tcp6       0      0 ::1:6379                :::*                    LISTEN      105        7372       711/redis-server 12
              tcp6       0      0 :::8086                 :::*                    LISTEN      995        9402       804/influxd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       542469     25966/io.admin.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1900       511/avahi-daemon: r
              udp        0      0 0.0.0.0:51259           0.0.0.0:*                           104        1902       511/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        1901       511/avahi-daemon: r
              udp6       0      0 :::37244                :::*                                104        1903       511/avahi-daemon: r
              udp6       0      0 fe80::ac27:561:7181:546 :::*                                0          6847       592/NetworkManager
              2026-01-22 18:20:50.867  - info: host.ioBroker-RasPi4 instance system.adapter.feiertage.0 in version "1.2.1" started with pid 26246
              2026-01-22 18:20:53.736  - info: host.ioBroker-RasPi4 instance system.adapter.hm-rpc.1 in version "3.0.1" started with pid 26261
              2026-01-22 18:20:57.914  - info: host.ioBroker-RasPi4 instance system.adapter.hmip.0 in version "1.27.0" started with pid 26295
              2026-01-22 18:20:59.390  - info: sql.0 (26041) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.sql, node: v22.22.0, js-controller: 7.0.7
              2026-01-22 18:21:00.324  - info: sql.0 (26041) Connected to mysql
              2026-01-22 18:21:00.416  - info: host.ioBroker-RasPi4 instance system.adapter.hue.0 in version "3.16.2" started with pid 26310
              2026-01-22 18:21:01.267  - info: sql.0 (26041) enabled logging of hm-rega.0.4459, Alias=false, 1 points now activated
              2026-01-22 18:21:01.268  - info: sql.0 (26041) enabled logging of modbus.0.inputRegisters.2.30053_Gesamtleistung, Alias=false, 2 points now activated
              2026-01-22 18:21:01.269  - info: sql.0 (26041) enabled logging of sonoff.0.3D Drucker.ENERGY_Power, Alias=false, 3 points now activated
              2026-01-22 18:21:01.278  - info: sql.0 (26041) enabled logging of sonoff.0.Garage Kompressor.ENERGY_Power, Alias=false, 4 points now activated
              2026-01-22 18:21:01.283  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose Klima Schlafzimmer.ENERGY_Power, Alias=false, 5 points now activated
              2026-01-22 18:21:01.284  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose PC.ENERGY_Power, Alias=false, 6 points now activated
              2026-01-22 18:21:01.286  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose Solaranlage.ENERGY_Power, Alias=false, 7 points now activated
              2026-01-22 18:21:01.301  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose Solaranlage.ENERGY_Today, Alias=false, 8 points now activated
              2026-01-22 18:21:01.302  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose Solaranlage.ENERGY_Total, Alias=false, 9 points now activated
              2026-01-22 18:21:01.307  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose Solaranlage.ENERGY_Yesterday, Alias=false, 10 points now activated
              2026-01-22 18:21:01.308  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose Spülmaschine.ENERGY_Power, Alias=false, 11 points now activated
              2026-01-22 18:21:01.309  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose Trockner.ENERGY_Power, Alias=false, 12 points now activated
              2026-01-22 18:21:01.310  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose Waschmaschine.ENERGY_Power, Alias=false, 13 points now activated
              2026-01-22 18:21:01.310  - info: sql.0 (26041) enabled logging of sonoff.0.Steckdose Wasserbett.ENERGY_Power, Alias=false, 14 points now activated
              2026-01-22 18:21:01.315  - info: sql.0 (26041) enabled logging of sonoff.0.Stromzähler.ENERGY_ActivePower_3, Alias=false, 15 points now activated
              2026-01-22 18:21:01.316  - info: sql.0 (26041) enabled logging of sonoff.0.Stromzähler.ENERGY_Total, Alias=false, 16 points now activated
              2026-01-22 18:21:03.324  - info: host.ioBroker-RasPi4 iobroker npm-install: NPM version: 10.9.4Installing iobroker.rpi2@3.0.2... (System call)
              2026-01-22 18:21:06.354  - info: host.ioBroker-RasPi4 instance scheduled system.adapter.ical.0 0,30 * * * *
              2026-01-22 18:21:06.374  - info: host.ioBroker-RasPi4 instance system.adapter.ical.0 in version "1.19.2" started with pid 26358
              • W Westfale
                Script v.2025-08-09
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                SUDO_HOME=/home/pi
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Swap:           536M        469M         67M
                         3796 M total memory
                         3340 M used memory
                          133 M free memory
                           73 M buffer memory
                          333 M swap cache
                          511 M total swap
                          448 M used swap
                           63 M free swap
                *** FILESYSTEM ***
                /var:
                1.9G    /var/
                1.2G    /var/lib
                969M    /var/lib/mysql
                177M    /var/cache
                USB-Devices by-id:
                HINT:
                /dev/ttyUSB0
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.9.4
                /usr/bin/npx            10.9.4
                nodejs:
                  Version table:
                     20.19.2+dfsg-1 500
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                Hosts:
                admin:          7.7.22
                javascript:     9.0.18
                Adapter State
                + instance is alive
                Objects and States
                Objects:        34460
                States:         32880
                Pending Updates: 0
                Könnte für 4GB Ram auch zu hochgegriffen sein. Die Auslastung nähert sich da auch dem oberen Bereich an.
                HINT:
                /dev/ttyUSB0
                Solltest du auf 'by-id' umstellen.
                Da sieht man (vermutlich) auch die hohe Auslastung.
                Ist dein Logfile immer so geschwätzig? Stell das mal leiser.
                W 1 Antwort Letzte Antwort
                  HINT:
                  /dev/ttyUSB0
                  W Offline
                  W Offline
                  Westfale
                  @Thomas-Braun
                  Zigbee ist erledigt:
                  / $ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                  Aber könnte die RAM Auslastung zu der Fehlermeldung führen das ich den Scriptadapter nicht starten kann ??
                  • W Westfale
                    @Thomas-Braun
                    @Westfale
                    Eigentlich nicht. Aber stopp doch mal soviel wie möglich und dann schaust du nochmal wie ich der javaskript-Adapter dann verhält.
                    W HomoranH 2 Antworten Letzte Antwort
                      @Westfale
                      W Offline
                      W Offline
                      Westfale
                      @Thomas-Braun
                      Hatte jetzt mal testweise nur noch 11 Instanzen laufen und dadurch nur noch 34% RAM in Benutzung
                      Fehlermeldung ist aber gleich geblieben
                        @Westfale
                        @Thomas-Braun sagte in Javascript Adapter startet nicht mehr:
                        Eigentlich nicht.
                        naja, wenn dann das Swapping massiv loslegt und es dort ein Nadelöhr gibt, dann wohl doch
                          Eigentlich nicht.
                          @Homoran sagte in Javascript Adapter startet nicht mehr:
                          Dann wären aber die Meldungen andere.
                          • fuzzy1955F fuzzy1955
                            peterfido
                            @fuzzy1955 sagte in Javascript Adapter startet nicht mehr:
                            Das schon probiert? Zu finden unter
                            javascript.0.scriptEnabled
                            Peterfido
                            • P peterfido
                              W Offline
                              W Offline
                              Westfale
                              @peterfido
                              ja, hat aber leider nicht geholfen.
                              Gleiche Fehlermeldung
                              • W Offline
                                W Offline
                                Westfale
                                Nachdem ich Typescript neu installiert habe funktioniert es jetzt
